All Activity
- Past hour
Cura 5 simply doesnt open after install (resolved)
Slashee_the_Cow replied to lfraga172's topic in UltiMaker Cura
Please post the specs of your mini computer. It might not be capable of running newer versions of Cura for some reason. I'm guessing if it only has 32GB of storage (probably eMMC) it probably has a criminally low amount of RAM. -
Andrew_F started following Filament monitor for UM3/UM3E
Hi, Reviving an old thread as I think that this may be the issue. I'm a trade cabinetmaker, first year fitter/welder qualifications and a qualified engineer. I'm reviving an old UM3 and returning it to original specs - stripped it down a few times on the bench, and the local agent and I are on speed dial at the moment for spares. When I removed a feeder, there was a single nut and washer behind the case (muttered curses when I heard the nut fall inside the case). Fully stripped the LHS of the case down to retrieve it. There was also a 4 pin socket coming from the printer enclosure into the void, wires running down to the main board, with no corresponding electronics in the feed unit. I assume this 4 pin socket was for the now redundant filament sensor? A
Can't get Cura to connect w/ my Qidi X-Plus 3 printer...
Slashee_the_Cow replied to Josh623's topic in UltiMaker Cura
*pats on shoulder* Good job. Ah, but you never know when the cow might be near. I hope to be at some point in the next few years. That could mean tomorrow, or it could mean February 2027. Keep an eye out. And WoW portrayed it pretty well: Tauren rogues are so good at stealth you never see them. -
If you could post the Cura project (.3mf, in Cura get it read to slice then go to File > Save Project) that might help. But if you have support turned off, Cura will just slice things that will never print successfully and not give a stuff: In your case it's not bridging because your walls are round and bridges can only be straight. Looking at the size of the model, it could probably never do bridges that long anyway, especially with PETG (it's too stringy and is just going to stick to the nozzle if there's nothing else for it to attach to, like existing model). You can submit a feature request if you'd like though (make sure to include a copy of your model). Why do you say you can't use support with PETG though? I find it comes off with only a teeny bit more hassle than PLA, and then there's just some strings to get rid of. You want support that's hard to get rid of, try printing TPU at an angle.
I had a whole bunch of stuff that I wrote up before I dug a bit into your project file and saw that each printed part consists of three model files. This is, to use the technical term, bad. Cura is clearly slicing them as separate objects: They should all be combined into one model file (easy, plenty of software that does it, and it guarantees it's in the right place). But I will do the irresponsible thing and tell you how to do what you're trying to do. You're trying to avoid this, right, where objects aren't quite aligned (on the right)? Open the Object List at the bottom left. For each part of the same set: Click each part individually in the object list, so only that is selected: Open the move tool and input some co-ordinates manually. In this case I'm putting it pretty close to the location it already was on the build plate: Now repeat the process for the other two parts but make sure you put in the exact same co-ordinates for each one. Now click the first part in the object list, hold CTRL and click on the other two: (not a great screenshot because the object list isn't big enough to show them all - I just helped someone with that lol) Right click one of the selected objects in the list and click Group Models: Repeat for each other set of models you want to combine. Now if you move one part, the others move with it. If you need to change the settings for one of them, you need to right click the group in the object list and click Ungroup Models: Then after you've made your changes, group them back together. Next time, use one model instead of three. Also I can't help but notice that the centre cylinder especially isn't round: By my count that's about 32 sides. You can even see it in the preview, instead of being round you can clearly see where it changes angle each time: The effect isn't as bad on the inside though. Or maybe this could be part of your gear design or something. I don't know. A couple of other things: If you're sticking a pre-existing item (like a metal rod) through these, you need to look at Experimental > Slicing Tolerance. This determines which way Cura will round since an object's size is generally a multiple of the line width and minimum line width. Speaking of which, go set Walls > Minimum Wall Line Width to 0.24mm, that can generally be done on your average printer. Anyway, when the model isn't the exact size of what Cura can print, it determines how it rounds. Middle means it rounds to nearest combination of lines, but this can mean parts of your print will be bigger than the model. Inclusive makes it always round up, which means the print will always be at least as big as your model, meaning any holes will be the same size or smaller than they are in your model. Exclusive makes it always round down. This means your print will only be at most as big as your model, meaning any holes will be the same size or bigger as the one in your middle. Go set Mesh Fixes > Maximum Resolution to 0.1mm. This setting is mostly to deal with older printers which can't keep up with a bunch of tiny movements so end up moving slower which resulted in overextrusion. Printers these days can do better. I usually set it to 0.1mm. It's hard to demonstrate the difference graphically, but hopefully I managed to pull it off: The brightly coloured lines are from the preview with the maximum resolution set to 0.1mm. You can see they follow a rounder path than the others, although it's only going to be so round anyway given your edges aren't exactly round themselves (you can see the individual faces):
Mvargas3d joined the community
- Today
leaves79 joined the community
boofdas joined the community
maegannelias38 joined the community
Turboweevel joined the community
At least you can get thumbnails working. But don't worry, it's already been submitted as a feature request. Probably several times.
