All Activity
- Past hour
rcabada joined the community
Build plate don't reach nozzle during active leveling S5
madmax21 replied to madmax21's topic in Improve your 3D prints
Unfortunately one test print was ok, but after I have again noise 60+, si is strange. Is the same noise even with Fab desabeld. -
Dustin started following How to unlock trust wallet?
Trust.. wallet.. account?? I don't think your asking for help in the right place..
Cura 5 simply doesnt open after install (resolved)
DivingDuck replied to lfraga172's topic in UltiMaker Cura
There are at least two ways to run Octoprint. One as a (Server-) program on a PC like in your little PC that is connected to the Printer via USB or LAN. The other way is to run Octoprint with a raspberry pi and connect this device to the printer via USB or LAN. -
dbyard1 joined the community
natayil67 started following How to unlock trust wallet? and unexpected error when updating
or anyone hitting this post with the same error: I also got this error, but I fixed it by selecting one of the default slicing profiles like "Dynamic Quality - 0.16 mm". So I probably created the error by selecting something odd in the Advanced profile settings. Starting with a fresh profile and adjusting settings and checking regularly if it's still working seems like a good idea... I should probably post the error on the Cura GitHub repo, but I was more interested in fixing my immediate problem. Sorry, about that 🫤
Can anyone help me to unlock my trust wallet account?
natayil67 joined the community
Ups das muss ich ändern. Dann werde ich mich wieder melden. Danke
Faf666 started following BASF Ultrafuse 17-4, Ultimaker Metal Expansion Kit
- Today
Hello, Seems to work for me. I clean all the fans, and the plate again. Now the noise is around 10. I started a print to test. I will disconnect the front fan to see if i have any changes in noise. I will let you know. -
S5 has constant auto bed leveling issues
madmax21 replied to b3_engineering's topic in UltiMaker 3D printers
Hello, For me the issue is solved. Seem to work. I clean again all the fans, plate etc. Thank you -
ghbarbehenn replied to lfraga172's topic in UltiMaker Cura
I have Octoprint, as others have suggested it as well. Near as I can tell it can only communicate with printers that have an IP connection? This solution appeals to me for a variety of reasons, including the fact that the processor on the Z83 wasn't born to slice, so to speak. But, I couldn't figure out how to have Octoprint talk to a USB printer on the Z83. If this is possible, perhaps you could suggest where to start on figuring out how to do that? I have a complete wired LAN, in my house, so this would work well if I can figure out how to use Octoprint with a USB connection. -
Dustin started following problems whit z axis
This is the UltiMaker 3d printers and UltiMaker Cura community.. Not really the best place to look for help with this kind of issue for your Flying Bear.
ggg517gabry started following problems whit z axis
hi, this is the first time i write here, i hope somwon can help me and maby teach me somthing new (im new in this world) I have an old Flying Bear Gost 5 whit marlin software (2.0.9.3), and yesterday i installed TMC2209 v1.3drivers from BigTreeTech. i dit becouse i wase experiencing several problems whit the Z-axis during prints (like layer shifting or very poor quality), and i hoped this would solve them. however, afther setting the vref (following the instructions in this link: [https://all3dp.com/2/vref-calculator-tmc2209-tmc2208-a4988/](to mee result 1.7 for X Y Z and 2 for E)) and changing the drivers in Marlin, when i start auto homing or try to move the z-axis by 10mm, the Z-axis moves non stop until i turn of the power
matthew1975 joined the community
ggg517gabry joined the community
PeerKaan started following Ultimaker 2 does not start anymore
Hello, because I wanted to replace my heater block, I had to replace my heater cartridge and my temperature sensor wire. These were stuck firmly in the block. Everything is connected as it came out, but now it won't start at all. Very disappointing of course. Who knows? Thank you in advance.
Buenos dias desde argentina , estuve imprimiendo bien todo este tiempo y hoy al generar un stl nuevo no pude imprimir mas, si cargo un stl anterior la maquina imprime pero si genero un simple cubo y lo compilo en cura ya no lo imprime, primero pensé que era un problema del archivo que modifique que era uno descargado, así que opte por crear un simple cubo en fusion 360 y exportarlo como stl ... tampoco me lo imprimió, incluso los parámetros para que empiece a imprimir como temperatura del extrusor o de la cama caliente llegan a los rangos indicados y la impresora no se mueve.
ferchu_zen joined the community
Slashee_the_Cow started following Nozzle sizes
The nozzle size set in Cura doesn't technically do that much anyway - mostly just affects warnings about lines being too narrow/wide, stuff like that. Whether you're using a 0.4mm or a 1mm nozzle, a (for example) 0.6mm wide line that's 0.3mm high requires the same amount of material flow. It's generally better to use the most appropriate size nozzle for your situation (it makes the output more controlled) but for setting print settings and such in Cura you can just ignore its warnings if you know what you're doing. (And if you don't know what you're doing: select the right size nozzle and pay attention to Cura's warnings)
GregValiant started following Not Watertight
The developers are so sick of looking for this bug that in 5.7.0 they added automatic slicing error reporting. Just make sure you have the Send engine crash reports setting in the Privacy section of the Cura preferences turned on: It's almost certainly not a problem with any particular quality profile setting. Sometimes you can get a successful slice after changing a setting (almost any of them, really) to something different, slicing, then changing it back and slicing it again. Or move your model slightly on the build plate and slice again.
