All Activity
This stream auto-updates
  1. Past hour
  2. I did at that time of test, also got a x/y shift months after. In the end like I say on the other post I just moved out to duet3d and been enjoying the quality of life of a proper 32bit cpu with trinamic steppers. Happy printer, happy life
  3. Here is a sample piece for this problem, a plate with a cylinder hole which diameter is small (2 -3 mm) if you look at the preview slicing for the first layer below is the picture there is a problem if the speed of the red circle outer wall is too high. The picture below give an idea of what would happen, the blue line . The plastic , which in this place, is alone and not glued to the brim as the red square, will be dragged by the movement of the nozzle. So the hole is very badly initiated, One solution is to drastically lower down ( to 10mm/s for instance) the printing speed for the outer wall and inner wall during this kind of movement. You have to do that only on the first layer, on the other layers, the printed filament sticks a lot better the plastic on the level below, than on the hot bed This is what this plugIn does; reducing the printing speed on outer and inner walls on the first layer if the nozzle changes direction over very short distances (such as those made to make a circle) The plugIn is realised with 2 files, to achieve 2 main goals 1) allow a debbugging process using stand alone Python with IDLE interpreter (I shall show it in a seperate post later) 2) create a script superclass to get all the mechanic to have the scripts follow the same process in the GCode file For this you have 2 files, myScripts for the super script class and the script file here BottomTinyHolesSpeed1.py Below a picture of the begining of the GCode file after post process You can see that 2 scripts were executed (BLHWS1 which is this one and RPT1 which is a new version of the plug in I gave in another post) I tried to launch twice the 2 plug ins and as they are designed to be launched only once the super script class manage it and write it in the GCode Also, in the LAYER 0, which is the one on the hot bed, the script modify the printing speed in the walls of the tiny hole inside the red line the lower speed and in the blue line the older one scripts.zip
  4. En utilisant ça : CuraEngine.exe slice -v -j "D:\Program Files\Ultimaker Cura 4.0\resources\definitions\ultimaker2_plus.def.json" -l "D:\Program Files\Ultimaker Cura 4.0\TEST\anthony.STL" -o "D:\Program Files\Ultimaker Cura 4.0\TEST\test.gcode" Et en ayant créé un dossier "TEST" contenant un STL bidon. J'ai le GCODE en PJ Est-ce que tu peux essayer de reproduire exactement ces étapes ? test.gcode
  5. Merci pour l'info. Regarde par hasard s'il est possible d'activer un logger qui soit verbeux et de récupérer ce qu'il dit. Il y a probablement une erreur (fichier de conf, variables d'environnement, etc) qui est échappée et que tu ne vois pas. Sinon je n'ai pas de finalité avec Python, mais bien avec l'invite de commande (je travaille en NodeJs). Et il se trouve que cette commande sera la même dans les deux cas 🙂. C'est pour gérer ma ferme
  6. Today
  7. Eine statische IP-Adresse alleine verhindert nicht die Firmware-Updates (zur Cloud kann ich nichts sagen). Ich vermute, das je nach Netzwerk-Route noch irgendwo eine Firewall oder ein Proxy-Server im Weg steht und der Drucker dadurch nicht "nach Hause telefonieren" kann. Die IT-Abteilung sollte aber in der Lage sein, herauszubekommen, wo es hängen bleibt.
  8. ok tu si tu veux l'intégralité des commande curaEngine et leur usage tu peux ouvrir l'invite de commande de window taper cd C:\Program Files\Ultimaker Cura 3.6 CuraEngine - help et tu auras tu se dont tu a besoin pour les utiliser. Je continue a tenté d’éclairesire ce mystère. Dans qu'elle finaliter tu aurais besoin de dialoguer en python avec cura ?
