All Activity
This stream auto-updates
  1. Past hour
  2. I found Ultimaker tutorial for that. I'm curious how did I get perfect prints in first 30 h of printing... Conclusion: 1. cable was out of it's place (there is slot in side panel behind cable) 2. Pulleys were not tightened in right place (almost all of them) 3. G code was bad I solved everything and I'm happy to continue printing 😄 stu_le_brew thx for everything. good luck
  3. Today
  4. wie macht man das besser? ich möchte aber ohne Stützstruktur auskommen. das Teil wurde stehend gedruckt, d.h. die Öffung mit Gewinde für die Aufnahme vom Sensor ist ein 100% Überhang
  5. Hi, I am trying to build an interruptor to save filament and or to "pause" prints, when no filament is available anymore. An important step to complete this task is to be able to change the state of the printer from "Printing" to "pause". I asked some pros in the exibition "formnext" and they told me in the api of the Ultimaker there should be a code. So I looked it up. I found someting promising, but I don´ t get too far. I will add some screenshots so you will see, what I am talking about. 1. The api asks me an authorisation. Somehow it lets me go forward if I use "ultimaker" and "admin", so I guess it´ s the same PW as the PW I used to change the extruders... 2. There is a command that gives out the current state of the printer. But somehow I can not change the state. 3. There is a command that starts with "Curl -x...." But I cannot use that command, as I would like to change the state directly in the command line instead of only getting the current state of the printer. I think that has to do with programming JSON-Files and I cannot yet program json or python-Files 4. Then I looked at the printer connection of Cura and there is a button that allows the printer to be paused. So I tried to find out, what command this button triggers (see screenshot) but still those command lead to nowhere. Maybe someone can help me out here. Without me having to program anything in json or python or something else to be able to stop the print with that command line... A tech in the exibition told me that should be possible so maybe I overlooked something... Once I have that command ready I will implement that command to be executed when the filament runs out. This I am trying to get done with a raspbery pi. I would appreciate any help here. Thank you Daniel
  6. Hi aag, If you select the main tab for extruder 2, what's the value for build plate adhesion extruder there? If it's extruder 2, that might be the culprit; change to extruder 1. Regards
  7. The movement shown in your second video is absolutely NOT correct there should be no movement at all you need to loosen the pulley an move outwards to prevent this movement
  8. Don't forget the user configuration folder, I guess this it the problematic place.
  9. Thanks for the feedback! I'm glad it worked.
  10. I guess so 🙂 I will try to remove it completely and make a reinstall... Keep you informed, thanks for the advise.
  11. Jetzt wo du es sagst, stimmt, das war glaube ich schon immer so. Aus irgend einem Grund habe mich damals mit dem Startcode gespielt, ich glaube er hat mir zu wenig extruded oder so etwas in der Art. Aber praktisch, denn dann kann jeder einfach umstellen ohne noch großartig etwas zu tun. Das Finetuning wenn man das haben möchte kommt dann eh später. Danke für den Hinweis!
  12. Hi Herve, @fbrc8-erin has posted a good tutorial video about reseating axles and sliding blocks on youtube: I think this perfectly fits (and hopefully solves) your issues. Regards
  13. It seems you have somehow messed up your Cura installation. I would try to remove the user configuration folder of Cura and do a complete reinstallation.
  14. @Smithy genau das ist in der Cura-Druckerdefinition standardmäßig schon als Start-Skript mit drin. Es wird nur für "Ulti-Gcode" ausgeblendet. Das Start-Skript erscheint also "automatisch", sobald man auf "Marlin" umstellt. Fein-Tuning kann man natürlich immer betreiben, und es kann sein, das es in früheren Cura-Versionen anders war. Aber heutzutage muss man dafür nichts mehr manuell einfügen.
  15. Thx for your response! Problem is that I have no materials in my CURA 4.4 material settings. Only 1 material called "unknown" that I cannot edit. Tried to import several files from the material folder (for example: "generic_pla.xml.fdm_material"), program says Import done, but no results. Can someone export his material settings and give me that file to try? This problem also makes that I cannot select material when I want to create a print file... Thanks in advance!
  16. I have changed some settings, and now Cura is making a brim with Extruder 2 (PVA) surrounded by a second brim with Extruder 1. However I do not see how I can revert to normal, which would be an Extruder-1-only brim. Can somebody enlighten me? Thanks in advance
  17. Thanks for your answer. Yes, I unsnapped and fully snapped in. It is fine now.
  18. ceuse
    Cura 4.4
    I face to the same probem, what to do? wait an updated version
  19. Den Startcode brauchst du nur damit er am Anfang nach links vorne fährt, dort ein bisschen Material extruded und dann mit dem Druck anfängt. Kann sein, dass dies bei dir auch so geht, ich habe nicht mehr die original UM Firmware drauf, daher weiß ich das nicht, ob bei der UM Firmware das auch so geht. Mehr tut der GCode aber nicht, also wenns bei dir auch so klappt, dann lasse es so.
  20. Seems that the axle is not fully snapped in the sliding block. You should be able to move the block a little bit and check also the other side of the axle, that both sides are fully snapped in.
  21. Gerne, freut mich, dass es klappt.
  22. Bonjour, Je rencontrais le même problème hier avec ma CR-X. J'ai mis les paramètres suivants et je n'ai plus eu de dÊcalage ni ne mÊlange des couleurs (le paramètre le plus important est wipe inactive nozzle, c'est lui qui règle le problème de dÊcalage). Bonne journÊe
  23. Guten Morgen, nein, da hättest auch keine Chanze, bin super zufrieden damit, war ja nur mein blÜder Fehler beim letzten Teil, sonst wie gesagt ist es die einfachste Handhabung und fkt. eigentlich immer.
  24. Hallo, The right axle seems to be too inclined and touch the white guiding piece. How is it possible to fix this. Many thanks in advance, Herve
  25. Danke fĂźr die Nachhilfe. Es funzt einwandfrei
  26. ich hatte gestern mit Marlin einen Druck gestartet, der hat super funktioniert, deine G-Codes habe ich aber nicht eingefügt gehabt. Kann es sein das die Startsequenzen dann schon automatisch enthalten waren? Oder haben deine Codes einen anderen Hintergrund? Im Übrigen, der Testdruckwürfel mit 20mmx 20mm war auf das 100ertstel genau. Insofern bin ich mit dem Ulti 2+ absolut zufrieden. Aber der 3S Ulti reizt mich ja schon......
  1. Load more activity
Important Information
