All Activity
- Past hour
geert_2 started following ABS Print Temperature and Speed
I would print a dummy "cooling tower" next to the real model. So the hot nozzle is moved away from the model, while it is busy printing the dummy, and the model has time to cool down and solidify. Where the bottom of the dummy is empty, since the real model is big enough, and the top of the dummy is 100% filled for the extra cooling time. My standard pictures on the subject: Printing with and without dummy: Concept: inverse shaped dummy, to keep printing time per layer constant: Part of a real model, with pink dummy. The dummy is only
cura 4.8.0 Y axis Coordinates difference in software screen and gcode
GregValiant replied to onr's topic in Ultimaker Cura
@gr5, it's the Y so 20mm below the build plate mid-point. I'm going to ignore the suitability of "Origin at Center". @onr, Look at the Cura origin icon. The green arm is the Y. The Cura origin is showing "+Y" as being UP in the view. Now look at the "part" origin icon. The part origin green arm is point down. I have no idea why that is, but that is the confusion. You moved the part Y-20 in relation to itself, but the "part" origin (not the part itself) is mirrored about the X in relation to Cura. So in that view, the part is sitting wholly in the +Y even though you have it -
geert_2 started following Issue with PETg printing
I occasionally print PET. In the beginning I tried printing on bare glass, which gave mixed results. Then I tried dilluted wood glue, which gave *very good* bonding. Way too good, because at one time, it chipped the glass. This already happened while cooling down, I heard it crack violently. When I removed the print, it came off without any force, but with the glass chip stuck to the print. Now I use my salt method: apply a few drops of salt water to the glass bed, and wipe that with a paper tissue until it dries into a very thin mist of salt. For PLA, and as long as the glass is h
- Today
Printcore replacement heater cartridge and pt100 sensor parts
CarloK replied to marine3D's topic in Ultimaker 3D printers
I don't know if a reseller has these parts, but you can ask. Perhaps you are lucky and they have a damaged print core where you can get spare parts from. Expect minimum EUR20 for the PT100 and EUR15 for the heater cartridge. Counting labour costs, professional users will just replace the whole print core and keep the old one for spare parts. Since you consider repairing the print core I've the feeling you don't count labour costs. Then you can go for a cheaper UM2 compatible components from a third party supplier. Even with the lower cable quality you will save money over time -
GregValiant started following Cura 4.6.1. Slicing Problem
@gianluca2021 - Is this still the "won't slice" problem? It opened for me (4.8), the model appears to be OK, and it sliced as it should. (There are things in the settings I would do differently, but that is just personal preference. It would certainly print as you have it set up.) EDIT: I exported the model from Cura, opened the file in 3dBuilder, and it did some repair work. Attached is the "repaired" file with the model only. TabletStandV4a.3mf
vjmikey joined the community
markvk42 joined the community
@nallath Yes. It's a cloud-based functionaility. Thank you!
Okey. Yes I installed it yesterday. But direkt from the Version bevore 6.1 (skipped 6.1 because of the comments here 😅) I printed 2 things yesterday. Till now no issues. (Yes of course the history is gone but...)
- 59 replies
- UMS5 Pro Bundle
- UMS3
(and 1 more)
Tagged with:
dirrunner started following Help on fixing missing z layers
AndersK started following Issue with PETg printing
I have done a fair share of PETG printing (20-30 kg) and has given up on printing on glass, it just sticks to hard. Have changed to printing on PEI instead and that does magic. No need to fiddle with glue or anything to get a good match. Do yourself a favour and get the flexplate system from Build-Tak makes removal so much easier. The PEI sheets have been good with most materials I have used (PETG, PETG+Carbon fibre, PLA, TPU) Mixed results with Nylon+carbon fibre, some good some got loose. Failure might be due to getting lazy not cleaning the PEI after
marcel0611 started following Arc Welder Anti Stutter plugin
dirrunner joined the community
hello sorry, I'm sending you another file, of a model with I can't print, thank you very much AU30_TabletStandV4a.3mf
...très étrange.
atdavkron joined the community
gonzalovaya started following Escala automatica
nallath started following backup all Cura settings
You can also enable the backup plugin. It's shipped with Cura by default.
gonzalovaya joined the community
Jogam joined the community
nhakhoaFlora joined the community
Hier , j'ai couché ma machine sur le côté droit, installé un capteur de température contre le moteur Z, redressé la machine et relancé l'impression précédente qui s'était interrompue après 8h30 de travail. Les températures des moteurs sont montés aux maximum à 54°c pour X, 50°C pour Y, et 44°C pour Z. L'impression s'est déroulée correctement durant 19h et ma pièce est terminée correctement ce matin. Comme je n'ai pas trouvé de causes réelle au défaut, je ne sais pas comment se déroulera la prochaine impression, mais ce sera pour la semaine prochaine.
