All Activity
This stream auto-updates
  1. Past hour
  2. Oui, il me semblais bien mais je trouve qu'il fait mal son taf. Si mon fil est un peu tordu je suis obligé de le redresser.
  3. Today
  4. Here's a version that should work with the UM S5 and UM 3 with newer firmware: http://files.fieldofview.com/cura/ZOffsetPlugin-v6.0.0-2019-04-19T15_13_09Z.curapackage Download the file and drop it into a running Cura window. Then restart Cura. Feedback is appreciated.
  5. Enter anything in the "text to display" field of the postprocessing script. A space, an exclamation mark, my name. Just don't leave it blank.
  6. So after a long time I instaled Cura 4.0 and tried slicing something , but the progress bar just won't advance , it did not work in 3.6 either. Here is a log file : 2019-04-19 16:57:08,328 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin FileLogger 2019-04-19 16:57:08,360 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin FirmwareUpdateChecker 2019-04-19 16:57:08,391 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin FirmwareUpdater 2019-04-19 16:57:08,407 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin GCodeGzReader 2019-04-19 16:57:08,422 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin GCodeGzWriter 2019-04-19 16:57:08,453 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin GCodeProfileReader 2019-04-19 16:57:08,485 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin GCodeReader 2019-04-19 16:57:08,516 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin GCodeWriter 2019-04-19 16:57:08,532 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin ImageReader 2019-04-19 16:57:08,563 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin LegacyProfileReader 2019-04-19 16:57:08,578 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin LocalContainerProvider 2019-04-19 16:57:08,610 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin LocalFileOutputDevice 2019-04-19 16:57:08,625 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin MachineSettingsAction 2019-04-19 16:57:08,641 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin ModelChecker 2019-04-19 16:57:08,672 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin MonitorStage 2019-04-19 16:57:08,688 - WARNING - [MainThread] UM.Preferences.getValue [97]: Tried to get the value of non-existing setting cura/active_mode. 2019-04-19 16:57:08,703 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin PerObjectSettingsTool 2019-04-19 16:57:08,735 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin PostProcessingPlugin 2019-04-19 16:57:08,750 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin PrepareStage 2019-04-19 16:57:08,766 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin PreviewStage 2019-04-19 16:57:08,797 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin RemovableDriveOutputDevice 2019-04-19 16:57:08,844 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin SimulationView 2019-04-19 16:57:08,875 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin SliceInfoPlugin 2019-04-19 16:57:08,907 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin SolidView 2019-04-19 16:57:08,922 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin SupportEraser 2019-04-19 16:57:08,969 - DEBUG - [MainThread] cura.OAuth2.AuthorizationService.getAccessToken [106]: No auth data to retrieve the access_token from 2019-04-19 16:57:08,985 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin Toolbox 2019-04-19 16:57:09,000 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin CameraTool 2019-04-19 16:57:09,032 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin MirrorTool 2019-04-19 16:57:09,063 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin RotateTool 2019-04-19 16:57:09,094 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin ScaleTool 2019-04-19 16:57:09,125 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin SelectionTool 2019-04-19 16:57:09,157 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin TranslateTool 2019-04-19 16:57:09,203 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin UFPWriter 2019-04-19 16:57:09,235 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin UltimakerMachineActions 2019-04-19 16:57:09,453 - DEBUG - [MainThread] UM3NetworkPrinting.src.Cloud.CloudOutputDeviceManager._onLoginStateChanged [57]: Log in state changed to False 2019-04-19 16:57:09,453 - DEBUG - [MainThread] UM3NetworkPrinting.src.Cloud.CloudOutputDeviceManager._onGetRemoteClustersFinished [80]: Parsed remote clusters to [] 2019-04-19 16:57:09,453 - DEBUG - [MainThread] UM3NetworkPrinting.src.Cloud.CloudOutputDeviceManager._onGetRemoteClustersFinished [81]: Removed: 0, added: 0, updates: 0 2019-04-19 16:57:09,453 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin UM3NetworkPrinting 2019-04-19 16:57:09,485 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin UpdateChecker 2019-04-19 16:57:09,500 - INFO - [Thread-2] UpdateChecker.UpdateCheckerJob.run [36]: Checking for new version of cura 2019-04-19 16:57:09,563 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin USBPrinting 2019-04-19 16:57:09,594 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin UserAgreement 2019-04-19 16:57:09,641 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade21to22 2019-04-19 16:57:09,657 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade22to24 2019-04-19 16:57:09,688 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade25to26 2019-04-19 16:57:09,719 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade26to27 2019-04-19 16:57:09,750 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade27to30 2019-04-19 16:57:09,782 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade30to31 2019-04-19 16:57:09,813 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade32to33 2019-04-19 16:57:09,844 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade33to34 2019-04-19 16:57:09,875 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade34to35 2019-04-19 16:57:09,891 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade35to40 2019-04-19 16:57:09,922 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin SimpleView 2019-04-19 16:57:09,969 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin X3DReader 2019-04-19 16:57:10,016 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin XmlMaterialProfile 2019-04-19 16:57:10,047 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin XRayView 2019-04-19 16:57:10,078 - INFO - [MainThread] UM.VersionUpgradeManager.upgrade [143]: Looking for old configuration files to upgrade. 2019-04-19 16:57:10,078 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\packages.json, skip it 2019-04-19 16:57:10,094 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\plugins.json, skip it 2019-04-19 16:57:10,094 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\packages.json, skip it 2019-04-19 16:57:10,094 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\plugins.json, skip it 2019-04-19 16:57:10,110 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\packages.json, skip it 2019-04-19 16:57:10,110 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\plugins.json, skip it 2019-04-19 16:57:10,125 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\packages.json, skip it 2019-04-19 16:57:10,125 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\plugins.json, skip it 2019-04-19 16:57:10,125 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\packages.json, skip it 2019-04-19 16:57:10,141 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\plugins.json, skip it 2019-04-19 16:57:10,141 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\packages.json, skip it 2019-04-19 16:57:10,141 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\plugins.json, skip it 2019-04-19 16:57:10,157 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\packages.json, skip it 2019-04-19 16:57:10,157 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\plugins.json, skip it 2019-04-19 16:57:10,172 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\packages.json, skip it 2019-04-19 16:57:10,172 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\plugins.json, skip it 2019-04-19 16:57:10,172 - INFO - [MainThread] UM.Qt.QtApplication.startSplashWindowPhase [198]: The preferences file cannot be found, will use default values 2019-04-19 16:57:10,188 - DEBUG - [MainThread] UM.Backend.Backend._onSocketError [213]: Socket was unable to bind to port, increasing port number to 49675 2019-04-19 16:57:10,188 - DEBUG - [MainThread] UM.Backend.Backend._createSocket [227]: Previous socket existed. Closing that first. 2019-04-19 16:57:10,188 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._terminate [295]: Attempting to kill the engine process 2019-04-19 16:57:10,203 - DEBUG - [MainThread] UM.Backend.Backend._createSocket [227]: Previous socket existed. Closing that first. 2019-04-19 16:57:10,203 - INFO - [MainThread] UM.Qt.QtApplication.startSplashWindowPhase [207]: The preferences file 'None' cannot be found, will use default values 2019-04-19 16:57:10,391 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [187]: Socket state changed to Listening 2019-04-19 16:57:10,407 - INFO - [MainThread] UM.Backend.Backend.startEngine [81]: Started engine process: C:\Program Files\Ultimaker Cura 4.0\CuraEngine.exe 2019-04-19 16:57:10,407 - DEBUG - [MainThread] UM.Backend.Backend._backendLog [101]: [Backend] Calling engine with: ['C:\\Program Files\\Ultimaker Cura 4.0\\CuraEngine.exe', 'connect', '127.0.0.1:49675', ''] 2019-04-19 16:57:10,453 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 16:57:10,469 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] Cura_SteamEngine version 4.0.0 2019-04-19 16:57:10,469 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] Copyright (C) 2018 Ultimaker 2019-04-19 16:57:10,469 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 16:57:10,485 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] This program is free software: you can redistribute it and/or modify 2019-04-19 16:57:10,485 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] it under the terms of the GNU Affero General Public License as published by 2019-04-19 16:57:10,485 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] the Free Software Foundation, either version 3 of the License, or 2019-04-19 16:57:10,485 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] (at your option) any later version. 2019-04-19 16:57:10,500 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 16:57:10,500 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] This program is distributed in the hope that it will be useful, 2019-04-19 16:57:10,500 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] but WITHOUT ANY WARRANTY; without even the implied warranty of 2019-04-19 16:57:10,516 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the 2019-04-19 16:57:10,516 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] GNU Affero General Public License for more details. 2019-04-19 16:57:10,516 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 16:57:10,516 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] You should have received a copy of the GNU Affero General Public License 2019-04-19 16:57:10,532 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] along with this program. If not, see <http://www.gnu.org/licenses/>. 2019-04-19 16:57:13,235 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.loadAllMetadata [338]: Loading metadata into container registry took 2.8125009536743164 seconds 2019-04-19 16:57:13,360 - DEBUG - [MainThread] cura.Scene.CuraSceneController.setActiveBuildPlate [104]: Select build plate: 0 2019-04-19 16:57:13,375 - INFO - [MainThread] cura.CuraApplication.run [695]: Initializing variant manager 2019-04-19 16:57:13,375 - DEBUG - [MainThread] cura.Machines.VariantManager.initialize [59]: Exclude variant [empty_variant] 2019-04-19 16:57:13,391 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container ultimaker_s5_glass 2019-04-19 16:57:13,391 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [ultimaker_s5_glass] added. 2019-04-19 16:57:13,391 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container ultimaker_s5 2019-04-19 16:57:13,469 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [ultimaker_s5] added. 2019-04-19 16:57:13,469 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container ultimaker_s5_aluminum 2019-04-19 16:57:13,485 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [ultimaker_s5_aluminum] added. 2019-04-19 16:57:13,485 - INFO - [MainThread] cura.CuraApplication.run [699]: Initializing material manager 2019-04-19 16:57:13,657 - INFO - [MainThread] cura.CuraApplication.run [704]: Initializing quality manager 2019-04-19 16:57:13,672 - DEBUG - [MainThread] cura.Machines.QualityManager.initialize [136]: Lookup tables updated. 2019-04-19 16:57:13,672 - INFO - [MainThread] cura.CuraApplication.run [709]: Initializing machine manager 2019-04-19 16:57:13,688 - INFO - [MainThread] cura.CuraApplication.run [712]: Initializing container manager 2019-04-19 16:57:13,688 - INFO - [MainThread] cura.CuraApplication.run [715]: Initializing machine error checker 2019-04-19 16:57:15,015 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin._createView [280]: Creating post processing plugin view. 2019-04-19 16:57:15,031 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [170]: Begin loading of script: BQ_PauseAtHeight 2019-04-19 16:57:15,031 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [170]: Begin loading of script: ChangeAtZ 2019-04-19 16:57:15,031 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [170]: Begin loading of script: DisplayFilenameAndLayerOnLCD 2019-04-19 16:57:15,031 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [170]: Begin loading of script: FilamentChange 2019-04-19 16:57:15,046 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [170]: Begin loading of script: PauseAtHeight 2019-04-19 16:57:15,046 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [170]: Begin loading of script: PauseAtHeightRepRapFirmwareDuet 2019-04-19 16:57:15,046 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [170]: Begin loading of script: PauseAtHeightforRepetier 2019-04-19 16:57:15,046 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [170]: Begin loading of script: SearchAndReplace 2019-04-19 16:57:15,062 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [170]: Begin loading of script: Stretch 2019-04-19 16:57:15,187 - DEBUG - [MainThread] UM.Qt.Bindings.Theme.load [158]: Loading theme file: C:\Program Files\Ultimaker Cura 4.0\resources\themes\cura-light\theme.json 2019-04-19 16:57:15,296 - DEBUG - [MainThread] UM.Qt.Bindings.Theme.load [230]: Loaded theme C:\Program Files\Ultimaker Cura 4.0\resources\themes\cura-light 2019-04-19 16:57:15,390 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin._createView [290]: Post processing view created. 2019-04-19 16:57:15,609 - WARNING - [MainThread] UM.Qt.Bindings.Theme.getImage [133]: No image header_pattern defined in Theme 2019-04-19 16:57:15,624 - DEBUG - [MainThread] cura.Machines.Models.BuildPlateModel._update [33]: Updating BuildPlateModel. 2019-04-19 16:57:16,624 - DEBUG - [MainThread] cura.Machines.Models.NozzleModel._update [34]: Updating NozzleModel. 2019-04-19 16:57:16,796 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/resources/qml/Menus/SettingsMenu.qml:23:20: Unable to assign [undefined] to QString 2019-04-19 16:57:16,796 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/resources/qml/Menus/MaterialMenu.qml:17:39: Unable to assign [undefined] to QString 2019-04-19 16:57:16,796 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/resources/qml/Menus/MaterialMenu.qml:16:44: Unable to assign [undefined] to QString 2019-04-19 16:57:16,796 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/resources/qml/Menus/SettingsMenu.qml:43: TypeError: Cannot read property 'isEnabled' of null 2019-04-19 16:57:16,812 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/resources/qml/Menus/SettingsMenu.qml:50: TypeError: Cannot read property 'isEnabled' of null 2019-04-19 16:57:16,812 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/resources/qml/Menus/SettingsMenu.qml:19: TypeError: Cannot read property 'extruderList' of null 2019-04-19 16:57:16,827 - DEBUG - [MainThread] UM3NetworkPrinting.src.DiscoverUM3Action._createAdditionalComponentsView [196]: Creating additional ui components for UM3. 2019-04-19 16:57:16,874 - DEBUG - [MainThread] UM3NetworkPrinting.src.DiscoverUM3Action.startDiscovery [47]: Starting device discovery. 2019-04-19 16:57:16,983 - DEBUG - [MainThread] UM.Controller.setActiveStage [159]: Setting active stage to PrepareStage 2019-04-19 16:57:17,146 - DEBUG - [MainThread] cura.Machines.Models.NozzleModel._update [34]: Updating NozzleModel. 2019-04-19 16:57:17,192 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/resources/qml/Menus/MaterialMenu.qml:17:39: Unable to assign [undefined] to QString 2019-04-19 16:57:17,196 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/resources/qml/Menus/MaterialMenu.qml:16:44: Unable to assign [undefined] to QString 2019-04-19 16:57:17,278 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/plugins/PrepareStage/PrepareMain.qml:16:5: QML ActionPanelWidget: Binding loop detected for property "width" 2019-04-19 16:57:17,283 - DEBUG - [MainThread] UM.Controller.setActiveView [92]: Setting active view to SolidView 2019-04-19 16:57:17,286 - DEBUG - [MainThread] ModelChecker.ModelChecker._createView [103]: Creating model checker view. 2019-04-19 16:57:17,300 - DEBUG - [MainThread] ModelChecker.ModelChecker._createView [112]: Model checker view created. 2019-04-19 16:57:17,302 - DEBUG - [MainThread] SliceInfoPlugin.SliceInfo._createDialog [82]: Creating dialog [MoreInfoWindow.qml] 2019-04-19 16:57:17,374 - DEBUG - [MainThread] cura.CuraApplication.run [747]: Booting Cura took 10.725345849990845 seconds 2019-04-19 16:57:17,469 - DEBUG - [MainThread] cura.Machines.Models.QualityProfilesDropDownMenuModel._update [61]: Updating QualityProfilesDropDownMenuModel. 2019-04-19 16:57:17,474 - DEBUG - [MainThread] cura.Machines.Models.QualityProfilesDropDownMenuModel._update [66]: No active GlobalStack, set quality profile model as empty. 2019-04-19 16:57:17,479 - DEBUG - [MainThread] cura.Machines.Models.CustomQualityProfilesDropDownMenuModel._update [15]: Updating CustomQualityProfilesDropDownMenuModel. 2019-04-19 16:57:17,484 - DEBUG - [MainThread] cura.Machines.Models.CustomQualityProfilesDropDownMenuModel._update [20]: No active GlobalStack, set CustomQualityProfilesDropDownMenuModel as empty. 2019-04-19 16:57:17,759 - DEBUG - [MainThread] UM.Qt.QtRenderer._initialize [183]: Support for Vertex Array Objects: True 2019-04-19 16:57:17,776 - DEBUG - [MainThread] UM.View.GL.OpenGL.__init__ [99]: Initialized OpenGL subsystems. 2019-04-19 16:57:17,781 - DEBUG - [MainThread] UM.View.GL.OpenGL.__init__ [100]: OpenGL Version: 3.3.0 2019-04-19 16:57:17,785 - DEBUG - [MainThread] UM.View.GL.OpenGL.__init__ [101]: OpenGL Vendor: NVIDIA Corporation 2019-04-19 16:57:17,790 - DEBUG - [MainThread] UM.View.GL.OpenGL.__init__ [102]: OpenGL Renderer: GeForce 9500 GT/PCIe/SSE2 2019-04-19 16:57:17,794 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\default.shader]... 2019-04-19 16:57:17,802 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\selection.shader]... 2019-04-19 16:57:17,809 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\default.shader]... 2019-04-19 16:57:17,816 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\composite.shader]... 2019-04-19 16:57:17,824 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\overhang.shader]... 2019-04-19 16:57:17,832 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\striped.shader]... 2019-04-19 16:57:17,840 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\transparent_object.shader]... 2019-04-19 16:57:17,848 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\striped.shader]... 2019-04-19 16:57:17,856 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\platform.shader]... 2019-04-19 16:57:25,360 - INFO - [MainThread] UserAgreement.UserAgreement.didAgree [35]: User agreed to the user agreement 2019-04-19 16:57:31,081 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container creality_cr10 2019-04-19 16:57:31,159 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [creality_cr10] added. 2019-04-19 16:57:31,206 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [Creality CR-10_settings] added. 2019-04-19 16:57:31,222 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [Creality CR-10_user] added. 2019-04-19 16:57:31,222 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container creality_cr10_extruder_0 2019-04-19 16:57:31,222 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [creality_cr10_extruder_0] added. 2019-04-19 16:57:31,222 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container generic_pla_175 2019-04-19 16:57:31,237 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [generic_pla_175_imade3d_jellybox] added. 2019-04-19 16:57:31,253 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [generic_pla_175_imade3d_jellybox_0.4_mm] added. 2019-04-19 16:57:31,253 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [generic_pla_175_imade3d_jellybox_0.4_mm_2-fans] added. 2019-04-19 16:57:31,253 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [generic_pla_175_cartesio] added. 2019-04-19 16:57:31,269 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [generic_pla_175_cartesio_0.25mm_thermoplastic_extruder] added. 2019-04-19 16:57:31,269 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [generic_pla_175_cartesio_0.4mm_thermoplastic_extruder] added. 2019-04-19 16:57:31,269 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [generic_pla_175_cartesio_0.8mm_thermoplastic_extruder] added. 2019-04-19 16:57:31,284 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [generic_pla_175] added. 2019-04-19 16:57:31,331 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [creality_cr10_extruder_0 #2_settings] added. 2019-04-19 16:57:31,331 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [creality_cr10_extruder_0 #2_user] added. 2019-04-19 16:57:31,347 - INFO - [MainThread] cura.Settings.GlobalStack.addExtruder [136]: Extruder[creality_cr10_extruder_0 #2] added to [Creality CR-10] at position [0] 2019-04-19 16:57:31,347 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/resources/qml/Menus/MaterialMenu.qml:17:39: Unable to assign [undefined] to QString 2019-04-19 16:57:31,347 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/resources/qml/Menus/MaterialMenu.qml:17:39: Unable to assign [undefined] to QString 2019-04-19 16:57:31,362 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [creality_cr10_extruder_0 #2] added. 2019-04-19 16:57:31,362 - WARNING - [MainThread] UM.Settings.ContainerRegistry.addContainer [375]: Container with ID creality_cr10_extruder_0 #2 was already added. 2019-04-19 16:57:31,362 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container draft 2019-04-19 16:57:31,378 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [draft] added. 2019-04-19 16:57:31,378 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [Creality CR-10] added. 2019-04-19 16:57:31,378 - INFO - [MainThread] cura.MachineActionManager.addDefaultMachineActions [72]: Default machine actions added for machine definition [creality_cr10] 2019-04-19 16:57:31,394 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container fdmprinter 2019-04-19 16:57:31,472 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [fdmprinter] added. 2019-04-19 16:57:31,487 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] [ERROR] Could not connect to the given address 2019-04-19 16:57:31,519 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/resources/qml/Menus/MaterialMenu.qml:16:44: Unable to assign [undefined] to QString 2019-04-19 16:57:31,519 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/resources/qml/Menus/MaterialMenu.qml:17:39: Unable to assign [undefined] to QString 2019-04-19 16:57:31,519 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/resources/qml/Menus/MaterialMenu.qml:17:39: Unable to assign [undefined] to QString 2019-04-19 16:57:31,534 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/resources/qml/Menus/MaterialMenu.qml:17:39: Unable to assign [undefined] to QString 2019-04-19 16:57:31,550 - DEBUG - [MainThread] UM3NetworkPrinting.src.UM3OutputDevicePlugin.checkCloudFlowIsPossible [412]: Checking if cloud connection is possible... 2019-04-19 16:57:31,550 - DEBUG - [MainThread] UM3NetworkPrinting.src.UM3OutputDevicePlugin.checkCloudFlowIsPossible [435]: Cloud Flow not possible: User not logged in! 2019-04-19 16:57:31,721 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/resources/qml/Menus/SettingsMenu.qml:50: TypeError: Cannot read property 'isEnabled' of null 2019-04-19 16:57:31,726 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/resources/qml/Menus/SettingsMenu.qml:43: TypeError: Cannot read property 'isEnabled' of null 2019-04-19 16:57:31,731 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/resources/qml/Menus/MaterialMenu.qml:16:44: Unable to assign [undefined] to QString 2019-04-19 16:57:31,736 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/resources/qml/Menus/MaterialMenu.qml:17:39: Unable to assign [undefined] to QString 2019-04-19 16:57:31,741 - DEBUG - [MainThread] cura.Machines.Models.NozzleModel._update [34]: Updating NozzleModel. 2019-04-19 16:57:31,803 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/resources/qml/Menus/MaterialMenu.qml:16:44: Unable to assign [undefined] to QString 2019-04-19 16:57:31,854 - DEBUG - [MainThread] cura.Machines.Models.BuildPlateModel._update [33]: Updating BuildPlateModel. 2019-04-19 16:57:31,859 - DEBUG - [MainThread] cura.Machines.Models.NozzleModel._update [34]: Updating NozzleModel. 2019-04-19 16:57:31,864 - DEBUG - [MainThread] cura.Machines.Models.NozzleModel._update [34]: Updating NozzleModel. 2019-04-19 16:57:31,869 - DEBUG - [MainThread] cura.Machines.Models.NozzleModel._update [34]: Updating NozzleModel. 2019-04-19 16:57:31,921 - WARNING - [MainThread] cura.Settings.GlobalStack.addExtruder [132]: Extruder [creality_cr10_extruder_0 #2] has already been added to this stack [Creality CR-10] 2019-04-19 16:57:31,926 - WARNING - [MainThread] cura.Settings.ExtruderManager.registerExtruder [169]: Extruder [creality_cr10_extruder_0 #2] has already been registered on machine [Creality CR-10], not doing anything 2019-04-19 16:57:31,990 - INFO - [MainThread] cura.Settings.MachineManager._initMachineState [337]: Machine 'Creality CR-10' quality set to 'draft' 2019-04-19 16:57:31,997 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/resources/qml/Menus/SettingsMenu.qml:50: TypeError: Cannot read property 'isEnabled' of null 2019-04-19 16:57:32,002 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/resources/qml/Menus/SettingsMenu.qml:43: TypeError: Cannot read property 'isEnabled' of null 2019-04-19 16:57:32,007 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/resources/qml/Menus/MaterialMenu.qml:16:44: Unable to assign [undefined] to QString 2019-04-19 16:57:32,012 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/resources/qml/Menus/MaterialMenu.qml:17:39: Unable to assign [undefined] to QString 2019-04-19 16:57:32,018 - DEBUG - [MainThread] cura.Machines.Models.NozzleModel._update [34]: Updating NozzleModel. 2019-04-19 16:57:32,126 - DEBUG - [MainThread] cura.Machines.Models.BuildPlateModel._update [33]: Updating BuildPlateModel. 2019-04-19 16:57:32,131 - DEBUG - [MainThread] cura.Machines.Models.NozzleModel._update [34]: Updating NozzleModel. 2019-04-19 16:57:32,136 - DEBUG - [MainThread] cura.Machines.Models.NozzleModel._update [34]: Updating NozzleModel. 2019-04-19 16:57:32,142 - DEBUG - [MainThread] cura.Machines.Models.NozzleModel._update [34]: Updating NozzleModel. 2019-04-19 16:57:32,154 - DEBUG - [MainThread] cura.Machines.Models.NozzleModel._update [34]: Updating NozzleModel. 2019-04-19 16:57:32,456 - INFO - [MainThread] FirmwareUpdateChecker.FirmwareUpdateChecker.checkFirmwareVersion [76]: No machine with name Creality CR-10 in list of firmware to check. 2019-04-19 16:57:32,461 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onBackendQuit [811]: Backend quit with return code 0. Resetting process and socket. 2019-04-19 16:57:32,592 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._rescheduleCheck [136]: New error check scheduled. 2019-04-19 16:57:32,621 - DEBUG - [MainThread] cura.Machines.Models.QualityProfilesDropDownMenuModel._update [61]: Updating QualityProfilesDropDownMenuModel. 2019-04-19 16:57:32,623 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container coarse 2019-04-19 16:57:32,631 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [coarse] added. 2019-04-19 16:57:32,668 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container extra_coarse 2019-04-19 16:57:32,676 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [extra_coarse] added. 2019-04-19 16:57:32,714 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container fast 2019-04-19 16:57:32,722 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [fast] added. 2019-04-19 16:57:32,808 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container high 2019-04-19 16:57:32,816 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [high] added. 2019-04-19 16:57:32,858 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container normal 2019-04-19 16:57:32,993 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [normal] added. 2019-04-19 16:57:32,995 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container extra_fast 2019-04-19 16:57:33,003 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [extra_fast] added. 2019-04-19 16:57:33,055 - DEBUG - [MainThread] cura.Machines.Models.CustomQualityProfilesDropDownMenuModel._update [15]: Updating CustomQualityProfilesDropDownMenuModel. 2019-04-19 16:57:33,060 - INFO - [MainThread] cura.Machines.QualityManager.getQualityChangesGroups [179]: Cannot find node for machine def [fdmprinter] in QualityChanges lookup table 2019-04-19 16:57:33,065 - INFO - [MainThread] cura.Machines.MaterialManager._updateMaps [279]: Updating material lookup data ... 2019-04-19 16:57:33,132 - INFO - [MainThread] cura.Settings.MachineManager._updateQualityWithMaterial [1270]: Updating quality/quality_changes due to material change 2019-04-19 16:57:33,138 - DEBUG - [MainThread] cura.Settings.MachineManager._updateQualityWithMaterial [1277]: Current quality type = [draft] 2019-04-19 16:57:33,142 - INFO - [MainThread] cura.Settings.MachineManager._updateQualityWithMaterial [1291]: Current available quality type [draft] is available, applying changes. 2019-04-19 16:57:33,219 - DEBUG - [MainThread] cura.Machines.QualityManager.initialize [136]: Lookup tables updated. 2019-04-19 16:57:33,412 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\default.shader]... 2019-04-19 16:57:33,419 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\grid.shader]... 2019-04-19 16:57:33,827 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._checkStack [140]: Need to check for errors again. Discard the current progress and reschedule a check. 2019-04-19 16:57:33,885 - DEBUG - [MainThread] cura.Machines.Models.QualityProfilesDropDownMenuModel._update [61]: Updating QualityProfilesDropDownMenuModel. 2019-04-19 16:57:33,910 - DEBUG - [MainThread] cura.Machines.Models.CustomQualityProfilesDropDownMenuModel._update [15]: Updating CustomQualityProfilesDropDownMenuModel. 2019-04-19 16:57:33,915 - INFO - [MainThread] cura.Machines.QualityManager.getQualityChangesGroups [179]: Cannot find node for machine def [fdmprinter] in QualityChanges lookup table 2019-04-19 16:57:33,921 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._rescheduleCheck [136]: New error check scheduled. 