All Activity
- Past hour
Nozzle repeatedly clogging while printing Ninjaflex TPU
Jdo300 replied to Jdo300's topic in Materials & profiles
@gr5, thank you for the great tips! I haven't had a chance to come back to this recently, but I plan to resume optimizing my profile soon. Hopefully I'll have some "Good" news for you once I try a few settings changes according to what you mentioned. Thank you! Jason O -
Support Settings for ABS cup with overhangs
Jdo300 replied to Jdo300's topic in Improve your 3D prints
Thank you both @geert_2 and @Enigma_M4 for the suggestions! These are both excellent! @geert_2, I currently created a revised 3D model of my part with the support structure you suggested and hope to try it out soon on my printer. I'm currently fighting a couple of other, more basic ABS profile optimization issues that I need to solve before I come back to this one (See my post here). I will update you here with my results once I have had a chance to try a test print of it. @Enigma_M4. I tried your suggestion, but unfortunately, for this part, the bottom of the lip has to be flat in -
Jdo300 started following Odd Artifacts on bottom few layers of vase print ABS part
Hello All, I've been working on optimizing an ABS profile in Cura 4.8.0 for printing a small test part (a miniature studded vase in this case), but I am running into issues with the outside surface quality of the first few layers. The part is printed in vase mode (spiralize outer contour) with the following basic settings: Printer: Airwolf3D AXIOM Dual Direct Drive Nozzle Size: 0.5 mm Layer Height: 0.25 mm Line Width: 0.5 mm Top/Bottom Thickness: 1.2 mm Print Temperature: 250 C Bed Temperature: 230 C Print Speed: 80 mm/s Outer wall Speed: 60
- Today
hwmiller joined the community
- Yesterday
kmanstudios started following I designed an adjustable shelf to go on top of a TV or Monitor.
DevExit joined the community
You were right Geert_2! the left stepper motor bolts became sightly lose. The belt was loose and the speed was causing the teeth to skip and causing the print to shift... tightened it up and all good thanks again
Cheoto joined the community
Rhino07 joined the community
pairair joined the community
Maybe @fbrc8-erin as come across this problem before that you are having and she might know of some things to try.
Kein Problem, hast du das Handbuch noch, dort stehen einige Dinge über den Drucker und die Wartung. Eventuell kannst du es ohne Ausbau testen, zB. wenn du die Spannung vom Riemen nimmst, die Schrauben sind an der Außenseite vom Gehäuse, auf der Innenseite sitzt der Motor.
Well none of those things helped it's still not printing
okay, thanks. I am trying reinstalling the firmware first it is actually pretty easy can be done right from the maintenance section. Will let you know if that works and if not I'll try the system reset
Ja danke Smithy. Meinst du ob ich mit dieser dummen Aktion die Geometrie meines Drucker verstellt oder kaputt gemacht habe ? Ich habe nur Angst das er jetzt beim Drucken die darauffolgenden Linien nicht mehr sauber gleichmäßig trifft, oder nicht mehr sauber im rechten Winkel druckt.
traniere joined the community
I would say so yes, because it resets all settings, so better to do them again to be safe.
Will I have to recalibrate x and y offsets after?
I would personally try a factory set on the printer. To do this go to the printers menu and pick settings - settings - and reset both "reset all printer settings" & "reset digital factory". If that don't work then maybe (If its able to be done) reinstalling the firmware might do the trick, hopefully someone here knows if this can be done and how to. But with luck doing the resets above will sort it.
> All the reasons you mentioned are why I would like a cover over it. Unfortunately that makes it much harder for me to give you a good answer. So if you have kids know that you can stick your hand in the gantry and your hand will survive without much or any pain (the print will be ruined of course). So if this was the only reason then don't get a cover. You shouldn't be printing ABS which is the only material I know of that really emits nasty smells. Most materials (PLA, PETG, Nylon) have very little smell. Research studies suggest that the dang
Im 3D Druck ist es so, dass der Druckkopf zu Beginn nach links hinten fährt, dort sind 2 Microschalter. Das nennt man auch Homing. Dadurch weiß der Drucker exakt wo sich der Druckkopf befindet und von diesem Referenzpunkt kann er dann sehr exakt und genau jeden Punkt auf der Platte anfahren. Sobald du nun etwas blockierst oder was auch immer, stimmt das dann natürlich nicht mehr überein. Der Drucker weiß nicht, dass der Kopf blockiert wurde und denkt er ist eh noch immer auf der richtigen Position. Daher dann der versetzte Druck. Aber mach dir jetzt keinen Kopf darüber,
More than one Raspberry pi connected to Cura
Smithy replied to Lakes_Rivers's topic in Ultimaker Cura
In the Cura printer settings, you have these 2 printer profiles and for each printer you have a Connect button where you can set the Octorprint instance and the API key. So you have to configure it for each printer. Maybe check that again and don't forget that you have to activate the printer you want to configure before. -
wie meinst du das mit dem Hinderniss und rattern ? Würde dann auch mein Druck versetzt werden ? Kann man auf dem Foto sagen, das ich für circa 50mm den Antrieb/Riemen mit meiner blöden Pinselaktion blockiert habe?
Was ist das stabilste Material für die Ultimaker Drucker
Smithy replied to RaphaelOst's topic in Deutsch
Es kommt stark darauf an welche Eigenschaften du erwartest. Man kann nicht sagen, das ist das stärkste Material, weil was ist stark? Belastbarkeit auf Druck, Biegung etc. da gibt es viele Unterschiede. Ich empfehle dir einmal in den Marketplace von Ultimaker zu schauen, dort kannst du Materialien sortieren. Oder bei iGo3D findest du auch einen guten Filter nach Eigenschaften vom Filament. Das Markforged kenne ich nicht, kann daher auch nicht sagen ob das mit dem S5 druckbar ist. Das Ultrafuse kannst du nicht selbst sintern, das kannst du nur einschicken. -
Just a power cycle
Have you done a factory reset on the printer? I know you said you restarted, but not sure if you meant a power cycle or a full factory reset.
Preview disappearing and objects not moveable?
cucumber_qt replied to cucumber_qt's topic in Ultimaker Cura
Thank you very much. Is there any guess how long this will take? Can I solve the problems using an older version, i.E. 4.7 or sth like that? (On Big Sur) -
Hallo tinkergnome, das hast du schön formuliert, derjenige bin ich 🙂 ich werde so eine Aktion nicht mehr machen.
Jman15x started following s5 not producing prints
My print jobs are "completing" in a matter of seconds. When I send the job from cura to my ultimaker s5 pro bundle via Wi-Fi it starts to get ready for the print and then moments later it says "finishing". I do not get the print completion screen. I have tried printing different files, with other materials and by using a usb drive to import the file instead of the internet connection. I have also restarted both the printer and Cura to no avail .
ssummers joined the community
Yes, gr5 pegged it! One of the people on 'another network' suggested I put a model DeLorean on a street to the left of the building, but I'm not that much of a BTTF geek. 😉 I do have another BTTF reference on the theater in a row of facades on the table edge.
Hallo kruzo7, Nein, das habe ich noch nicht gemacht. Ich weiß nicht ob ich das zerlegen kann, kannst du es bitte für mich etwas genauer beschreiben ? Sorry für die Umstände, aber danke für deine Hilfe und Unterstützung. Grüße Gosman aus Rgbg
