All Activity
- Past hour
DDoove started following Researching New 3D printers for office upgrade
DDoove replied to PaddyMack's topic in UltiMaker 3D printers
I've been using the S5 since it's release and upgraded to pro bundle when that was released. I've been quite happy with it. It does sometimes come with errors especially when it becomes older (>3 years), but after a while you will know how to fix most of them. We also have a BambuLab X1E since a few months, it does print faster, but it also comes with errors, less though. In general I really need the water soluble support material (PVA) for decent quality complex geometries, I use the "Support for PLA" from Bambulab, but it takes a lot of time and effort to get it off (if even possible) in small corners and grooves. So if I had to choose 1 printer, I'd still go for the S5/S7 pro bundle, but the second printer would definitely be a Bambulab. I've attached my findings so far, if you have questions, let me know. - Today
vroli8 joined the community
No longer possible to set print order when printing "One at a time"!?
X-Type replied to X-Type's topic in UltiMaker Cura
Ok, Great thanks! It used to work the way I described. I've done it many times. -
Also I just remembered that @jaysenodell (I'm pretty sure, anyway) has been working with bigger nozzles lately (even if not quite that big) and notice that mention and possibly have advice.
Thank you very much. I will try that.
FSR_2024-03-27 .3mfHere is the file.
quyettam310 joined the community
I agree, that API flag is likely your best bet for an alert on filament directly. Do you also have an alert for the printer status? There is a parameter exposed to the API that will tell you if a printer is stopped mid-print, such as when filament runs out. That seems like a worthwhile alert trigger as well, particularly since it would also catch other issues that require operator intervention.
spetert joined the community
If you could provide the Cura project file (.3mf, in Cura get it ready to print then go to File > Save Project) that might help, since I can look at the settings and where the Z seams are and such to see if anything strikes me as odd. Although looking at your pictures, it seems like your project has a cross section something like this? \_| |_/ You could always cheat. Since it seems to be the inner section giving you problems just do it separately in spiralize mode (no Z seams at all!) and glue it to the other piece 😉
yep understand all that, perhaps I should use the material empty flag on the api as the trigger for my alert email. The printers will sit there for days until someone tells us that it is out of material, if thats mid print it can be an issue. I have a dashboard that shows us the amount remaining on all the slots across the fleet of printers, but without an accurate measure on the tag, its not very reliable.
I didn't even know there was a material empty tag. The machine definitely does not use the amount remaining on the spool in any functional way. What it has is a sensor just inside the hole where you poke the filament into the material station. When the material is pushed in, it trips the sensor and the machine reads the tag to see what you just stuck in it. As the print is running, if that sensor trips back the other way, that means the tail of the roll just passed the sensor, so the machine takes that as empty and does the unload cycle on the remaining filament. The inside of the material station is such that if the machine kept printing past that point, the material could get stuck in there, so that's why it won't print the last meter or two of filament.
The material remaining on the spool tag is only read for display purposes then I guess. If there is an end of roll sensor in the material station, the remaining field on the tag could be whatever you like, its only going to affect the display bar. As it is now I have a printer which when queried via the api is showing remaining amount of 0 yet is happily printing away. I guess the empty flag gets set when the end sensor is tripped. { "slot_index": 2, "material_guid": "44a029e6-e31b-4c9e-a12f-9282e29a92ff", "direction": 0, "material_selection_source": "RFID", "material_insertion_datetime": "2024-03-25T00:41:23", "status": "loaded", "material_empty": 0, "material_remaining": 0, "material_remaining_mm": 0 }, Kind of makes it hard to try and report when machines are empty.
It takes well over a meter of filament to get from the spool in the Material Station to the print head, maybe even more than 1.5m, which amounts to more than a few wraps left on the spool at the end. One might hope or expect that it would just keep pulling the filament in until it actually ran out at the print head, but it does not. As soon as the tail end of the filament passes the sensor at the entry point, the machine considers the material empty and whatever is inside the machine gets pushed back and usually coils back around the spool. I don't know if the amount left in the machine comes out to 40g, but it doesn't seem like an unreasonable number. I doubt they deliberately put extra on the roll for that purpose though, particularly since you could be using the filament from the back spool holder (which has a much shorter path) or on another machine like a 2+. More likely, in a high speed filament production line, it is just easier to err a little on the heavy side, rather than risk shorting a customer and facing a complaint or regulatory action.
thanks, I've taken some readings and found below. New full spool - NFC reads 750000 New full spool - scale weight 1019g Empty spool - scale weight - 229g That leaves 790g of material, yet the tag is programmed with 750g of material. Is this an extra 40g that can't be printed because of the length to feed up the bowden tubes? I'll measure a few more semi-used spools and compare scale weights to nfc readings and see if there if the 40g difference is consistent. On more than one occurrence, we have had the printers say material is empty, when there looks to be quire a few loops of the spool left.
Slashee_the_Cow started following gaps in perimeter at z-Scar
It can be hard to tell sometimes whether it's underextrusion at the start or the end of the layer, but try increasing your wipe distance to 0.4mm and see if that makes a difference. And remember, small scale testing is your friend: You don't need to print the whole thing each time. Just part of the handle, because it's visible the whole way down. The mechanics of Outer Wall Wipe Distance: It's not actually very complex. It stops pushing out more filament when it gets back to the Z seam, but then moves a bit past it so any filament left in the end of the nozzle can fill in the gaps.
That's a Bowden extruder, this bit specifically: Those wheels control how fast the filament goes through, then the filament goes through that blue tube and into the hot end. Nice to see whoever you got it from seems to have gotten the upgraded dual wheel metal one rather than the stock one it comes with, which is plastic 🙂
Important Cura settings to make waterproof prints?