2019-04-19 16:57:33,981 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._checkStack [140]: Need to check for errors again. Discard the current progress and reschedule a check. 2019-04-19 16:57:34,550 - DEBUG - [MainThread] cura.Machines.QualityManager.initialize [136]: Lookup tables updated. 2019-04-19 16:57:34,669 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._rescheduleCheck [136]: New error check scheduled. 2019-04-19 16:57:34,674 - DEBUG - [MainThread] cura.Machines.Models.QualityProfilesDropDownMenuModel._update [61]: Updating QualityProfilesDropDownMenuModel. 2019-04-19 16:57:34,695 - DEBUG - [MainThread] cura.Machines.Models.CustomQualityProfilesDropDownMenuModel._update [15]: Updating CustomQualityProfilesDropDownMenuModel. 2019-04-19 16:57:34,699 - INFO - [MainThread] cura.Machines.QualityManager.getQualityChangesGroups [179]: Cannot find node for machine def [fdmprinter] in QualityChanges lookup table 2019-04-19 16:57:36,637 - INFO - [MainThread] cura.Machines.MachineErrorChecker._setResult [188]: Error check finished, result = False, time = 2.0s 2019-04-19 16:57:43,980 - DEBUG - [MainThread] cura.AutoSave._onTimeout [48]: Autosaving preferences, instances and profiles 2019-04-19 16:57:58,205 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._rescheduleCheck [136]: New error check scheduled. 2019-04-19 16:57:59,325 - INFO - [MainThread] cura.Machines.MachineErrorChecker._setResult [188]: Error check finished, result = False, time = 1.1s 2019-04-19 16:58:08,085 - DEBUG - [MainThread] cura.AutoSave._onTimeout [48]: Autosaving preferences, instances and profiles 2019-04-19 16:58:09,096 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._rescheduleCheck [136]: New error check scheduled. 2019-04-19 16:58:10,466 - INFO - [MainThread] cura.Machines.MachineErrorChecker._setResult [188]: Error check finished, result = False, time = 1.4s 2019-04-19 16:58:18,974 - DEBUG - [MainThread] cura.AutoSave._onTimeout [48]: Autosaving preferences, instances and profiles 2019-04-19 17:01:51,278 - DEBUG - [MainThread] cura.AutoSave._onTimeout [48]: Autosaving preferences, instances and profiles 2019-04-19 17:01:57,921 - WARNING - [MainThread] UM.PluginRegistry._populateMetaData [604]: Could not find plugin global_stack 2019-04-19 17:01:57,930 - WARNING - [MainThread] UM.PluginRegistry._populateMetaData [604]: Could not find plugin extruder_stack 2019-04-19 17:01:57,952 - WARNING - [MainThread] cura.Settings.ContainerManager.getContainerMetaDataEntry [65]: Could not get metadata of container Unknown because it was not found. 2019-04-19 17:01:58,189 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/resources/qml/Preferences/Materials/MaterialsBrandSection.qml:97:5: QML Column: Binding loop detected for property "height" 2019-04-19 17:01:58,311 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/resources/qml/Preferences/Materials/MaterialsPage.qml:236:13: QML MaterialsList: Binding loop detected for property "height" 2019-04-19 17:01:58,317 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/resources/qml/Preferences/Materials/MaterialsList.qml:135:5: QML Column: Binding loop detected for property "height" 2019-04-19 17:02:00,831 - DEBUG - [MainThread] cura.Machines.Models.QualityManagementModel._update [38]: Updating QualityManagementModel. 2019-04-19 17:02:00,847 - INFO - [MainThread] cura.Machines.QualityManager.getQualityChangesGroups [179]: Cannot find node for machine def [fdmprinter] in QualityChanges lookup table 2019-04-19 17:02:00,971 - DEBUG - [MainThread] cura.Machines.Models.QualitySettingsModel._update [73]: Updating QualitySettingsModel. 2019-04-19 17:02:00,976 - DEBUG - [MainThread] cura.Machines.Models.QualitySettingsModel._update [73]: Updating QualitySettingsModel. 2019-04-19 17:02:01,091 - DEBUG - [MainThread] cura.Machines.Models.QualitySettingsModel._update [73]: Updating QualitySettingsModel. 2019-04-19 17:02:08,211 - DEBUG - [MainThread] cura.AutoSave._onTimeout [48]: Autosaving preferences, instances and profiles 2019-04-19 17:02:17,265 - DEBUG - [MainThread] cura.Settings.CuraContainerRegistry.importProfile [168]: Attempting to import profile C:/Users/andre/Desktop/PETG.curaprofile 2019-04-19 17:02:17,328 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [creality_cr10_petg] added. 2019-04-19 17:02:17,343 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [creality_cr10_extruder_0_petg] added. 2019-04-19 17:02:17,766 - DEBUG - [MainThread] cura.Machines.QualityManager.initialize [136]: Lookup tables updated. 2019-04-19 17:02:17,773 - DEBUG - [MainThread] cura.Machines.Models.QualityManagementModel._update [38]: Updating QualityManagementModel. 2019-04-19 17:02:17,784 - DEBUG - [MainThread] cura.Machines.Models.QualitySettingsModel._update [73]: Updating QualitySettingsModel. 2019-04-19 17:02:17,888 - DEBUG - [MainThread] cura.Machines.Models.QualityProfilesDropDownMenuModel._update [61]: Updating QualityProfilesDropDownMenuModel. 2019-04-19 17:02:17,987 - DEBUG - [MainThread] cura.Machines.Models.CustomQualityProfilesDropDownMenuModel._update [15]: Updating CustomQualityProfilesDropDownMenuModel. 2019-04-19 17:02:23,177 - DEBUG - [MainThread] cura.Settings.CuraContainerRegistry.importProfile [168]: Attempting to import profile C:/Users/andre/Desktop/PLA.curaprofile 2019-04-19 17:02:23,224 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [creality_cr10_pla] added. 2019-04-19 17:02:23,255 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [creality_cr10_extruder_0_pla] added. 2019-04-19 17:02:23,607 - DEBUG - [MainThread] cura.Machines.QualityManager.initialize [136]: Lookup tables updated. 2019-04-19 17:02:23,612 - DEBUG - [MainThread] cura.Machines.Models.QualityManagementModel._update [38]: Updating QualityManagementModel. 2019-04-19 17:02:23,620 - DEBUG - [MainThread] cura.Machines.Models.QualitySettingsModel._update [73]: Updating QualitySettingsModel. 2019-04-19 17:02:23,718 - DEBUG - [MainThread] cura.Machines.Models.QualityProfilesDropDownMenuModel._update [61]: Updating QualityProfilesDropDownMenuModel. 2019-04-19 17:02:23,834 - DEBUG - [MainThread] cura.Machines.Models.CustomQualityProfilesDropDownMenuModel._update [15]: Updating CustomQualityProfilesDropDownMenuModel. 2019-04-19 17:02:27,377 - DEBUG - [MainThread] cura.AutoSave._onTimeout [48]: Autosaving preferences, instances and profiles 2019-04-19 17:02:28,133 - DEBUG - [MainThread] cura.Settings.CuraContainerRegistry.importProfile [168]: Attempting to import profile C:/Users/andre/Desktop/Polyflex.curaprofile 2019-04-19 17:02:28,164 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [creality_cr10_polyflex] added. 2019-04-19 17:02:28,195 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [creality_cr10_extruder_0_polyflex] added. 2019-04-19 17:02:28,559 - DEBUG - [MainThread] cura.Machines.QualityManager.initialize [136]: Lookup tables updated. 2019-04-19 17:02:28,565 - DEBUG - [MainThread] cura.Machines.Models.QualityManagementModel._update [38]: Updating QualityManagementModel. 2019-04-19 17:02:28,573 - DEBUG - [MainThread] cura.Machines.Models.QualitySettingsModel._update [73]: Updating QualitySettingsModel. 2019-04-19 17:02:28,670 - DEBUG - [MainThread] cura.Machines.Models.QualityProfilesDropDownMenuModel._update [61]: Updating QualityProfilesDropDownMenuModel. 2019-04-19 17:02:28,790 - DEBUG - [MainThread] cura.Machines.Models.CustomQualityProfilesDropDownMenuModel._update [15]: Updating CustomQualityProfilesDropDownMenuModel. 2019-04-19 17:02:33,314 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._rescheduleCheck [136]: New error check scheduled. 2019-04-19 17:02:33,335 - DEBUG - [MainThread] cura.Machines.Models.QualityProfilesDropDownMenuModel._update [61]: Updating QualityProfilesDropDownMenuModel. 2019-04-19 17:02:33,353 - DEBUG - [MainThread] cura.Machines.Models.CustomQualityProfilesDropDownMenuModel._update [15]: Updating CustomQualityProfilesDropDownMenuModel. 2019-04-19 17:02:35,370 - INFO - [MainThread] cura.Machines.MachineErrorChecker._setResult [188]: Error check finished, result = False, time = 2.0s 2019-04-19 17:02:48,842 - DEBUG - [MainThread] cura.AutoSave._onTimeout [48]: Autosaving preferences, instances and profiles 2019-04-19 17:04:55,605 - INFO - [Thread-1] STLReader.STLReader.load_file [46]: Using NumPy-STL to load STL data. 2019-04-19 17:04:55,615 - DEBUG - [Thread-1] UM.Mesh.MeshData.calculateNormalsFromVertices [444]: Calculating normals took 0.0009968280792236328 seconds 2019-04-19 17:04:55,616 - DEBUG - [Thread-1] STLReader.STLReader._read [97]: Loaded a mesh with 11556 vertices 2019-04-19 17:04:55,637 - DEBUG - [Thread-1] UM.Mesh.MeshData.approximateConvexHull [401]: approximateConvexHull(target_count=1024) Calculating 3D convex hull took 0.01399993896484375 seconds. 208 input vertices. 208 output vertices. 2019-04-19 17:04:55,723 - DEBUG - [Thread-1] UM.FileHandler.ReadFileJob.run [69]: Loading file took 0.1 seconds 2019-04-19 17:04:55,750 - DEBUG - [Thread-1] UM.Mesh.MeshData.approximateConvexHull [401]: approximateConvexHull(target_count=1024) Calculating 3D convex hull took 0.023181915283203125 seconds. 208 input vertices. 208 output vertices. 2019-04-19 17:04:55,816 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [per_object_stack_1854010908624] added. 2019-04-19 17:04:55,861 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\transparent_object.shader]... 2019-04-19 17:04:56,640 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\toolhandle.shader]... 2019-04-19 17:05:01,427 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend.slice [228]: Starting to slice... 2019-04-19 17:05:01,427 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend.slice [246]: Going to slice build plate [0]! 2019-04-19 17:05:01,427 - DEBUG - [MainThread] UM.Backend.Backend._createSocket [227]: Previous socket existed. Closing that first. 2019-04-19 17:05:01,537 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [187]: Socket state changed to Listening 2019-04-19 17:05:01,646 - INFO - [MainThread] UM.Backend.Backend.startEngine [81]: Started engine process: C:\Program Files\Ultimaker Cura 4.0\CuraEngine.exe 2019-04-19 17:05:01,662 - DEBUG - [MainThread] UM.Backend.Backend._backendLog [101]: [Backend] Calling engine with: ['C:\\Program Files\\Ultimaker Cura 4.0\\CuraEngine.exe', 'connect', '127.0.0.1:49675', ''] 2019-04-19 17:05:01,719 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:05:01,782 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] Cura_SteamEngine version 4.0.0 2019-04-19 17:05:01,860 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] Copyright (C) 2018 Ultimaker 2019-04-19 17:05:01,938 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:05:01,985 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] This program is free software: you can redistribute it and/or modify 2019-04-19 17:05:02,047 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] it under the terms of the GNU Affero General Public License as published by 2019-04-19 17:05:02,110 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] the Free Software Foundation, either version 3 of the License, or 2019-04-19 17:05:02,172 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] (at your option) any later version. 2019-04-19 17:05:02,235 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:05:02,266 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] This program is distributed in the hope that it will be useful, 2019-04-19 17:05:02,266 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] but WITHOUT ANY WARRANTY; without even the implied warranty of 2019-04-19 17:05:02,282 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the 2019-04-19 17:05:02,282 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] GNU Affero General Public License for more details. 2019-04-19 17:05:02,297 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:05:02,297 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] You should have received a copy of the GNU Affero General Public License 2019-04-19 17:05:02,297 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] along with this program. If not, see <http://www.gnu.org/licenses/>. 2019-04-19 17:05:02,727 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onStartSliceCompleted [432]: Sending slice message took 1.2998261451721191 seconds 2019-04-19 17:05:05,376 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/resources/qml/RoundedRectangle.qml:68: TypeError: Cannot read property of null 2019-04-19 17:05:10,533 - INFO - [MainThread] Toolbox.src.Toolbox._makeRequestByType [553]: Requesting packages metadata from server. 2019-04-19 17:05:11,675 - INFO - [MainThread] Toolbox.src.Toolbox._makeRequestByType [553]: Requesting authors metadata from server. 2019-04-19 17:05:11,675 - DEBUG - [MainThread] Toolbox.src.Toolbox._createDialog [225]: Marketplace: Creating dialog [Toolbox.qml]. 2019-04-19 17:05:13,299 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/qml/QtQuick/Controls/ScrollView.qml:234:9: QML Binding: Binding loop detected for property "value" 2019-04-19 17:05:15,359 - DEBUG - [MainThread] cura.AutoSave._onTimeout [48]: Autosaving preferences, instances and profiles 2019-04-19 17:05:22,727 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] [ERROR] Could not connect to the given address 2019-04-19 17:05:22,827 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onBackendQuit [811]: Backend quit with return code 0. Resetting process and socket. 2019-04-19 17:05:44,406 - INFO - [MainThread] Toolbox.src.Toolbox.startDownload [562]: Attempting to download & install package from https://api.ultimaker.com/cura-packages/v1/cura/v6.0.0/packages/OrientationPlugin/download. 2019-04-19 17:05:45,059 - INFO - [MainThread] Toolbox.src.Toolbox._onDownloadComplete [680]: Download complete. 2019-04-19 17:05:45,064 - DEBUG - [MainThread] UM.PackageManager.getPackageInfo [430]: Found potential package.json file '/package.json' 2019-04-19 17:05:45,070 - DEBUG - [MainThread] UM.PackageManager.getPackageLicense [455]: Found potential license file '/files/plugins/OrientationPlugin/LICENSE' 2019-04-19 17:05:46,555 - DEBUG - [MainThread] UM.PackageManager.getPackageInfo [430]: Found potential package.json file '/package.json' 2019-04-19 17:05:46,555 - INFO - [MainThread] UM.PackageManager.installPackage [303]: Package [OrientationPlugin] version [3.2.1] is scheduled to be installed. 2019-04-19 17:05:46,571 - INFO - [MainThread] UM.PackageManager._saveManagementData [168]: Package management file C:\Users\andre\AppData\Roaming\cura\4.0\packages.json was saved 2019-04-19 17:05:53,283 - INFO - [MainThread] Toolbox.src.Toolbox.startDownload [562]: Attempting to download & install package from https://api.ultimaker.com/cura-packages/v1/cura/v6.0.0/packages/CustomSupports/download. 2019-04-19 17:05:53,619 - INFO - [MainThread] Toolbox.src.Toolbox._onDownloadComplete [680]: Download complete. 2019-04-19 17:05:53,625 - DEBUG - [MainThread] UM.PackageManager.getPackageInfo [430]: Found potential package.json file '/package.json' 2019-04-19 17:05:53,631 - DEBUG - [MainThread] UM.PackageManager.getPackageLicense [455]: Found potential license file '/files/plugins/CustomSupports/LICENSE' 2019-04-19 17:05:54,869 - DEBUG - [MainThread] UM.PackageManager.getPackageInfo [430]: Found potential package.json file '/package.json' 2019-04-19 17:05:54,869 - INFO - [MainThread] UM.PackageManager.installPackage [303]: Package [CustomSupports] version [0.0.4] is scheduled to be installed. 2019-04-19 17:05:54,885 - INFO - [MainThread] UM.PackageManager._saveManagementData [168]: Package management file C:\Users\andre\AppData\Roaming\cura\4.0\packages.json was saved 2019-04-19 17:06:05,968 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/plugins/Toolbox/resources/qml/SmallRatingWidget.qml:27: TypeError: Cannot read property 'average_rating' of null 2019-04-19 17:06:05,973 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/plugins/Toolbox/resources/qml/SmallRatingWidget.qml:17: TypeError: Cannot read property 'user_rating' of null 2019-04-19 17:06:05,978 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/plugins/Toolbox/resources/qml/SmallRatingWidget.qml:10: TypeError: Cannot read property 'average_rating' of null 2019-04-19 17:06:05,982 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/plugins/Toolbox/resources/qml/ToolboxDetailPage.qml:140: TypeError: Cannot read property 'type' of null 2019-04-19 17:06:05,987 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/plugins/Toolbox/resources/qml/ToolboxDetailPage.qml:141: TypeError: Cannot read property 'id' of null 2019-04-19 17:06:05,992 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/plugins/Toolbox/resources/qml/ToolboxDetailPage.qml:142: TypeError: Cannot read property 'user_rating' of null 2019-04-19 17:06:05,996 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/plugins/Toolbox/resources/qml/ToolboxDetailPage.qml:143: TypeError: Cannot read property 'id' of null 2019-04-19 17:06:06,001 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/plugins/Toolbox/resources/qml/SmallRatingWidget.qml:27: TypeError: Cannot read property 'average_rating' of null 2019-04-19 17:06:06,006 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/plugins/Toolbox/resources/qml/SmallRatingWidget.qml:17: TypeError: Cannot read property 'user_rating' of null 2019-04-19 17:06:06,010 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/plugins/Toolbox/resources/qml/SmallRatingWidget.qml:10: TypeError: Cannot read property 'average_rating' of null 2019-04-19 17:06:06,015 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/plugins/Toolbox/resources/qml/ToolboxAuthorPage.qml:136: TypeError: Cannot read property 'email' of null 2019-04-19 17:06:06,020 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/plugins/Toolbox/resources/qml/ToolboxAuthorPage.qml:119: TypeError: Cannot read property 'website' of null 2019-04-19 17:06:06,024 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/plugins/Toolbox/resources/qml/ToolboxAuthorPage.qml:67: TypeError: Cannot read property 'description' of null 2019-04-19 17:06:06,029 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/plugins/Toolbox/resources/qml/ToolboxAuthorPage.qml:57: TypeError: Cannot read property 'name' of null 2019-04-19 17:06:06,034 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/plugins/Toolbox/resources/qml/ToolboxAuthorPage.qml:34: TypeError: Cannot read property 'icon_url' of null 2019-04-19 17:07:16,469 - DEBUG - [MainThread] cura.TaskManagement.OnExitCallbackManager.triggerNextCallback [51]: No more on-app-exit callbacks to process. Tell the app to exit. 2019-04-19 17:07:16,469 - INFO - [MainThread] cura.CuraApplication.closeApplication [547]: Close application 2019-04-19 17:07:16,535 - DEBUG - [MainThread] UM.Qt.QtApplication.windowClosed [417]: Shutting down cura 2019-04-19 17:07:16,661 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._terminate [295]: Attempting to kill the engine process 2019-04-19 17:07:29,549 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin FileLogger 2019-04-19 17:07:29,580 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin FirmwareUpdateChecker 2019-04-19 17:07:29,596 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin FirmwareUpdater 2019-04-19 17:07:29,627 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin GCodeGzReader 2019-04-19 17:07:29,643 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin GCodeGzWriter 2019-04-19 17:07:29,658 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin GCodeProfileReader 2019-04-19 17:07:29,705 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin GCodeReader 2019-04-19 17:07:29,721 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin GCodeWriter 2019-04-19 17:07:29,752 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin ImageReader 2019-04-19 17:07:29,768 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin LegacyProfileReader 2019-04-19 17:07:29,799 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin LocalContainerProvider 2019-04-19 17:07:29,815 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin LocalFileOutputDevice 2019-04-19 17:07:29,846 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin MachineSettingsAction 2019-04-19 17:07:29,862 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin ModelChecker 2019-04-19 17:07:29,893 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin MonitorStage 2019-04-19 17:07:29,924 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin PerObjectSettingsTool 2019-04-19 17:07:29,940 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin PostProcessingPlugin 2019-04-19 17:07:29,971 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin PrepareStage 2019-04-19 17:07:29,987 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin PreviewStage 2019-04-19 17:07:30,018 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin RemovableDriveOutputDevice 2019-04-19 17:07:30,065 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin SimulationView 2019-04-19 17:07:30,107 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin SliceInfoPlugin 2019-04-19 17:07:30,125 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin SolidView 2019-04-19 17:07:30,156 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin SupportEraser 2019-04-19 17:07:30,203 - DEBUG - [MainThread] cura.OAuth2.AuthorizationService.getAccessToken [106]: No auth data to retrieve the access_token from 2019-04-19 17:07:30,203 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin Toolbox 2019-04-19 17:07:30,234 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin CameraTool 2019-04-19 17:07:30,281 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin MirrorTool 2019-04-19 17:07:30,320 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin RotateTool 2019-04-19 17:07:30,369 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin ScaleTool 2019-04-19 17:07:30,390 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin SelectionTool 2019-04-19 17:07:30,421 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin TranslateTool 2019-04-19 17:07:30,468 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin UFPWriter 2019-04-19 17:07:30,513 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin UltimakerMachineActions 2019-04-19 17:07:30,752 - DEBUG - [MainThread] UM3NetworkPrinting.src.Cloud.CloudOutputDeviceManager._onLoginStateChanged [57]: Log in state changed to False 2019-04-19 17:07:30,752 - DEBUG - [MainThread] UM3NetworkPrinting.src.Cloud.CloudOutputDeviceManager._onGetRemoteClustersFinished [80]: Parsed remote clusters to [] 2019-04-19 17:07:30,752 - DEBUG - [MainThread] UM3NetworkPrinting.src.Cloud.CloudOutputDeviceManager._onGetRemoteClustersFinished [81]: Removed: 0, added: 0, updates: 0 2019-04-19 17:07:30,752 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin UM3NetworkPrinting 2019-04-19 17:07:30,799 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin UpdateChecker 2019-04-19 17:07:30,799 - INFO - [Thread-2] UpdateChecker.UpdateCheckerJob.run [36]: Checking for new version of cura 2019-04-19 17:07:30,882 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin USBPrinting 2019-04-19 17:07:30,914 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin UserAgreement 2019-04-19 17:07:30,947 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade21to22 2019-04-19 17:07:30,978 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade22to24 2019-04-19 17:07:31,025 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade25to26 2019-04-19 17:07:31,077 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade26to27 2019-04-19 17:07:31,121 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade27to30 2019-04-19 17:07:31,164 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade30to31 2019-04-19 17:07:31,205 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade32to33 2019-04-19 17:07:31,244 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade33to34 2019-04-19 17:07:31,298 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade34to35 2019-04-19 17:07:31,361 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade35to40 2019-04-19 17:07:31,428 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin SimpleView 2019-04-19 17:07:31,508 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin X3DReader 2019-04-19 17:07:31,609 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin XmlMaterialProfile 2019-04-19 17:07:31,672 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin XRayView 2019-04-19 17:07:31,721 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin CustomSupports 2019-04-19 17:07:31,789 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin OrientationPlugin 2019-04-19 17:07:31,830 - INFO - [MainThread] UM.VersionUpgradeManager.upgrade [143]: Looking for old configuration files to upgrade. 2019-04-19 17:07:31,898 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\packages.json, skip it 2019-04-19 17:07:31,904 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\plugins.json, skip it 2019-04-19 17:07:31,934 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\packages.json, skip it 2019-04-19 17:07:31,934 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\plugins.json, skip it 2019-04-19 17:07:31,966 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\packages.json, skip it 2019-04-19 17:07:31,966 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\plugins.json, skip it 2019-04-19 17:07:32,065 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\packages.json, skip it 2019-04-19 17:07:32,068 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\plugins.json, skip it 2019-04-19 17:07:32,110 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\packages.json, skip it 2019-04-19 17:07:32,116 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\plugins.json, skip it 2019-04-19 17:07:32,156 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\packages.json, skip it 2019-04-19 17:07:32,163 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\plugins.json, skip it 2019-04-19 17:07:32,204 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\packages.json, skip it 2019-04-19 17:07:32,210 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\plugins.json, skip it 2019-04-19 17:07:32,254 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\packages.json, skip it 2019-04-19 17:07:32,260 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\plugins.json, skip it 2019-04-19 17:07:32,389 - DEBUG - [MainThread] UM.Backend.Backend._onSocketError [213]: Socket was unable to bind to port, increasing port number to 49675 2019-04-19 17:07:32,394 - DEBUG - [MainThread] UM.Backend.Backend._createSocket [227]: Previous socket existed. Closing that first. 2019-04-19 17:07:32,400 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._terminate [295]: Attempting to kill the engine process 2019-04-19 17:07:32,406 - DEBUG - [MainThread] UM.Backend.Backend._createSocket [227]: Previous socket existed. Closing that first. 2019-04-19 17:07:32,636 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [187]: Socket state changed to Listening 2019-04-19 17:07:32,636 - INFO - [MainThread] UM.Backend.Backend.startEngine [81]: Started engine process: C:\Program Files\Ultimaker Cura 4.0\CuraEngine.exe 2019-04-19 17:07:32,652 - DEBUG - [MainThread] UM.Backend.Backend._backendLog [101]: [Backend] Calling engine with: ['C:\\Program Files\\Ultimaker Cura 4.0\\CuraEngine.exe', 'connect', '127.0.0.1:49675', ''] 2019-04-19 17:07:32,746 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:07:32,751 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] Cura_SteamEngine version 4.0.0 2019-04-19 17:07:32,756 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] Copyright (C) 2018 Ultimaker 2019-04-19 17:07:32,761 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:07:32,766 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] This program is free software: you can redistribute it and/or modify 2019-04-19 17:07:32,771 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] it under the terms of the GNU Affero General Public License as published by 2019-04-19 17:07:32,777 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] the Free Software Foundation, either version 3 of the License, or 2019-04-19 17:07:32,783 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] (at your option) any later version. 2019-04-19 17:07:32,788 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:07:32,793 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] This program is distributed in the hope that it will be useful, 2019-04-19 17:07:32,796 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] but WITHOUT ANY WARRANTY; without even the implied warranty of 2019-04-19 17:07:32,796 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the 2019-04-19 17:07:32,796 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] GNU Affero General Public License for more details. 2019-04-19 17:07:32,811 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:07:32,811 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] You should have received a copy of the GNU Affero General Public License 2019-04-19 17:07:32,811 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] along with this program. If not, see <http://www.gnu.org/licenses/>. 2019-04-19 17:07:36,698 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.loadAllMetadata [338]: Loading metadata into container registry took 4.042280912399292 seconds 2019-04-19 17:07:36,860 - DEBUG - [MainThread] cura.Scene.CuraSceneController.setActiveBuildPlate [104]: Select build plate: 0 2019-04-19 17:07:36,865 - INFO - [MainThread] cura.CuraApplication.run [695]: Initializing variant manager 2019-04-19 17:07:36,873 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container ultimaker_s5_aluminum 2019-04-19 17:07:36,881 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [ultimaker_s5_aluminum] added. 2019-04-19 17:07:36,882 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container ultimaker_s5 2019-04-19 17:07:37,058 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [ultimaker_s5] added. 2019-04-19 17:07:37,087 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container ultimaker_s5_glass 2019-04-19 17:07:37,117 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [ultimaker_s5_glass] added. 2019-04-19 17:07:37,128 - DEBUG - [MainThread] cura.Machines.VariantManager.initialize [59]: Exclude variant [empty_variant] 2019-04-19 17:07:37,134 - INFO - [MainThread] cura.CuraApplication.run [699]: Initializing material manager 2019-04-19 17:07:37,265 - INFO - [MainThread] cura.CuraApplication.run [704]: Initializing quality manager 2019-04-19 17:07:37,293 - DEBUG - [MainThread] cura.Machines.QualityManager.initialize [136]: Lookup tables updated. 2019-04-19 17:07:37,300 - INFO - [MainThread] cura.CuraApplication.run [709]: Initializing machine manager 2019-04-19 17:07:37,306 - INFO - [MainThread] cura.CuraApplication.run [712]: Initializing container manager 2019-04-19 17:07:37,311 - INFO - [MainThread] cura.CuraApplication.run [715]: Initializing machine error checker 2019-04-19 17:07:37,350 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container Creality CR-10 2019-04-19 17:07:37,355 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container Creality CR-10_user 2019-04-19 17:07:37,365 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [Creality CR-10_user] added. 2019-04-19 17:07:37,367 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container creality_cr10_pla 2019-04-19 17:07:37,376 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [creality_cr10_pla] added. 2019-04-19 17:07:37,379 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container draft 2019-04-19 17:07:37,388 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [draft] added. 