All Activity
- Past hour
LilGabs24 joined the community
dokhang295 joined the community
- Today
Ender3v2 with Z-Height problems.
Slashee_the_Cow replied to th31nfamous's topic in Third party products & modifications
If you just did your first ever firmware install but it did not hurt, you're doing better than I did 🙂 My next suggestion would be "do a factory reset of the settings" - I'm guessing it's somewhere in the menus, I just couldn't tell you where. Oh, and I only just realised I should mention, at least on the Ender-3 V2 Neo (which comes with a CR-Touch preinstalled) but probably any Ender-3 v1 or v2 that the CR-Touch does not do auto Z offset. It exclusively does ABL. I don't know about a BL-Touch, I've never used one. The Ender-3 V3 series does do auto Z offset, but that's because it has force gauges under the bed which measure the pressure from the levelling probe. -
The StartUp Gcode is very machine dependent. I used to have separate printers for PLA, PETG and TPU because I wanted different StartUp's depending on the material and speeds. With the StartUp now able to handle logic I'm taking advantage. This makes adjustments to the StartUp per the current Cura settings. That makes it ambidextrous and I now only have one printer defined. ;--------------------------StartUp Gcode G21 ; Metric Units G90 ; Absolute Movement M82 ; Absolute Extrusion M220 S100 ; Reset FeedRate M221 S100 ; Reset FlowRate M140 S{material_bed_temperature_layer_0} ; Start heating the bed {'M104 S175 ; Standby while bed heats' if material_bed_temperature_layer_0 > 65 else ';M104 ; No standby'} {'M190 S' if material_bed_temperature_layer_0 > 65 else 'M140 S'}{material_bed_temperature_layer_0} ; Bed wait if over 65 M109 S{material_print_temperature_layer_0} ; Hot End Temperature G92 E0 ; Reset E G28 X Y ; Home XY axes G1 F2700 Z10.0 ; Move Z G0 F{speed_travel*60} X1.0 Y20 Z0.3 ; Move G1 F{speed_print*60*2/3} X1.0 Y200.0 E15 ; First purge line G0 F{speed_travel*60} X3.0 Y200.0 ; Move G1 F{speed_print*60*2/3} X3.0 Y20 E30 ; Second purge line {";G1 F" if "TPU" in material_type else "G1 F"}{retraction_retract_speed*60} E28 ; Retract if not TPU G92 E0 ; Reset Extruder G1 F2700 Z12.0 ; Move Z Axis up G4 S1 ; Wait for booger to solidify G0 F{speed_travel*60} X3.0 Y35 Z.35 ; Move over G0 F{speed_travel*60} X3 Y50 Z0.35 ; Wipe ;--------------------------End of StartUp
ky0ri joined the community
Derpnuken joined the community
wholefoodrunner joined the community
infamouscheater joined the community
th31nfamous replied to th31nfamous's topic in Third party products & modifications
I just did my first ever firmware install, however it did not help, i just ordered a cr touch, ill install that tomorrow and see how it goes thanks for your help -
usernamepls joined the community
zentrie101 joined the community
- Yesterday
Slashee_the_Cow started following Modifying gcode on export? and Ender3v2 with Z-Height problems.
