All Activity
This stream auto-updates
  1. Today
  2. Yesterday
  3. Hi, I really like the support type of the Cura custom support (the harmonica support that is really easy to remove), but wondered whether this is a special support type only available when using the custom support or is it also available as a regular supporttype when using the automatic support creation of cura (not creating support using the custom support option)? Thanks, Leo
  4. I don't know if the Buildtak works with the S5, but be aware that you cannot disable the active leveling on the S5.
  5. First thing i would try is to update to the latest version whats 4.3 and see if the bug still happens.
  6. Buildtak sells flexplate systems for ultimaker S5. Does this work with active leveling? Or do we need to disable active leveling like with UM3 ?
  7. Thank you for the suggestion. Unfortunately, it does not work. This setting causes the support to be a single line up to the finger tip. My printer is not able to print a single line straight up since the bed moves. I am going to use the "Custom Supports" add-in that was recommended by a YouTuber called "Chep". Wish me luck!
  8. That is, in fact, the instructions I was referring to, but you do seem to have hit on the problem; I was screwing it in the wrong direction and so it was tightening all the way but not getting tense-- it seems to be reassembled now; thank you!
  9. Cura 4.2.1 can be downloaded here: https://github.com/Ultimaker/Cura/releases/tag/4.2.1
  10. Ultimaker Cura versions 2.1 and up don't have a COM port selection in Machine Settings. The (very old by now) Cura 15.04 does have it. The Lulzbot Edition of Cura (Cura LE) also has it.
  11. I'd talk to your reseller. Unfortunately they might prefer to have you send it to them but ask them if it's something you can fix yourself (these printers come apart pretty easily but there are deadly voltages under the S5).
  12. Birk
    Ultimaker 2 Dualprint ?
    Ich dachte das hat schon mal gehandelt gemacht oder geht in der Firmenware leicht zu erstellen .. ich habe absolut kein Plan von Firmenwäre oder anderen Dingen an Software einstellen oder erstellen .. also is sozusagen das Projekt jetzt schon gestorben scheinbar
  13. Wenn es noch die ältere Elektronik ist, wo alle 5 Stepper-Treiber bestückt sind, können auch 5 Motoren angesteuert werden (falls das die Frage war...?) Das läuft darauf hinaus, das es nur eine Düse (Heizung und Temperatursensor) gibt, aber zwei Feeder. Mir ist keine UM2-Firmware bekannt, die so konfiguriert ist. Wenn Google auch niemanden findet, der das schon gemacht hat, müsstest Du zuerst mal eine passende Firmware "bauen".
  14. Hallo Zusammen Ich habe das selbe Problem habe es mit der Problemlösung versucht jedoch funktionert es nicht. Vielen Dank für Ihre Hilfe
  15. Birk
    Ich möchte aber nicht die Methode mit dem Wechsler haben und leider bin ich mit englisch nicht so bewandert das ich mir aus den Texten die nötigen Information ziehen kann . Die sogenannte russische Methode is für mich die einfachste von Umbau her und mir geht es auch nicht um das es gut und schön wechselt . Ich wollte die Option benutzen das ich zwischen weisen und schwarzen filament beim drucken einer Farbe nicht immer wechseln muss . Die Mark 2 Methode is zwar schön aber leider für mich nicht realisierbar .
  16. Hello everbody, I have a question about the bridging settings. How can I prevent the build up of filament in the top of the circle. (see the bridging picture) And how can I change the starting point of the bridging. I hope somebody can help me
  17. Make sure your printer is set to the correct com port in Machine settings menu. If the com port is set to AUTO it doesn't work! (Mine needs to be set to COM 7)
  18. Es gibt dazu ein eigenes Projekt welches schon mehrfach wenn nicht hundertfach erfolgreich umgesetzt wurde. Allerdings nicht mit der "russischen" Methode mit einem Y-Splitter. Lies dich einfach ein und wenn du Dual drucken möchtest, dann solltest du es so machen wie es dort beschrieben ist. https://magnetic-tool-changer.com
  19. Hallo Ich habe mal eine Frage in Sachen Dualprint am Ultimaker2 . Kommt das Orginalboard mit 2 Filamenten klar? Ein Steckplatz is ja noch frei für einen Motoranschluss. Auf meinem Ultimaker 2 läuft zur Zeit Thingergnome Software . Ich würde gern 2 Filamenten über einen y-Splitter in eine Düse machen(nicht zur gleichen Zeit) . Muss an der Software noch etwas geändert werden ? Ich weis das ich im Cura auch noch etwas umstellen muss . Mir geht es erstmal darum was am Drucker gemacht werden muss eigentlich noch oder is die Firmenware schon drauf vorbereitet .. Der Motor mit Antrieb ist schon verbaut am Drucker nur noch nicht angeschlossen weil zufeige das was kaputt gehen könnte . Der Ultimaker ist auf 1,75mm umgebaut mit olsenblock . Gruß
  20. If this is the wrong place to post this, please let me know where the right place is. I can't coast volume more than 0.242 mm3. I'm trying to eliminate stringing. I'm using the popular stringing test (see here: https://www.youtube.com/watch?v=_QRb54zVPfQ). I've got an Ender 3, using Hatchbox PLA at 190C, 50 mm/s. I've attached the screenshots showing when it will and won't slice. If I up my coasting vol to 0.243 mm3, then it just hangs.
  21. yes i insert an Object "a supporting stucture block" and select it but that icon is gray
  22. did you select a model? with nothing selected the icons are grey.
  23. Hi guys, I seem to have a little problem at the moment. I am trying to look for Cura's previous version as it had some time ago in a drop down list and you chose whatever version was suitable for you but I now can not find nor see where you can download a previous Cura version. I have Cura 4.3.0 but it has proved to be a disaster as my prints looked chopped and horrible. I want to go back to Cura 4.2.0 but I can only see a page where it says previous version but with a page that only has zip files that don't work. Can someone help me? Many thanks, Tiimy
  24. Muy buen día Amigo. he estado revisando la información en ingles sobre el problema debido a que yo tenia el mismo inconveniente. la forma de solucionar este problema es ejecutar el diagnostico de compatibilidad del programa, el cual lo ejecuta como win 8 y permite que funcione de manera correcta. espero que te sea de ayuda y a todos los que por curiosidad o buscando solución miren esta comunidad.
  25. Hallo , kann mir jemand sagen wie ich "Einstellungen pro Objekt" in Cura 4.3.0 aktivieren kann ist bei mir ausgegraut, sowohl bei stl-dateinen aus Thinkiverse als auch bei selbst erstellten dateien
  26. play with the initial layer thickness until the letters show in the first layer. There is also another little trick: print the first layer thin with the letters, pause the print, change the colour and resume the print. In your case I would start with one thin layer with the letters and stop the print, change the colour, change the first layer thickness to a solid first layer and print over the first layer. Info from an old topic:
  1. Load more activity
Important Information