2019-04-19 17:07:37,399 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container Creality CR-10_settings 2019-04-19 17:07:37,450 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [Creality CR-10_settings] added. 2019-04-19 17:07:37,453 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container creality_cr10 2019-04-19 17:07:37,620 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [creality_cr10] added. 2019-04-19 17:07:37,625 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [Creality CR-10] added. 2019-04-19 17:07:37,634 - INFO - [MainThread] cura.MachineActionManager.addDefaultMachineActions [72]: Default machine actions added for machine definition [creality_cr10] 2019-04-19 17:07:37,642 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container creality_cr10_extruder_0 #2 2019-04-19 17:07:37,648 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container creality_cr10_extruder_0 #2_user 2019-04-19 17:07:37,669 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [creality_cr10_extruder_0 #2_user] added. 2019-04-19 17:07:37,671 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container creality_cr10_extruder_0_pla 2019-04-19 17:07:37,683 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [creality_cr10_extruder_0_pla] added. 2019-04-19 17:07:37,685 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container generic_pla_175 2019-04-19 17:07:37,705 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [generic_pla_175_imade3d_jellybox] added. 2019-04-19 17:07:37,718 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [generic_pla_175_imade3d_jellybox_0.4_mm] added. 2019-04-19 17:07:37,724 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [generic_pla_175_imade3d_jellybox_0.4_mm_2-fans] added. 2019-04-19 17:07:37,776 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [generic_pla_175_cartesio] added. 2019-04-19 17:07:37,783 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [generic_pla_175_cartesio_0.25mm_thermoplastic_extruder] added. 2019-04-19 17:07:37,792 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [generic_pla_175_cartesio_0.4mm_thermoplastic_extruder] added. 2019-04-19 17:07:37,802 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [generic_pla_175_cartesio_0.8mm_thermoplastic_extruder] added. 2019-04-19 17:07:37,810 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [generic_pla_175] added. 2019-04-19 17:07:37,813 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container creality_cr10_extruder_0 #2_settings 2019-04-19 17:07:37,829 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [creality_cr10_extruder_0 #2_settings] added. 2019-04-19 17:07:37,841 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container creality_cr10_extruder_0 2019-04-19 17:07:37,850 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [creality_cr10_extruder_0] added. 2019-04-19 17:07:37,857 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [creality_cr10_extruder_0 #2] added. 2019-04-19 17:07:37,865 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container fdmprinter 2019-04-19 17:07:38,036 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [fdmprinter] added. 2019-04-19 17:07:38,719 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [170]: Begin loading of script: BQ_PauseAtHeight 2019-04-19 17:07:38,725 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [170]: Begin loading of script: ChangeAtZ 2019-04-19 17:07:38,731 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [170]: Begin loading of script: DisplayFilenameAndLayerOnLCD 2019-04-19 17:07:38,737 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [170]: Begin loading of script: FilamentChange 2019-04-19 17:07:38,745 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [170]: Begin loading of script: PauseAtHeight 2019-04-19 17:07:38,748 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [170]: Begin loading of script: PauseAtHeightRepRapFirmwareDuet 2019-04-19 17:07:38,758 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [170]: Begin loading of script: PauseAtHeightforRepetier 2019-04-19 17:07:38,764 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [170]: Begin loading of script: SearchAndReplace 2019-04-19 17:07:38,777 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [170]: Begin loading of script: Stretch 2019-04-19 17:07:38,783 - DEBUG - [MainThread] UM3NetworkPrinting.src.UM3OutputDevicePlugin.checkCloudFlowIsPossible [412]: Checking if cloud connection is possible... 2019-04-19 17:07:38,784 - DEBUG - [MainThread] UM3NetworkPrinting.src.UM3OutputDevicePlugin.checkCloudFlowIsPossible [435]: Cloud Flow not possible: User not logged in! 2019-04-19 17:07:38,964 - INFO - [MainThread] cura.Settings.GlobalStack.addExtruder [136]: Extruder[creality_cr10_extruder_0 #2] added to [Creality CR-10] at position [0] 2019-04-19 17:07:38,969 - WARNING - [MainThread] cura.Settings.ExtruderManager.registerExtruder [169]: Extruder [creality_cr10_extruder_0 #2] has already been registered on machine [Creality CR-10], not doing anything 2019-04-19 17:07:38,983 - INFO - [MainThread] cura.Settings.MachineManager._initMachineState [330]: Machine 'Creality CR-10' quality changes set to 'PLA #2' 2019-04-19 17:07:39,329 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._rescheduleCheck [136]: New error check scheduled. 2019-04-19 17:07:39,329 - INFO - [MainThread] FirmwareUpdateChecker.FirmwareUpdateChecker.checkFirmwareVersion [76]: No machine with name Creality CR-10 in list of firmware to check. 2019-04-19 17:07:40,899 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin._createView [280]: Creating post processing plugin view. 2019-04-19 17:07:41,024 - DEBUG - [MainThread] UM.Qt.Bindings.Theme.load [158]: Loading theme file: C:\Program Files\Ultimaker Cura 4.0\resources\themes\cura-light\theme.json 2019-04-19 17:07:41,136 - DEBUG - [MainThread] UM.Qt.Bindings.Theme.load [230]: Loaded theme C:\Program Files\Ultimaker Cura 4.0\resources\themes\cura-light 2019-04-19 17:07:41,214 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin._createView [290]: Post processing view created. 2019-04-19 17:07:41,472 - WARNING - [MainThread] UM.Qt.Bindings.Theme.getImage [133]: No image header_pattern defined in Theme 2019-04-19 17:07:41,488 - DEBUG - [MainThread] cura.Machines.Models.BuildPlateModel._update [33]: Updating BuildPlateModel. 2019-04-19 17:07:42,667 - DEBUG - [MainThread] cura.Machines.Models.NozzleModel._update [34]: Updating NozzleModel. 2019-04-19 17:07:42,950 - DEBUG - [MainThread] UM3NetworkPrinting.src.DiscoverUM3Action._createAdditionalComponentsView [196]: Creating additional ui components for UM3. 2019-04-19 17:07:43,037 - DEBUG - [MainThread] UM3NetworkPrinting.src.DiscoverUM3Action.startDiscovery [47]: Starting device discovery. 2019-04-19 17:07:43,064 - DEBUG - [MainThread] UM.Controller.setActiveStage [159]: Setting active stage to PrepareStage 2019-04-19 17:07:43,267 - DEBUG - [MainThread] cura.Machines.Models.NozzleModel._update [34]: Updating NozzleModel. 2019-04-19 17:07:43,439 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/plugins/PrepareStage/PrepareMain.qml:16:5: QML ActionPanelWidget: Binding loop detected for property "width" 2019-04-19 17:07:43,448 - DEBUG - [MainThread] UM.Controller.setActiveView [92]: Setting active view to SolidView 2019-04-19 17:07:43,453 - DEBUG - [MainThread] ModelChecker.ModelChecker._createView [103]: Creating model checker view. 2019-04-19 17:07:43,468 - DEBUG - [MainThread] ModelChecker.ModelChecker._createView [112]: Model checker view created. 2019-04-19 17:07:43,469 - DEBUG - [MainThread] SliceInfoPlugin.SliceInfo._createDialog [82]: Creating dialog [MoreInfoWindow.qml] 2019-04-19 17:07:43,568 - DEBUG - [MainThread] cura.CuraApplication.run [747]: Booting Cura took 15.748594284057617 seconds 2019-04-19 17:07:43,580 - INFO - [MainThread] cura.Machines.MaterialManager._updateMaps [279]: Updating material lookup data ... 2019-04-19 17:07:43,644 - INFO - [MainThread] cura.Settings.MachineManager._updateQualityWithMaterial [1270]: Updating quality/quality_changes due to material change 2019-04-19 17:07:43,644 - DEBUG - [MainThread] cura.Settings.MachineManager._updateQualityWithMaterial [1277]: Current quality type = [draft] 2019-04-19 17:07:43,644 - INFO - [MainThread] cura.Settings.MachineManager._updateQualityWithMaterial [1291]: Current available quality type [draft] is available, applying changes. 2019-04-19 17:07:43,738 - DEBUG - [MainThread] cura.Machines.QualityManager.initialize [136]: Lookup tables updated. 2019-04-19 17:07:43,775 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._checkStack [140]: Need to check for errors again. Discard the current progress and reschedule a check. 2019-04-19 17:07:43,856 - DEBUG - [MainThread] cura.Machines.Models.QualityProfilesDropDownMenuModel._update [61]: Updating QualityProfilesDropDownMenuModel. 2019-04-19 17:07:43,858 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container coarse 2019-04-19 17:07:43,866 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [coarse] added. 2019-04-19 17:07:43,905 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container extra_coarse 2019-04-19 17:07:43,915 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [extra_coarse] added. 2019-04-19 17:07:43,954 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container fast 2019-04-19 17:07:43,962 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [fast] added. 2019-04-19 17:07:44,044 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container high 2019-04-19 17:07:44,052 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [high] added. 2019-04-19 17:07:44,092 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container normal 2019-04-19 17:07:44,100 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [normal] added. 2019-04-19 17:07:44,101 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container extra_fast 2019-04-19 17:07:44,111 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [extra_fast] added. 2019-04-19 17:07:44,171 - DEBUG - [MainThread] cura.Machines.Models.CustomQualityProfilesDropDownMenuModel._update [15]: Updating CustomQualityProfilesDropDownMenuModel. 2019-04-19 17:07:44,180 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._rescheduleCheck [136]: New error check scheduled. 2019-04-19 17:07:44,436 - DEBUG - [MainThread] UM.Qt.QtRenderer._initialize [183]: Support for Vertex Array Objects: True 2019-04-19 17:07:44,451 - DEBUG - [MainThread] UM.View.GL.OpenGL.__init__ [99]: Initialized OpenGL subsystems. 2019-04-19 17:07:44,456 - DEBUG - [MainThread] UM.View.GL.OpenGL.__init__ [100]: OpenGL Version: 3.3.0 2019-04-19 17:07:44,461 - DEBUG - [MainThread] UM.View.GL.OpenGL.__init__ [101]: OpenGL Vendor: NVIDIA Corporation 2019-04-19 17:07:44,465 - DEBUG - [MainThread] UM.View.GL.OpenGL.__init__ [102]: OpenGL Renderer: GeForce 9500 GT/PCIe/SSE2 2019-04-19 17:07:44,470 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\default.shader]... 2019-04-19 17:07:44,478 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\selection.shader]... 2019-04-19 17:07:44,487 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\default.shader]... 2019-04-19 17:07:44,496 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\composite.shader]... 2019-04-19 17:07:44,504 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\overhang.shader]... 2019-04-19 17:07:44,512 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\striped.shader]... 2019-04-19 17:07:44,520 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\transparent_object.shader]... 2019-04-19 17:07:44,528 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\striped.shader]... 2019-04-19 17:07:44,537 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\default.shader]... 2019-04-19 17:07:44,544 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\grid.shader]... 2019-04-19 17:07:44,552 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\platform.shader]... 2019-04-19 17:07:44,680 - DEBUG - [MainThread] cura.Machines.QualityManager.initialize [136]: Lookup tables updated. 2019-04-19 17:07:45,187 - DEBUG - [MainThread] cura.Machines.Models.QualityProfilesDropDownMenuModel._update [61]: Updating QualityProfilesDropDownMenuModel. 2019-04-19 17:07:45,194 - INFO - [Thread-3] STLReader.STLReader.load_file [46]: Using NumPy-STL to load STL data. 2019-04-19 17:07:45,203 - DEBUG - [Thread-3] UM.Mesh.MeshData.calculateNormalsFromVertices [444]: Calculating normals took 0.0009996891021728516 seconds 2019-04-19 17:07:45,205 - DEBUG - [Thread-3] STLReader.STLReader._read [97]: Loaded a mesh with 11556 vertices 2019-04-19 17:07:45,223 - DEBUG - [Thread-3] UM.Mesh.MeshData.approximateConvexHull [401]: approximateConvexHull(target_count=1024) Calculating 3D convex hull took 0.013009071350097656 seconds. 208 input vertices. 208 output vertices. 2019-04-19 17:07:45,230 - DEBUG - [MainThread] cura.Machines.Models.CustomQualityProfilesDropDownMenuModel._update [15]: Updating CustomQualityProfilesDropDownMenuModel. 2019-04-19 17:07:45,246 - DEBUG - [Thread-3] UM.FileHandler.ReadFileJob.run [69]: Loading file took 0.1 seconds 2019-04-19 17:07:45,263 - DEBUG - [Thread-3] UM.Mesh.MeshData.approximateConvexHull [401]: approximateConvexHull(target_count=1024) Calculating 3D convex hull took 0.01200103759765625 seconds. 208 input vertices. 208 output vertices. 2019-04-19 17:07:45,317 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [per_object_stack_3125713048520] added. 2019-04-19 17:07:45,385 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\transparent_object.shader]... 2019-04-19 17:07:46,718 - INFO - [MainThread] cura.Machines.MachineErrorChecker._setResult [188]: Error check finished, result = False, time = 2.5s 2019-04-19 17:07:53,758 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] [ERROR] Could not connect to the given address 2019-04-19 17:07:53,855 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onBackendQuit [811]: Backend quit with return code 0. Resetting process and socket. 2019-04-19 17:07:54,747 - DEBUG - [MainThread] cura.AutoSave._onTimeout [48]: Autosaving preferences, instances and profiles 2019-04-19 17:09:02,798 - DEBUG - [MainThread] cura.TaskManagement.OnExitCallbackManager.triggerNextCallback [51]: No more on-app-exit callbacks to process. Tell the app to exit. 2019-04-19 17:09:02,803 - INFO - [MainThread] cura.CuraApplication.closeApplication [547]: Close application 2019-04-19 17:09:02,830 - DEBUG - [MainThread] UM.Qt.QtApplication.windowClosed [417]: Shutting down cura 2019-04-19 17:09:02,876 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._terminate [295]: Attempting to kill the engine process 2019-04-19 17:09:11,687 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin FileLogger 2019-04-19 17:09:11,731 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin FirmwareUpdateChecker 2019-04-19 17:09:11,759 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin FirmwareUpdater 2019-04-19 17:09:11,786 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin GCodeGzReader 2019-04-19 17:09:11,812 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin GCodeGzWriter 2019-04-19 17:09:11,872 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin GCodeProfileReader 2019-04-19 17:09:11,926 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin GCodeReader 2019-04-19 17:09:11,956 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin GCodeWriter 2019-04-19 17:09:11,993 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin ImageReader 2019-04-19 17:09:12,025 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin LegacyProfileReader 2019-04-19 17:09:12,061 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin LocalContainerProvider 2019-04-19 17:09:12,097 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin LocalFileOutputDevice 2019-04-19 17:09:12,124 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin MachineSettingsAction 2019-04-19 17:09:12,152 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin ModelChecker 2019-04-19 17:09:12,182 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin MonitorStage 2019-04-19 17:09:12,221 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin PerObjectSettingsTool 2019-04-19 17:09:12,253 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin PostProcessingPlugin 2019-04-19 17:09:12,286 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin PrepareStage 2019-04-19 17:09:12,321 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin PreviewStage 2019-04-19 17:09:12,368 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin RemovableDriveOutputDevice 2019-04-19 17:09:12,434 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin SimulationView 2019-04-19 17:09:12,473 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin SliceInfoPlugin 2019-04-19 17:09:12,504 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin SolidView 2019-04-19 17:09:12,537 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin SupportEraser 2019-04-19 17:09:12,608 - DEBUG - [MainThread] cura.OAuth2.AuthorizationService.getAccessToken [106]: No auth data to retrieve the access_token from 2019-04-19 17:09:12,614 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin Toolbox 2019-04-19 17:09:12,660 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin CameraTool 2019-04-19 17:09:12,713 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin MirrorTool 2019-04-19 17:09:12,760 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin RotateTool 2019-04-19 17:09:12,808 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin ScaleTool 2019-04-19 17:09:12,841 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin SelectionTool 2019-04-19 17:09:12,886 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin TranslateTool 2019-04-19 17:09:12,977 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin UFPWriter 2019-04-19 17:09:13,040 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin UltimakerMachineActions 2019-04-19 17:09:13,392 - DEBUG - [MainThread] UM3NetworkPrinting.src.Cloud.CloudOutputDeviceManager._onLoginStateChanged [57]: Log in state changed to False 2019-04-19 17:09:13,393 - DEBUG - [MainThread] UM3NetworkPrinting.src.Cloud.CloudOutputDeviceManager._onGetRemoteClustersFinished [80]: Parsed remote clusters to [] 2019-04-19 17:09:13,394 - DEBUG - [MainThread] UM3NetworkPrinting.src.Cloud.CloudOutputDeviceManager._onGetRemoteClustersFinished [81]: Removed: 0, added: 0, updates: 0 2019-04-19 17:09:13,401 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin UM3NetworkPrinting 2019-04-19 17:09:13,466 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin UpdateChecker 2019-04-19 17:09:13,472 - INFO - [Thread-2] UpdateChecker.UpdateCheckerJob.run [36]: Checking for new version of cura 2019-04-19 17:09:13,572 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin USBPrinting 2019-04-19 17:09:13,614 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin UserAgreement 2019-04-19 17:09:13,676 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade21to22 2019-04-19 17:09:13,725 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade22to24 2019-04-19 17:09:13,768 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade25to26 2019-04-19 17:09:13,808 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade26to27 2019-04-19 17:09:13,854 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade27to30 2019-04-19 17:09:13,933 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade30to31 2019-04-19 17:09:13,998 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade32to33 2019-04-19 17:09:14,059 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade33to34 2019-04-19 17:09:14,103 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade34to35 2019-04-19 17:09:14,144 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade35to40 2019-04-19 17:09:14,185 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin SimpleView 2019-04-19 17:09:14,237 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin X3DReader 2019-04-19 17:09:14,301 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin XmlMaterialProfile 2019-04-19 17:09:14,347 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin XRayView 2019-04-19 17:09:14,385 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin CustomSupports 2019-04-19 17:09:14,429 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin OrientationPlugin 2019-04-19 17:09:14,462 - INFO - [MainThread] UM.VersionUpgradeManager.upgrade [143]: Looking for old configuration files to upgrade. 2019-04-19 17:09:14,518 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\packages.json, skip it 2019-04-19 17:09:14,526 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\plugins.json, skip it 2019-04-19 17:09:14,564 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\packages.json, skip it 2019-04-19 17:09:14,569 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\plugins.json, skip it 2019-04-19 17:09:14,607 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\packages.json, skip it 2019-04-19 17:09:14,612 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\plugins.json, skip it 2019-04-19 17:09:14,651 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\packages.json, skip it 2019-04-19 17:09:14,657 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\plugins.json, skip it 2019-04-19 17:09:14,689 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\packages.json, skip it 2019-04-19 17:09:14,694 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\plugins.json, skip it 2019-04-19 17:09:14,726 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\packages.json, skip it 2019-04-19 17:09:14,731 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\plugins.json, skip it 2019-04-19 17:09:14,761 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\packages.json, skip it 2019-04-19 17:09:14,766 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\plugins.json, skip it 2019-04-19 17:09:14,798 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\packages.json, skip it 2019-04-19 17:09:14,803 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\plugins.json, skip it 2019-04-19 17:09:14,903 - DEBUG - [MainThread] UM.Backend.Backend._onSocketError [213]: Socket was unable to bind to port, increasing port number to 49675 2019-04-19 17:09:14,908 - DEBUG - [MainThread] UM.Backend.Backend._createSocket [227]: Previous socket existed. Closing that first. 2019-04-19 17:09:14,912 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._terminate [295]: Attempting to kill the engine process 2019-04-19 17:09:14,917 - DEBUG - [MainThread] UM.Backend.Backend._createSocket [227]: Previous socket existed. Closing that first. 2019-04-19 17:09:15,114 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [187]: Socket state changed to Listening 2019-04-19 17:09:15,128 - INFO - [MainThread] UM.Backend.Backend.startEngine [81]: Started engine process: C:\Program Files\Ultimaker Cura 4.0\CuraEngine.exe 2019-04-19 17:09:15,132 - DEBUG - [MainThread] UM.Backend.Backend._backendLog [101]: [Backend] Calling engine with: ['C:\\Program Files\\Ultimaker Cura 4.0\\CuraEngine.exe', 'connect', '127.0.0.1:49675', ''] 2019-04-19 17:09:15,187 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:09:15,191 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] Cura_SteamEngine version 4.0.0 2019-04-19 17:09:15,196 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] Copyright (C) 2018 Ultimaker 2019-04-19 17:09:15,201 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:09:15,205 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] This program is free software: you can redistribute it and/or modify 2019-04-19 17:09:15,210 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] it under the terms of the GNU Affero General Public License as published by 2019-04-19 17:09:15,214 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] the Free Software Foundation, either version 3 of the License, or 2019-04-19 17:09:15,219 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] (at your option) any later version. 2019-04-19 17:09:15,223 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:09:15,227 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] This program is distributed in the hope that it will be useful, 2019-04-19 17:09:15,232 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] but WITHOUT ANY WARRANTY; without even the implied warranty of 2019-04-19 17:09:15,237 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the 2019-04-19 17:09:15,242 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] GNU Affero General Public License for more details. 2019-04-19 17:09:15,246 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:09:15,251 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] You should have received a copy of the GNU Affero General Public License 2019-04-19 17:09:15,255 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] along with this program. If not, see <http://www.gnu.org/licenses/>. 2019-04-19 17:09:18,845 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.loadAllMetadata [338]: Loading metadata into container registry took 3.693957567214966 seconds 2019-04-19 17:09:19,016 - DEBUG - [MainThread] cura.Scene.CuraSceneController.setActiveBuildPlate [104]: Select build plate: 0 2019-04-19 17:09:19,021 - INFO - [MainThread] cura.CuraApplication.run [695]: Initializing variant manager 2019-04-19 17:09:19,030 - DEBUG - [MainThread] cura.Machines.VariantManager.initialize [59]: Exclude variant [empty_variant] 2019-04-19 17:09:19,032 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container ultimaker_s5_glass 2019-04-19 17:09:19,040 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [ultimaker_s5_glass] added. 2019-04-19 17:09:19,041 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container ultimaker_s5 2019-04-19 17:09:19,201 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [ultimaker_s5] added. 2019-04-19 17:09:19,206 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container ultimaker_s5_aluminum 2019-04-19 17:09:19,214 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [ultimaker_s5_aluminum] added. 2019-04-19 17:09:19,226 - INFO - [MainThread] cura.CuraApplication.run [699]: Initializing material manager 2019-04-19 17:09:19,344 - INFO - [MainThread] cura.CuraApplication.run [704]: Initializing quality manager 2019-04-19 17:09:19,367 - DEBUG - [MainThread] cura.Machines.QualityManager.initialize [136]: Lookup tables updated. 2019-04-19 17:09:19,372 - INFO - [MainThread] cura.CuraApplication.run [709]: Initializing machine manager 2019-04-19 17:09:19,378 - INFO - [MainThread] cura.CuraApplication.run [712]: Initializing container manager 2019-04-19 17:09:19,383 - INFO - [MainThread] cura.CuraApplication.run [715]: Initializing machine error checker 2019-04-19 17:09:19,415 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container Creality CR-10 2019-04-19 17:09:19,420 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container Creality CR-10_user 2019-04-19 17:09:19,429 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [Creality CR-10_user] added. 2019-04-19 17:09:19,430 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container creality_cr10_pla 2019-04-19 17:09:19,439 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [creality_cr10_pla] added. 2019-04-19 17:09:19,440 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container draft 2019-04-19 17:09:19,448 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [draft] added. 2019-04-19 17:09:19,451 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container Creality CR-10_settings 2019-04-19 17:09:19,459 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [Creality CR-10_settings] added. 2019-04-19 17:09:19,460 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container creality_cr10 2019-04-19 17:09:19,552 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [creality_cr10] added. 2019-04-19 17:09:19,558 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [Creality CR-10] added. 2019-04-19 17:09:19,563 - INFO - [MainThread] cura.MachineActionManager.addDefaultMachineActions [72]: Default machine actions added for machine definition [creality_cr10] 2019-04-19 17:09:19,571 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container creality_cr10_extruder_0 #2 2019-04-19 17:09:19,575 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container creality_cr10_extruder_0 #2_user 2019-04-19 17:09:19,584 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [creality_cr10_extruder_0 #2_user] added. 2019-04-19 17:09:19,586 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container creality_cr10_extruder_0_pla 2019-04-19 17:09:19,596 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [creality_cr10_extruder_0_pla] added. 2019-04-19 17:09:19,600 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container generic_pla_175 2019-04-19 17:09:19,615 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [generic_pla_175_imade3d_jellybox] added. 2019-04-19 17:09:19,621 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [generic_pla_175_imade3d_jellybox_0.4_mm] added. 2019-04-19 17:09:19,627 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [generic_pla_175_imade3d_jellybox_0.4_mm_2-fans] added. 2019-04-19 17:09:19,633 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [generic_pla_175_cartesio] added. 2019-04-19 17:09:19,640 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [generic_pla_175_cartesio_0.25mm_thermoplastic_extruder] added. 2019-04-19 17:09:19,646 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [generic_pla_175_cartesio_0.4mm_thermoplastic_extruder] added. 2019-04-19 17:09:19,653 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [generic_pla_175_cartesio_0.8mm_thermoplastic_extruder] added. 2019-04-19 17:09:19,658 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [generic_pla_175] added. 2019-04-19 17:09:19,660 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container creality_cr10_extruder_0 #2_settings 2019-04-19 17:09:19,672 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [creality_cr10_extruder_0 #2_settings] added. 2019-04-19 17:09:19,673 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container creality_cr10_extruder_0 2019-04-19 17:09:19,681 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [creality_cr10_extruder_0] added. 2019-04-19 17:09:19,685 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [creality_cr10_extruder_0 #2] added. 2019-04-19 17:09:19,693 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container fdmprinter 2019-04-19 17:09:19,780 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [fdmprinter] added. 2019-04-19 17:09:20,312 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [170]: Begin loading of script: BQ_PauseAtHeight 2019-04-19 17:09:20,320 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [170]: Begin loading of script: ChangeAtZ 2019-04-19 17:09:20,328 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [170]: Begin loading of script: DisplayFilenameAndLayerOnLCD 2019-04-19 17:09:20,335 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [170]: Begin loading of script: FilamentChange 2019-04-19 17:09:20,344 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [170]: Begin loading of script: PauseAtHeight 2019-04-19 17:09:20,351 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [170]: Begin loading of script: PauseAtHeightRepRapFirmwareDuet 2019-04-19 17:09:20,402 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [170]: Begin loading of script: PauseAtHeightforRepetier 2019-04-19 17:09:20,430 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [170]: Begin loading of script: SearchAndReplace 2019-04-19 17:09:20,450 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [170]: Begin loading of script: Stretch 2019-04-19 17:09:20,457 - DEBUG - [MainThread] UM3NetworkPrinting.src.UM3OutputDevicePlugin.checkCloudFlowIsPossible [412]: Checking if cloud connection is possible... 