- 7 replies
- post-processing
- script
(and 1 more)
Tagged with:
I still have to check the Ender-5 firmware, install what is required (if anything), and set up and learn the Sonic Pad. That will be all day Saturday, probably. The attached 3MFs looks okay. For starter temperatures, I will set the nozzle and bed temperature settings to 230:100°C. I should probably try this print right away and check what's going on. The dimension are supposed to be about 40 X 1.5 mm. If I really want to go for it, I can test the file named "pair," with the 0.2mm gap. And I can double check the speed settings and set them slower than 4:20. CE5S1_28_cup.4x4.3mf CE5S1_28_4x4.pair.3mf
It would be nice - I currently run 7 scripts just to get thumbnails working for my setup. Small Thumb (for device) Large Thumb (for device) Small find and replace "thumb" with "png" Large find and replace "thumb" with "png" End find and replace "thumb" with "png" Small Thumb (for fluidd) Large Thumb (for fluidd) It'd be great to combine those consistently consistently settings into a single script/addon
- 7 replies
- post-processing
- script
(and 1 more)
Tagged with:
Brianne163 started following concentric part position
I have 4 gears to print and wish to include a reinforcing sleeve in the centre. I need to make sure that the sleeve is exactly central to each gear rather than judging by eye. Is there a way to make sure both items are concentric before slicing? Cura 5.7 Thanks Brian CCT_4XSmallGear_Tube_Shaft.3mf
Okay, very funny. But I will be using my 0.2 mm nozzle. Super sharp outside corners are very important. I had no bed adhesion or nozzle problems with my 0.2 mm nozzle on the Ender-3 — printing on a glass plate with Magigoo (and it had no enclosure). I would pour the Magigoo straight out of the bottle, and use a soft tooth brush to spread it around. On the Ender-5, I just hadn't prepared the glass plate properly, I believe. Today, I just finished cleaning the glass bed for my next Ender-5 attempts: I coated the bottom with some thermal paste using a 1" metal spatula (< 40 grams), and let it sit a few minutes. It leveled itself. I placed the glass plate onto the printer bed, it slid around very nicely, and I subsequently clamped it down. Nothing oozed out the sides (yet, at 100 °C). I applied the teflon tape to the nozzle threads, a very tiny strip (a couple wraps at about 3 mm wide). The tape is resistant up to 260°C, it says. The nozzle screwed in nicely at 230°C but I haven't printed anything yet to see if it works. I hope it doesn't leak. I didn't torque it down to the umpteenth force, like I usually do, and it still leaks (occasionally). I will try using spray adhesive on the bed first, then move onto other adhesives. The Magigoo is a little sloppy, especially best to completely start from scratch after each application or two, three max. I will report back on the results after a few attempts, probably in a couple days. Thank you so much for your advice, I really appreciate it !!! I will definitely scale down the array to a 2 x 2. Maybe I'll set up different files and print four of them under different settings at different locations on the print bed. I really thought I could just repeat what I did from the Ender-3 days, but I guess not. I thought I would get lucky soon enough.
Cura Filling in Top Corners of Models
Adventurehill1 replied to Adventurehill1's topic in Improve your 3D prints
I ran a quick print with those settings and support turned on. It definitely improved the stringing problem, but didn't solve it completely. I'm curious what setting you tweaked? -
JimSchanz joined the community
- Yesterday
SkyValleyJim joined the community
jcarnevale193 joined the community
alison joined the community
Mijn zoon (13) heeft waarschijnlijk abusievelijk een verkeerde firmware update gedaan. Volgens hem stond het hele LCD scherm vol met U4 meldingen. Connectie via USB niet mogelijk. LCD is blauw (zie foto). Fan draait wel (hard als voeding aan staat, zacht als USB is aangesloten). Verder helemaal niets. Is er een oplossing voor dit probleem? Met vriendelijke groet, Sabri
maximosg joined the community
"... the nozzle hit the object while passing from ..." I am not a fan of using "Z-Hops" but for some models it is unavoidable. There are several causes of the nozzle hitting a print. The two most popular are: Depending on the Infill Pattern, the infill can develop high points that are above the layer height. Enabling "Connect Infill Lines" can help with this. Feather edges develop and warp upwards (like when closing large horizontal holes). Enabling "Z-hop on Retraction" can help a lot. I usually set it to 0.50mm.