Have you tried flashing/reflashing the latest firmware? If there's a firmware file on the SD card that has a filename different to the last one you installed, it considers it new and installs that. BTW: "Improve your 3D prints" is not "Ender-3 Support Forum" so I'm moving this to "third party products & modifications" -
On my E3V3SE I find when I do that I have the extruder idling for a while waiting for the bed to finish heating, and the bed heating is a roadblock in my startup code since I like to home when it's hot (it's a PC metal bed, so it will technically be slightly larger when heated, but this is one of my many cases of "it works in theory, so I'm doing it" rather than the "in practice, it won't make a damn difference" line of thinking). My bed seems to take interminately long to heat up (it's probably average), but if I only start heating the extruder once the bed is hot, then I'm waiting for that after it homes and moves into drooling position it takes a while for the extruder to finish heating, so I did this: M190 S{material_bed_temperature_layer_0 - 15} ; Start heating the bed M104 S{material_print_temperature_layer_0} ; Get the extruder going M190 S{material_bed_temperature_layer_0} ; Finish heating the bed G28 ;Home
fabiokt88 joined the community
Cura transparent Window after opening on Plasma 6 and in Hyprland
ltommy replied to bsilverthorn's topic in UltiMaker Cura
added "export QT_QPA_PLATFORM=xcb" to .bashrc fixed this -
ricardo001 joined the community
Celia7 started following Material Sync not working
I have a brand new S7 that is having this issue. When i hit sync, it just spins infinitely. Tried the USB method but Ultimaker does not recognize the material profile. No news on the fix? Running Cura 5.6.0
ltommy started following Cura transparent Window after opening on Plasma 6 and in Hyprland
Same issue here. Window is transparent with Nvidia 550.67-2, Cura and 5* version, ArchLinux, Wayland, Plasma or Gnome. Start either using X11 works fine. Cura 4.13.1 works fine under Wayland. However, running Cura 5.6.0 in Wayland on Debian 12 stable, Gnome 44.8-1, it works fine. A clue? -
It isn't an override as such. The keywords in the StartUp tell Cura that the temperatures are being handled. When that is the case the automatic "Prepend" doesn't get inserted.
No longer possible to set print order when printing "One at a time"!?
GregValiant replied to X-Type's topic in UltiMaker Cura
Unfortunately "One at a Time" is not available for multi-extruder printers when more than a single extruder is enabled. You would need to disable Extruder 2. If you happen to be using Extruder 2 for a model or for support then you are out of luck. -
Super merci pour les infos je vais regarder est modifier les valeurs
th31nfamous started following Ender3v2 with Z-Height problems.
Hey guys, i need help with a problem i have on my ender3v2 printer. My printer is literally just randomly adjusting it's offset when i start a print. So every time i start a print, i have to manually change the Z-offset position while the printer is doing the initial strip. It can go from -.01 to - 1.50 .. (it is always too low) The bed is correcly aligned and i know for sure that the home position is always the same before the print start because i made a mark on the z threaded shaft and it always match the other mark on the collar . The problem started when during a print a made a pause to switch filament, and after this the nozzle came in contact with the print. Pretty sure the problem is not from the slicer gcode because when i use old gcode that i was using before the problem started, the height problem is still there. Other that than that the printer works fine but i'm just getting tired of fine-tuning the z offset in a rush when the print starts, i also want to buy/install a bl touch and id rather solve this problem before i make the install of the BLtouch Thanks guys !!
mekkihussein changed their profile photo
Burtoogles work on "discreet infill lines" looks really interesting. I will try to start a dialogue with him to find out what is possible with the existing code and if there are other possibilities such as the Honeycomb I was working on. I did get it to work to a degree but it was kinda hard to get the diagonal cell walls to be generated with only one line. I'm certain this and even more optimal solutions can be solved. The biggest problem I have in regards to this stuff is understanding how to install and configure software. I know what I would like to see as far as printed structures and how the slicers tool path should move but (for example looking at the smartavionics git page I have no idea how to download what to download and how to use if I was to download!
Researching New 3D printers for office upgrade
DDoove replied to PaddyMack's topic in UltiMaker 3D printers
@Dadkitess, no, unfortunately we rarely print with PETG so far. -
X-Type replied to X-Type's topic in UltiMaker Cura
I have now downloaded and testet 5.7.0-beta.1 The objects list is there. But unfortunately I do not get these alternatives in the drop down menu inside the objects list. -
Thanks a ton! I didn't know the startup Gcode field overrode the default commands. Seems to be working great now. 👍
GregValiant started following Modifying gcode on export?