2019-04-19 17:09:20,461 - DEBUG - [MainThread] UM3NetworkPrinting.src.UM3OutputDevicePlugin.checkCloudFlowIsPossible [435]: Cloud Flow not possible: User not logged in! 2019-04-19 17:09:20,691 - INFO - [MainThread] cura.Settings.GlobalStack.addExtruder [136]: Extruder[creality_cr10_extruder_0 #2] added to [Creality CR-10] at position [0] 2019-04-19 17:09:20,696 - WARNING - [MainThread] cura.Settings.ExtruderManager.registerExtruder [169]: Extruder [creality_cr10_extruder_0 #2] has already been registered on machine [Creality CR-10], not doing anything 2019-04-19 17:09:20,723 - INFO - [MainThread] cura.Settings.MachineManager._initMachineState [330]: Machine 'Creality CR-10' quality changes set to 'PLA #2' 2019-04-19 17:09:21,364 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._rescheduleCheck [136]: New error check scheduled. 2019-04-19 17:09:21,367 - INFO - [MainThread] FirmwareUpdateChecker.FirmwareUpdateChecker.checkFirmwareVersion [76]: No machine with name Creality CR-10 in list of firmware to check. 2019-04-19 17:09:21,711 - INFO - [MainThread] cura.Machines.MaterialManager._updateMaps [279]: Updating material lookup data ... 2019-04-19 17:09:21,866 - INFO - [MainThread] cura.Settings.MachineManager._updateQualityWithMaterial [1270]: Updating quality/quality_changes due to material change 2019-04-19 17:09:21,876 - DEBUG - [MainThread] cura.Settings.MachineManager._updateQualityWithMaterial [1277]: Current quality type = [draft] 2019-04-19 17:09:21,884 - INFO - [MainThread] cura.Settings.MachineManager._updateQualityWithMaterial [1291]: Current available quality type [draft] is available, applying changes. 2019-04-19 17:09:21,937 - DEBUG - [MainThread] cura.Machines.QualityManager.initialize [136]: Lookup tables updated. 2019-04-19 17:09:22,052 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._checkStack [140]: Need to check for errors again. Discard the current progress and reschedule a check. 2019-04-19 17:09:28,972 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin._createView [280]: Creating post processing plugin view. 2019-04-19 17:09:29,685 - DEBUG - [MainThread] UM.Qt.Bindings.Theme.load [158]: Loading theme file: C:\Program Files\Ultimaker Cura 4.0\resources\themes\cura-light\theme.json 2019-04-19 17:09:30,058 - DEBUG - [MainThread] UM.Qt.Bindings.Theme.load [230]: Loaded theme C:\Program Files\Ultimaker Cura 4.0\resources\themes\cura-light 2019-04-19 17:09:30,272 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin._createView [290]: Post processing view created. 2019-04-19 17:09:30,985 - WARNING - [MainThread] UM.Qt.Bindings.Theme.getImage [133]: No image header_pattern defined in Theme 2019-04-19 17:09:31,045 - DEBUG - [MainThread] cura.Machines.Models.BuildPlateModel._update [33]: Updating BuildPlateModel. 2019-04-19 17:09:32,520 - DEBUG - [MainThread] cura.Machines.Models.NozzleModel._update [34]: Updating NozzleModel. 2019-04-19 17:09:32,889 - DEBUG - [MainThread] UM3NetworkPrinting.src.DiscoverUM3Action._createAdditionalComponentsView [196]: Creating additional ui components for UM3. 2019-04-19 17:09:33,046 - DEBUG - [MainThread] UM3NetworkPrinting.src.DiscoverUM3Action.startDiscovery [47]: Starting device discovery. 2019-04-19 17:09:33,064 - DEBUG - [MainThread] UM.Controller.setActiveStage [159]: Setting active stage to PrepareStage 2019-04-19 17:09:33,778 - DEBUG - [MainThread] cura.Machines.Models.NozzleModel._update [34]: Updating NozzleModel. 2019-04-19 17:09:34,229 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/plugins/PrepareStage/PrepareMain.qml:16:5: QML ActionPanelWidget: Binding loop detected for property "width" 2019-04-19 17:09:34,236 - DEBUG - [MainThread] UM.Controller.setActiveView [92]: Setting active view to SolidView 2019-04-19 17:09:34,242 - DEBUG - [MainThread] ModelChecker.ModelChecker._createView [103]: Creating model checker view. 2019-04-19 17:09:34,284 - DEBUG - [MainThread] ModelChecker.ModelChecker._createView [112]: Model checker view created. 2019-04-19 17:09:34,286 - DEBUG - [MainThread] SliceInfoPlugin.SliceInfo._createDialog [82]: Creating dialog [MoreInfoWindow.qml] 2019-04-19 17:09:34,493 - DEBUG - [MainThread] cura.CuraApplication.run [747]: Booting Cura took 24.689333200454712 seconds 2019-04-19 17:09:34,507 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._rescheduleCheck [136]: New error check scheduled. 2019-04-19 17:09:34,553 - DEBUG - [MainThread] cura.Machines.Models.QualityProfilesDropDownMenuModel._update [61]: Updating QualityProfilesDropDownMenuModel. 2019-04-19 17:09:34,555 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container coarse 2019-04-19 17:09:34,568 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [coarse] added. 2019-04-19 17:09:34,609 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container extra_coarse 2019-04-19 17:09:34,618 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [extra_coarse] added. 2019-04-19 17:09:34,666 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container fast 2019-04-19 17:09:34,676 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [fast] added. 2019-04-19 17:09:34,818 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container high 2019-04-19 17:09:34,829 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [high] added. 2019-04-19 17:09:34,911 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container normal 2019-04-19 17:09:34,919 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [normal] added. 2019-04-19 17:09:34,921 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container extra_fast 2019-04-19 17:09:34,928 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [extra_fast] added. 2019-04-19 17:09:34,986 - DEBUG - [MainThread] cura.Machines.Models.CustomQualityProfilesDropDownMenuModel._update [15]: Updating CustomQualityProfilesDropDownMenuModel. 2019-04-19 17:09:35,381 - DEBUG - [MainThread] UM.Qt.QtRenderer._initialize [183]: Support for Vertex Array Objects: True 2019-04-19 17:09:35,408 - DEBUG - [MainThread] UM.View.GL.OpenGL.__init__ [99]: Initialized OpenGL subsystems. 2019-04-19 17:09:35,419 - DEBUG - [MainThread] UM.View.GL.OpenGL.__init__ [100]: OpenGL Version: 3.3.0 2019-04-19 17:09:35,427 - DEBUG - [MainThread] UM.View.GL.OpenGL.__init__ [101]: OpenGL Vendor: NVIDIA Corporation 2019-04-19 17:09:35,432 - DEBUG - [MainThread] UM.View.GL.OpenGL.__init__ [102]: OpenGL Renderer: GeForce 9500 GT/PCIe/SSE2 2019-04-19 17:09:35,437 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\default.shader]... 2019-04-19 17:09:35,446 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\selection.shader]... 2019-04-19 17:09:35,454 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\default.shader]... 2019-04-19 17:09:35,462 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\composite.shader]... 2019-04-19 17:09:35,471 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\overhang.shader]... 2019-04-19 17:09:35,481 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\striped.shader]... 2019-04-19 17:09:35,490 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\transparent_object.shader]... 2019-04-19 17:09:35,499 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\striped.shader]... 2019-04-19 17:09:35,510 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\default.shader]... 2019-04-19 17:09:35,517 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\grid.shader]... 2019-04-19 17:09:35,526 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\platform.shader]... 2019-04-19 17:09:35,677 - DEBUG - [MainThread] cura.Machines.QualityManager.initialize [136]: Lookup tables updated. 2019-04-19 17:09:36,215 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] [ERROR] Could not connect to the given address 2019-04-19 17:09:36,302 - DEBUG - [MainThread] cura.Machines.Models.QualityProfilesDropDownMenuModel._update [61]: Updating QualityProfilesDropDownMenuModel. 2019-04-19 17:09:36,323 - DEBUG - [MainThread] cura.Machines.Models.CustomQualityProfilesDropDownMenuModel._update [15]: Updating CustomQualityProfilesDropDownMenuModel. 2019-04-19 17:09:36,331 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onBackendQuit [811]: Backend quit with return code 0. Resetting process and socket. 2019-04-19 17:09:37,409 - INFO - [MainThread] cura.Machines.MachineErrorChecker._setResult [188]: Error check finished, result = False, time = 2.9s 2019-04-19 17:09:45,785 - DEBUG - [MainThread] cura.AutoSave._onTimeout [48]: Autosaving preferences, instances and profiles 2019-04-19 17:13:41,083 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._rescheduleCheck [136]: New error check scheduled. 2019-04-19 17:13:42,324 - INFO - [MainThread] cura.Machines.MachineErrorChecker._setResult [188]: Error check finished, result = False, time = 1.2s 2019-04-19 17:13:43,216 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._rescheduleCheck [136]: New error check scheduled. 2019-04-19 17:13:44,202 - INFO - [MainThread] cura.Machines.MachineErrorChecker._setResult [188]: Error check finished, result = False, time = 1.0s 2019-04-19 17:14:09,237 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/resources/qml/Settings/SettingItem.qml:124:19: Unable to assign [undefined] to QString 2019-04-19 17:14:09,243 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/resources/qml/Settings/SettingTextField.qml:97:19: Unable to assign [undefined] to QString 2019-04-19 17:14:09,248 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/resources/qml/Settings/SettingItem.qml:124:19: Unable to assign [undefined] to QString 2019-04-19 17:14:09,253 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/resources/qml/Settings/SettingTextField.qml:97:19: Unable to assign [undefined] to QString 2019-04-19 17:14:09,257 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/resources/qml/Settings/SettingItem.qml:124:19: Unable to assign [undefined] to QString 2019-04-19 17:14:09,263 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/resources/qml/Settings/SettingTextField.qml:97:19: Unable to assign [undefined] to QString 2019-04-19 17:14:09,267 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/resources/qml/Settings/SettingItem.qml:124:19: Unable to assign [undefined] to QString 2019-04-19 17:14:09,272 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/resources/qml/Settings/SettingTextField.qml:97:19: Unable to assign [undefined] to QString 2019-04-19 17:14:09,276 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/resources/qml/Settings/SettingItem.qml:124:19: Unable to assign [undefined] to QString 2019-04-19 17:14:09,281 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/resources/qml/Settings/SettingTextField.qml:97:19: Unable to assign [undefined] to QString 2019-04-19 17:14:09,285 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/resources/qml/Settings/SettingItem.qml:124:19: Unable to assign [undefined] to QString 2019-04-19 17:14:09,290 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/resources/qml/Settings/SettingTextField.qml:97:19: Unable to assign [undefined] to QString 2019-04-19 17:14:09,295 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/resources/qml/Settings/SettingItem.qml:124:19: Unable to assign [undefined] to QString 2019-04-19 17:14:09,299 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/resources/qml/Settings/SettingTextField.qml:97:19: Unable to assign [undefined] to QString 2019-04-19 17:14:21,503 - DEBUG - [MainThread] cura.AutoSave._onTimeout [48]: Autosaving preferences, instances and profiles 2019-04-19 17:14:36,244 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._rescheduleCheck [136]: New error check scheduled. 2019-04-19 17:14:36,680 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._checkStack [140]: Need to check for errors again. Discard the current progress and reschedule a check. 2019-04-19 17:14:36,790 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._rescheduleCheck [136]: New error check scheduled. 2019-04-19 17:14:37,770 - INFO - [MainThread] cura.Machines.MachineErrorChecker._setResult [188]: Error check finished, result = False, time = 1.0s 2019-04-19 17:14:39,916 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._rescheduleCheck [136]: New error check scheduled. 2019-04-19 17:14:40,901 - INFO - [MainThread] cura.Machines.MachineErrorChecker._setResult [188]: Error check finished, result = False, time = 1.0s 2019-04-19 17:14:44,796 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._rescheduleCheck [136]: New error check scheduled. 2019-04-19 17:14:44,951 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._checkStack [140]: Need to check for errors again. Discard the current progress and reschedule a check. 2019-04-19 17:14:45,061 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._rescheduleCheck [136]: New error check scheduled. 2019-04-19 17:14:45,515 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._checkStack [140]: Need to check for errors again. Discard the current progress and reschedule a check. 2019-04-19 17:14:45,612 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._rescheduleCheck [136]: New error check scheduled. 2019-04-19 17:14:46,282 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._checkStack [140]: Need to check for errors again. Discard the current progress and reschedule a check. 2019-04-19 17:14:46,383 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._rescheduleCheck [136]: New error check scheduled. 2019-04-19 17:14:47,735 - INFO - [MainThread] cura.Machines.MachineErrorChecker._setResult [188]: Error check finished, result = False, time = 1.4s 2019-04-19 17:14:51,228 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._rescheduleCheck [136]: New error check scheduled. 2019-04-19 17:14:51,929 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._checkStack [140]: Need to check for errors again. Discard the current progress and reschedule a check. 2019-04-19 17:14:52,038 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._rescheduleCheck [136]: New error check scheduled. 2019-04-19 17:14:53,152 - INFO - [MainThread] cura.Machines.MachineErrorChecker._setResult [188]: Error check finished, result = False, time = 1.1s 2019-04-19 17:15:02,263 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._rescheduleCheck [136]: New error check scheduled. 2019-04-19 17:15:03,433 - INFO - [MainThread] cura.Machines.MachineErrorChecker._setResult [188]: Error check finished, result = False, time = 1.2s 2019-04-19 17:15:04,825 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._rescheduleCheck [136]: New error check scheduled. 2019-04-19 17:15:06,041 - INFO - [MainThread] cura.Machines.MachineErrorChecker._setResult [188]: Error check finished, result = False, time = 1.2s 2019-04-19 17:15:09,140 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._rescheduleCheck [136]: New error check scheduled. 2019-04-19 17:15:09,273 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._checkStack [140]: Need to check for errors again. Discard the current progress and reschedule a check. 2019-04-19 17:15:09,383 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._rescheduleCheck [136]: New error check scheduled. 2019-04-19 17:15:09,674 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._checkStack [140]: Need to check for errors again. Discard the current progress and reschedule a check. 2019-04-19 17:15:09,784 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._rescheduleCheck [136]: New error check scheduled. 2019-04-19 17:15:10,749 - INFO - [MainThread] cura.Machines.MachineErrorChecker._setResult [188]: Error check finished, result = False, time = 0.9s 2019-04-19 17:15:10,972 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._rescheduleCheck [136]: New error check scheduled. 2019-04-19 17:15:11,576 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._checkStack [140]: Need to check for errors again. Discard the current progress and reschedule a check. 2019-04-19 17:15:11,685 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._rescheduleCheck [136]: New error check scheduled. 2019-04-19 17:15:11,878 - DEBUG - [MainThread] cura.AutoSave._onTimeout [48]: Autosaving preferences, instances and profiles 2019-04-19 17:15:12,424 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._checkStack [140]: Need to check for errors again. Discard the current progress and reschedule a check. 2019-04-19 17:15:12,534 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._rescheduleCheck [136]: New error check scheduled. 2019-04-19 17:15:13,910 - INFO - [MainThread] cura.Machines.MachineErrorChecker._setResult [188]: Error check finished, result = False, time = 1.4s 2019-04-19 17:15:31,173 - DEBUG - [MainThread] cura.AutoSave._onTimeout [48]: Autosaving preferences, instances and profiles 2019-04-19 17:15:43,933 - DEBUG - [MainThread] cura.AutoSave._onTimeout [48]: Autosaving preferences, instances and profiles 2019-04-19 17:16:22,206 - DEBUG - [MainThread] cura.AutoSave._onTimeout [48]: Autosaving preferences, instances and profiles 2019-04-19 17:16:46,422 - INFO - [Thread-1] STLReader.STLReader.load_file [46]: Using NumPy-STL to load STL data. 2019-04-19 17:16:46,423 - INFO - [Thread-2] STLReader.STLReader.load_file [46]: Using NumPy-STL to load STL data. 2019-04-19 17:16:46,424 - INFO - [Thread-3] STLReader.STLReader.load_file [46]: Using NumPy-STL to load STL data. 2019-04-19 17:16:46,452 - DEBUG - [Thread-1] UM.Mesh.MeshData.calculateNormalsFromVertices [444]: Calculating normals took 0.006998777389526367 seconds 2019-04-19 17:16:46,453 - DEBUG - [Thread-2] UM.Mesh.MeshData.calculateNormalsFromVertices [444]: Calculating normals took 0.0039980411529541016 seconds 2019-04-19 17:16:46,459 - DEBUG - [Thread-2] STLReader.STLReader._read [97]: Loaded a mesh with 11556 vertices 2019-04-19 17:16:46,460 - DEBUG - [Thread-1] STLReader.STLReader._read [97]: Loaded a mesh with 82644 vertices 2019-04-19 17:16:46,491 - DEBUG - [Thread-2] UM.Mesh.MeshData.approximateConvexHull [401]: approximateConvexHull(target_count=1024) Calculating 3D convex hull took 0.016998767852783203 seconds. 208 input vertices. 208 output vertices. 2019-04-19 17:16:46,505 - DEBUG - [Thread-3] UM.Mesh.MeshData.calculateNormalsFromVertices [444]: Calculating normals took 0.02187514305114746 seconds 2019-04-19 17:16:46,567 - DEBUG - [Thread-2] UM.FileHandler.ReadFileJob.run [69]: Loading file took 0.1 seconds 2019-04-19 17:16:46,583 - DEBUG - [Thread-1] UM.Mesh.MeshData.approximateConvexHull [401]: approximateConvexHull(target_count=1024) Calculating 3D convex hull took 0.10736823081970215 seconds. 351 input vertices. 351 output vertices. 2019-04-19 17:16:46,583 - DEBUG - [Thread-3] STLReader.STLReader._read [97]: Loaded a mesh with 291300 vertices 2019-04-19 17:16:46,598 - DEBUG - [Thread-2] UM.Mesh.MeshData.approximateConvexHull [401]: approximateConvexHull(target_count=1024) Calculating 3D convex hull took 0.03125357627868652 seconds. 208 input vertices. 208 output vertices. 2019-04-19 17:16:46,616 - INFO - [Thread-2] STLReader.STLReader.load_file [46]: Using NumPy-STL to load STL data. 2019-04-19 17:16:46,626 - DEBUG - [Thread-2] UM.Mesh.MeshData.calculateNormalsFromVertices [444]: Calculating normals took 0.0019989013671875 seconds 2019-04-19 17:16:46,628 - DEBUG - [Thread-2] STLReader.STLReader._read [97]: Loaded a mesh with 26622 vertices 2019-04-19 17:16:46,638 - DEBUG - [Thread-1] UM.FileHandler.ReadFileJob.run [69]: Loading file took 0.2 seconds 2019-04-19 17:16:46,647 - DEBUG - [Thread-2] UM.Mesh.MeshData.approximateConvexHull [401]: approximateConvexHull(target_count=1024) Calculating 3D convex hull took 0.014001846313476562 seconds. 55 input vertices. 55 output vertices. 2019-04-19 17:16:46,662 - DEBUG - [Thread-2] UM.FileHandler.ReadFileJob.run [69]: Loading file took 0.0 seconds 2019-04-19 17:16:46,681 - DEBUG - [Thread-2] UM.Mesh.MeshData.approximateConvexHull [401]: approximateConvexHull(target_count=1024) Calculating 3D convex hull took 0.01399850845336914 seconds. 54 input vertices. 54 output vertices. 2019-04-19 17:16:46,693 - DEBUG - [Thread-1] UM.Mesh.MeshData.approximateConvexHull [401]: approximateConvexHull(target_count=1024) Calculating 3D convex hull took 0.05099940299987793 seconds. 351 input vertices. 351 output vertices. 2019-04-19 17:16:46,790 - DEBUG - [Thread-3] UM.Mesh.MeshData.approximateConvexHull [401]: approximateConvexHull(target_count=1024) Calculating 3D convex hull took 0.20237088203430176 seconds. 2315 input vertices. 2315 output vertices. 2019-04-19 17:16:46,812 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [per_object_stack_2810009056144] added. 2019-04-19 17:16:46,881 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [per_object_stack_2810009095528] added. 2019-04-19 17:16:46,924 - DEBUG - [Thread-3] UM.FileHandler.ReadFileJob.run [69]: Loading file took 0.5 seconds 2019-04-19 17:16:46,949 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [per_object_stack_2810008705344] added. 2019-04-19 17:16:46,992 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\transparent_object.shader]... 2019-04-19 17:16:47,114 - DEBUG - [Thread-3] UM.Mesh.MeshData.approximateConvexHull [401]: approximateConvexHull(target_count=1024) Calculating 3D convex hull took 0.18399786949157715 seconds. 2315 input vertices. 2315 output vertices. 2019-04-19 17:16:47,186 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [per_object_stack_2810009164992] added. 2019-04-19 17:16:53,610 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\toolhandle.shader]... 2019-04-19 17:16:57,282 - DEBUG - [MainThread] cura.AutoSave._onTimeout [48]: Autosaving preferences, instances and profiles 2019-04-19 17:17:09,461 - DEBUG - [MainThread] cura.AutoSave._onTimeout [48]: Autosaving preferences, instances and profiles 2019-04-19 17:18:18,660 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend.slice [228]: Starting to slice... 2019-04-19 17:18:18,660 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend.slice [246]: Going to slice build plate [0]! 2019-04-19 17:18:18,660 - DEBUG - [MainThread] UM.Backend.Backend._createSocket [227]: Previous socket existed. Closing that first. 2019-04-19 17:18:18,785 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [187]: Socket state changed to Listening 2019-04-19 17:18:18,927 - INFO - [MainThread] UM.Backend.Backend.startEngine [81]: Started engine process: C:\Program Files\Ultimaker Cura 4.0\CuraEngine.exe 2019-04-19 17:18:18,938 - DEBUG - [MainThread] UM.Backend.Backend._backendLog [101]: [Backend] Calling engine with: ['C:\\Program Files\\Ultimaker Cura 4.0\\CuraEngine.exe', 'connect', '127.0.0.1:49675', ''] 2019-04-19 17:18:19,013 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:18:19,044 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] Cura_SteamEngine version 4.0.0 2019-04-19 17:18:19,060 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] Copyright (C) 2018 Ultimaker 2019-04-19 17:18:19,107 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:18:19,122 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] This program is free software: you can redistribute it and/or modify 2019-04-19 17:18:19,201 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] it under the terms of the GNU Affero General Public License as published by 2019-04-19 17:18:19,326 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] the Free Software Foundation, either version 3 of the License, or 2019-04-19 17:18:19,372 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] (at your option) any later version. 2019-04-19 17:18:19,372 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:18:19,451 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] This program is distributed in the hope that it will be useful, 2019-04-19 17:18:19,544 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] but WITHOUT ANY WARRANTY; without even the implied warranty of 2019-04-19 17:18:19,654 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the 2019-04-19 17:18:19,685 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] GNU Affero General Public License for more details. 2019-04-19 17:18:19,716 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:18:19,763 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] You should have received a copy of the GNU Affero General Public License 2019-04-19 17:18:19,925 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] along with this program. If not, see <http://www.gnu.org/licenses/>. 2019-04-19 17:18:20,951 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onStartSliceCompleted [432]: Sending slice message took 2.290106773376465 seconds 2019-04-19 17:18:40,018 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] [ERROR] Could not connect to the given address 2019-04-19 17:18:40,128 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onBackendQuit [811]: Backend quit with return code 0. Resetting process and socket. 2019-04-19 17:19:18,625 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._terminate [295]: Attempting to kill the engine process 2019-04-19 17:19:18,630 - DEBUG - [MainThread] UM.Backend.Backend._createSocket [227]: Previous socket existed. Closing that first. 2019-04-19 17:19:18,666 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [187]: Socket state changed to Listening 2019-04-19 17:19:18,681 - INFO - [MainThread] UM.Backend.Backend.startEngine [81]: Started engine process: C:\Program Files\Ultimaker Cura 4.0\CuraEngine.exe 2019-04-19 17:19:18,686 - DEBUG - [MainThread] UM.Backend.Backend._backendLog [101]: [Backend] Calling engine with: ['C:\\Program Files\\Ultimaker Cura 4.0\\CuraEngine.exe', 'connect', '127.0.0.1:49675', ''] 2019-04-19 17:19:18,817 - DEBUG - [Thread-17] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:19:18,833 - DEBUG - [Thread-17] UM.Backend.Backend._backendLog [101]: [Backend] Cura_SteamEngine version 4.0.0 2019-04-19 17:19:18,838 - DEBUG - [Thread-17] UM.Backend.Backend._backendLog [101]: [Backend] Copyright (C) 2018 Ultimaker 2019-04-19 17:19:18,844 - DEBUG - [Thread-17] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:19:18,850 - DEBUG - [Thread-17] UM.Backend.Backend._backendLog [101]: [Backend] This program is free software: you can redistribute it and/or modify 2019-04-19 17:19:18,855 - DEBUG - [Thread-17] UM.Backend.Backend._backendLog [101]: [Backend] it under the terms of the GNU Affero General Public License as published by 2019-04-19 17:19:18,861 - DEBUG - [Thread-17] UM.Backend.Backend._backendLog [101]: [Backend] the Free Software Foundation, either version 3 of the License, or 2019-04-19 17:19:18,867 - DEBUG - [Thread-17] UM.Backend.Backend._backendLog [101]: [Backend] (at your option) any later version. 2019-04-19 17:19:18,873 - DEBUG - [Thread-17] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:19:18,879 - DEBUG - [Thread-17] UM.Backend.Backend._backendLog [101]: [Backend] This program is distributed in the hope that it will be useful, 2019-04-19 17:19:18,885 - DEBUG - [Thread-17] UM.Backend.Backend._backendLog [101]: [Backend] but WITHOUT ANY WARRANTY; without even the implied warranty of 2019-04-19 17:19:18,891 - DEBUG - [Thread-17] UM.Backend.Backend._backendLog [101]: [Backend] MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the 2019-04-19 17:19:18,897 - DEBUG - [Thread-17] UM.Backend.Backend._backendLog [101]: [Backend] GNU Affero General Public License for more details. 2019-04-19 17:19:18,902 - DEBUG - [Thread-17] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:19:18,908 - DEBUG - [Thread-17] UM.Backend.Backend._backendLog [101]: [Backend] You should have received a copy of the GNU Affero General Public License 2019-04-19 17:19:18,913 - DEBUG - [Thread-17] UM.Backend.Backend._backendLog [101]: [Backend] along with this program. If not, see <http://www.gnu.org/licenses/>. 2019-04-19 17:19:38,689 - DEBUG - [MainThread] cura.AutoSave._onTimeout [48]: Autosaving preferences, instances and profiles 2019-04-19 17:19:39,842 - DEBUG - [Thread-17] UM.Backend.Backend._backendLog [101]: [Backend] [ERROR] Could not connect to the given address 2019-04-19 17:19:40,433 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onBackendQuit [811]: Backend quit with return code 0. Resetting process and socket. 2019-04-19 17:19:43,228 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._rescheduleCheck [136]: New error check scheduled. 2019-04-19 17:19:44,636 - INFO - [MainThread] cura.Machines.MachineErrorChecker._setResult [188]: Error check finished, result = False, time = 1.4s 2019-04-19 17:19:52,723 - DEBUG - [MainThread] cura.AutoSave._onTimeout [48]: Autosaving preferences, instances and profiles 2019-04-19 17:20:03,584 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._rescheduleCheck [136]: New error check scheduled. 2019-04-19 17:20:05,069 - INFO - [MainThread] cura.Machines.MachineErrorChecker._setResult [188]: Error check finished, result = False, time = 1.5s 2019-04-19 17:20:08,974 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._rescheduleCheck [136]: New error check scheduled. 2019-04-19 17:20:09,383 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._checkStack [140]: Need to check for errors again. Discard the current progress and reschedule a check. 2019-04-19 17:20:09,588 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._rescheduleCheck [136]: New error check scheduled. 2019-04-19 17:20:11,404 - INFO - [MainThread] cura.Machines.MachineErrorChecker._setResult [188]: Error check finished, result = False, time = 1.8s 2019-04-19 17:20:12,788 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend.slice [228]: Starting to slice... 2019-04-19 17:20:12,788 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend.slice [246]: Going to slice build plate [0]! 2019-04-19 17:20:12,788 - DEBUG - [MainThread] UM.Backend.Backend._createSocket [227]: Previous socket existed. Closing that first. 2019-04-19 17:20:12,929 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [187]: Socket state changed to Listening 2019-04-19 17:20:12,976 - INFO - [MainThread] UM.Backend.Backend.startEngine [81]: Started engine process: C:\Program Files\Ultimaker Cura 4.0\CuraEngine.exe 2019-04-19 17:20:12,992 - DEBUG - [MainThread] UM.Backend.Backend._backendLog [101]: [Backend] Calling engine with: ['C:\\Program Files\\Ultimaker Cura 4.0\\CuraEngine.exe', 'connect', '127.0.0.1:49675', ''] 2019-04-19 17:20:13,152 - DEBUG - [Thread-20] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:20:13,199 - DEBUG - [Thread-20] UM.Backend.Backend._backendLog [101]: [Backend] Cura_SteamEngine version 4.0.0 2019-04-19 17:20:13,246 - DEBUG - [Thread-20] UM.Backend.Backend._backendLog [101]: [Backend] Copyright (C) 2018 Ultimaker 2019-04-19 17:20:13,262 - DEBUG - [Thread-20] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:20:13,324 - DEBUG - [Thread-20] UM.Backend.Backend._backendLog [101]: [Backend] This program is free software: you can redistribute it and/or modify 2019-04-19 17:20:13,340 - DEBUG - [Thread-20] UM.Backend.Backend._backendLog [101]: [Backend] it under the terms of the GNU Affero General Public License as published by 2019-04-19 17:20:13,387 - DEBUG - [Thread-20] UM.Backend.Backend._backendLog [101]: [Backend] the Free Software Foundation, either version 3 of the License, or 2019-04-19 17:20:13,418 - DEBUG - [Thread-20] UM.Backend.Backend._backendLog [101]: [Backend] (at your option) any later version. 2019-04-19 17:20:13,449 - DEBUG - [Thread-20] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:20:13,481 - DEBUG - [Thread-20] UM.Backend.Backend._backendLog [101]: [Backend] This program is distributed in the hope that it will be useful, 2019-04-19 17:20:13,527 - DEBUG - [Thread-20] UM.Backend.Backend._backendLog [101]: [Backend] but WITHOUT ANY WARRANTY; without even the implied warranty of 2019-04-19 17:20:13,543 - DEBUG - [Thread-20] UM.Backend.Backend._backendLog [101]: [Backend] MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the 2019-04-19 17:20:13,574 - DEBUG - [Thread-20] UM.Backend.Backend._backendLog [101]: [Backend] GNU Affero General Public License for more details. 