RevengeBG joined the community
Battrix joined the community
Best place to look is always the UltiMaker Cura Marketplace. Looks like over a dozen options. https://marketplace.ultimaker.com/app/cura/materials?fillings=carbon_fiber&machine_variant=Ultimaker S5,Ultimaker S7&material_station_optimized=true&page=1&polymer_classes=copolyester,pa,pa_6_66,pa_6_69,pa12,pa6
gr5 replied to b3_engineering's topic in UltiMaker 3D printers
Yay! I didn't know it was 3DGBIRE and I didn't know you were close by. I know a guy who works there. Great guy. 225 pounds is a steal as it will probably take them a few hours. -
overkill. The feeder on the 2+ can pull/push about 10 pounds (6kg) of force. More importantly, if the filament enters the feeder at an angle it can cause a LOT of friction. And wear on the feeder (hence that metal gromet in the bottom of the feeder). Also a problem with the above spool holder is that some spools of filament have a much smaller hole through the middle and won't fit on this spool holder (although most will fit). Instead I'd do a spool holder like this and put it on the floor. https://www.thingiverse.com/thing:32204
Here are the firmware recoveries I have. The ones with "R1" should all be for the older S5. Note the dates. Pick the oldest and newest (newest supplied from Ultimaker) This is a listing from my website gr5.org so just go to https://gr5.org/insert_image_name_here.img And it should automatically start downloading. Or create the link on a web page and right click and select to download. If there is a newer firmware let me know and I should get off my butt and add it to the below list. Why UM hides the old firmwares, I don't know. They are useful. -rw-r--r-- 1 grfivorg grfivorg 279969792 Jul 19 2023 UM3_recovery-3.7.7.20170627.img -rw-r--r-- 1 grfivorg grfivorg 332398592 Sep 11 2020 UM3_recovery-4.3.3.20180529.img -rw-r--r-- 1 grfivorg grfivorg 181449728 Nov 14 2020 gr-S5-R1.img -rw-r--r-- 1 grfivorg grfivorg 309789184 May 26 2021 um-restore-6.4.0-R1-gr.img -rw-r--r-- 1 grfivorg grfivorg 326318080 May 4 2023 um-restore-7.1.3-S5R1.img
You need to talk to Elegoo about that as UltiMaker won't be involved in someone else's hardware. On the other hand, the "variable line width" of Cura means that the nozzle size isn't near as important as it used to be. You can make up a custom profile of settings you use. When I print in spiralize I often kick the line width to 0.60 or 0.80 with a 0.4 nozzle. That works fine. You can't really go smaller though as there isn't enough squish. You can also add a nozzle size by editing a nozzle file (in the variants folder) and doing a Save-As. You might have to do the same thing with at least one "Quality" file for a material. Quality files contain a line that mentions the nozzle size. Between the nozzle file and a quality file there might be 3 or 4 lines that need a number changed (like from 0.4 to 0.5). When you do the Save-As make sure you use the same file naming format as the original file.
So from your description I think you probably have bad blocks in your "hard drive". By hard drive I mean the SSD chip that serves as the drives for the linux computer. The chip automatically detects bad blocks and routes them to new locations but the data in the bad block is lost so you have to re-install the software. Sometimes the bad block is part of the formatting so sometimes you have to reformat one of the 3 partitions. Sometimes the bad block is part of the partition table so you have to repartition everything. Sometimes there are many bad blocks so you have to do the above steps a few times. Always there are excessive amounts of good blocks because we use maybe 1/4 of the SSD. Most of the firmware installers are "too smart" and won't reformat or repartition unless the size has changed. So I find the easiest way to deal with all this is to install 2 different versions that had different partition sizes. That way the firmware recovery sees the partition size is different and it has to do a complete reinstall. I have links to a few of these firmware recoveries here: https://gr5.org/unbricking/ Okay I just checked the above link and for some reason I don't see very many S5 (any?) recoveries although I know I have some for sure as I've used them for my S5. I guess I'd try to get one from firmware 4.X and one from 5.X because somewhere in there they changed the partition size. Or you can get an olimex cable and see what's going on step by step. Described in the unbricking page. Unfortunately the unbricking page is a mess. I have edited it maybe 30 times and it gets more confusing each time. Sorry. If you have an olimex cable you can repartition it to random partition sizes and then run the latest firmware recovery, it will be forced to repartition. Basically - keep trying firmware recoveries. Try different ones to force them to repartion and hence also reformat each partition. With the olimex cable you can also run connman (which sets up and controls the wifi and ethernet).
This looks really good. Just got my hands on a Ultimaker 2+, and was given a pile of different brands of spools so I was looking for something like this. The inset wheel is awesome. I was hoping you would make the printable file available, however I was thinking I could use two skateboard bearings (of good quality), to make the rotation even smother by placing them at the side of the shaft. Worth it or just overkill? - or maybe just for heavier spools?
NTwoO replied to b3_engineering's topic in UltiMaker 3D printers
Once I had a print core that became unscrewed. See if you can feel play in the core when holding the heat block and gently turning the collar where the filament is inserted. Don't use tools or force as the connecting section is very thin. -
Cenjpas joined the community
laserlady58 changed their profile photo
beadster replied to b3_engineering's topic in UltiMaker 3D printers
Just had a nice chat with the service dept at 3DGBIRE and a very helpful lady gave me some more tips, along the lines you just suggested, they have had breaks in the sensor wires internally, the diag test will read OK but the self-levelling doesn't work. yes, I am good with electronics, I build all sorts of race car electronics stuff from scratch. and we suffer similar issues on the race cars to solve it we use very high spec wire and very careful with routing going to do as she and you suggest and test continuity on all wires. then if I have no joy and due to time constraints (jobs stacking up) I will drop it off with them, and because it's out of warranty pay the 225£ for a fix it which isn't so bad.
