All Activity
This stream auto-updates
  1. Past hour
  2. No problem. At the moment I'm about to correct an issue around the conversion process in the plugin, too. You probably noticed issues with that already. Feel free to join the general discussion all around the plugin here:
  3. @RobyRob You can find the macro (Python script) for the conversion inside the plugin here: https://thopiekar.eu:5443/cura-cad-integration/CuraFreeCadPlugin/blob/master-updating-conversion-script/CuraFreeCADPlugin/scripts/convertIntoSTL.py This is the one I use in the latest unreleased package. As far as I understand, after opening the file I should be able to get the active object via native_file.ActiveObject, no? So the differences you probably see, is that you have unsaved changes. The plugin runs FreeCAD and the mentioned macro in the background. It doesn't know anything about the unsaved changes someone made inside FreeCAD's window at the moment.
  4. I promised myself I wouldn't get into gcode or writing 3d printing tools, but then I always promise myself I won't get carried away writing "little" tools for games... After several days trying to get the print bed low enough that material *would* come out of the nozzle, a thought occurred to me: Is there a good reason to print a blob on the plate instead of purging the nozzle off the edge of the bed and wiping it? I realize you don't want to smack the delicate nozzle on the something hard and potentially sharp, especially not while it's hot. But isn't there a way to access the auto-level sensor through g-code so that a plugin could look for the edge of the bed and thus carefully move past it, purge, and then wipe the nozzle on the edge of the build pate?
  5. OH. MY. GOD. I want to cry 😞 I was literally in the process of putting my UM 3 back in the box earlier this week after feeling so utterly betrayed when the printer started behaving like any-old $140 printer. But the real issue was I'd gotten *so* delighted with it, that to speed up my printing cycle, I had flipped the glass over to start a print on the other side. The first print had gone fine, and I forgot. But after that the printer went to absolute crap. The next print failed to adhere Colorfabb nGen, but not on the first few layers like you'd like. The result was a huge nasty blob of ngen which utterly covered both printcores(*). I couldn't get Printcore 1 off so I followed a guide to strip down the print head. I got most of the ngen off both heads, I survived re-assembly of the printhead with only stupid derps (I put all the power connectors back in r-to-l instead of l-to-r). But then I couldn't get any adhesion. I couldn't print the x/y calibration because either the head was too close and nothing came out, or the calibration just wouldn't stick and wound up wrapped around the print core (causing those little white pad things on the bottom of the print head to get sucked into a ball of filament while I was waiting for it to calibrate). I spent literal days messing with settings. When I did find settings that worked on the first layer, things went back to crap the instant I tried a real print - I think cura tries to wipe the nozzle on the prime blob, which used to work with the same temp/ultimaker filament but now routinely just drags the blob into the print; brim and raft are welded so tightly to the model I have to try and design them into the print because they're not coming off... The only thing I didn't think to try was to flip the god damn bed over. Fortunately, buildtak seems to have come to my rescue. But ... this is something you need to get to your users! Is there a way to permanently stain the bed? My sticker came off as I was inserting it into the printer the first time and then permanently the first time I cleaned the bed. (* They *touch wood* seem to be working now ... but there's definitely some evidence of deterioration :()
  6. Today
  7. See my reply here: - Make sure you check the print core, under those soft-white tabs ... and on the back of the heating element, make sure you don't have gunk; - Don't mix manual and auto; - "Some resistance" is a really terrible description of what you are looking for 😞
  8. I've just gotten done recovering with leveling issues on my UM3, my core findings being this: - Glue, even fingerprints on the bed, can affect the leveling results, - There are little soft-material covers by the print head. They're not solid, and material can get pushed up behind them. Take your printcores out and give them a thorough inspection, as this can throw leveling, - When I added a buildtak flex bed, I didn't realize just how much it would throw leveling, or that it would render auto-leveling useless, - Manual level OR auto level, don't expect both to work The auto leveling seems to have certain limitations that go out of whack the instant you touch any of the screws. There also seem to be several bugs in the manual leveling process. In order to successfully level my printer, I totally ignored the display and did