2019-04-19 17:20:13,606 - DEBUG - [Thread-20] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:20:13,652 - DEBUG - [Thread-20] UM.Backend.Backend._backendLog [101]: [Backend] You should have received a copy of the GNU Affero General Public License 2019-04-19 17:20:13,684 - DEBUG - [Thread-20] UM.Backend.Backend._backendLog [101]: [Backend] along with this program. If not, see <http://www.gnu.org/licenses/>. 2019-04-19 17:20:14,992 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onStartSliceCompleted [432]: Sending slice message took 2.202559471130371 seconds 2019-04-19 17:20:34,057 - DEBUG - [Thread-20] UM.Backend.Backend._backendLog [101]: [Backend] [ERROR] Could not connect to the given address 2019-04-19 17:20:34,068 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onBackendQuit [811]: Backend quit with return code 0. Resetting process and socket. 2019-04-19 17:22:05,995 - DEBUG - [MainThread] UM.Controller.setActiveStage [159]: Setting active stage to PreviewStage 2019-04-19 17:22:06,085 - DEBUG - [MainThread] UM.Controller.setActiveView [92]: Setting active view to SimulationView 2019-04-19 17:22:06,087 - INFO - [MainThread] STLReader.STLReader.load_file [46]: Using NumPy-STL to load STL data. 2019-04-19 17:22:06,094 - DEBUG - [MainThread] UM.Mesh.MeshData.calculateNormalsFromVertices [444]: Calculating normals took 0.0009989738464355469 seconds 2019-04-19 17:22:06,115 - DEBUG - [MainThread] UM.Mesh.MeshData.approximateConvexHull [401]: approximateConvexHull(target_count=1024) Calculating 3D convex hull took 0.014994144439697266 seconds. 351 input vertices. 351 output vertices. 2019-04-19 17:22:06,116 - DEBUG - [MainThread] STLReader.STLReader._read [97]: Loaded a mesh with 12612 vertices 2019-04-19 17:22:06,125 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\plugins\SimulationView\simulationview_composite.shader]... 2019-04-19 17:22:06,276 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/plugins/PreviewStage/PreviewMain.qml:22:5: QML ActionPanelWidget: Binding loop detected for property "width" 2019-04-19 17:22:06,656 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\color.shader]... 2019-04-19 17:22:06,670 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\plugins\SimulationView\layers.shader]... 2019-04-19 17:22:06,678 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\plugins\SimulationView\layers_shadow.shader]... 2019-04-19 17:22:06,686 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\toolhandle.shader]... 2019-04-19 17:22:06,693 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\color.shader]... 2019-04-19 17:22:07,236 - DEBUG - [MainThread] UM.Controller.setActiveStage [159]: Setting active stage to MonitorStage 2019-04-19 17:22:07,251 - DEBUG - [MainThread] UM.Controller.setActiveView [92]: Setting active view to SolidView 2019-04-19 17:22:09,556 - DEBUG - [MainThread] UM.Controller.setActiveStage [159]: Setting active stage to PrepareStage 2019-04-19 17:22:09,592 - DEBUG - [MainThread] cura.Machines.Models.NozzleModel._update [34]: Updating NozzleModel. 2019-04-19 17:22:09,705 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/plugins/PrepareStage/PrepareMain.qml:16:5: QML ActionPanelWidget: Binding loop detected for property "width" 2019-04-19 17:22:37,097 - DEBUG - [MainThread] cura.AutoSave._onTimeout [48]: Autosaving preferences, instances and profiles 2019-04-19 17:22:57,376 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._terminate [295]: Attempting to kill the engine process 2019-04-19 17:22:57,381 - DEBUG - [MainThread] UM.Backend.Backend._createSocket [227]: Previous socket existed. Closing that first. 2019-04-19 17:22:57,422 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [187]: Socket state changed to Listening 2019-04-19 17:22:57,436 - INFO - [MainThread] UM.Backend.Backend.startEngine [81]: Started engine process: C:\Program Files\Ultimaker Cura 4.0\CuraEngine.exe 2019-04-19 17:22:57,442 - DEBUG - [MainThread] UM.Backend.Backend._backendLog [101]: [Backend] Calling engine with: ['C:\\Program Files\\Ultimaker Cura 4.0\\CuraEngine.exe', 'connect', '127.0.0.1:49675', ''] 2019-04-19 17:22:57,507 - DEBUG - [Thread-23] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:22:57,507 - DEBUG - [Thread-23] UM.Backend.Backend._backendLog [101]: [Backend] Cura_SteamEngine version 4.0.0 2019-04-19 17:22:57,522 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._rescheduleCheck [136]: New error check scheduled. 2019-04-19 17:22:57,522 - DEBUG - [Thread-23] UM.Backend.Backend._backendLog [101]: [Backend] Copyright (C) 2018 Ultimaker 2019-04-19 17:22:57,537 - DEBUG - [Thread-23] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:22:57,544 - DEBUG - [Thread-23] UM.Backend.Backend._backendLog [101]: [Backend] This program is free software: you can redistribute it and/or modify 2019-04-19 17:22:57,544 - DEBUG - [Thread-23] UM.Backend.Backend._backendLog [101]: [Backend] it under the terms of the GNU Affero General Public License as published by 2019-04-19 17:22:57,559 - DEBUG - [Thread-23] UM.Backend.Backend._backendLog [101]: [Backend] the Free Software Foundation, either version 3 of the License, or 2019-04-19 17:22:57,559 - DEBUG - [Thread-23] UM.Backend.Backend._backendLog [101]: [Backend] (at your option) any later version. 2019-04-19 17:22:57,575 - DEBUG - [Thread-23] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:22:57,575 - DEBUG - [Thread-23] UM.Backend.Backend._backendLog [101]: [Backend] This program is distributed in the hope that it will be useful, 2019-04-19 17:22:57,575 - DEBUG - [Thread-23] UM.Backend.Backend._backendLog [101]: [Backend] but WITHOUT ANY WARRANTY; without even the implied warranty of 2019-04-19 17:22:57,591 - DEBUG - [Thread-23] UM.Backend.Backend._backendLog [101]: [Backend] MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the 2019-04-19 17:22:57,591 - DEBUG - [Thread-23] UM.Backend.Backend._backendLog [101]: [Backend] GNU Affero General Public License for more details. 2019-04-19 17:22:57,591 - DEBUG - [Thread-23] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:22:57,606 - DEBUG - [Thread-23] UM.Backend.Backend._backendLog [101]: [Backend] You should have received a copy of the GNU Affero General Public License 2019-04-19 17:22:57,606 - DEBUG - [Thread-23] UM.Backend.Backend._backendLog [101]: [Backend] along with this program. If not, see <http://www.gnu.org/licenses/>. 2019-04-19 17:22:57,755 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._checkStack [140]: Need to check for errors again. Discard the current progress and reschedule a check. 2019-04-19 17:22:57,883 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._rescheduleCheck [136]: New error check scheduled. 2019-04-19 17:22:58,722 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._checkStack [140]: Need to check for errors again. Discard the current progress and reschedule a check. 2019-04-19 17:22:58,877 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._rescheduleCheck [136]: New error check scheduled. 2019-04-19 17:22:59,858 - INFO - [MainThread] cura.Machines.MachineErrorChecker._setResult [188]: Error check finished, result = False, time = 1.0s 2019-04-19 17:23:02,384 - DEBUG - [MainThread] cura.AutoSave._onTimeout [48]: Autosaving preferences, instances and profiles 2019-04-19 17:23:08,684 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._rescheduleCheck [136]: New error check scheduled. 2019-04-19 17:23:09,744 - INFO - [MainThread] cura.Machines.MachineErrorChecker._setResult [188]: Error check finished, result = False, time = 1.0s 2019-04-19 17:23:10,209 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._rescheduleCheck [136]: New error check scheduled. 2019-04-19 17:23:11,190 - INFO - [MainThread] cura.Machines.MachineErrorChecker._setResult [188]: Error check finished, result = False, time = 1.0s 2019-04-19 17:23:18,528 - DEBUG - [Thread-23] UM.Backend.Backend._backendLog [101]: [Backend] [ERROR] Could not connect to the given address 2019-04-19 17:23:18,560 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onBackendQuit [811]: Backend quit with return code 0. Resetting process and socket. 2019-04-19 17:23:25,376 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend.slice [228]: Starting to slice... 2019-04-19 17:23:25,377 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend.slice [246]: Going to slice build plate [0]! 2019-04-19 17:23:25,382 - DEBUG - [MainThread] UM.Backend.Backend._createSocket [227]: Previous socket existed. Closing that first. 2019-04-19 17:23:26,247 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [187]: Socket state changed to Listening 2019-04-19 17:23:26,309 - INFO - [MainThread] UM.Backend.Backend.startEngine [81]: Started engine process: C:\Program Files\Ultimaker Cura 4.0\CuraEngine.exe 2019-04-19 17:23:26,356 - DEBUG - [MainThread] UM.Backend.Backend._backendLog [101]: [Backend] Calling engine with: ['C:\\Program Files\\Ultimaker Cura 4.0\\CuraEngine.exe', 'connect', '127.0.0.1:49675', ''] 2019-04-19 17:23:26,387 - DEBUG - [Thread-26] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:23:26,450 - DEBUG - [Thread-26] UM.Backend.Backend._backendLog [101]: [Backend] Cura_SteamEngine version 4.0.0 2019-04-19 17:23:26,575 - DEBUG - [Thread-26] UM.Backend.Backend._backendLog [101]: [Backend] Copyright (C) 2018 Ultimaker 2019-04-19 17:23:26,775 - DEBUG - [Thread-26] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:23:26,781 - DEBUG - [Thread-26] UM.Backend.Backend._backendLog [101]: [Backend] This program is free software: you can redistribute it and/or modify 2019-04-19 17:23:26,786 - DEBUG - [Thread-26] UM.Backend.Backend._backendLog [101]: [Backend] it under the terms of the GNU Affero General Public License as published by 2019-04-19 17:23:26,792 - DEBUG - [Thread-26] UM.Backend.Backend._backendLog [101]: [Backend] the Free Software Foundation, either version 3 of the License, or 2019-04-19 17:23:26,797 - DEBUG - [Thread-26] UM.Backend.Backend._backendLog [101]: [Backend] (at your option) any later version. 2019-04-19 17:23:26,802 - DEBUG - [Thread-26] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:23:26,808 - DEBUG - [Thread-26] UM.Backend.Backend._backendLog [101]: [Backend] This program is distributed in the hope that it will be useful, 2019-04-19 17:23:26,813 - DEBUG - [Thread-26] UM.Backend.Backend._backendLog [101]: [Backend] but WITHOUT ANY WARRANTY; without even the implied warranty of 2019-04-19 17:23:26,819 - DEBUG - [Thread-26] UM.Backend.Backend._backendLog [101]: [Backend] MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the 2019-04-19 17:23:26,825 - DEBUG - [Thread-26] UM.Backend.Backend._backendLog [101]: [Backend] GNU Affero General Public License for more details. 2019-04-19 17:23:26,831 - DEBUG - [Thread-26] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:23:26,836 - DEBUG - [Thread-26] UM.Backend.Backend._backendLog [101]: [Backend] You should have received a copy of the GNU Affero General Public License 2019-04-19 17:23:26,842 - DEBUG - [Thread-26] UM.Backend.Backend._backendLog [101]: [Backend] along with this program. If not, see <http://www.gnu.org/licenses/>. 2019-04-19 17:23:27,315 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onStartSliceCompleted [432]: Sending slice message took 1.9387853145599365 seconds 2019-04-19 17:23:32,197 - DEBUG - [MainThread] cura.AutoSave._onTimeout [48]: Autosaving preferences, instances and profiles 2019-04-19 17:23:47,399 - DEBUG - [Thread-26] UM.Backend.Backend._backendLog [101]: [Backend] [ERROR] Could not connect to the given address 2019-04-19 17:23:47,430 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onBackendQuit [811]: Backend quit with return code 0. Resetting process and socket. 2019-04-19 17:24:58,931 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._terminate [295]: Attempting to kill the engine process 2019-04-19 17:24:58,936 - DEBUG - [MainThread] UM.Backend.Backend._createSocket [227]: Previous socket existed. Closing that first. 2019-04-19 17:24:58,974 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [187]: Socket state changed to Listening 2019-04-19 17:24:58,988 - INFO - [MainThread] UM.Backend.Backend.startEngine [81]: Started engine process: C:\Program Files\Ultimaker Cura 4.0\CuraEngine.exe 2019-04-19 17:24:58,994 - DEBUG - [MainThread] UM.Backend.Backend._backendLog [101]: [Backend] Calling engine with: ['C:\\Program Files\\Ultimaker Cura 4.0\\CuraEngine.exe', 'connect', '127.0.0.1:49675', ''] 2019-04-19 17:24:59,233 - DEBUG - [Thread-29] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:24:59,238 - DEBUG - [Thread-29] UM.Backend.Backend._backendLog [101]: [Backend] Cura_SteamEngine version 4.0.0 2019-04-19 17:24:59,244 - DEBUG - [Thread-29] UM.Backend.Backend._backendLog [101]: [Backend] Copyright (C) 2018 Ultimaker 2019-04-19 17:24:59,249 - DEBUG - [Thread-29] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:24:59,255 - DEBUG - [Thread-29] UM.Backend.Backend._backendLog [101]: [Backend] This program is free software: you can redistribute it and/or modify 2019-04-19 17:24:59,260 - DEBUG - [Thread-29] UM.Backend.Backend._backendLog [101]: [Backend] it under the terms of the GNU Affero General Public License as published by 2019-04-19 17:24:59,266 - DEBUG - [Thread-29] UM.Backend.Backend._backendLog [101]: [Backend] the Free Software Foundation, either version 3 of the License, or 2019-04-19 17:24:59,271 - DEBUG - [Thread-29] UM.Backend.Backend._backendLog [101]: [Backend] (at your option) any later version. 2019-04-19 17:24:59,276 - DEBUG - [Thread-29] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:24:59,281 - DEBUG - [Thread-29] UM.Backend.Backend._backendLog [101]: [Backend] This program is distributed in the hope that it will be useful, 2019-04-19 17:24:59,285 - DEBUG - [Thread-29] UM.Backend.Backend._backendLog [101]: [Backend] but WITHOUT ANY WARRANTY; without even the implied warranty of 2019-04-19 17:24:59,290 - DEBUG - [Thread-29] UM.Backend.Backend._backendLog [101]: [Backend] MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the 2019-04-19 17:24:59,295 - DEBUG - [Thread-29] UM.Backend.Backend._backendLog [101]: [Backend] GNU Affero General Public License for more details. 2019-04-19 17:24:59,300 - DEBUG - [Thread-29] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:24:59,305 - DEBUG - [Thread-29] UM.Backend.Backend._backendLog [101]: [Backend] You should have received a copy of the GNU Affero General Public License 2019-04-19 17:24:59,310 - DEBUG - [Thread-29] UM.Backend.Backend._backendLog [101]: [Backend] along with this program. If not, see <http://www.gnu.org/licenses/>. 2019-04-19 17:25:02,207 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend.slice [228]: Starting to slice... 2019-04-19 17:25:02,208 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend.slice [246]: Going to slice build plate [0]! 2019-04-19 17:25:04,511 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onStartSliceCompleted [432]: Sending slice message took 2.3029661178588867 seconds 2019-04-19 17:25:20,254 - DEBUG - [Thread-29] UM.Backend.Backend._backendLog [101]: [Backend] [ERROR] Could not connect to the given address 2019-04-19 17:25:20,332 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onBackendQuit [811]: Backend quit with return code 0. Resetting process and socket. 2019-04-19 17:29:36,760 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._terminate [295]: Attempting to kill the engine process 2019-04-19 17:29:36,765 - DEBUG - [MainThread] UM.Backend.Backend._createSocket [227]: Previous socket existed. Closing that first. 2019-04-19 17:29:36,799 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [187]: Socket state changed to Listening 2019-04-19 17:29:36,815 - INFO - [MainThread] UM.Backend.Backend.startEngine [81]: Started engine process: C:\Program Files\Ultimaker Cura 4.0\CuraEngine.exe 2019-04-19 17:29:36,821 - DEBUG - [MainThread] UM.Backend.Backend._backendLog [101]: [Backend] Calling engine with: ['C:\\Program Files\\Ultimaker Cura 4.0\\CuraEngine.exe', 'connect', '127.0.0.1:49675', ''] 2019-04-19 17:29:36,896 - DEBUG - [Thread-32] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:29:36,901 - DEBUG - [Thread-32] UM.Backend.Backend._backendLog [101]: [Backend] Cura_SteamEngine version 4.0.0 2019-04-19 17:29:36,905 - DEBUG - [Thread-32] UM.Backend.Backend._backendLog [101]: [Backend] Copyright (C) 2018 Ultimaker 2019-04-19 17:29:36,911 - DEBUG - [Thread-32] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:29:36,916 - DEBUG - [Thread-32] UM.Backend.Backend._backendLog [101]: [Backend] This program is free software: you can redistribute it and/or modify 2019-04-19 17:29:36,921 - DEBUG - [Thread-32] UM.Backend.Backend._backendLog [101]: [Backend] it under the terms of the GNU Affero General Public License as published by 2019-04-19 17:29:36,925 - DEBUG - [Thread-32] UM.Backend.Backend._backendLog [101]: [Backend] the Free Software Foundation, either version 3 of the License, or 2019-04-19 17:29:36,930 - DEBUG - [Thread-32] UM.Backend.Backend._backendLog [101]: [Backend] (at your option) any later version. 2019-04-19 17:29:36,950 - DEBUG - [Thread-32] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:29:36,958 - DEBUG - [Thread-32] UM.Backend.Backend._backendLog [101]: [Backend] This program is distributed in the hope that it will be useful, 2019-04-19 17:29:36,964 - DEBUG - [Thread-32] UM.Backend.Backend._backendLog [101]: [Backend] but WITHOUT ANY WARRANTY; without even the implied warranty of 2019-04-19 17:29:36,970 - DEBUG - [Thread-32] UM.Backend.Backend._backendLog [101]: [Backend] MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the 2019-04-19 17:29:36,979 - DEBUG - [Thread-32] UM.Backend.Backend._backendLog [101]: [Backend] GNU Affero General Public License for more details. 2019-04-19 17:29:36,988 - DEBUG - [Thread-32] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:29:36,994 - DEBUG - [Thread-32] UM.Backend.Backend._backendLog [101]: [Backend] You should have received a copy of the GNU Affero General Public License 2019-04-19 17:29:37,000 - DEBUG - [Thread-32] UM.Backend.Backend._backendLog [101]: [Backend] along with this program. If not, see <http://www.gnu.org/licenses/>. 2019-04-19 17:29:57,904 - DEBUG - [Thread-32] UM.Backend.Backend._backendLog [101]: [Backend] [ERROR] Could not connect to the given address 2019-04-19 17:29:57,983 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onBackendQuit [811]: Backend quit with return code 0. Resetting process and socket. 2019-04-19 17:30:11,386 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend.slice [228]: Starting to slice... 2019-04-19 17:30:11,386 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend.slice [246]: Going to slice build plate [0]! 2019-04-19 17:30:11,392 - DEBUG - [MainThread] UM.Backend.Backend._createSocket [227]: Previous socket existed. Closing that first. 2019-04-19 17:30:11,448 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [187]: Socket state changed to Listening 2019-04-19 17:30:11,535 - INFO - [MainThread] UM.Backend.Backend.startEngine [81]: Started engine process: C:\Program Files\Ultimaker Cura 4.0\CuraEngine.exe 2019-04-19 17:30:11,543 - DEBUG - [MainThread] UM.Backend.Backend._backendLog [101]: [Backend] Calling engine with: ['C:\\Program Files\\Ultimaker Cura 4.0\\CuraEngine.exe', 'connect', '127.0.0.1:49675', ''] 2019-04-19 17:30:11,599 - DEBUG - [Thread-35] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:30:11,695 - DEBUG - [Thread-35] UM.Backend.Backend._backendLog [101]: [Backend] Cura_SteamEngine version 4.0.0 2019-04-19 17:30:11,702 - DEBUG - [Thread-35] UM.Backend.Backend._backendLog [101]: [Backend] Copyright (C) 2018 Ultimaker 2019-04-19 17:30:11,710 - DEBUG - [Thread-35] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:30:11,720 - DEBUG - [Thread-35] UM.Backend.Backend._backendLog [101]: [Backend] This program is free software: you can redistribute it and/or modify 2019-04-19 17:30:11,731 - DEBUG - [Thread-35] UM.Backend.Backend._backendLog [101]: [Backend] it under the terms of the GNU Affero General Public License as published by 2019-04-19 17:30:11,941 - DEBUG - [Thread-35] UM.Backend.Backend._backendLog [101]: [Backend] the Free Software Foundation, either version 3 of the License, or 2019-04-19 17:30:11,955 - DEBUG - [Thread-35] UM.Backend.Backend._backendLog [101]: [Backend] (at your option) any later version. 2019-04-19 17:30:11,976 - DEBUG - [Thread-35] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:30:11,983 - DEBUG - [Thread-35] UM.Backend.Backend._backendLog [101]: [Backend] This program is distributed in the hope that it will be useful, 2019-04-19 17:30:11,997 - DEBUG - [Thread-35] UM.Backend.Backend._backendLog [101]: [Backend] but WITHOUT ANY WARRANTY; without even the implied warranty of 2019-04-19 17:30:12,013 - DEBUG - [Thread-35] UM.Backend.Backend._backendLog [101]: [Backend] MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the 2019-04-19 17:30:12,018 - DEBUG - [Thread-35] UM.Backend.Backend._backendLog [101]: [Backend] GNU Affero General Public License for more details. 2019-04-19 17:30:12,023 - DEBUG - [Thread-35] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:30:12,032 - DEBUG - [Thread-35] UM.Backend.Backend._backendLog [101]: [Backend] You should have received a copy of the GNU Affero General Public License 2019-04-19 17:30:12,042 - DEBUG - [Thread-35] UM.Backend.Backend._backendLog [101]: [Backend] along with this program. If not, see <http://www.gnu.org/licenses/>. 2019-04-19 17:30:13,580 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onStartSliceCompleted [432]: Sending slice message took 2.19296932220459 seconds 2019-04-19 17:30:13,974 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._terminate [295]: Attempting to kill the engine process 2019-04-19 17:30:13,974 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._terminate [301]: Killing engine process 2019-04-19 17:30:13,982 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._terminate [304]: Engine process is killed. Received return code 1 2019-04-19 17:30:13,988 - DEBUG - [MainThread] UM.Backend.Backend._createSocket [227]: Previous socket existed. Closing that first. 2019-04-19 17:30:14,011 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [187]: Socket state changed to Listening 2019-04-19 17:30:14,025 - INFO - [MainThread] UM.Backend.Backend.startEngine [81]: Started engine process: C:\Program Files\Ultimaker Cura 4.0\CuraEngine.exe 2019-04-19 17:30:14,030 - DEBUG - [MainThread] UM.Backend.Backend._backendLog [101]: [Backend] Calling engine with: ['C:\\Program Files\\Ultimaker Cura 4.0\\CuraEngine.exe', 'connect', '127.0.0.1:49675', ''] 2019-04-19 17:30:14,099 - DEBUG - [Thread-38] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:30:14,104 - DEBUG - [Thread-38] UM.Backend.Backend._backendLog [101]: [Backend] Cura_SteamEngine version 4.0.0 2019-04-19 17:30:14,108 - DEBUG - [Thread-38] UM.Backend.Backend._backendLog [101]: [Backend] Copyright (C) 2018 Ultimaker 2019-04-19 17:30:14,113 - DEBUG - [Thread-38] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:30:14,118 - DEBUG - [Thread-38] UM.Backend.Backend._backendLog [101]: [Backend] This program is free software: you can redistribute it and/or modify 2019-04-19 17:30:14,122 - DEBUG - [Thread-38] UM.Backend.Backend._backendLog [101]: [Backend] it under the terms of the GNU Affero General Public License as published by 2019-04-19 17:30:14,127 - DEBUG - [Thread-38] UM.Backend.Backend._backendLog [101]: [Backend] the Free Software Foundation, either version 3 of the License, or 2019-04-19 17:30:14,131 - DEBUG - [Thread-38] UM.Backend.Backend._backendLog [101]: [Backend] (at your option) any later version. 2019-04-19 17:30:14,136 - DEBUG - [Thread-38] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:30:14,141 - DEBUG - [Thread-38] UM.Backend.Backend._backendLog [101]: [Backend] This program is distributed in the hope that it will be useful, 2019-04-19 17:30:14,145 - DEBUG - [Thread-38] UM.Backend.Backend._backendLog [101]: [Backend] but WITHOUT ANY WARRANTY; without even the implied warranty of 2019-04-19 17:30:14,150 - DEBUG - [Thread-38] UM.Backend.Backend._backendLog [101]: [Backend] MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the 2019-04-19 17:30:14,155 - DEBUG - [Thread-38] UM.Backend.Backend._backendLog [101]: [Backend] GNU Affero General Public License for more details. 2019-04-19 17:30:14,159 - DEBUG - [Thread-38] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:30:14,164 - DEBUG - [Thread-38] UM.Backend.Backend._backendLog [101]: [Backend] You should have received a copy of the GNU Affero General Public License 2019-04-19 17:30:14,169 - DEBUG - [Thread-38] UM.Backend.Backend._backendLog [101]: [Backend] along with this program. If not, see <http://www.gnu.org/licenses/>. 2019-04-19 17:30:14,642 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend.slice [228]: Starting to slice... 2019-04-19 17:30:14,643 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend.slice [246]: Going to slice build plate [0]! 2019-04-19 17:30:16,551 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onStartSliceCompleted [432]: Sending slice message took 1.906975507736206 seconds 2019-04-19 17:30:32,310 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._terminate [295]: Attempting to kill the engine process 2019-04-19 17:30:32,312 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._terminate [301]: Killing engine process 2019-04-19 17:30:32,317 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._terminate [304]: Engine process is killed. Received return code 1 2019-04-19 17:30:32,323 - DEBUG - [MainThread] UM.Backend.Backend._createSocket [227]: Previous socket existed. Closing that first. 2019-04-19 17:30:32,346 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [187]: Socket state changed to Listening 2019-04-19 17:30:32,362 - INFO - [MainThread] UM.Backend.Backend.startEngine [81]: Started engine process: C:\Program Files\Ultimaker Cura 4.0\CuraEngine.exe 2019-04-19 17:30:32,367 - DEBUG - [MainThread] UM.Backend.Backend._backendLog [101]: [Backend] Calling engine with: ['C:\\Program Files\\Ultimaker Cura 4.0\\CuraEngine.exe', 'connect', '127.0.0.1:49675', ''] 2019-04-19 17:30:32,437 - DEBUG - [Thread-41] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:30:32,442 - DEBUG - [Thread-41] UM.Backend.Backend._backendLog [101]: [Backend] Cura_SteamEngine version 4.0.0 2019-04-19 17:30:32,447 - DEBUG - [Thread-41] UM.Backend.Backend._backendLog [101]: [Backend] Copyright (C) 2018 Ultimaker 2019-04-19 17:30:32,451 - DEBUG - [Thread-41] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:30:32,456 - DEBUG - [Thread-41] UM.Backend.Backend._backendLog [101]: [Backend] This program is free software: you can redistribute it and/or modify 2019-04-19 17:30:32,460 - DEBUG - [Thread-41] UM.Backend.Backend._backendLog [101]: [Backend] it under the terms of the GNU Affero General Public License as published by 2019-04-19 17:30:32,465 - DEBUG - [Thread-41] UM.Backend.Backend._backendLog [101]: [Backend] the Free Software Foundation, either version 3 of the License, or 2019-04-19 17:30:32,470 - DEBUG - [Thread-41] UM.Backend.Backend._backendLog [101]: [Backend] (at your option) any later version. 2019-04-19 17:30:32,474 - DEBUG - [Thread-41] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:30:32,479 - DEBUG - [Thread-41] UM.Backend.Backend._backendLog [101]: [Backend] This program is distributed in the hope that it will be useful, 2019-04-19 17:30:32,484 - DEBUG - [Thread-41] UM.Backend.Backend._backendLog [101]: [Backend] but WITHOUT ANY WARRANTY; without even the implied warranty of 2019-04-19 17:30:32,489 - DEBUG - [Thread-41] UM.Backend.Backend._backendLog [101]: [Backend] MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the 2019-04-19 17:30:32,493 - DEBUG - [Thread-41] UM.Backend.Backend._backendLog [101]: [Backend] GNU Affero General Public License for more details. 2019-04-19 17:30:32,498 - DEBUG - [Thread-41] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:30:32,502 - DEBUG - [Thread-41] UM.Backend.Backend._backendLog [101]: [Backend] You should have received a copy of the GNU Affero General Public License 2019-04-19 17:30:32,507 - DEBUG - [Thread-41] UM.Backend.Backend._backendLog [101]: [Backend] along with this program. If not, see <http://www.gnu.org/licenses/>. 2019-04-19 17:30:33,328 - DEBUG - [MainThread] cura.TaskManagement.OnExitCallbackManager.triggerNextCallback [51]: No more on-app-exit callbacks to process. Tell the app to exit. 2019-04-19 17:30:33,333 - INFO - [MainThread] cura.CuraApplication.closeApplication [547]: Close application 2019-04-19 17:30:33,355 - DEBUG - [MainThread] UM.Qt.QtApplication.windowClosed [417]: Shutting down cura 2019-04-19 17:30:33,448 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._terminate [295]: Attempting to kill the engine process 2019-04-19 17:30:33,449 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._terminate [301]: Killing engine process 2019-04-19 17:30:33,460 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._terminate [304]: Engine process is killed. Received return code 1 2019-04-19 17:30:50,531 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin FileLogger 2019-04-19 17:30:50,561 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin FirmwareUpdateChecker 2019-04-19 17:30:50,588 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin FirmwareUpdater 2019-04-19 17:30:50,617 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin GCodeGzReader 2019-04-19 17:30:50,644 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin GCodeGzWriter 2019-04-19 17:30:50,673 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin GCodeProfileReader 2019-04-19 17:30:50,720 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin GCodeReader 2019-04-19 17:30:50,747 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin GCodeWriter 2019-04-19 17:30:50,774 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin ImageReader 2019-04-19 17:30:50,798 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin LegacyProfileReader 2019-04-19 17:30:50,821 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin LocalContainerProvider 2019-04-19 17:30:50,851 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin LocalFileOutputDevice 2019-04-19 17:30:50,877 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin MachineSettingsAction 2019-04-19 17:30:50,903 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin ModelChecker 2019-04-19 17:30:50,937 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin MonitorStage 2019-04-19 17:30:50,981 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin PerObjectSettingsTool 2019-04-19 17:30:51,025 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin PostProcessingPlugin 2019-04-19 17:30:51,057 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin PrepareStage 2019-04-19 17:30:51,090 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin PreviewStage 2019-04-19 17:30:51,126 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin RemovableDriveOutputDevice 2019-04-19 17:30:51,165 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin SimulationView 2019-04-19 17:30:51,193 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin SliceInfoPlugin 2019-04-19 17:30:51,219 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin SolidView 2019-04-19 17:30:51,247 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin SupportEraser 2019-04-19 17:30:51,289 - DEBUG - [MainThread] cura.OAuth2.AuthorizationService.getAccessToken [106]: No auth data to retrieve the access_token from 2019-04-19 17:30:51,297 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin Toolbox 2019-04-19 17:30:51,329 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin CameraTool 2019-04-19 17:30:51,362 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin MirrorTool 2019-04-19 17:30:51,401 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin RotateTool 2019-04-19 17:30:51,441 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin ScaleTool 2019-04-19 17:30:51,471 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin SelectionTool 2019-04-19 17:30:51,506 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin TranslateTool 2019-04-19 17:30:51,563 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin UFPWriter 2019-04-19 17:30:51,600 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin UltimakerMachineActions 2019-04-19 17:30:51,788 - DEBUG - [MainThread] UM3NetworkPrinting.src.Cloud.CloudOutputDeviceManager._onLoginStateChanged [57]: Log in state changed to False 2019-04-19 17:30:51,789 - DEBUG - [MainThread] UM3NetworkPrinting.src.Cloud.CloudOutputDeviceManager._onGetRemoteClustersFinished [80]: Parsed remote clusters to [] 2019-04-19 17:30:51,789 - DEBUG - [MainThread] UM3NetworkPrinting.src.Cloud.CloudOutputDeviceManager._onGetRemoteClustersFinished [81]: Removed: 0, added: 0, updates: 0 2019-04-19 17:30:51,796 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin UM3NetworkPrinting 2019-04-19 17:30:51,852 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin UpdateChecker 2019-04-19 17:30:51,864 - INFO - [Thread-2] UpdateChecker.UpdateCheckerJob.run [36]: Checking for new version of cura 2019-04-19 17:30:51,936 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin USBPrinting 2019-04-19 17:30:51,991 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin UserAgreement 2019-04-19 17:30:52,042 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade21to22 2019-04-19 17:30:52,077 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade22to24 2019-04-19 17:30:52,111 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade25to26 2019-04-19 17:30:52,147 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade26to27 2019-04-19 17:30:52,181 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade27to30 2019-04-19 17:30:52,216 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade30to31 2019-04-19 17:30:52,251 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade32to33 2019-04-19 17:30:52,289 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade33to34 2019-04-19 17:30:52,323 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade34to35 2019-04-19 17:30:52,362 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade35to40 2019-04-19 17:30:52,399 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin SimpleView 2019-04-19 17:30:52,437 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin X3DReader 2019-04-19 17:30:52,479 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin XmlMaterialProfile 2019-04-19 17:30:52,518 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin XRayView 2019-04-19 17:30:52,557 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin CustomSupports 2019-04-19 17:30:52,599 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin OrientationPlugin 2019-04-19 17:30:52,628 - INFO - [MainThread] UM.VersionUpgradeManager.upgrade [143]: Looking for old configuration files to upgrade. 