@ahoeben OK. Thank you!
The local solution would be backing up %APPDATA%\cura\4.8 as you indicated.
I've used dd for decades. However, I have not played around with the S5 enough to even know how to drop to a command prompt and beat on it at a shell level. I figure since it's working fine, it's best not to go {f-bomb}-ing with it, as in ain't broke, don't fix it. 😉 You know what would be a Real Nice Thing (tm) for Ultimaker to do in the name of Good Customer Relations (tm) would be to publish some instructions on how to do just that. I for one would feel far more warm and fuzzy and more willing to upgrade if I knew that there was a safety net to let me put things back the way
- 59 replies
- UMS5 Pro Bundle
- UMS3
(and 1 more)
Tagged with:
Thanks! A local solution would be great.
In the "cura cloud"...???
Über die Web Oberfläche? Das klingt interessant, jedoch wie Verbinde ich mit UM+ Connect mit dieser? Zwar ist der Drucker per WLan in meinem Netzwerk eingebunden, doch dient dies nur für das senden der Druckdatei von Cura in die UltimakerCloud zum Drucker. Direkt auf den Drucker zugreifen kann ich so leider nicht.
Poikilos joined the community
I have 2 cutomized printers, 2 customized materials, and 10+ customized profiles. I wonder what's the easiest way to backup all my Cura settings reliably. Is it keeping a copy of the folder "C:\Users\xxx\AppData\Roaming\cura\4.8\"? Thank you!
gr5 replied to onr's topic in Ultimaker Cura
Y=-20 means 20mm left of center of your printer. however... For some reason, Cura thinks you have a delta printer. But I'm sure you don't. Go to left side of screen in PREPARE mode. Click on your printer, then do "manage printers" then "machine settings", Uncheck "origin at center". That will fix it so it prints in the center of your printer instead of the front left corner. -
JCChia joined the community
5S / „There is a problem with the active level sensor“
Torgeir replied to PhantomGnom's topic in Ultimaker 3D printers
This is a more close up pictures for sure, -but cannot be sure that there is an open wiring. At this close distance from the heater core, the heat will extend along the wire and sometimes you burn the insulation at some distance from the sleeve. But with this much wear and tear on the fastening tab, it's strange if there is no hole in the wires insulation.. Another thing, if there is no short here, this short/close distance -mean higher capacitance. So could this increased capacitance be the reason for (out of specification sensed) this error? For sure, there -
Hello guys I have an issue with y axis. as you can see in the picture, printer settings, origin at center(0,0)selected. I select the object and changed its coordinate to y:-20 and create the gcode. I checked the output of gcode, Y coordinates in gcode all + also min max also in + side. I believe It should be minus side. why this is happening? could someone explain the behavior? Thank you for the effort to make such great software for free.
- Yesterday
jeffroe replied to PhantomGnom's topic in Ultimaker 3D printers
I will take a closer look next time i am in office. I wondered the same - it could be a hole in the insulation or at least a place where it frayed (since the heatshrink on the tab was in bad shape I think this is a good possibility. Here are a few more pics I took this afternoon along with a pic I think I posted before of the tab on that side of the sensor board. I put new heatshrink on that tab now. -
Ultimaker 3 extended "Max Temp. error on Build Plate"
hoehneb replied to hoehneb's topic in Ultimaker 3D printers
Okay, thanks for the advice. Given this, will be easier if I put the PLA on spool one, where it can more easily be removed after each print. We're using it for its solubility in water, BTW. We do use PVA as well, would there be any issues with PVA/PLA compatibility? -
That did it! Thank you very much for the help! Can't believe I missed that little arrow -_- Edit: So now the temperatures will change accordingly but I cant change the retraction because the retraction setting doesn't have an arrow... Edit #2: Ok so I stumbled into this article: https://github.com/Ultimaker/Cura/issues/4041 which solved my problem. I had to go into the configuration folder and delete the lines for retraction speed and distance to have them "unlock". Maybe they should just add an arrow to undo the setting instead.
