All Activity
- Past hour
ricardo001 joined the community
- Today
fightdirector joined the community
omarelaghil96 joined the community
Celia7 started following Material Sync not working
ltommy started following Cura transparent Window after opening on Plasma 6 and in Hyprland
ltommy replied to bsilverthorn's topic in UltiMaker Cura
Same issue here. Window is transparent with Nvidia 550.67-2, Cura and 5* version, ArchLinux, Wayland, Plasma or Gnome. Start either using X11 works fine. Cura 4.13.1 works fine under Wayland. However, running Cura 5.6.0 in Wayland on Debian 12 stable, Gnome 44.8-1, it works fine. A clue? -
ltommy joined the community
ietomit77 joined the community
It isn't an override as such. The keywords in the StartUp tell Cura that the temperatures are being handled. When that is the case the automatic "Prepend" doesn't get inserted.
No longer possible to set print order when printing "One at a time"!?
GregValiant replied to X-Type's topic in UltiMaker Cura
Unfortunately "One at a Time" is not available for multi-extruder printers when more than a single extruder is enabled. You would need to disable Extruder 2. If you happen to be using Extruder 2 for a model or for support then you are out of luck. -
Super merci pour les infos je vais regarder est modifier les valeurs
th31nfamous started following Ender3v2 with Z-Height problems.
Hey guys, i need help with a problem i have on my ender3v2 printer. My printer is literally just randomly adjusting it's offset when i start a print. So every time i start a print, i have to manually change the Z-offset position while the printer is doing the initial strip. It can go from -.01 to - 1.50 .. (it is always too low) The bed is correcly aligned and i know for sure that the home position is always the same before the print start because i made a mark on the z threaded shaft and it always match the other mark on the collar . The problem started when during a print a made a pause to switch filament, and after this the nozzle came in contact with the print. Pretty sure the problem is not from the slicer gcode because when i use old gcode that i was using before the problem started, the height problem is still there. Other that than that the printer works fine but i'm just getting tired of fine-tuning the z offset in a rush when the print starts, i also want to buy/install a bl touch and id rather solve this problem before i make the install of the BLtouch Thanks guys !!
mekkihussein changed their profile photo
plbyrd joined the community
mekkihussein joined the community
greenpizza55 joined the community
Burtoogles work on "discreet infill lines" looks really interesting. I will try to start a dialogue with him to find out what is possible with the existing code and if there are other possibilities such as the Honeycomb I was working on. I did get it to work to a degree but it was kinda hard to get the diagonal cell walls to be generated with only one line. I'm certain this and even more optimal solutions can be solved. The biggest problem I have in regards to this stuff is understanding how to install and configure software. I know what I would like to see as far as printed structures and how the slicers tool path should move but (for example looking at the smartavionics git page I have no idea how to download what to download and how to use if I was to download!
frickdewey joined the community
thomas1212 joined the community
Researching New 3D printers for office upgrade
DDoove replied to PaddyMack's topic in UltiMaker 3D printers
@Dadkitess, no, unfortunately we rarely print with PETG so far. -
X-Type replied to X-Type's topic in UltiMaker Cura
I have now downloaded and testet 5.7.0-beta.1 The objects list is there. But unfortunately I do not get these alternatives in the drop down menu inside the objects list. -
Thanks a ton! I didn't know the startup Gcode field overrode the default commands. Seems to be working great now. 👍
GregValiant started following Modifying gcode on export?
Go to "Manage Printers" and "Machine Settings". You want to edit the "StartUp G-Code". Cura will always put the heating commands in if there are no "replacement patterns" in the startup. This is based on the Ender 3 Startup Gcode. My changes are in bold. ; Ender 3 Custom Start G-code G92 E0 ; Reset Extruder M220 S100 ; Reset the feed rate M221 S100 ; Reset the flow rate M140 S{material_bed_temperature_layer_0} ; Start heating the bed M104 S{material_print_temperature_layer_0} ; Start heating the nozzle G28 ; Home all axes G0 F600 Z5 ; Move up to ooze M190 S{material_bed_temperature_layer_0} ; Wait for the bed M109 S{material_print_temperature_layer_0} ; Wait for the nozzle G1 Z2.0 F3000 ; Move Z Axis up little to prevent scratching of Heat Bed G1 X0.1 Y20 Z0.3 F5000.0 ; Move to start position G1 X0.1 Y200.0 Z0.3 F1500.0 E15 ; Draw the first line G1 X0.4 Y200.0 Z0.3 F5000.0 ; Move to side a little G1 X0.4 Y20 Z0.3 F1500.0 E30 ; Draw the second line G92 E0 ; Reset Extruder G1 Z2.0 F3000 ; Move Z Axis up little to prevent scratching of Heat Bed G1 X5 Y20 Z0.3 F5000.0 ; Move over to prevent blob squish" ;End of StartUp The "reset" lines are in case you happened to tune a previous print from the LCD. They set the printer back to the default 100% feed and flow rates.
cotem2021 started following Modifying gcode on export?