2019-04-19 17:30:52,683 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\packages.json, skip it 2019-04-19 17:30:52,690 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\plugins.json, skip it 2019-04-19 17:30:52,724 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\packages.json, skip it 2019-04-19 17:30:52,729 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\plugins.json, skip it 2019-04-19 17:30:52,774 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\packages.json, skip it 2019-04-19 17:30:52,781 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\plugins.json, skip it 2019-04-19 17:30:52,815 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\packages.json, skip it 2019-04-19 17:30:52,820 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\plugins.json, skip it 2019-04-19 17:30:52,855 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\packages.json, skip it 2019-04-19 17:30:52,862 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\plugins.json, skip it 2019-04-19 17:30:52,898 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\packages.json, skip it 2019-04-19 17:30:52,904 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\plugins.json, skip it 2019-04-19 17:30:52,945 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\packages.json, skip it 2019-04-19 17:30:52,954 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\plugins.json, skip it 2019-04-19 17:30:53,002 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\packages.json, skip it 2019-04-19 17:30:53,009 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\plugins.json, skip it 2019-04-19 17:30:53,111 - DEBUG - [MainThread] UM.Backend.Backend._onSocketError [213]: Socket was unable to bind to port, increasing port number to 49675 2019-04-19 17:30:53,116 - DEBUG - [MainThread] UM.Backend.Backend._createSocket [227]: Previous socket existed. Closing that first. 2019-04-19 17:30:53,119 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._terminate [295]: Attempting to kill the engine process 2019-04-19 17:30:53,124 - DEBUG - [MainThread] UM.Backend.Backend._createSocket [227]: Previous socket existed. Closing that first. 2019-04-19 17:30:53,341 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [187]: Socket state changed to Listening 2019-04-19 17:30:53,356 - INFO - [MainThread] UM.Backend.Backend.startEngine [81]: Started engine process: C:\Program Files\Ultimaker Cura 4.0\CuraEngine.exe 2019-04-19 17:30:53,361 - DEBUG - [MainThread] UM.Backend.Backend._backendLog [101]: [Backend] Calling engine with: ['C:\\Program Files\\Ultimaker Cura 4.0\\CuraEngine.exe', 'connect', '127.0.0.1:49675', ''] 2019-04-19 17:30:53,424 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:30:53,430 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] Cura_SteamEngine version 4.0.0 2019-04-19 17:30:53,435 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] Copyright (C) 2018 Ultimaker 2019-04-19 17:30:53,441 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:30:53,446 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] This program is free software: you can redistribute it and/or modify 2019-04-19 17:30:53,451 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] it under the terms of the GNU Affero General Public License as published by 2019-04-19 17:30:53,456 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] the Free Software Foundation, either version 3 of the License, or 2019-04-19 17:30:53,462 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] (at your option) any later version. 2019-04-19 17:30:53,469 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:30:53,475 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] This program is distributed in the hope that it will be useful, 2019-04-19 17:30:53,481 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] but WITHOUT ANY WARRANTY; without even the implied warranty of 2019-04-19 17:30:53,486 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the 2019-04-19 17:30:53,490 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] GNU Affero General Public License for more details. 2019-04-19 17:30:53,496 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:30:53,501 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] You should have received a copy of the GNU Affero General Public License 2019-04-19 17:30:53,507 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] along with this program. If not, see <http://www.gnu.org/licenses/>. 2019-04-19 17:30:57,467 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.loadAllMetadata [338]: Loading metadata into container registry took 4.09795880317688 seconds 2019-04-19 17:30:57,617 - DEBUG - [MainThread] cura.Scene.CuraSceneController.setActiveBuildPlate [104]: Select build plate: 0 2019-04-19 17:30:57,622 - INFO - [MainThread] cura.CuraApplication.run [695]: Initializing variant manager 2019-04-19 17:30:57,629 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container ultimaker_s5_glass 2019-04-19 17:30:57,637 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [ultimaker_s5_glass] added. 2019-04-19 17:30:57,639 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container ultimaker_s5 2019-04-19 17:30:57,838 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [ultimaker_s5] added. 2019-04-19 17:30:57,846 - DEBUG - [MainThread] cura.Machines.VariantManager.initialize [59]: Exclude variant [empty_variant] 2019-04-19 17:30:57,848 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container ultimaker_s5_aluminum 2019-04-19 17:30:57,857 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [ultimaker_s5_aluminum] added. 2019-04-19 17:30:57,866 - INFO - [MainThread] cura.CuraApplication.run [699]: Initializing material manager 2019-04-19 17:30:57,976 - INFO - [MainThread] cura.CuraApplication.run [704]: Initializing quality manager 2019-04-19 17:30:58,000 - DEBUG - [MainThread] cura.Machines.QualityManager.initialize [136]: Lookup tables updated. 2019-04-19 17:30:58,005 - INFO - [MainThread] cura.CuraApplication.run [709]: Initializing machine manager 2019-04-19 17:30:58,010 - INFO - [MainThread] cura.CuraApplication.run [712]: Initializing container manager 2019-04-19 17:30:58,015 - INFO - [MainThread] cura.CuraApplication.run [715]: Initializing machine error checker 2019-04-19 17:30:58,047 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container Creality CR-10 2019-04-19 17:30:58,052 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container Creality CR-10_user 2019-04-19 17:30:58,061 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [Creality CR-10_user] added. 2019-04-19 17:30:58,062 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container creality_cr10_pla 2019-04-19 17:30:58,070 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [creality_cr10_pla] added. 2019-04-19 17:30:58,072 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container draft 2019-04-19 17:30:58,080 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [draft] added. 2019-04-19 17:30:58,082 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container Creality CR-10_settings 2019-04-19 17:30:58,090 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [Creality CR-10_settings] added. 2019-04-19 17:30:58,092 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container creality_cr10 2019-04-19 17:30:58,169 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [creality_cr10] added. 2019-04-19 17:30:58,174 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [Creality CR-10] added. 2019-04-19 17:30:58,179 - INFO - [MainThread] cura.MachineActionManager.addDefaultMachineActions [72]: Default machine actions added for machine definition [creality_cr10] 2019-04-19 17:30:58,186 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container creality_cr10_extruder_0 #2 2019-04-19 17:30:58,191 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container creality_cr10_extruder_0 #2_user 2019-04-19 17:30:58,200 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [creality_cr10_extruder_0 #2_user] added. 2019-04-19 17:30:58,202 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container creality_cr10_extruder_0_pla 2019-04-19 17:30:58,213 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [creality_cr10_extruder_0_pla] added. 2019-04-19 17:30:58,216 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container generic_pla_175 2019-04-19 17:30:58,230 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [generic_pla_175_imade3d_jellybox] added. 2019-04-19 17:30:58,235 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [generic_pla_175_imade3d_jellybox_0.4_mm] added. 2019-04-19 17:30:58,240 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [generic_pla_175_imade3d_jellybox_0.4_mm_2-fans] added. 2019-04-19 17:30:58,246 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [generic_pla_175_cartesio] added. 2019-04-19 17:30:58,251 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [generic_pla_175_cartesio_0.25mm_thermoplastic_extruder] added. 2019-04-19 17:30:58,257 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [generic_pla_175_cartesio_0.4mm_thermoplastic_extruder] added. 2019-04-19 17:30:58,263 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [generic_pla_175_cartesio_0.8mm_thermoplastic_extruder] added. 2019-04-19 17:30:58,268 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [generic_pla_175] added. 2019-04-19 17:30:58,270 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container creality_cr10_extruder_0 #2_settings 2019-04-19 17:30:58,283 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [creality_cr10_extruder_0 #2_settings] added. 2019-04-19 17:30:58,284 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container creality_cr10_extruder_0 2019-04-19 17:30:58,292 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [creality_cr10_extruder_0] added. 2019-04-19 17:30:58,297 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [creality_cr10_extruder_0 #2] added. 2019-04-19 17:30:58,324 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container fdmprinter 2019-04-19 17:30:58,405 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [fdmprinter] added. 2019-04-19 17:30:58,724 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [170]: Begin loading of script: BQ_PauseAtHeight 2019-04-19 17:30:58,726 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [170]: Begin loading of script: ChangeAtZ 2019-04-19 17:30:58,728 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [170]: Begin loading of script: DisplayFilenameAndLayerOnLCD 2019-04-19 17:30:58,730 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [170]: Begin loading of script: FilamentChange 2019-04-19 17:30:58,732 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [170]: Begin loading of script: PauseAtHeight 2019-04-19 17:30:58,735 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [170]: Begin loading of script: PauseAtHeightRepRapFirmwareDuet 2019-04-19 17:30:58,737 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [170]: Begin loading of script: PauseAtHeightforRepetier 2019-04-19 17:30:58,738 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [170]: Begin loading of script: SearchAndReplace 2019-04-19 17:30:58,741 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [170]: Begin loading of script: Stretch 2019-04-19 17:30:58,744 - DEBUG - [MainThread] UM3NetworkPrinting.src.UM3OutputDevicePlugin.checkCloudFlowIsPossible [412]: Checking if cloud connection is possible... 2019-04-19 17:30:58,745 - DEBUG - [MainThread] UM3NetworkPrinting.src.UM3OutputDevicePlugin.checkCloudFlowIsPossible [435]: Cloud Flow not possible: User not logged in! 2019-04-19 17:30:59,009 - INFO - [MainThread] cura.Settings.GlobalStack.addExtruder [136]: Extruder[creality_cr10_extruder_0 #2] added to [Creality CR-10] at position [0] 2019-04-19 17:30:59,014 - WARNING - [MainThread] cura.Settings.ExtruderManager.registerExtruder [169]: Extruder [creality_cr10_extruder_0 #2] has already been registered on machine [Creality CR-10], not doing anything 2019-04-19 17:30:59,024 - INFO - [MainThread] cura.Settings.MachineManager._initMachineState [330]: Machine 'Creality CR-10' quality changes set to 'PLA #2' 2019-04-19 17:30:59,376 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._rescheduleCheck [136]: New error check scheduled. 2019-04-19 17:30:59,378 - INFO - [MainThread] FirmwareUpdateChecker.FirmwareUpdateChecker.checkFirmwareVersion [76]: No machine with name Creality CR-10 in list of firmware to check. 2019-04-19 17:31:01,130 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin._createView [280]: Creating post processing plugin view. 2019-04-19 17:31:01,384 - DEBUG - [MainThread] UM.Qt.Bindings.Theme.load [158]: Loading theme file: C:\Program Files\Ultimaker Cura 4.0\resources\themes\cura-light\theme.json 2019-04-19 17:31:01,536 - DEBUG - [MainThread] UM.Qt.Bindings.Theme.load [230]: Loaded theme C:\Program Files\Ultimaker Cura 4.0\resources\themes\cura-light 2019-04-19 17:31:01,628 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin._createView [290]: Post processing view created. 2019-04-19 17:31:01,903 - WARNING - [MainThread] UM.Qt.Bindings.Theme.getImage [133]: No image header_pattern defined in Theme 2019-04-19 17:31:01,921 - DEBUG - [MainThread] cura.Machines.Models.BuildPlateModel._update [33]: Updating BuildPlateModel. 2019-04-19 17:31:03,176 - DEBUG - [MainThread] cura.Machines.Models.NozzleModel._update [34]: Updating NozzleModel. 2019-04-19 17:31:03,462 - DEBUG - [MainThread] UM3NetworkPrinting.src.DiscoverUM3Action._createAdditionalComponentsView [196]: Creating additional ui components for UM3. 2019-04-19 17:31:03,523 - DEBUG - [MainThread] UM3NetworkPrinting.src.DiscoverUM3Action.startDiscovery [47]: Starting device discovery. 2019-04-19 17:31:03,539 - DEBUG - [MainThread] UM.Controller.setActiveStage [159]: Setting active stage to PrepareStage 2019-04-19 17:31:03,713 - DEBUG - [MainThread] cura.Machines.Models.NozzleModel._update [34]: Updating NozzleModel. 2019-04-19 17:31:03,920 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/plugins/PrepareStage/PrepareMain.qml:16:5: QML ActionPanelWidget: Binding loop detected for property "width" 2019-04-19 17:31:03,926 - DEBUG - [MainThread] UM.Controller.setActiveView [92]: Setting active view to SolidView 2019-04-19 17:31:03,931 - DEBUG - [MainThread] ModelChecker.ModelChecker._createView [103]: Creating model checker view. 2019-04-19 17:31:03,948 - DEBUG - [MainThread] ModelChecker.ModelChecker._createView [112]: Model checker view created. 2019-04-19 17:31:03,950 - DEBUG - [MainThread] SliceInfoPlugin.SliceInfo._createDialog [82]: Creating dialog [MoreInfoWindow.qml] 2019-04-19 17:31:04,055 - DEBUG - [MainThread] cura.CuraApplication.run [747]: Booting Cura took 15.656819820404053 seconds 2019-04-19 17:31:04,083 - INFO - [MainThread] cura.Machines.MaterialManager._updateMaps [279]: Updating material lookup data ... 2019-04-19 17:31:04,224 - INFO - [MainThread] cura.Settings.MachineManager._updateQualityWithMaterial [1270]: Updating quality/quality_changes due to material change 2019-04-19 17:31:04,231 - DEBUG - [MainThread] cura.Settings.MachineManager._updateQualityWithMaterial [1277]: Current quality type = [draft] 2019-04-19 17:31:04,241 - INFO - [MainThread] cura.Settings.MachineManager._updateQualityWithMaterial [1291]: Current available quality type [draft] is available, applying changes. 2019-04-19 17:31:04,494 - DEBUG - [MainThread] cura.Machines.QualityManager.initialize [136]: Lookup tables updated. 2019-04-19 17:31:04,770 - DEBUG - [MainThread] cura.Machines.Models.QualityProfilesDropDownMenuModel._update [61]: Updating QualityProfilesDropDownMenuModel. 2019-04-19 17:31:04,773 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container coarse 2019-04-19 17:31:04,783 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [coarse] added. 2019-04-19 17:31:04,990 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container extra_coarse 2019-04-19 17:31:05,013 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [extra_coarse] added. 2019-04-19 17:31:05,127 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container fast 2019-04-19 17:31:05,140 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [fast] added. 2019-04-19 17:31:05,330 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container high 2019-04-19 17:31:05,352 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [high] added. 2019-04-19 17:31:05,475 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container normal 2019-04-19 17:31:05,498 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [normal] added. 2019-04-19 17:31:05,500 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container extra_fast 2019-04-19 17:31:05,517 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [extra_fast] added. 2019-04-19 17:31:05,595 - DEBUG - [MainThread] cura.Machines.Models.CustomQualityProfilesDropDownMenuModel._update [15]: Updating CustomQualityProfilesDropDownMenuModel. 2019-04-19 17:31:05,604 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._checkStack [140]: Need to check for errors again. Discard the current progress and reschedule a check. 2019-04-19 17:31:05,613 - INFO - [Thread-1] STLReader.STLReader.load_file [46]: Using NumPy-STL to load STL data. 2019-04-19 17:31:05,622 - DEBUG - [Thread-1] UM.Mesh.MeshData.calculateNormalsFromVertices [444]: Calculating normals took 0.0009999275207519531 seconds 2019-04-19 17:31:05,625 - DEBUG - [Thread-1] STLReader.STLReader._read [97]: Loaded a mesh with 11556 vertices 2019-04-19 17:31:05,645 - DEBUG - [MainThread] UM.Mesh.MeshData.approximateConvexHull [401]: approximateConvexHull(target_count=1024) Calculating 3D convex hull took 0.016993999481201172 seconds. 208 input vertices. 208 output vertices. 2019-04-19 17:31:05,717 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._rescheduleCheck [136]: New error check scheduled. 2019-04-19 17:31:05,746 - DEBUG - [Thread-1] UM.FileHandler.ReadFileJob.run [69]: Loading file took 0.1 seconds 2019-04-19 17:31:05,796 - DEBUG - [Thread-1] UM.Mesh.MeshData.approximateConvexHull [401]: approximateConvexHull(target_count=1024) Calculating 3D convex hull took 0.042996883392333984 seconds. 208 input vertices. 208 output vertices. 2019-04-19 17:31:07,502 - DEBUG - [MainThread] UM.Qt.QtRenderer._initialize [183]: Support for Vertex Array Objects: True 2019-04-19 17:31:07,529 - DEBUG - [MainThread] UM.View.GL.OpenGL.__init__ [99]: Initialized OpenGL subsystems. 2019-04-19 17:31:07,535 - DEBUG - [MainThread] UM.View.GL.OpenGL.__init__ [100]: OpenGL Version: 3.3.0 2019-04-19 17:31:07,541 - DEBUG - [MainThread] UM.View.GL.OpenGL.__init__ [101]: OpenGL Vendor: NVIDIA Corporation 2019-04-19 17:31:07,547 - DEBUG - [MainThread] UM.View.GL.OpenGL.__init__ [102]: OpenGL Renderer: GeForce 9500 GT/PCIe/SSE2 2019-04-19 17:31:07,552 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\default.shader]... 2019-04-19 17:31:07,563 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\selection.shader]... 2019-04-19 17:31:07,571 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\default.shader]... 2019-04-19 17:31:07,580 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\composite.shader]... 2019-04-19 17:31:07,590 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\overhang.shader]... 2019-04-19 17:31:07,598 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\striped.shader]... 2019-04-19 17:31:07,609 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\transparent_object.shader]... 2019-04-19 17:31:07,617 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\striped.shader]... 2019-04-19 17:31:07,629 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\default.shader]... 2019-04-19 17:31:07,637 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\grid.shader]... 2019-04-19 17:31:07,649 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\platform.shader]... 2019-04-19 17:31:07,845 - DEBUG - [MainThread] cura.Machines.QualityManager.initialize [136]: Lookup tables updated. 2019-04-19 17:31:07,978 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [per_object_stack_2376451691352] added. 2019-04-19 17:31:08,568 - DEBUG - [MainThread] cura.Machines.Models.QualityProfilesDropDownMenuModel._update [61]: Updating QualityProfilesDropDownMenuModel. 2019-04-19 17:31:08,608 - DEBUG - [MainThread] cura.Machines.Models.CustomQualityProfilesDropDownMenuModel._update [15]: Updating CustomQualityProfilesDropDownMenuModel. 2019-04-19 17:31:08,640 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\transparent_object.shader]... 2019-04-19 17:31:12,094 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend.slice [228]: Starting to slice... 2019-04-19 17:31:12,095 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend.slice [246]: Going to slice build plate [0]! 2019-04-19 17:31:13,119 - INFO - [MainThread] cura.Machines.MachineErrorChecker._setResult [188]: Error check finished, result = False, time = 7.4s 2019-04-19 17:31:13,591 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onStartSliceCompleted [432]: Sending slice message took 1.495973825454712 seconds 2019-04-19 17:31:14,436 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] [ERROR] Could not connect to the given address 2019-04-19 17:31:14,440 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onBackendQuit [811]: Backend quit with return code 0. Resetting process and socket. 2019-04-19 17:31:18,032 - DEBUG - [MainThread] cura.AutoSave._onTimeout [48]: Autosaving preferences, instances and profiles 2019-04-19 17:31:32,791 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._terminate [295]: Attempting to kill the engine process 2019-04-19 17:31:32,796 - DEBUG - [MainThread] UM.Backend.Backend._createSocket [227]: Previous socket existed. Closing that first. 2019-04-19 17:31:32,814 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [187]: Socket state changed to Listening 2019-04-19 17:31:32,828 - INFO - [MainThread] UM.Backend.Backend.startEngine [81]: Started engine process: C:\Program Files\Ultimaker Cura 4.0\CuraEngine.exe 2019-04-19 17:31:32,834 - DEBUG - [MainThread] UM.Backend.Backend._backendLog [101]: [Backend] Calling engine with: ['C:\\Program Files\\Ultimaker Cura 4.0\\CuraEngine.exe', 'connect', '127.0.0.1:49675', ''] 2019-04-19 17:31:32,917 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:31:32,923 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] Cura_SteamEngine version 4.0.0 2019-04-19 17:31:32,930 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] Copyright (C) 2018 Ultimaker 2019-04-19 17:31:32,936 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:31:32,943 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] This program is free software: you can redistribute it and/or modify 2019-04-19 17:31:32,949 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] it under the terms of the GNU Affero General Public License as published by 2019-04-19 17:31:32,964 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] the Free Software Foundation, either version 3 of the License, or 2019-04-19 17:31:32,970 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] (at your option) any later version. 2019-04-19 17:31:32,978 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:31:32,984 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] This program is distributed in the hope that it will be useful, 2019-04-19 17:31:32,990 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] but WITHOUT ANY WARRANTY; without even the implied warranty of 2019-04-19 17:31:32,996 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the 2019-04-19 17:31:33,003 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] GNU Affero General Public License for more details. 2019-04-19 17:31:33,010 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:31:33,018 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] You should have received a copy of the GNU Affero General Public License 2019-04-19 17:31:33,023 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] along with this program. If not, see <http://www.gnu.org/licenses/>. 2019-04-19 17:31:53,923 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] [ERROR] Could not connect to the given address 2019-04-19 17:31:54,056 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onBackendQuit [811]: Backend quit with return code 0. Resetting process and socket. 2019-04-19 17:36:35,969 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend.slice [228]: Starting to slice... 2019-04-19 17:36:35,969 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend.slice [246]: Going to slice build plate [0]! 2019-04-19 17:36:35,975 - DEBUG - [MainThread] UM.Backend.Backend._createSocket [227]: Previous socket existed. Closing that first. 2019-04-19 17:36:36,032 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [187]: Socket state changed to Listening 2019-04-19 17:36:36,127 - INFO - [MainThread] UM.Backend.Backend.startEngine [81]: Started engine process: C:\Program Files\Ultimaker Cura 4.0\CuraEngine.exe 2019-04-19 17:36:36,134 - DEBUG - [MainThread] UM.Backend.Backend._backendLog [101]: [Backend] Calling engine with: ['C:\\Program Files\\Ultimaker Cura 4.0\\CuraEngine.exe', 'connect', '127.0.0.1:49675', ''] 2019-04-19 17:36:36,228 - DEBUG - [Thread-17] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:36:36,357 - DEBUG - [Thread-17] UM.Backend.Backend._backendLog [101]: [Backend] Cura_SteamEngine version 4.0.0 2019-04-19 17:36:36,408 - DEBUG - [Thread-17] UM.Backend.Backend._backendLog [101]: [Backend] Copyright (C) 2018 Ultimaker 2019-04-19 17:36:36,431 - DEBUG - [Thread-17] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:36:36,578 - DEBUG - [Thread-17] UM.Backend.Backend._backendLog [101]: [Backend] This program is free software: you can redistribute it and/or modify 2019-04-19 17:36:36,597 - DEBUG - [Thread-17] UM.Backend.Backend._backendLog [101]: [Backend] it under the terms of the GNU Affero General Public License as published by 2019-04-19 17:36:36,602 - DEBUG - [Thread-17] UM.Backend.Backend._backendLog [101]: [Backend] the Free Software Foundation, either version 3 of the License, or 2019-04-19 17:36:36,609 - DEBUG - [Thread-17] UM.Backend.Backend._backendLog [101]: [Backend] (at your option) any later version. 2019-04-19 17:36:36,639 - DEBUG - [Thread-17] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:36:36,649 - DEBUG - [Thread-17] UM.Backend.Backend._backendLog [101]: [Backend] This program is distributed in the hope that it will be useful, 2019-04-19 17:36:36,661 - DEBUG - [Thread-17] UM.Backend.Backend._backendLog [101]: [Backend] but WITHOUT ANY WARRANTY; without even the implied warranty of 2019-04-19 17:36:36,778 - DEBUG - [Thread-17] UM.Backend.Backend._backendLog [101]: [Backend] MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the 2019-04-19 17:36:36,871 - DEBUG - [Thread-17] UM.Backend.Backend._backendLog [101]: [Backend] GNU Affero General Public License for more details. 2019-04-19 17:36:36,876 - DEBUG - [Thread-17] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:36:36,881 - DEBUG - [Thread-17] UM.Backend.Backend._backendLog [101]: [Backend] You should have received a copy of the GNU Affero General Public License 2019-04-19 17:36:36,886 - DEBUG - [Thread-17] UM.Backend.Backend._backendLog [101]: [Backend] along with this program. If not, see <http://www.gnu.org/licenses/>. 2019-04-19 17:36:37,332 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onStartSliceCompleted [432]: Sending slice message took 1.3629786968231201 seconds 2019-04-19 17:36:41,199 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._terminate [295]: Attempting to kill the engine process 2019-04-19 17:36:41,200 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._terminate [301]: Killing engine process 2019-04-19 17:36:41,206 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._terminate [304]: Engine process is killed. Received return code 1 2019-04-19 17:36:41,212 - DEBUG - [MainThread] UM.Backend.Backend._createSocket [227]: Previous socket existed. Closing that first. 