my own thing, because so many of the prompts were unhelpful (and the lack of a "go back" or "cancel" option is totally frigging annoying with the U3s oops-I-dialed-when-you-clicked dial). I would recommend you do a fresh manual level: Start by turning all of the screws to make sure they don't feel super loose - don't over-tighten them either. I changed mine from being so lose I could brush one finger tip past and turn them to where I don't need to grip them but I need a fingertip on both sides for them to turn. Next, run the manual level and for the "1mm away" step, use something like a credit card. I used an old one and made sure that the raised print fit under the nozzle. No accuracy is really required for this step but I found it helped if all 3 checks were about the same height. For the calibration card check: my leveling had resulted in the nozzle being so low that nothing came out. So, I replaced the calibration card with a thin sheet of card, about double+ the thickness of the calibration card. This had several advantages, not least being that its flat without requiring any pressure which might invalidate the calibration. When you do this, you're not looking to feel like the card is being caught on the nozzle. You should be sweeping the card/sheet back and forth and then adjusting until you can *just* barely tell that there might be contact with the card. I found this so hard to judge that what I actually did was reach the original point I considered "a little resistance" and then give the screw a 1/16th turn in the opposite direction, which put me at a place that ever-so barely felt a little different than moving the card away from the nozzle. Then I did a fairly simple test print of a single-layer circular face with a rectangular cut-out in the middle (15mm diameter, 8x5 rectangle). I still ultimately wound up making a couple tiny screw adjustments, but I also discovered that running an autolevel after this made things worse again, so I repeated the manual level and I've been getting great prints again. I'm about to apply GR5's tip on setting "Combing Mode" to "not in skin" in the hopes I stop getting horrible, messed up first/top layers.
  9. That is correct. In the object tree (where you see all steps, which have been done to build your body) you will see the active object in bold letters. Normally, this is the state which you can see in the 3D view at the same time. So what you see after opening FreeCAD, should be what you get in Cura. 🙂
  10. Bump with thanks to @gr5 -- great info. Thinking about how my printer routinely drags the prime blob into the print (it looks like it tries to wipe the nozzle but the nozzle is still too hot) and wanted a repl to experiment with - this seems like it might be close enough. You mentioned a web service, and I guess it'd be easy enough to flask something, but is there any real interest in poking at this kind of level by other people? If so, maybe I'll look at making time to write a Jupyter kernel (https://github.com/jupyter/jupyter/wiki/Jupyter-kernels)
  11. @thopiekar Thank for your answer. Another question / clarify: which is the Freecad object that is import in Cura? From my test it is the last body created in Freecad before saving it, not the active body or selected body: So if I have more body I need to fuse all toghether as last operation before save. Is this right?
  12. Yes, it is the same, but it is a nightly build. In short: The package has been built automatically without increasing the version. It will be 0.3.1 in the future if nothing comes in between. If someone else could also confirm that everything works great, I'll care about uploading it to the marketplace as soon as possible. If there is anything else like other remaining problems or missing features, please share them in the other thread I mentioned above! 😉 Regards - Thomas
  13. Hello @Froissart. Yes, the z-hop will work irrespective of whether it is the extruder that moves up and down or the build plate that moves up and down.
  14. I'm using Cura at school with CR10S and Ender 3 printers. We are having trouble with the extruder bumping the models off the build plate. I see the Z hop option but it explains the build plate will move down but on the printers we use the plates are fixed the extruder moves in the Z direction. Will this option work with the Creality printers or other printers with fixed build plates?
  15. Hi, i see this problem also in other slice, in cura sometimes there is support column when no need, this is an example: in this case the problem is the stringing effect between the real 3 part and the "no need" support column between... How i can manage this. I got same problem also with other part, in similar condition, 2 hole near each other but i not need support. I'm not sure is that the problem
  16. The front belt looks loose on the bottom but is tight on top. It prints well like it is so I have chosen not to adjust it. At some point you might want to make this adjustment or replace the belt.