Hi, still relatively new to using Cura for only about a year. I noticed that whenever I create a gcode file to print on my Ender 3, it is written so the bed heats up first, waits until it is up to temp, then starts heating the extruder. I believe I can make small savings in print time by modifying it to preheat both at the same time. I have written out the gcode that Cura spits out below. M140 S62 M105 M190 S62 M104 S210 M105 M109 S210 I rearranged this code to be: M140 S62 M104 S210 M105 M104 S210 M109 S210 This seemed to work in preheating both at once. Is there a capability in Cura to change this on all gcode files that Cura generates? I looked in the printer settings and it seems the custom start gcode appears after this code snippet. I have attached an example gcode file to this post. My cura version is 5.2.1. I would greatly appreciate any help anyone can provide. Thanks! CE3E3V2 Feeder Adapter v17 .gcode
How do you have the API alert you of these triggers or that there was a problem with the filament?
"...as Cura printed them in the order I had loaded or copied them." And it did work that way UNTIL you moved them around by height or some personal criteria, or deleted one, or added one after multiplying others. There were a lot of ways to get different ordering and straightening it out was a lot of effort. -
Dadkitess replied to PaddyMack's topic in UltiMaker 3D printers
Ok, Thanks for your feedback, I definitely need to understand how to fix that issue on our side... By any chance, did you use the Ultimaker PETG as well ? I'm trying to switch to this material to replace the T-PLA, which is too limited when it comes to heat resistance. -
Dadkitess replied to X-Type's topic in UltiMaker Cura
Ha, I thought he answered "It used to work the way I described. I've done it many times." regarding your screenshot of the 5.7 new version, like "Yeah, I already have that menu for months" haha. -
Yes, correct. Easy 90% success rate. Most of the times Fast or Normal Engineering profile. with PVA as support I print up to a speed of 60 mm/sec with mostly TPLA but also PLA. I change Roof and floor thickness to 1 mm, for easy removal within grooves. It does take several days of bathing before it is finally dissolved. If time is of the essence I print all support with PVA. I change the setting Minimum X/Y offset to 0, but I don't think that really does something anymore. I only use the normal support structure by the way, the Tree structure often failed. -
Sooo... You actually manage to get high successful rate when using the PVA as "interface support" only, the rest of the support being made with T-PLA ? Because I really won't exceed 60-70% of success when doing so, it tends to not stick the T-PLA for the floor unfortunately. It would help a LOT since it would reduce the PVA printing by 90% probably, reducing also the time, the scars left because of PrintCore changes, etc. Never found proper advices / tips about it unfortunately. -
Slashee_the_Cow changed their profile photo
Well it's definitely prettier than a lot of models I've tried to troubleshoot 🙂. Some observations: You put in a ChangeAtZ post-processor to speed up the top four layers? I can't think of any good reason to do that (but feel free to explain your reason, maybe it's just good and I couldn't think of it) I hope this thing doesn't collapse under its own weight at the top because there's no infill. But given how much filament infill would add, I can see why you'd want to avoid it. This thing is going to be weak. The kind of "pick it up from the bottom and cradle it when you move it" weak. Okay, done with the observations. Now the suggestions (and I might be using some of the more advanced settings here so if you can't see them, just search for them): Turn off Travel > Retract at Layer Change: At the extrusion distance and speed you're using, it's not going to be doing the retraction in then back out fast enough. Do this one. I mean it. Any stringing is going to be on the inside of the print, hidden, anyway. Turn off Experimental > Use Adaptive Layers. We want to get a consistent flow rate and adaptive makes it different for different layers. Seriously consider using two 0.6mm walls instead of a single 1.2mm wall: As well as Quality > Line Width, you're going to need to change Walls > Minimum Wall Line Width to 0.6mm and turn off Walls > Print Thin Walls It reduces the flow rate - that makes it easier for the printer to control the flow Retractions will be more effective since it only has to retract half as much filament (by volume) We can put the starting Z seams on the inside wall so if the problem is when it starts a line it'll be hidden. For that you'd need the following settings: Walls > Optimize Wall Printing Order turned on Walls > Wall Ordering set to Inside To Outside Experimental > Group Outer Walls turned off If the problem is when it ends a line, just use the the settings above but with Wall Ordering set to Outside To Inside If it has problems at both starts and ends, then obviously another fix needs to be found Yes, it'll take nearly twice as long to print. Slow print > bad print It'll make it marginally stronger. Like, just so little it's barely worth mentioning. But it's science! The thinner something is, the more likely it is to bend instead of break. PLA is pretty brittle so tends to default to "break" and this probably won't change that, but I'm weird in that I subscribe to the "in theory, it'll help" way of thinking, not caring about the "in practice, it won't make a difference" part Turn down Speed > Travel Speed to 50mm/s. Filament can be a bit clingy, especially when you're extruding a lot more than someone on a 0.4mm nozzle would be, and I've seen travel speeds so high they've literally pulled parts of the model with them, making them warp I'll admit, this will likely make no difference. But your print has so few travels it barely adds anything to the print time so it can't hurt As @jaysenodell mentioned, you could set Walls > Z Seam Alignment to Random but that is sort of a cop out in that you might still have the problems, they just won't be nearly as noticeable because they're not all in one line. It will introduce a lot more travels but if there's any stringing, thanks to combing, Cura makes them all go around the hole in the middle, so they still won't be visible from the outside %!&*ing hoons in their Commodores doing 80 in a 60 zone. Where's a cop when you need one?