  9. So basically, I started using Cura 4.0. Using almost the same settings, now I get results like this (last one I cut in half to see the supports as the print is empty inside):
  10. Hi, I am using an Ultimaker 2+ and have successfully completed around 20 prints. I have recently run into an issue whereby the filament won't extrude during print. I found the exact same issue on a video on Youtube but I don't know how it was solved: Just before the print, the filament extrudes fine, but when it begins to print there is nothing. I am using Cura 4 & version 3.3.0 firmware and printing using an SD card. Thank you in advance for any help / suggestions. Adam
  11. Ok, je me documente sur le sujet, en attendant il y a déjà le repo officiel. Ensuite ce lien à l'air de bien expliquer ce qu'on peut faire en lignes de commande. N'hésite pas si tu as trouvé un truc en plus de ton côté 😃
  12. This is why we need a print farm!
  13. Yeah this is all new to me... had no idea the settings wouldn't be exported. I will do that tonight and re-upload. Maybe i have something set wrong.
  14. Yes! it does rock! when I loosen the screws I should just tap it with a mallet to knock it into shape or do I need to remove the screws to do that? The frame has tabs that click into each other so it looks like hitting them with a hammer might break them. Thank you
  15. Hey DirgDiggler, ich wollte noch Rückmeldung geben. Dein Tipp scheint das Problem tatsächlich gelöst zu haben. Bei mir stand in den Einstellungen auch 215°C, habe auf 230°C erhöht. Zudem habe ich noch den Rückzug auf 5mm runtergestellt. Jetzt läuft es vorerst wieder, Danke!
  16. Ah, I just noticed that your file doesn't contain any settings so I was using my settings. You should do File -> Save not File -> Export. This confuses Cura users new and old but the Cura devs do not seem very keen on making it obvious that to save a project file you need to save rather than export.
  17. Voici mes paramètres pour imprimer du PP : Buse -> peu importe même avec une de 0.25 ça a fonctionné Température -> Buse 225 / Bed 30° Adhésion -> Scotch de déménagement marron en PP Vitesse -> 35mm/s pour la 1ère couche puis après tout dépend de la taille de l'objet mais je peux monter à 50-60mm/s à partir de la 3ème (avec grosse buse bien entendu) Flow -> 104% Fan Speed -> 0 pour la 1ère puis 100% à partir de la 5ème L'avantage avec une faible température de bed, c'est que le scotch n'attache pas trop à la pièce :)
  18. Bonjour,je viens d'essaie ce qui été indiquer sur la page indiquer cela me donne ne donne rien. La seul chose qui change entre sa commande et la mien ce qu'il a modifier certain paramètre d’impression, via l’argument -s. Dans un premier temps modifier les paramètre de tranchage ne m'intéresse pas, mais je l'envisage pour la suite, mais je pensée plutôt utiliser des fichier ".json" cela permet de passer plus argument sans surcharger le code. Apres j'ai tenter de passer "help" a la fonction "os.popen" et la sortie fut tout a fait correcte s'est pour cette raison que je pense que qu'il y a qu'elle chose de différents entre CuraEngine et les autre fonction. Mais je ne trouve pas quoi.
  19. I didn't install a smoother on the extruder, is there still a chance of loss of torque on that without the smoother? My travel speed is usually 120-150mm/s and no slippage so far(its early days in the testing though). As for the case, its ABS Pro from formfutura and i've tested it myself up to 110c without any issue, so it should be ok.
  20. But my layer height is set to .2mm So when you sliced it it was with different settings? I wasn't trying to talk up another product here or put down cura. I'm asking in this forum because i use Cura and would like to continue to do so. Using other software does what it's supposed to do ruling out the printer which again is why I'm here. If my line width is set to .4mm and a single wall setting with .4mm wall thickness should i really have to under-extrude by almost 40% to get that? Further to that if i set my wall thickness to .5mm and at %100 flow I'm still getting the same wall thickness as a .4mm setting then i have to change my flow % for the same filament depending what my wall thickness is set to. I'm sorry but that doesn't seem right at all. I will try some other filament to see the results but i expect it to be more or less the same. I'm just looking for confirmation that the line width setting in cura 4.0.0 actually has a real effect on extruder output because i can change that all day long and it doesn't appear to make a difference.