Slashee_the_Cow replied to TheMainMan's topic in UltiMaker Cura
Ironing the top layer is just going to make it look pretty (although go for it if that's what you want). And I'm not saying go short (because there is such a thing as too short in this case) but while taller layers have fewer layer gaps, the gaps are going to be bigger and harder to cover by a method like increasing flow.- 3 replies
- CURA
- waterproof
(and 2 more)
Tagged with:
Cura uses different keywords as variable names in the StartUp and Ending Gcodes than Prusa does. Cura also uses {curly} brackets around the keywords where Prusa uses [square] brackets. AHoeben has put together the list of Cura keywords HERE. The startups and endings will be close, but because the keywords and brackets are different they won't be the same.
GregValiant replied to X-Type's topic in UltiMaker Cura
You must have been lucky because prior to 5.7beta there has not been a way to adjust the print order in One-at-a-Time. It's been a source of aggravation for a lot of people. In 5.7beta, when you set the Print Sequence to One-at-a-Time a new setting comes up below it. When "Set Print Sequence Manually" is enabled then select a model from the object list in the lower left corner of the work space and right click on it. There will be two new options at the bottom of the right-click menu. They are basically "Move it up" and "Move it down" controls. I haven't played with it much, but it looks like it works. I don't know how much fun it would be if you had 50 models on the build plate that you wanted in an exact order. For the four I used in the example it was quick. - Yesterday
mbhsict started following How to dismantle Material Station
I had no end of trouble with PVA material and how it goes so brittle even with the material station. Ended up using some 3rd party BVOH material for disolvable support which was so much better.
Corrupt SD files
Tranquil_Orbit replied to Tranquil_Orbit's topic in Third party products & modifications
Thanks, I tried asking the Flsun support -
Woah, holy cow, first of all, thank you for taking so much time with this, I was not expecting it to be such a skull breaker, I thought it was just me being a complete n00b that doesn't know how to use this thing (which I am), but I'm starting to believe that the model itself is one of those scans made out of the real thing irl, when I opened the original one it was literally massive, I think almost a meter in diameter or something (it almost blew my computer up, I'm working without a GPU at the moment due to electrical issues with my motherboard), so I knew right off the bat that this was not gonna be as easy as I thought, but I don't tend to give up easily on things like these. A lot of what you said is simplified Chinese (for now) so I will have to open a window and work along what you say and compare it to the project and model you left for me, I have very little filament left to test, so I will have to save up, the print is merely a personal project for me to learn to print complex things (I aim to print anime figures, I know I don't have the ideal printer for it but I shot myself in the foot and bought a resin printer I was never able to use due to toxic fumes and I had to trade it for this one just to do something, I looked for supplies everywhere in my country, masks etc, to no avail so, yes, no resin for me at least for now), so it's not functional in any way, just a project to learn, which I'm already doing, even if I feel like I don't understand right now hahaha I will in due time. Here's the pictures you requested (I think) I haen't even loaded up that filament myself, the guy that brought the printer did it for me to teach me how to do it, once it runs out I'll have to do it myself, I already see myself messing up, what's that about snipping the filament? Please before I fuck up the only extruder I have, it's too early for me to pull this thing apart yet, I don't even know if other Ender 3 PRO tutorials would work for this one due to the upgrades LOL what did I get myself into please spare me. If these pictures don't work please tell me how to take better ones and I'll get them for you, I'll do the tests once we figure out what extruder I got hahaha Thank you so much again, I can't wait to be this knowledgable myself!!!
isma666 joined the community
X-Type started following No longer possible to set print order when printing "One at a time"!?
Hi I print many parts in one go with the printer. Almost always I use "One at a time". I want to control in which order the items are printed, so I can optimize how many items I can fit onto the bed in one go. This didn't use to be any problem, as Cura printed them in the order I had loaded or copied them. But today I noticed in the version I am running now, Cura decided its own order regardless, and if I noted in what order Cura printed the items, and reordered them on the print bed and re-sliced, Cura re-ordered the print order, so now I cannot set the order in which the items are printed and place them on the print bed accordingly. Or can I? and if so, how? If this cannot be done anymore, it's a huge degradation for those of us who print many items in one go. I am using the latest version, 5.6.0
Pausing on UM3 control panels causes nozzle to dig into part.
CarloK2 replied to CarbonGod's topic in UltiMaker 3D printers
Thanks for answering all those questions, it really helped. I was able to reproduce the problem and know where the bug is. I don't expect UltiMaker to fix this, but there is a work around. The problem comes from manually adjusting the buildplate screws in the levelling procedure. Each time the build plate gets set a bit higher. Over time, this adds up to a few centimeter and this extra height is not corrected for in the pausing procedure. See the maintenance page on bed leveling, section 'Factory position' for re-adjusting the bed to the correct height. Do not set the build plate lower than prescribed as it will negatively impact the Active Bed Leveling function (the springs in the build plate should be looser than the spring in the printcore). -
When the version number is the same, then the update is not executed. But, when the date online is different from the internal date, then the printer keeps bothering you, unless you select 'ignore'. You could also do a downgrade (from usb file) and then an upgrade again.
Jmazik joined the community
JPreacher joined the community
Digibike started following Fehler Print Core
Klingt, wie wenn die Platine im Druckkopf defekt ist - wenn die einen weg hat, kannst du machen, was du willst, dann erkennt die nichts. Eventuell mal die Platte oben (X-Lager-Home und Kabeleingang) aufschrauben und schauen, ob Kabelbruch erkennbar ist oder sich ein Stecker etwas "rausgearbeitet" hat. Ansonsten wird dann wohl nur ein Tausch der Platine Linderung bringen, fürchte ich. Gruß, Digibike