I dont share this experience with PVA, I often print complex geometry parts which take several days with Ultimaker (T)PLA and PVA and it rarely fails. The only thing we have trouble with is when the printer unloads the material and reloads it again. Most of the time it then breaks somewhere within the bowden tube. I always cut the filament after it has unloaded to remove all material that has been through a bowden tube. Other problems are mostly because the spool has been within the material station for too long. A new spool generally solves the problem then. I don't tweak the print settings alot. Mostly infill type and density, print speed for (PLA up to 70mm/sec), core temperature, and bed adhesion type. For support I change to PVA when needed and then choose if all support is printed with PVA or only floor and roof. Other than these I tend to stick to the generic presets. Maybe I'm still satisfied because I only have experience with Ultimaker 3 and S5, Bambulab X1E and Ender 5 Max and don't search for the limits of these printers. -
How the hell did you get that option before the 5.7 ? 😮 -
I don't have a Bumbulab at work / home myself, but do have a UMS5. I would tend to approve every single line except the speed single material that I would set to 1 : it's horribly slow and there is nothing you can do to accelerate it, its max flow rate is really poor. You might want to add the "perfect first layer" that would get an honest 5 with UMS5 : I've never ever ever ever failed a single first layer, be it with Polycarbonate, PA12-CF, PETG, PVA, etc. But on the opposite it lacks something about overall design flaws, the chance to get a failed print, which is definitely WAY too high if you use PVA as a daily support. Damn, that thing is horrendous, especially the Ultimaker official one. And the dedicated printcore, the BB, don't seem to help at all. It will jam so often, it will trigger the flow sensor, it won't stick to itself, to PLA, it... It's endless. You really have to have proper "basic" simple shape, with very classic parameters, and a re-dried spool to ensure a long print to success. Unfortunately, this 2 printcores configuration is the reason to be of the UMS5, there is nothing else that set it apart, nothing, except maybe that incredible first layer. So yeah, I would mitigate the overall review of UMS5 with a note on the PVA / 2 printcore configuration that is an absolute must BUT it will work only time to time and will lead to a lot of frustration. And since, apart from that and the first layer, the print speed is atrociously slow and will have ghosting even at 25 mm/s + very expensive spool + very expensive printer at all + quite noisy + really not ergonomic + multiple errors + CURA that tends to be the best AND the worst slicer sometimes + build quality issues, etc, it's hard to recommend except when, well, Soluble Support. I'm really looking forward a Bambulab IDEX. And I need to see how a Prusa XL would not do exactly the same job as the UMS5 while also correcting most of it flaws by a good margin. -
jaysenodell started following Underextrusion after seam?
Yep.. that was me. 1.0mm noz for big tubes that eat entire 1kg spools at a go. I'm dumb. I found the problems to be Retraction extra prime amount - 1.5mm3 SLOOOOOOOOOOWWWWW DOOOOOOOOOOOWN ... this is for PLA Print speed - 50mm/s (my normal is 80mm/s which will make slashee call me names) ZSeam aligment - Random Outer wall wipe distance = 0 Layer height - 0.6mm I get a textured surface (ridged) but no holes in the layers. If you see underextrusion middle of a layer you may need to increase noz temp to help the booger string flow. I wound up at 200. The two biggest factors were print speed (slower is better) and the prime amounts (there is more than retraction prime, that's the only one I needed to change). Let me know if I can be of any help.
kallisti5 started following [UM2] ABS Warping? The final solution.
I just wanted to post here that i've *FINALLY* solved all of my Ultimaker 2's warping issues. I've always had a theory that the open top was just too much for thermal management of prints. Over several years, I noticed that closing in the top with painters tape helped control warping and greatly improve bed adhesion. Whelp. I ordered one of these https://www.aliexpress.us/item/3256805493131735.html and installed it last night. Immediately did a print, and had absolutely zero ABS warping for the first time ever. *HIGHLY* recommended. I have no connection or affiliation with that aliexpress seller, or the manufacturer. For the price under $100, I wish I bought one years ago and wasted less of my time messing around with "free" solutions.
I've been using the S5 since it's release and upgraded to pro bundle when that was released. I've been quite happy with it. It does sometimes come with errors especially when it becomes older (>3 years with an average of at least 60h printing per week), but after a while you will know how to fix most of them. We also have a BambuLab X1E since a few months, it does print faster, but it also comes with errors, less though. In general I really need the water soluble support material (PVA) for decent quality complex geometries, I use the "Support for PLA" from Bambulab, but it takes a lot of time and effort to get it off (if even possible) in small corners and grooves. So if I had to choose 1 printer, I'd still go for the S5/S7 pro bundle, but the second printer would definitely be a Bambulab. I've attached my findings so far, if you have questions, let me know.