2019-04-19 17:36:41,229 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [187]: Socket state changed to Listening 2019-04-19 17:36:41,239 - INFO - [MainThread] UM.Backend.Backend.startEngine [81]: Started engine process: C:\Program Files\Ultimaker Cura 4.0\CuraEngine.exe 2019-04-19 17:36:41,245 - DEBUG - [MainThread] UM.Backend.Backend._backendLog [101]: [Backend] Calling engine with: ['C:\\Program Files\\Ultimaker Cura 4.0\\CuraEngine.exe', 'connect', '127.0.0.1:49675', ''] 2019-04-19 17:36:41,316 - DEBUG - [Thread-20] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:36:41,323 - DEBUG - [Thread-20] UM.Backend.Backend._backendLog [101]: [Backend] Cura_SteamEngine version 4.0.0 2019-04-19 17:36:41,329 - DEBUG - [Thread-20] UM.Backend.Backend._backendLog [101]: [Backend] Copyright (C) 2018 Ultimaker 2019-04-19 17:36:41,335 - DEBUG - [Thread-20] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:36:41,341 - DEBUG - [Thread-20] UM.Backend.Backend._backendLog [101]: [Backend] This program is free software: you can redistribute it and/or modify 2019-04-19 17:36:41,347 - DEBUG - [Thread-20] UM.Backend.Backend._backendLog [101]: [Backend] it under the terms of the GNU Affero General Public License as published by 2019-04-19 17:36:41,352 - DEBUG - [Thread-20] UM.Backend.Backend._backendLog [101]: [Backend] the Free Software Foundation, either version 3 of the License, or 2019-04-19 17:36:41,357 - DEBUG - [Thread-20] UM.Backend.Backend._backendLog [101]: [Backend] (at your option) any later version. 2019-04-19 17:36:41,362 - DEBUG - [Thread-20] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:36:41,366 - DEBUG - [Thread-20] UM.Backend.Backend._backendLog [101]: [Backend] This program is distributed in the hope that it will be useful, 2019-04-19 17:36:41,371 - DEBUG - [Thread-20] UM.Backend.Backend._backendLog [101]: [Backend] but WITHOUT ANY WARRANTY; without even the implied warranty of 2019-04-19 17:36:41,376 - DEBUG - [Thread-20] UM.Backend.Backend._backendLog [101]: [Backend] MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the 2019-04-19 17:36:41,381 - DEBUG - [Thread-20] UM.Backend.Backend._backendLog [101]: [Backend] GNU Affero General Public License for more details. 2019-04-19 17:36:41,386 - DEBUG - [Thread-20] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:36:41,391 - DEBUG - [Thread-20] UM.Backend.Backend._backendLog [101]: [Backend] You should have received a copy of the GNU Affero General Public License 2019-04-19 17:36:41,395 - DEBUG - [Thread-20] UM.Backend.Backend._backendLog [101]: [Backend] along with this program. If not, see <http://www.gnu.org/licenses/>. 2019-04-19 17:37:02,323 - DEBUG - [Thread-20] UM.Backend.Backend._backendLog [101]: [Backend] [ERROR] Could not connect to the given address 2019-04-19 17:37:02,327 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onBackendQuit [811]: Backend quit with return code 0. Resetting process and socket. 2019-04-19 17:37:42,709 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend.slice [228]: Starting to slice... 2019-04-19 17:37:42,710 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend.slice [246]: Going to slice build plate [0]! 2019-04-19 17:37:42,717 - DEBUG - [MainThread] UM.Backend.Backend._createSocket [227]: Previous socket existed. Closing that first. 2019-04-19 17:37:42,740 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [187]: Socket state changed to Listening 2019-04-19 17:37:43,122 - INFO - [MainThread] UM.Backend.Backend.startEngine [81]: Started engine process: C:\Program Files\Ultimaker Cura 4.0\CuraEngine.exe 2019-04-19 17:37:43,128 - DEBUG - [MainThread] UM.Backend.Backend._backendLog [101]: [Backend] Calling engine with: ['C:\\Program Files\\Ultimaker Cura 4.0\\CuraEngine.exe', 'connect', '127.0.0.1:49675', ''] 2019-04-19 17:37:43,854 - DEBUG - [Thread-23] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:37:43,860 - DEBUG - [Thread-23] UM.Backend.Backend._backendLog [101]: [Backend] Cura_SteamEngine version 4.0.0 2019-04-19 17:37:43,865 - DEBUG - [Thread-23] UM.Backend.Backend._backendLog [101]: [Backend] Copyright (C) 2018 Ultimaker 2019-04-19 17:37:43,870 - DEBUG - [Thread-23] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:37:43,875 - DEBUG - [Thread-23] UM.Backend.Backend._backendLog [101]: [Backend] This program is free software: you can redistribute it and/or modify 2019-04-19 17:37:43,880 - DEBUG - [Thread-23] UM.Backend.Backend._backendLog [101]: [Backend] it under the terms of the GNU Affero General Public License as published by 2019-04-19 17:37:43,891 - DEBUG - [Thread-23] UM.Backend.Backend._backendLog [101]: [Backend] the Free Software Foundation, either version 3 of the License, or 2019-04-19 17:37:43,898 - DEBUG - [Thread-23] UM.Backend.Backend._backendLog [101]: [Backend] (at your option) any later version. 2019-04-19 17:37:43,903 - DEBUG - [Thread-23] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:37:43,908 - DEBUG - [Thread-23] UM.Backend.Backend._backendLog [101]: [Backend] This program is distributed in the hope that it will be useful, 2019-04-19 17:37:43,913 - DEBUG - [Thread-23] UM.Backend.Backend._backendLog [101]: [Backend] but WITHOUT ANY WARRANTY; without even the implied warranty of 2019-04-19 17:37:43,919 - DEBUG - [Thread-23] UM.Backend.Backend._backendLog [101]: [Backend] MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the 2019-04-19 17:37:43,927 - DEBUG - [Thread-23] UM.Backend.Backend._backendLog [101]: [Backend] GNU Affero General Public License for more details. 2019-04-19 17:37:43,933 - DEBUG - [Thread-23] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:37:43,939 - DEBUG - [Thread-23] UM.Backend.Backend._backendLog [101]: [Backend] You should have received a copy of the GNU Affero General Public License 2019-04-19 17:37:43,944 - DEBUG - [Thread-23] UM.Backend.Backend._backendLog [101]: [Backend] along with this program. If not, see <http://www.gnu.org/licenses/>. 2019-04-19 17:37:46,053 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend.slice [228]: Starting to slice... 2019-04-19 17:37:46,072 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend.slice [246]: Going to slice build plate [0]! 2019-04-19 17:37:46,073 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._terminate [295]: Attempting to kill the engine process 2019-04-19 17:37:46,074 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._terminate [301]: Killing engine process 2019-04-19 17:37:46,092 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._terminate [304]: Engine process is killed. Received return code 1 2019-04-19 17:37:46,099 - DEBUG - [MainThread] UM.Backend.Backend._createSocket [227]: Previous socket existed. Closing that first. 2019-04-19 17:37:46,115 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [187]: Socket state changed to Listening 2019-04-19 17:37:46,130 - INFO - [MainThread] UM.Backend.Backend.startEngine [81]: Started engine process: C:\Program Files\Ultimaker Cura 4.0\CuraEngine.exe 2019-04-19 17:37:46,136 - DEBUG - [MainThread] UM.Backend.Backend._backendLog [101]: [Backend] Calling engine with: ['C:\\Program Files\\Ultimaker Cura 4.0\\CuraEngine.exe', 'connect', '127.0.0.1:49675', ''] 2019-04-19 17:37:46,281 - DEBUG - [Thread-26] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:37:46,304 - DEBUG - [Thread-26] UM.Backend.Backend._backendLog [101]: [Backend] Cura_SteamEngine version 4.0.0 2019-04-19 17:37:46,319 - DEBUG - [Thread-26] UM.Backend.Backend._backendLog [101]: [Backend] Copyright (C) 2018 Ultimaker 2019-04-19 17:37:46,333 - DEBUG - [Thread-26] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:37:46,348 - DEBUG - [Thread-26] UM.Backend.Backend._backendLog [101]: [Backend] This program is free software: you can redistribute it and/or modify 2019-04-19 17:37:46,361 - DEBUG - [Thread-26] UM.Backend.Backend._backendLog [101]: [Backend] it under the terms of the GNU Affero General Public License as published by 2019-04-19 17:37:46,370 - DEBUG - [Thread-26] UM.Backend.Backend._backendLog [101]: [Backend] the Free Software Foundation, either version 3 of the License, or 2019-04-19 17:37:46,440 - DEBUG - [Thread-26] UM.Backend.Backend._backendLog [101]: [Backend] (at your option) any later version. 2019-04-19 17:37:46,453 - DEBUG - [Thread-26] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:37:46,479 - DEBUG - [Thread-26] UM.Backend.Backend._backendLog [101]: [Backend] This program is distributed in the hope that it will be useful, 2019-04-19 17:37:46,488 - DEBUG - [Thread-26] UM.Backend.Backend._backendLog [101]: [Backend] but WITHOUT ANY WARRANTY; without even the implied warranty of 2019-04-19 17:37:46,526 - DEBUG - [Thread-26] UM.Backend.Backend._backendLog [101]: [Backend] MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the 2019-04-19 17:37:46,544 - DEBUG - [Thread-26] UM.Backend.Backend._backendLog [101]: [Backend] GNU Affero General Public License for more details. 2019-04-19 17:37:46,554 - DEBUG - [Thread-26] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:37:46,571 - DEBUG - [Thread-26] UM.Backend.Backend._backendLog [101]: [Backend] You should have received a copy of the GNU Affero General Public License 2019-04-19 17:37:46,590 - DEBUG - [Thread-26] UM.Backend.Backend._backendLog [101]: [Backend] along with this program. If not, see <http://www.gnu.org/licenses/>. 2019-04-19 17:37:52,381 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onStartSliceCompleted [432]: Sending slice message took 6.327927589416504 seconds 2019-04-19 17:37:57,606 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._terminate [295]: Attempting to kill the engine process 2019-04-19 17:37:57,607 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._terminate [301]: Killing engine process 2019-04-19 17:37:57,614 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._terminate [304]: Engine process is killed. Received return code 1 2019-04-19 17:37:57,620 - DEBUG - [MainThread] UM.Backend.Backend._createSocket [227]: Previous socket existed. Closing that first. 2019-04-19 17:37:57,639 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [187]: Socket state changed to Listening 2019-04-19 17:37:57,654 - INFO - [MainThread] UM.Backend.Backend.startEngine [81]: Started engine process: C:\Program Files\Ultimaker Cura 4.0\CuraEngine.exe 2019-04-19 17:37:57,659 - DEBUG - [MainThread] UM.Backend.Backend._backendLog [101]: [Backend] Calling engine with: ['C:\\Program Files\\Ultimaker Cura 4.0\\CuraEngine.exe', 'connect', '127.0.0.1:49675', ''] 2019-04-19 17:37:57,760 - DEBUG - [Thread-29] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:37:57,767 - DEBUG - [Thread-29] UM.Backend.Backend._backendLog [101]: [Backend] Cura_SteamEngine version 4.0.0 2019-04-19 17:37:57,774 - DEBUG - [Thread-29] UM.Backend.Backend._backendLog [101]: [Backend] Copyright (C) 2018 Ultimaker 2019-04-19 17:37:57,781 - DEBUG - [Thread-29] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:37:57,788 - DEBUG - [Thread-29] UM.Backend.Backend._backendLog [101]: [Backend] This program is free software: you can redistribute it and/or modify 2019-04-19 17:37:57,794 - DEBUG - [Thread-29] UM.Backend.Backend._backendLog [101]: [Backend] it under the terms of the GNU Affero General Public License as published by 2019-04-19 17:37:57,803 - DEBUG - [Thread-29] UM.Backend.Backend._backendLog [101]: [Backend] the Free Software Foundation, either version 3 of the License, or 2019-04-19 17:37:57,810 - DEBUG - [Thread-29] UM.Backend.Backend._backendLog [101]: [Backend] (at your option) any later version. 2019-04-19 17:37:57,817 - DEBUG - [Thread-29] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:37:57,823 - DEBUG - [Thread-29] UM.Backend.Backend._backendLog [101]: [Backend] This program is distributed in the hope that it will be useful, 2019-04-19 17:37:57,830 - DEBUG - [Thread-29] UM.Backend.Backend._backendLog [101]: [Backend] but WITHOUT ANY WARRANTY; without even the implied warranty of 2019-04-19 17:37:57,838 - DEBUG - [Thread-29] UM.Backend.Backend._backendLog [101]: [Backend] MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the 2019-04-19 17:37:57,844 - DEBUG - [Thread-29] UM.Backend.Backend._backendLog [101]: [Backend] GNU Affero General Public License for more details. 2019-04-19 17:37:57,850 - DEBUG - [Thread-29] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:37:57,855 - DEBUG - [Thread-29] UM.Backend.Backend._backendLog [101]: [Backend] You should have received a copy of the GNU Affero General Public License 2019-04-19 17:37:57,860 - DEBUG - [Thread-29] UM.Backend.Backend._backendLog [101]: [Backend] along with this program. If not, see <http://www.gnu.org/licenses/>. 2019-04-19 17:38:18,757 - DEBUG - [Thread-29] UM.Backend.Backend._backendLog [101]: [Backend] [ERROR] Could not connect to the given address 2019-04-19 17:38:18,813 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onBackendQuit [811]: Backend quit with return code 0. Resetting process and socket. 2019-04-19 17:38:48,283 - WARNING - [MainThread] UM.PluginRegistry._populateMetaData [604]: Could not find plugin extruder_stack 2019-04-19 17:38:48,295 - WARNING - [MainThread] UM.PluginRegistry._populateMetaData [604]: Could not find plugin global_stack 2019-04-19 17:38:48,320 - WARNING - [MainThread] cura.Settings.ContainerManager.getContainerMetaDataEntry [65]: Could not get metadata of container Unknown because it was not found. 2019-04-19 17:38:48,703 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/resources/qml/Preferences/Materials/MaterialsPage.qml:236:13: QML MaterialsList: Binding loop detected for property "height" 2019-04-19 17:38:48,710 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/resources/qml/Preferences/Materials/MaterialsList.qml:135:5: QML Column: Binding loop detected for property "height" 2019-04-19 17:38:54,435 - DEBUG - [MainThread] cura.AutoSave._onTimeout [48]: Autosaving preferences, instances and profiles 2019-04-19 17:39:59,878 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend.slice [228]: Starting to slice... 2019-04-19 17:39:59,879 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend.slice [246]: Going to slice build plate [0]! 2019-04-19 17:39:59,884 - DEBUG - [MainThread] UM.Backend.Backend._createSocket [227]: Previous socket existed. Closing that first. 2019-04-19 17:40:00,003 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [187]: Socket state changed to Listening 2019-04-19 17:40:00,121 - INFO - [MainThread] UM.Backend.Backend.startEngine [81]: Started engine process: C:\Program Files\Ultimaker Cura 4.0\CuraEngine.exe 2019-04-19 17:40:00,127 - DEBUG - [MainThread] UM.Backend.Backend._backendLog [101]: [Backend] Calling engine with: ['C:\\Program Files\\Ultimaker Cura 4.0\\CuraEngine.exe', 'connect', '127.0.0.1:49675', ''] 2019-04-19 17:40:00,310 - DEBUG - [Thread-32] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:40:00,323 - DEBUG - [Thread-32] UM.Backend.Backend._backendLog [101]: [Backend] Cura_SteamEngine version 4.0.0 2019-04-19 17:40:00,337 - DEBUG - [Thread-32] UM.Backend.Backend._backendLog [101]: [Backend] Copyright (C) 2018 Ultimaker 2019-04-19 17:40:00,355 - DEBUG - [Thread-32] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:40:00,398 - DEBUG - [Thread-32] UM.Backend.Backend._backendLog [101]: [Backend] This program is free software: you can redistribute it and/or modify 2019-04-19 17:40:00,458 - DEBUG - [Thread-32] UM.Backend.Backend._backendLog [101]: [Backend] it under the terms of the GNU Affero General Public License as published by 2019-04-19 17:40:00,551 - DEBUG - [Thread-32] UM.Backend.Backend._backendLog [101]: [Backend] the Free Software Foundation, either version 3 of the License, or 2019-04-19 17:40:00,557 - DEBUG - [Thread-32] UM.Backend.Backend._backendLog [101]: [Backend] (at your option) any later version. 2019-04-19 17:40:00,570 - DEBUG - [Thread-32] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:40:00,585 - DEBUG - [Thread-32] UM.Backend.Backend._backendLog [101]: [Backend] This program is distributed in the hope that it will be useful, 2019-04-19 17:40:00,606 - DEBUG - [Thread-32] UM.Backend.Backend._backendLog [101]: [Backend] but WITHOUT ANY WARRANTY; without even the implied warranty of 2019-04-19 17:40:00,614 - DEBUG - [Thread-32] UM.Backend.Backend._backendLog [101]: [Backend] MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the 2019-04-19 17:40:00,622 - DEBUG - [Thread-32] UM.Backend.Backend._backendLog [101]: [Backend] GNU Affero General Public License for more details. 2019-04-19 17:40:00,628 - DEBUG - [Thread-32] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:40:00,644 - DEBUG - [Thread-32] UM.Backend.Backend._backendLog [101]: [Backend] You should have received a copy of the GNU Affero General Public License 2019-04-19 17:40:00,676 - DEBUG - [Thread-32] UM.Backend.Backend._backendLog [101]: [Backend] along with this program. If not, see <http://www.gnu.org/licenses/>. 2019-04-19 17:40:01,281 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onStartSliceCompleted [432]: Sending slice message took 1.4019780158996582 seconds 2019-04-19 17:40:20,152 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._terminate [295]: Attempting to kill the engine process 2019-04-19 17:40:20,153 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._terminate [301]: Killing engine process 2019-04-19 17:40:20,160 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._terminate [304]: Engine process is killed. Received return code 1 2019-04-19 17:40:20,165 - DEBUG - [MainThread] UM.Backend.Backend._createSocket [227]: Previous socket existed. Closing that first. 2019-04-19 17:40:20,182 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [187]: Socket state changed to Listening 2019-04-19 17:40:20,197 - INFO - [MainThread] UM.Backend.Backend.startEngine [81]: Started engine process: C:\Program Files\Ultimaker Cura 4.0\CuraEngine.exe 2019-04-19 17:40:20,203 - DEBUG - [MainThread] UM.Backend.Backend._backendLog [101]: [Backend] Calling engine with: ['C:\\Program Files\\Ultimaker Cura 4.0\\CuraEngine.exe', 'connect', '127.0.0.1:49675', ''] 2019-04-19 17:40:20,270 - DEBUG - [Thread-35] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:40:20,276 - DEBUG - [Thread-35] UM.Backend.Backend._backendLog [101]: [Backend] Cura_SteamEngine version 4.0.0 2019-04-19 17:40:20,282 - DEBUG - [Thread-35] UM.Backend.Backend._backendLog [101]: [Backend] Copyright (C) 2018 Ultimaker 2019-04-19 17:40:20,288 - DEBUG - [Thread-35] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:40:20,295 - DEBUG - [Thread-35] UM.Backend.Backend._backendLog [101]: [Backend] This program is free software: you can redistribute it and/or modify 2019-04-19 17:40:20,299 - DEBUG - [Thread-35] UM.Backend.Backend._backendLog [101]: [Backend] it under the terms of the GNU Affero General Public License as published by 2019-04-19 17:40:20,304 - DEBUG - [Thread-35] UM.Backend.Backend._backendLog [101]: [Backend] the Free Software Foundation, either version 3 of the License, or 2019-04-19 17:40:20,309 - DEBUG - [Thread-35] UM.Backend.Backend._backendLog [101]: [Backend] (at your option) any later version. 2019-04-19 17:40:20,314 - DEBUG - [Thread-35] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:40:20,318 - DEBUG - [Thread-35] UM.Backend.Backend._backendLog [101]: [Backend] This program is distributed in the hope that it will be useful, 2019-04-19 17:40:20,323 - DEBUG - [Thread-35] UM.Backend.Backend._backendLog [101]: [Backend] but WITHOUT ANY WARRANTY; without even the implied warranty of 2019-04-19 17:40:20,328 - DEBUG - [Thread-35] UM.Backend.Backend._backendLog [101]: [Backend] MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the 2019-04-19 17:40:20,333 - DEBUG - [Thread-35] UM.Backend.Backend._backendLog [101]: [Backend] GNU Affero General Public License for more details. 2019-04-19 17:40:20,338 - DEBUG - [Thread-35] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:40:20,342 - DEBUG - [Thread-35] UM.Backend.Backend._backendLog [101]: [Backend] You should have received a copy of the GNU Affero General Public License 2019-04-19 17:40:20,347 - DEBUG - [Thread-35] UM.Backend.Backend._backendLog [101]: [Backend] along with this program. If not, see <http://www.gnu.org/licenses/>. 2019-04-19 17:40:21,259 - DEBUG - [MainThread] cura.TaskManagement.OnExitCallbackManager.triggerNextCallback [51]: No more on-app-exit callbacks to process. Tell the app to exit. 2019-04-19 17:40:21,264 - INFO - [MainThread] cura.CuraApplication.closeApplication [547]: Close application 2019-04-19 17:40:21,309 - DEBUG - [MainThread] UM.Qt.QtApplication.windowClosed [417]: Shutting down cura 2019-04-19 17:40:21,374 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._terminate [295]: Attempting to kill the engine process 2019-04-19 17:40:21,374 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._terminate [301]: Killing engine process 2019-04-19 17:40:21,384 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._terminate [304]: Engine process is killed. Received return code 1 2019-04-19 17:40:59,849 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin FileLogger 2019-04-19 17:40:59,879 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin FirmwareUpdateChecker 2019-04-19 17:40:59,903 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin FirmwareUpdater 2019-04-19 17:40:59,924 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin GCodeGzReader 2019-04-19 17:40:59,945 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin GCodeGzWriter 2019-04-19 17:40:59,965 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin GCodeProfileReader 2019-04-19 17:41:00,000 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin GCodeReader 2019-04-19 17:41:00,023 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin GCodeWriter 2019-04-19 17:41:00,046 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin ImageReader 2019-04-19 17:41:00,068 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin LegacyProfileReader 2019-04-19 17:41:00,088 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin LocalContainerProvider 2019-04-19 17:41:00,113 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin LocalFileOutputDevice 2019-04-19 17:41:00,134 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin MachineSettingsAction 2019-04-19 17:41:00,156 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin ModelChecker 2019-04-19 17:41:00,181 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin MonitorStage 2019-04-19 17:41:00,210 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin PerObjectSettingsTool 2019-04-19 17:41:00,235 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin PostProcessingPlugin 2019-04-19 17:41:00,260 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin PrepareStage 2019-04-19 17:41:00,284 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin PreviewStage 2019-04-19 17:41:00,315 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin RemovableDriveOutputDevice 2019-04-19 17:41:00,351 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin SimulationView 2019-04-19 17:41:00,378 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin SliceInfoPlugin 2019-04-19 17:41:00,403 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin SolidView 2019-04-19 17:41:00,431 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin SupportEraser 2019-04-19 17:41:00,467 - DEBUG - [MainThread] cura.OAuth2.AuthorizationService.getAccessToken [106]: No auth data to retrieve the access_token from 2019-04-19 17:41:00,473 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin Toolbox 2019-04-19 17:41:00,503 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin CameraTool 2019-04-19 17:41:00,533 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin MirrorTool 2019-04-19 17:41:00,565 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin RotateTool 2019-04-19 17:41:00,596 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin ScaleTool 2019-04-19 17:41:00,622 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin SelectionTool 2019-04-19 17:41:00,653 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin TranslateTool 2019-04-19 17:41:00,715 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin UFPWriter 2019-04-19 17:41:00,747 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin UltimakerMachineActions 2019-04-19 17:41:00,919 - DEBUG - [MainThread] UM3NetworkPrinting.src.Cloud.CloudOutputDeviceManager._onLoginStateChanged [57]: Log in state changed to False 2019-04-19 17:41:00,920 - DEBUG - [MainThread] UM3NetworkPrinting.src.Cloud.CloudOutputDeviceManager._onGetRemoteClustersFinished [80]: Parsed remote clusters to [] 2019-04-19 17:41:00,921 - DEBUG - [MainThread] UM3NetworkPrinting.src.Cloud.CloudOutputDeviceManager._onGetRemoteClustersFinished [81]: Removed: 0, added: 0, updates: 0 2019-04-19 17:41:00,927 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin UM3NetworkPrinting 2019-04-19 17:41:00,977 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin UpdateChecker 2019-04-19 17:41:00,983 - INFO - [Thread-2] UpdateChecker.UpdateCheckerJob.run [36]: Checking for new version of cura 2019-04-19 17:41:01,041 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin USBPrinting 2019-04-19 17:41:01,072 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin UserAgreement 2019-04-19 17:41:01,115 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade21to22 2019-04-19 17:41:01,147 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade22to24 2019-04-19 17:41:01,179 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade25to26 2019-04-19 17:41:01,211 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade26to27 2019-04-19 17:41:01,245 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade27to30 2019-04-19 17:41:01,278 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade30to31 2019-04-19 17:41:01,313 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade32to33 2019-04-19 17:41:01,346 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade33to34 2019-04-19 17:41:01,381 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade34to35 2019-04-19 17:41:01,416 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade35to40 2019-04-19 17:41:01,454 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin SimpleView 2019-04-19 17:41:01,490 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin X3DReader 2019-04-19 17:41:01,533 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin XmlMaterialProfile 2019-04-19 17:41:01,571 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin XRayView 2019-04-19 17:41:01,609 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin CustomSupports 2019-04-19 17:41:01,650 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin OrientationPlugin 2019-04-19 17:41:01,679 - INFO - [MainThread] UM.VersionUpgradeManager.upgrade [143]: Looking for old configuration files to upgrade. 2019-04-19 17:41:01,732 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\packages.json, skip it 2019-04-19 17:41:01,739 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\plugins.json, skip it 2019-04-19 17:41:01,772 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\packages.json, skip it 2019-04-19 17:41:01,777 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\plugins.json, skip it 2019-04-19 17:41:01,810 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\packages.json, skip it 2019-04-19 17:41:01,816 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\plugins.json, skip it 2019-04-19 17:41:01,847 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\packages.json, skip it 2019-04-19 17:41:01,853 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\plugins.json, skip it 2019-04-19 17:41:01,892 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\packages.json, skip it 2019-04-19 17:41:01,897 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\plugins.json, skip it 2019-04-19 17:41:01,930 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\packages.json, skip it 2019-04-19 17:41:01,936 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\plugins.json, skip it 2019-04-19 17:41:01,967 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\packages.json, skip it 2019-04-19 17:41:01,972 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\plugins.json, skip it 2019-04-19 17:41:02,004 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\packages.json, skip it 2019-04-19 17:41:02,009 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\plugins.json, skip it 2019-04-19 17:41:02,101 - DEBUG - [MainThread] UM.Backend.Backend._onSocketError [213]: Socket was unable to bind to port, increasing port number to 49675 2019-04-19 17:41:02,106 - DEBUG - [MainThread] UM.Backend.Backend._createSocket [227]: Previous socket existed. Closing that first. 2019-04-19 17:41:02,110 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._terminate [295]: Attempting to kill the engine process 2019-04-19 17:41:02,114 - DEBUG - [MainThread] UM.Backend.Backend._createSocket [227]: Previous socket existed. Closing that first. 2019-04-19 17:41:02,325 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [187]: Socket state changed to Listening 2019-04-19 17:41:02,339 - INFO - [MainThread] UM.Backend.Backend.startEngine [81]: Started engine process: C:\Program Files\Ultimaker Cura 4.0\CuraEngine.exe 2019-04-19 17:41:02,344 - DEBUG - [MainThread] UM.Backend.Backend._backendLog [101]: [Backend] Calling engine with: ['C:\\Program Files\\Ultimaker Cura 4.0\\CuraEngine.exe', 'connect', '127.0.0.1:49675', ''] 2019-04-19 17:41:02,404 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:41:02,409 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] Cura_SteamEngine version 4.0.0 2019-04-19 17:41:02,414 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] Copyright (C) 2018 Ultimaker 2019-04-19 17:41:02,419 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:41:02,424 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] This program is free software: you can redistribute it and/or modify 2019-04-19 17:41:02,428 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] it under the terms of the GNU Affero General Public License as published by 2019-04-19 17:41:02,433 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] the Free Software Foundation, either version 3 of the License, or 2019-04-19 17:41:02,438 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] (at your option) any later version. 2019-04-19 17:41:02,443 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:41:02,448 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] This program is distributed in the hope that it will be useful, 2019-04-19 17:41:02,452 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] but WITHOUT ANY WARRANTY; without even the implied warranty of 2019-04-19 17:41:02,457 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the 2019-04-19 17:41:02,462 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] GNU Affero General Public License for more details. 2019-04-19 17:41:02,466 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:41:02,471 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] You should have received a copy of the GNU Affero General Public License 2019-04-19 17:41:02,476 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] along with this program. If not, see <http://www.gnu.org/licenses/>. 2019-04-19 17:41:05,433 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.loadAllMetadata [338]: Loading metadata into container registry took 3.0819644927978516 seconds 2019-04-19 17:41:05,606 - DEBUG - [MainThread] cura.Scene.CuraSceneController.setActiveBuildPlate [104]: Select build plate: 0 2019-04-19 17:41:05,610 - INFO - [MainThread] cura.CuraApplication.run [695]: Initializing variant manager 2019-04-19 17:41:05,618 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container ultimaker_s5_aluminum 2019-04-19 17:41:05,625 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [ultimaker_s5_aluminum] added. 2019-04-19 17:41:05,627 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container ultimaker_s5 2019-04-19 17:41:05,792 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [ultimaker_s5] added. 2019-04-19 17:41:05,799 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container ultimaker_s5_glass 2019-04-19 17:41:05,807 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [ultimaker_s5_glass] added. 