Ok I just realized I used the stock TPU setting accidentally instead of your tweaks. I'm shocked that it even melted enough to do anything at 210 degrees. I'll print one with your settings. -
My dryer gets to about 110F, which does seem cold to me. I didn't unspool any filament and I left it in for 8 hours. -
Hey All, I've come across this issue where cura tries to start the walls mid air when it could easily start from where there is already material (yellow circle) as you can see in the picture i enable bridging but that doesn't keep it from starting mid air, I can't use support as I'm printing with PETG. Is there any existing settings I could try to make it start from one of the fins of the impeller? (yellow circle) if not this would be an awesome feature for the next update 🙂
Cuq started following Export or Copy the Object List
ghbarbehenn replied to lfraga172's topic in UltiMaker Cura
The suggestion has been made to delete the log files in %appdata%\cura. I have attached the log files from the successful execution of v5.3.1 (please note that stdout.log is empty, and so this app refused to attach it?). I then deleted them, and installed v5.7.0, which, not unexpectedly wouldn't start. However, it *also did NOT create* any new log files while attempting to start. So, deleting the log files in %appdata%\cura did not fix the problem, and in fact v5.7.0 doesn't even get as far as creating a log file. Perhaps the "debugging" was left on, and the offending call is to a logger? stderr v5.3.1.log -
ghbarbehenn started following Cura 5 simply doesnt open after install (resolved)
Installing up to version 5.3.1 works fine. Including installing it to a custom location, in my case the D drive. I'm installing it onto an Alfawise Z83 tiny PC, that lives in the garage with the 3D printer. I access it by remote desktop. The PC only has 32GB of internal storage, barely enough for Windows 10 Home (WinPE version), since Windows is a disk hog, so I have installed a 128GB SSD via an internal USB port, HDD D:\, and put all my applications on D:. If you try to install v5.4 and up you get the attached error message: Error message from 5.4 and above.pdf This message results from a call to a non-existent handle in the QTWidgets DLL, distributed with the version. If version 5.3.1 is installed, it can be started correctly. If v>5.4.0 is installed *on top of* v5.3.1 (same directory), version 5.3.1 won't start, and throws the same error message. Installing on top of another installation isn't kosher, but it is an interesting experiment showing that the QTwidgets DLL is the problem. It should be noted that I had v5.7.0 running on this PC. This PC has been used this way since v4.5, or so, and I just added the new versions as they came out. When I added the 128GB SSD, I damaged the OS image, and had to replace it. Since then I have been unable to reproduce the functioning installation. Nevertheless, v5.3.1 installs and runs *every time*, v>5.4.0 never runs after installation. My installation of Windows 10 Home is completely up to date, so this isn't a Windows staleness issue (polemics aside). I don't have Python installed on this machine, but the error is the call to a non-existent handle in the QTwidgets DLL, not Python. There is clearly a problem with a call to a non-existent handle in the QTwidgets DLL distributed with versions >5.4.0. -
Merci Alain_D de m'avoir aussi conseillé 🙂
Bonsoir GregValiant, Merci pour votre réponse. J'ai imprimé 2 objets, et les impressions se sont très bien passées, jusqu'à 100 %. J'en ai tenté une 3ème mais au 3/4 de l'impression, la buse a tapé dans l'objet en passant de la tour d'amorçage vers l'objet. Du coup, mon objet s'est décollé. Le problème d'arrêt de la température à 98% de l'impression est donc apparemment résolu et cela grâce à vous. Depuis 5 mois que j'ai cette imprimante, personne n'avait su me donner LA bonne solution. Je croise les doigts pour que les prochaines impressions n'apportent plus ce problème ! Un ENORME merci à vous 🤩 Je saurai à qui m'adresser en cas d'éventuels futurs problèmes ☺️😉
GregValiant replied to Josh623's topic in UltiMaker Cura
I'm not afraid of the cow. (I'm far enough away!!) -
jaysenodell replied to Josh623's topic in UltiMaker Cura
Look @Slashee_the_Cow!!! I didn't say it!