  21. My models are full of small circles and tiny features, and they print fine, both in PLA and PET. This is a keychain-miniature of dental models used in the hospital. I tend to print these things rather slow (25...30mm/s) and cool (195...200°C for PLA; 210...220°C for PET), bed temp 60°C for PLA, and 80...90°C for PET. Bed is leveled rather close so the first layer is squeezed well (manual leveling on old UM2 printers). Everything else is pretty much default (I am using an older version of Cura). For reference: text caps height = 3.5mm; character legs are 0.5mm wide. View of the bottom layers. This is transparent PET. The lighting from the back gives some weird highlights due to reflections and defractions in the model, but the circles are printed almost perfectly. They are ca. 2.5mm diameter. The ruler is in mm and cm. The tiny dark spots which look like corrosion pits are caused by salt, as I printed these using my "salt method" (=wipe the glass with a tissue moistened with salt water). This is the routine quality I get, with close to default settings. So there might be something else going on in your printer or settings? A setting that inadvertentie got changed? Or printing too hot or cold? Or a non-optimal bonding? Bed too far away, or too close?
  22. Hi, I am looking to buy an Utimaker 3 or Ultimaker 3 extended. Has to be in a good condition and needs to work perfectly. I am based in Romania. Pm if you have one for sale.
  23. Although this is not an answer to your question, it might also improve the situation: the cause of warping might also be because of the way you clean your glass plate, the bonding method you use (or lack of), the distance between nozzle and bed, and the environmental situation (air moisture, temp). Since I started using the "salt method" for bonding, I don't have Ultimaker PLA warping anymore. I use their nice "Pearl" color; I don't know about other colors. The "salt method" = first clean the glass with whatever means you want, e.g. isopropyl alcohol, acetone,... (but no soaps or oils). Then clean with pure warm tap water only. Then wipe the glass plate with a tissue moistened with salt water. Or put a few drops of salt water on the glass and wipe them dry with the tissue. Very gently (!!!) keep wiping until this dries in a thin almost invisible mist of salt stuck to the glass. Especially in moist weather this gives me a much improved bonding when the glass is hot (60°C). When cold, there is no bonding at all, so the models come off by themself after finishing and cooling down. The ease of applying and ease of model removal makes this method attractive for me. This works very well for low and flat models. My models are usually 12 to 15 cm long and 100% filled. But I don't recommend it for narrow and high models (e.g. lantern poles) or models with huge overhangs, because the salt can not absorb much shocks when the nozzle bangs into edges of a model (overhangs tend to curl up). An original model (bottom), perfectly flat after printing. And one that sat in a laboratory oven (top) at an elevated temperature of 70°C for a couple of hours, to see how it would react and warp due to its internal molded-in stresses, as a result of the 3D-printing process. Other people are very successfully using other bonding methods: hairspray, dilluted wood glue, glue stick (some wipe it with water afterwards), 3D-LAC, and other means. Each method may have its advantages and disadvantages. So it might be worth sorting out the basic cause of the warping and remedy that, instead of trying to find a workaround.
  24. pas très clair ton message. le fichier 3D issue d'un logiciel de CAO sera par exemple en .STL, cura ouvre ce fichier. cura va trancher le 3D pour le rendre interprétable par l'imprimante en créant un fichier .UPF pour une UMS5, en .GCODE pour une UM2 et UM3, tout dépend comment tu as paramétré CURA. je ne suis pas un spécialiste de CR10, mais Google me dit que .GCODE fonctionne. donc regarde bien ton paramétrage CURA, tu dois avoir un fichier .GCODE en fin de tranchage. PS je te suggère à l'avenir de créer ton propre sujet plutôt que mélanger ta question dans les problèmes d'épaisseur fine de @Poulpi
  25. Yes, I do fully understand that concern. I am feeling the same about post-processing work; I don't like it. :-) But printing vertically with lots of retractions, and the nozzle moving through the air a lot, also takes time, in addition to creating the imperfections you have seen. Depending on your designs and your printer, there might come a point where printing flat goes faster, and requires less post-processing than smoothing out these imperfections. So you could get more done with less effort. Maybe... If you plan on doing lots of prints, I think it might be a good idea to print a small representative test in both ways, and compare the time, quality and required post-processing? Or even not print them, but just slice them in Cura, and compare the predicted printing times?
  26. dsp
    cura 4.0 help
    Sorry I don't know if that is possible I print over the network so I always open the 3fm files in cura. Usually I use them if I think we need to print the project more often. but you can give it a try
  1. Load more activity
Important Information