Go to "Manage Printers" and "Machine Settings". You want to edit the "StartUp G-Code". Cura will always put the heating commands in if there are no "replacement patterns" in the startup. This is based on the Ender 3 Startup Gcode. My changes are in bold. ; Ender 3 Custom Start G-code G92 E0 ; Reset Extruder M220 S100 ; Reset the feed rate M221 S100 ; Reset the flow rate M140 S{material_bed_temperature_layer_0} ; Start heating the bed M104 S{material_print_temperature_layer_0} ; Start heating the nozzle G28 ; Home all axes G0 F600 Z5 ; Move up to ooze M190 S{material_bed_temperature_layer_0} ; Wait for the bed M109 S{material_print_temperature_layer_0} ; Wait for the nozzle G1 Z2.0 F3000 ; Move Z Axis up little to prevent scratching of Heat Bed G1 X0.1 Y20 Z0.3 F5000.0 ; Move to start position G1 X0.1 Y200.0 Z0.3 F1500.0 E15 ; Draw the first line G1 X0.4 Y200.0 Z0.3 F5000.0 ; Move to side a little G1 X0.4 Y20 Z0.3 F1500.0 E30 ; Draw the second line G92 E0 ; Reset Extruder G1 Z2.0 F3000 ; Move Z Axis up little to prevent scratching of Heat Bed G1 X5 Y20 Z0.3 F5000.0 ; Move over to prevent blob squish" ;End of StartUp The "reset" lines are in case you happened to tune a previous print from the LCD. They set the printer back to the default 100% feed and flow rates.
cotem2021 started following Modifying gcode on export?
Hi, still relatively new to using Cura for only about a year. I noticed that whenever I create a gcode file to print on my Ender 3, it is written so the bed heats up first, waits until it is up to temp, then starts heating the extruder. I believe I can make small savings in print time by modifying it to preheat both at the same time. I have written out the gcode that Cura spits out below. M140 S62 M105 M190 S62 M104 S210 M105 M109 S210 I rearranged this code to be: M140 S62 M104 S210 M105 M104 S210 M109 S210 This seemed to work in preheating both at once. Is there a capability in Cura to change this on all gcode files that Cura generates? I looked in the printer settings and it seems the custom start gcode appears after this code snippet. I have attached an example gcode file to this post. My cura version is 5.2.1. I would greatly appreciate any help anyone can provide. Thanks! CE3E3V2 Feeder Adapter v17 .gcode
How do you have the API alert you of these triggers or that there was a problem with the filament?
"...as Cura printed them in the order I had loaded or copied them." And it did work that way UNTIL you moved them around by height or some personal criteria, or deleted one, or added one after multiplying others. There were a lot of ways to get different ordering and straightening it out was a lot of effort. -
Dadkitess replied to PaddyMack's topic in UltiMaker 3D printers
Ok, Thanks for your feedback, I definitely need to understand how to fix that issue on our side... By any chance, did you use the Ultimaker PETG as well ? I'm trying to switch to this material to replace the T-PLA, which is too limited when it comes to heat resistance. -
Dadkitess replied to X-Type's topic in UltiMaker Cura
Ha, I thought he answered "It used to work the way I described. I've done it many times." regarding your screenshot of the 5.7 new version, like "Yeah, I already have that menu for months" haha. -
Yes, correct. Easy 90% success rate. Most of the times Fast or Normal Engineering profile. with PVA as support I print up to a speed of 60 mm/sec with mostly TPLA but also PLA. I change Roof and floor thickness to 1 mm, for easy removal within grooves. It does take several days of bathing before it is finally dissolved. If time is of the essence I print all support with PVA. I change the setting Minimum X/Y offset to 0, but I don't think that really does something anymore. I only use the normal support structure by the way, the Tree structure often failed. -
Sooo... You actually manage to get high successful rate when using the PVA as "interface support" only, the rest of the support being made with T-PLA ? Because I really won't exceed 60-70% of success when doing so, it tends to not stick the T-PLA for the floor unfortunately. It would help a LOT since it would reduce the PVA printing by 90% probably, reducing also the time, the scars left because of PrintCore changes, etc. Never found proper advices / tips about it unfortunately.