  17. "The difference between the detected height of the two printcores exceeds the realistic values" It will usually help if you have a correct bed leveling. Level the bed manually first, in a way that you have about 13-14mm to the bottom of the bed (works for me), see picture. Also if its one of the first UM3's it may still have a weak bed spring at the back of the 3 adjustment wheels. If you can very easily pres the bed down at the back, you want to replace this 3th spring. The AA0.4 core is indeed worn down by using abrasive materials. You can still print with it, use it for vase mode f.e., but you want to replace it for fine detail prints. If you want to print abrasives you need the CC0.6 core with the Ruby nozzle.
  18. pretty sure the gummy bears feel different about this 🙂
  19. Sure, here's my system directory. DuetSystemDirectory.zip
  20. Hi, first point, i suggest you turn your text-color to an eye-friendly black, als this (50%?) grey is very hard to read (no offend, just a proposal) ;-). This flat nozzle tip IS unusual and absolutely not correct. It reminds me to reports of other people, who printed with abrasive materials, which eroded the nozzles and made them unusable (that's why hardened steel nozzles and ruby nozzles, like the CC Printcore, exist). The tip of your BB Core looks as it should be. So, in my oppinion, the worn is to be replaced with a new one. Usualy the UM3(E) is shipped with two AA cores and one BB Core. Is the second AA still available? Greetings.
  21. Bonjour Je possède les deux machines, et mes deux machines partagent les mêmes programmes UltiGcode de Cura (15.04.06). Une vielle version de Cura. Jje sais, mais je ne pense pas que cela change avec la dernière version. Fred
  22. Hello @thopiekar. I just tried the new Cura plugin for import Freecad files and now it works all right. Thanks for your work. I'm just a little confused (my mistake) in finding the right files to install. the right place is https://thopiekar.eu:5443/cura-cad-integration/CuraFreeCadPlugin/-/jobs/1024/artifacts/browse but I tried https://thopiekar.eu:5443/cura-cad-integration / CuraFreeCadPlugin / by mistake. The version number is the same (0.3.0) and is the same in the Freecad marketplace. Personally,so far, I had solved with a macro in Freecad that generates the stl file and launches Cura, but the Cura plugin should be better
  23. Hello 3d printers, I make you a brief paragraph for the history: I recovered an Ultimaker 3 Extented which was neglected by his buyer who did not want more (an unscrupulous industrialist). He gave it to me saying that it did not work anymore ... Anyway, I decided to make it running. So I reset it, get started, configured, etc ... However, I have a problem with the next one raised by the printer: "The difference between the detected height of the two printcores exceeds the realistic values". Indeed the error is raised when I want to make an print or even make an XY calibration. I checked, the nozzles were not clogged, I cleaned the tray and made a leveling adjustment manually. However, still no way to print ... Then I discovered that my nozzle AA - 0.40 was unusually flat (Attached some photos as evidence). I thought maybe it was the Ultimaker design, but looking at the new ones on the shop, I see them more conical. Mine seems to have been ... damaged ?! I would like to have your opinion ... Do I have to buy a new print head? Can this flat nozzle be the cause of this error? How does the utimaker 3 detect the tray exactly? Is the probe inductive?
  24. I just did the same using these instructions. Easy to do, works great. There's a little bit of an uh-oh moment where it looks like you need to create a debian login on the LCD, but it just moves past that after a bit. Back to using my printer as it should work. Thanks mikkermik!
  25. And your plugins make Cura work better for a lot of people I bet. My favorite is the z-offset. Thank you for them.
  26. See my post below on using 'Outer wall inset'. Horizontal expansion essentially just scales the whole design bigger or smaller. 'Outer wall inset' move the outer wall in toward the inner wall a set amount to compensate for a line width that is slightly larger than what you specify.
  1. Load more activity
Important Information