2019-04-19 17:41:05,814 - DEBUG - [MainThread] cura.Machines.VariantManager.initialize [59]: Exclude variant [empty_variant] 2019-04-19 17:41:05,819 - INFO - [MainThread] cura.CuraApplication.run [699]: Initializing material manager 2019-04-19 17:41:06,049 - INFO - [MainThread] cura.CuraApplication.run [704]: Initializing quality manager 2019-04-19 17:41:06,071 - DEBUG - [MainThread] cura.Machines.QualityManager.initialize [136]: Lookup tables updated. 2019-04-19 17:41:06,076 - INFO - [MainThread] cura.CuraApplication.run [709]: Initializing machine manager 2019-04-19 17:41:06,081 - INFO - [MainThread] cura.CuraApplication.run [712]: Initializing container manager 2019-04-19 17:41:06,086 - INFO - [MainThread] cura.CuraApplication.run [715]: Initializing machine error checker 2019-04-19 17:41:06,117 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container Creality CR-10 2019-04-19 17:41:06,122 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container Creality CR-10_user 2019-04-19 17:41:06,130 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [Creality CR-10_user] added. 2019-04-19 17:41:06,132 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container creality_cr10_pla 2019-04-19 17:41:06,140 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [creality_cr10_pla] added. 2019-04-19 17:41:06,142 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container draft 2019-04-19 17:41:06,150 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [draft] added. 2019-04-19 17:41:06,155 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container Creality CR-10_settings 2019-04-19 17:41:06,163 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [Creality CR-10_settings] added. 2019-04-19 17:41:06,165 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container creality_cr10 2019-04-19 17:41:06,245 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [creality_cr10] added. 2019-04-19 17:41:06,250 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [Creality CR-10] added. 2019-04-19 17:41:06,255 - INFO - [MainThread] cura.MachineActionManager.addDefaultMachineActions [72]: Default machine actions added for machine definition [creality_cr10] 2019-04-19 17:41:06,259 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container creality_cr10_extruder_0 #2 2019-04-19 17:41:06,263 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container creality_cr10_extruder_0 #2_user 2019-04-19 17:41:06,271 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [creality_cr10_extruder_0 #2_user] added. 2019-04-19 17:41:06,272 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container creality_cr10_extruder_0_pla 2019-04-19 17:41:06,282 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [creality_cr10_extruder_0_pla] added. 2019-04-19 17:41:06,284 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container generic_pla_175 2019-04-19 17:41:06,296 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [generic_pla_175_imade3d_jellybox] added. 2019-04-19 17:41:06,301 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [generic_pla_175_imade3d_jellybox_0.4_mm] added. 2019-04-19 17:41:06,306 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [generic_pla_175_imade3d_jellybox_0.4_mm_2-fans] added. 2019-04-19 17:41:06,311 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [generic_pla_175_cartesio] added. 2019-04-19 17:41:06,316 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [generic_pla_175_cartesio_0.25mm_thermoplastic_extruder] added. 2019-04-19 17:41:06,320 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [generic_pla_175_cartesio_0.4mm_thermoplastic_extruder] added. 2019-04-19 17:41:06,325 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [generic_pla_175_cartesio_0.8mm_thermoplastic_extruder] added. 2019-04-19 17:41:06,330 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [generic_pla_175] added. 2019-04-19 17:41:06,332 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container creality_cr10_extruder_0 #2_settings 2019-04-19 17:41:06,342 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [creality_cr10_extruder_0 #2_settings] added. 2019-04-19 17:41:06,344 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container creality_cr10_extruder_0 2019-04-19 17:41:06,350 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [creality_cr10_extruder_0] added. 2019-04-19 17:41:06,356 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [creality_cr10_extruder_0 #2] added. 2019-04-19 17:41:06,379 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container fdmprinter 2019-04-19 17:41:06,457 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [fdmprinter] added. 2019-04-19 17:41:06,757 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [170]: Begin loading of script: BQ_PauseAtHeight 2019-04-19 17:41:06,759 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [170]: Begin loading of script: ChangeAtZ 2019-04-19 17:41:06,761 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [170]: Begin loading of script: DisplayFilenameAndLayerOnLCD 2019-04-19 17:41:06,764 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [170]: Begin loading of script: FilamentChange 2019-04-19 17:41:06,766 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [170]: Begin loading of script: PauseAtHeight 2019-04-19 17:41:06,768 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [170]: Begin loading of script: PauseAtHeightRepRapFirmwareDuet 2019-04-19 17:41:06,770 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [170]: Begin loading of script: PauseAtHeightforRepetier 2019-04-19 17:41:06,771 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [170]: Begin loading of script: SearchAndReplace 2019-04-19 17:41:06,774 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [170]: Begin loading of script: Stretch 2019-04-19 17:41:06,777 - DEBUG - [MainThread] UM3NetworkPrinting.src.UM3OutputDevicePlugin.checkCloudFlowIsPossible [412]: Checking if cloud connection is possible... 2019-04-19 17:41:06,778 - DEBUG - [MainThread] UM3NetworkPrinting.src.UM3OutputDevicePlugin.checkCloudFlowIsPossible [435]: Cloud Flow not possible: User not logged in! 2019-04-19 17:41:06,937 - INFO - [MainThread] cura.Settings.GlobalStack.addExtruder [136]: Extruder[creality_cr10_extruder_0 #2] added to [Creality CR-10] at position [0] 2019-04-19 17:41:06,941 - WARNING - [MainThread] cura.Settings.ExtruderManager.registerExtruder [169]: Extruder [creality_cr10_extruder_0 #2] has already been registered on machine [Creality CR-10], not doing anything 2019-04-19 17:41:06,951 - INFO - [MainThread] cura.Settings.MachineManager._initMachineState [330]: Machine 'Creality CR-10' quality changes set to 'PLA #2' 2019-04-19 17:41:07,265 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._rescheduleCheck [136]: New error check scheduled. 2019-04-19 17:41:07,267 - INFO - [MainThread] FirmwareUpdateChecker.FirmwareUpdateChecker.checkFirmwareVersion [76]: No machine with name Creality CR-10 in list of firmware to check. 2019-04-19 17:41:08,853 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin._createView [280]: Creating post processing plugin view. 2019-04-19 17:41:08,991 - DEBUG - [MainThread] UM.Qt.Bindings.Theme.load [158]: Loading theme file: C:\Program Files\Ultimaker Cura 4.0\resources\themes\cura-light\theme.json 2019-04-19 17:41:09,097 - DEBUG - [MainThread] UM.Qt.Bindings.Theme.load [230]: Loaded theme C:\Program Files\Ultimaker Cura 4.0\resources\themes\cura-light 2019-04-19 17:41:09,186 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin._createView [290]: Post processing view created. 2019-04-19 17:41:09,462 - WARNING - [MainThread] UM.Qt.Bindings.Theme.getImage [133]: No image header_pattern defined in Theme 2019-04-19 17:41:09,481 - DEBUG - [MainThread] cura.Machines.Models.BuildPlateModel._update [33]: Updating BuildPlateModel. 2019-04-19 17:41:10,546 - DEBUG - [MainThread] cura.Machines.Models.NozzleModel._update [34]: Updating NozzleModel. 2019-04-19 17:41:10,785 - DEBUG - [MainThread] UM3NetworkPrinting.src.DiscoverUM3Action._createAdditionalComponentsView [196]: Creating additional ui components for UM3. 2019-04-19 17:41:10,843 - DEBUG - [MainThread] UM3NetworkPrinting.src.DiscoverUM3Action.startDiscovery [47]: Starting device discovery. 2019-04-19 17:41:10,864 - DEBUG - [MainThread] UM.Controller.setActiveStage [159]: Setting active stage to PrepareStage 2019-04-19 17:41:11,031 - DEBUG - [MainThread] cura.Machines.Models.NozzleModel._update [34]: Updating NozzleModel. 2019-04-19 17:41:11,200 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/plugins/PrepareStage/PrepareMain.qml:16:5: QML ActionPanelWidget: Binding loop detected for property "width" 2019-04-19 17:41:11,205 - DEBUG - [MainThread] UM.Controller.setActiveView [92]: Setting active view to SolidView 2019-04-19 17:41:11,215 - DEBUG - [MainThread] ModelChecker.ModelChecker._createView [103]: Creating model checker view. 2019-04-19 17:41:11,232 - DEBUG - [MainThread] ModelChecker.ModelChecker._createView [112]: Model checker view created. 2019-04-19 17:41:11,234 - DEBUG - [MainThread] SliceInfoPlugin.SliceInfo._createDialog [82]: Creating dialog [MoreInfoWindow.qml] 2019-04-19 17:41:11,348 - DEBUG - [MainThread] cura.CuraApplication.run [747]: Booting Cura took 13.938833713531494 seconds 2019-04-19 17:41:11,392 - DEBUG - [MainThread] cura.Machines.QualityManager.initialize [136]: Lookup tables updated. 2019-04-19 17:41:11,413 - INFO - [MainThread] cura.Machines.MaterialManager._updateMaps [279]: Updating material lookup data ... 2019-04-19 17:41:11,481 - INFO - [MainThread] cura.Settings.MachineManager._updateQualityWithMaterial [1270]: Updating quality/quality_changes due to material change 2019-04-19 17:41:11,486 - DEBUG - [MainThread] cura.Settings.MachineManager._updateQualityWithMaterial [1277]: Current quality type = [draft] 2019-04-19 17:41:11,491 - INFO - [MainThread] cura.Settings.MachineManager._updateQualityWithMaterial [1291]: Current available quality type [draft] is available, applying changes. 2019-04-19 17:41:11,561 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._checkStack [140]: Need to check for errors again. Discard the current progress and reschedule a check. 2019-04-19 17:41:11,602 - DEBUG - [MainThread] cura.Machines.Models.QualityProfilesDropDownMenuModel._update [61]: Updating QualityProfilesDropDownMenuModel. 2019-04-19 17:41:11,604 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container coarse 2019-04-19 17:41:11,612 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [coarse] added. 2019-04-19 17:41:11,652 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container extra_coarse 2019-04-19 17:41:11,660 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [extra_coarse] added. 2019-04-19 17:41:11,696 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container fast 2019-04-19 17:41:11,704 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [fast] added. 2019-04-19 17:41:11,786 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container high 2019-04-19 17:41:11,794 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [high] added. 2019-04-19 17:41:11,835 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container normal 2019-04-19 17:41:11,842 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [normal] added. 2019-04-19 17:41:11,845 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container extra_fast 2019-04-19 17:41:11,852 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [extra_fast] added. 2019-04-19 17:41:11,910 - DEBUG - [MainThread] cura.Machines.Models.CustomQualityProfilesDropDownMenuModel._update [15]: Updating CustomQualityProfilesDropDownMenuModel. 2019-04-19 17:41:11,918 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._rescheduleCheck [136]: New error check scheduled. 2019-04-19 17:41:13,175 - DEBUG - [MainThread] UM.Qt.QtRenderer._initialize [183]: Support for Vertex Array Objects: True 2019-04-19 17:41:13,202 - DEBUG - [MainThread] UM.View.GL.OpenGL.__init__ [99]: Initialized OpenGL subsystems. 2019-04-19 17:41:13,207 - DEBUG - [MainThread] UM.View.GL.OpenGL.__init__ [100]: OpenGL Version: 3.3.0 2019-04-19 17:41:13,211 - DEBUG - [MainThread] UM.View.GL.OpenGL.__init__ [101]: OpenGL Vendor: NVIDIA Corporation 2019-04-19 17:41:13,216 - DEBUG - [MainThread] UM.View.GL.OpenGL.__init__ [102]: OpenGL Renderer: GeForce 9500 GT/PCIe/SSE2 2019-04-19 17:41:13,221 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\default.shader]... 2019-04-19 17:41:13,229 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\selection.shader]... 2019-04-19 17:41:13,236 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\default.shader]... 2019-04-19 17:41:13,243 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\composite.shader]... 2019-04-19 17:41:13,251 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\overhang.shader]... 2019-04-19 17:41:13,259 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\striped.shader]... 2019-04-19 17:41:13,268 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\transparent_object.shader]... 2019-04-19 17:41:13,276 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\striped.shader]... 2019-04-19 17:41:13,287 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\default.shader]... 2019-04-19 17:41:13,294 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\grid.shader]... 2019-04-19 17:41:13,302 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\platform.shader]... 2019-04-19 17:41:13,435 - DEBUG - [MainThread] cura.Machines.QualityManager.initialize [136]: Lookup tables updated. 2019-04-19 17:41:13,538 - INFO - [Thread-1] STLReader.STLReader.load_file [46]: Using NumPy-STL to load STL data. 2019-04-19 17:41:13,548 - DEBUG - [Thread-1] UM.Mesh.MeshData.calculateNormalsFromVertices [444]: Calculating normals took 0.0019996166229248047 seconds 2019-04-19 17:41:13,551 - DEBUG - [Thread-1] STLReader.STLReader._read [97]: Loaded a mesh with 26622 vertices 2019-04-19 17:41:13,568 - DEBUG - [MainThread] cura.Machines.Models.QualityProfilesDropDownMenuModel._update [61]: Updating QualityProfilesDropDownMenuModel. 2019-04-19 17:41:13,583 - DEBUG - [Thread-1] UM.Mesh.MeshData.approximateConvexHull [401]: approximateConvexHull(target_count=1024) Calculating 3D convex hull took 0.026998519897460938 seconds. 55 input vertices. 55 output vertices. 2019-04-19 17:41:13,602 - DEBUG - [MainThread] cura.Machines.Models.CustomQualityProfilesDropDownMenuModel._update [15]: Updating CustomQualityProfilesDropDownMenuModel. 2019-04-19 17:41:13,611 - DEBUG - [Thread-1] UM.FileHandler.ReadFileJob.run [69]: Loading file took 0.1 seconds 2019-04-19 17:41:13,630 - DEBUG - [Thread-1] UM.Mesh.MeshData.approximateConvexHull [401]: approximateConvexHull(target_count=1024) Calculating 3D convex hull took 0.01400136947631836 seconds. 54 input vertices. 54 output vertices. 2019-04-19 17:41:13,680 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [per_object_stack_2040198927304] added. 2019-04-19 17:41:13,767 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\transparent_object.shader]... 2019-04-19 17:41:15,838 - INFO - [MainThread] cura.Machines.MachineErrorChecker._setResult [188]: Error check finished, result = False, time = 3.9s 2019-04-19 17:41:23,413 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] [ERROR] Could not connect to the given address 2019-04-19 17:41:23,421 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onBackendQuit [811]: Backend quit with return code 0. Resetting process and socket. 2019-04-19 17:41:23,717 - DEBUG - [MainThread] cura.AutoSave._onTimeout [48]: Autosaving preferences, instances and profiles 2019-04-19 17:43:24,615 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend.slice [228]: Starting to slice... 2019-04-19 17:43:24,616 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend.slice [246]: Going to slice build plate [0]! 2019-04-19 17:43:24,622 - DEBUG - [MainThread] UM.Backend.Backend._createSocket [227]: Previous socket existed. Closing that first. 2019-04-19 17:43:24,836 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [187]: Socket state changed to Listening 2019-04-19 17:43:24,895 - INFO - [MainThread] UM.Backend.Backend.startEngine [81]: Started engine process: C:\Program Files\Ultimaker Cura 4.0\CuraEngine.exe 2019-04-19 17:43:24,909 - DEBUG - [MainThread] UM.Backend.Backend._backendLog [101]: [Backend] Calling engine with: ['C:\\Program Files\\Ultimaker Cura 4.0\\CuraEngine.exe', 'connect', '127.0.0.1:49675', ''] 2019-04-19 17:43:24,971 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:43:25,007 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] Cura_SteamEngine version 4.0.0 2019-04-19 17:43:25,014 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] Copyright (C) 2018 Ultimaker 2019-04-19 17:43:25,049 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:43:25,084 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] This program is free software: you can redistribute it and/or modify 2019-04-19 17:43:25,152 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] it under the terms of the GNU Affero General Public License as published by 2019-04-19 17:43:25,215 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] the Free Software Foundation, either version 3 of the License, or 2019-04-19 17:43:25,230 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] (at your option) any later version. 2019-04-19 17:43:25,249 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:43:25,340 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] This program is distributed in the hope that it will be useful, 2019-04-19 17:43:25,434 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] but WITHOUT ANY WARRANTY; without even the implied warranty of 2019-04-19 17:43:25,465 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the 2019-04-19 17:43:25,473 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] GNU Affero General Public License for more details. 2019-04-19 17:43:25,481 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:43:25,489 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] You should have received a copy of the GNU Affero General Public License 2019-04-19 17:43:25,496 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] along with this program. If not, see <http://www.gnu.org/licenses/>. 2019-04-19 17:43:26,060 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onStartSliceCompleted [432]: Sending slice message took 1.4439780712127686 seconds 2019-04-19 17:43:40,054 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._terminate [295]: Attempting to kill the engine process 2019-04-19 17:43:40,054 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._terminate [301]: Killing engine process 2019-04-19 17:43:40,061 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._terminate [304]: Engine process is killed. Received return code 1 2019-04-19 17:43:40,066 - DEBUG - [MainThread] UM.Backend.Backend._createSocket [227]: Previous socket existed. Closing that first. 2019-04-19 17:43:40,087 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [187]: Socket state changed to Listening 2019-04-19 17:43:40,101 - INFO - [MainThread] UM.Backend.Backend.startEngine [81]: Started engine process: C:\Program Files\Ultimaker Cura 4.0\CuraEngine.exe 2019-04-19 17:43:40,107 - DEBUG - [MainThread] UM.Backend.Backend._backendLog [101]: [Backend] Calling engine with: ['C:\\Program Files\\Ultimaker Cura 4.0\\CuraEngine.exe', 'connect', '127.0.0.1:49675', ''] 2019-04-19 17:43:40,196 - DEBUG - [Thread-17] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:43:40,201 - DEBUG - [Thread-17] UM.Backend.Backend._backendLog [101]: [Backend] Cura_SteamEngine version 4.0.0 2019-04-19 17:43:40,205 - DEBUG - [Thread-17] UM.Backend.Backend._backendLog [101]: [Backend] Copyright (C) 2018 Ultimaker 2019-04-19 17:43:40,210 - DEBUG - [Thread-17] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:43:40,215 - DEBUG - [Thread-17] UM.Backend.Backend._backendLog [101]: [Backend] This program is free software: you can redistribute it and/or modify 2019-04-19 17:43:40,219 - DEBUG - [Thread-17] UM.Backend.Backend._backendLog [101]: [Backend] it under the terms of the GNU Affero General Public License as published by 2019-04-19 17:43:40,224 - DEBUG - [Thread-17] UM.Backend.Backend._backendLog [101]: [Backend] the Free Software Foundation, either version 3 of the License, or 2019-04-19 17:43:40,229 - DEBUG - [Thread-17] UM.Backend.Backend._backendLog [101]: [Backend] (at your option) any later version. 2019-04-19 17:43:40,233 - DEBUG - [Thread-17] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:43:40,238 - DEBUG - [Thread-17] UM.Backend.Backend._backendLog [101]: [Backend] This program is distributed in the hope that it will be useful, 2019-04-19 17:43:40,243 - DEBUG - [Thread-17] UM.Backend.Backend._backendLog [101]: [Backend] but WITHOUT ANY WARRANTY; without even the implied warranty of 2019-04-19 17:43:40,247 - DEBUG - [Thread-17] UM.Backend.Backend._backendLog [101]: [Backend] MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the 2019-04-19 17:43:40,252 - DEBUG - [Thread-17] UM.Backend.Backend._backendLog [101]: [Backend] GNU Affero General Public License for more details. 2019-04-19 17:43:40,256 - DEBUG - [Thread-17] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:43:40,262 - DEBUG - [Thread-17] UM.Backend.Backend._backendLog [101]: [Backend] You should have received a copy of the GNU Affero General Public License 2019-04-19 17:43:40,266 - DEBUG - [Thread-17] UM.Backend.Backend._backendLog [101]: [Backend] along with this program. If not, see <http://www.gnu.org/licenses/>. 2019-04-19 17:43:41,894 - DEBUG - [MainThread] cura.TaskManagement.OnExitCallbackManager.triggerNextCallback [51]: No more on-app-exit callbacks to process. Tell the app to exit. 2019-04-19 17:43:41,899 - INFO - [MainThread] cura.CuraApplication.closeApplication [547]: Close application 2019-04-19 17:43:41,961 - DEBUG - [MainThread] UM.Qt.QtApplication.windowClosed [417]: Shutting down cura 2019-04-19 17:43:42,021 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._terminate [295]: Attempting to kill the engine process 2019-04-19 17:43:42,022 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._terminate [301]: Killing engine process 2019-04-19 17:43:42,028 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._terminate [304]: Engine process is killed. Received return code 1 2019-04-19 17:46:36,498 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin FileLogger 2019-04-19 17:46:36,523 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin FirmwareUpdateChecker 2019-04-19 17:46:36,545 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin FirmwareUpdater 2019-04-19 17:46:36,566 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin GCodeGzReader 2019-04-19 17:46:36,585 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin GCodeGzWriter 2019-04-19 17:46:36,606 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin GCodeProfileReader 2019-04-19 17:46:36,638 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin GCodeReader 2019-04-19 17:46:36,659 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin GCodeWriter 2019-04-19 17:46:36,682 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin ImageReader 2019-04-19 17:46:36,703 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin LegacyProfileReader 2019-04-19 17:46:36,723 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin LocalContainerProvider 2019-04-19 17:46:36,748 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin LocalFileOutputDevice 2019-04-19 17:46:36,768 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin MachineSettingsAction 2019-04-19 17:46:36,790 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin ModelChecker 2019-04-19 17:46:36,814 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin MonitorStage 2019-04-19 17:46:36,842 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin PerObjectSettingsTool 2019-04-19 17:46:36,866 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin PostProcessingPlugin 2019-04-19 17:46:36,891 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin PrepareStage 2019-04-19 17:46:36,914 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin PreviewStage 2019-04-19 17:46:36,945 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin RemovableDriveOutputDevice 2019-04-19 17:46:36,979 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin SimulationView 2019-04-19 17:46:37,006 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin SliceInfoPlugin 2019-04-19 17:46:37,030 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin SolidView 2019-04-19 17:46:37,057 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin SupportEraser 2019-04-19 17:46:37,092 - DEBUG - [MainThread] cura.OAuth2.AuthorizationService.getAccessToken [106]: No auth data to retrieve the access_token from 2019-04-19 17:46:37,098 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin Toolbox 2019-04-19 17:46:37,126 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin CameraTool 2019-04-19 17:46:37,156 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin MirrorTool 2019-04-19 17:46:37,188 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin RotateTool 2019-04-19 17:46:37,221 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin ScaleTool 2019-04-19 17:46:37,246 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin SelectionTool 2019-04-19 17:46:37,277 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin TranslateTool 2019-04-19 17:46:37,325 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin UFPWriter 2019-04-19 17:46:37,356 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin UltimakerMachineActions 2019-04-19 17:46:37,512 - DEBUG - [MainThread] UM3NetworkPrinting.src.Cloud.CloudOutputDeviceManager._onLoginStateChanged [57]: Log in state changed to False 2019-04-19 17:46:37,512 - DEBUG - [MainThread] UM3NetworkPrinting.src.Cloud.CloudOutputDeviceManager._onGetRemoteClustersFinished [80]: Parsed remote clusters to [] 2019-04-19 17:46:37,513 - DEBUG - [MainThread] UM3NetworkPrinting.src.Cloud.CloudOutputDeviceManager._onGetRemoteClustersFinished [81]: Removed: 0, added: 0, updates: 0 2019-04-19 17:46:37,519 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin UM3NetworkPrinting 2019-04-19 17:46:37,571 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin UpdateChecker 2019-04-19 17:46:37,578 - INFO - [Thread-2] UpdateChecker.UpdateCheckerJob.run [36]: Checking for new version of cura 2019-04-19 17:46:37,633 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin USBPrinting 2019-04-19 17:46:37,663 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin UserAgreement 2019-04-19 17:46:37,704 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade21to22 2019-04-19 17:46:37,736 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade22to24 2019-04-19 17:46:37,768 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade25to26 2019-04-19 17:46:37,801 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade26to27 2019-04-19 17:46:37,833 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade27to30 2019-04-19 17:46:37,867 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade30to31 2019-04-19 17:46:37,900 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade32to33 2019-04-19 17:46:37,932 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade33to34 2019-04-19 17:46:37,966 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade34to35 2019-04-19 17:46:37,999 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade35to40 2019-04-19 17:46:38,034 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin SimpleView 2019-04-19 17:46:38,070 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin X3DReader 2019-04-19 17:46:38,110 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin XmlMaterialProfile 2019-04-19 17:46:38,145 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin XRayView 2019-04-19 17:46:38,182 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin CustomSupports 2019-04-19 17:46:38,222 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin OrientationPlugin 2019-04-19 17:46:38,249 - INFO - [MainThread] UM.VersionUpgradeManager.upgrade [143]: Looking for old configuration files to upgrade. 2019-04-19 17:46:38,300 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\packages.json, skip it 2019-04-19 17:46:38,306 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\plugins.json, skip it 2019-04-19 17:46:38,338 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\packages.json, skip it 2019-04-19 17:46:38,343 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\plugins.json, skip it 2019-04-19 17:46:38,374 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\packages.json, skip it 2019-04-19 17:46:38,379 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\plugins.json, skip it 2019-04-19 17:46:38,410 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\packages.json, skip it 2019-04-19 17:46:38,415 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\plugins.json, skip it 2019-04-19 17:46:38,446 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\packages.json, skip it 2019-04-19 17:46:38,451 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\plugins.json, skip it 2019-04-19 17:46:38,482 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\packages.json, skip it 2019-04-19 17:46:38,487 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\plugins.json, skip it 2019-04-19 17:46:38,517 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\packages.json, skip it 2019-04-19 17:46:38,523 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\plugins.json, skip it 2019-04-19 17:46:38,553 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\packages.json, skip it 2019-04-19 17:46:38,560 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\plugins.json, skip it 2019-04-19 17:46:38,647 - DEBUG - [MainThread] UM.Backend.Backend._onSocketError [213]: Socket was unable to bind to port, increasing port number to 49675 2019-04-19 17:46:38,651 - DEBUG - [MainThread] UM.Backend.Backend._createSocket [227]: Previous socket existed. Closing that first. 2019-04-19 17:46:38,655 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._terminate [295]: Attempting to kill the engine process 2019-04-19 17:46:38,659 - DEBUG - [MainThread] UM.Backend.Backend._createSocket [227]: Previous socket existed. Closing that first. 2019-04-19 17:46:38,866 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [187]: Socket state changed to Listening 2019-04-19 17:46:38,879 - INFO - [MainThread] UM.Backend.Backend.startEngine [81]: Started engine process: C:\Program Files\Ultimaker Cura 4.0\CuraEngine.exe 2019-04-19 17:46:38,884 - DEBUG - [MainThread] UM.Backend.Backend._backendLog [101]: [Backend] Calling engine with: ['C:\\Program Files\\Ultimaker Cura 4.0\\CuraEngine.exe', 'connect', '127.0.0.1:49675', ''] 2019-04-19 17:46:38,946 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:46:38,951 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] Cura_SteamEngine version 4.0.0 2019-04-19 17:46:38,956 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] Copyright (C) 2018 Ultimaker 2019-04-19 17:46:38,961 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:46:38,966 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] This program is free software: you can redistribute it and/or modify 2019-04-19 17:46:38,970 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] it under the terms of the GNU Affero General Public License as published by 2019-04-19 17:46:38,975 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] the Free Software Foundation, either version 3 of the License, or 2019-04-19 17:46:38,980 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] (at your option) any later version. 2019-04-19 17:46:38,984 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:46:38,989 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] This program is distributed in the hope that it will be useful, 2019-04-19 17:46:38,994 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] but WITHOUT ANY WARRANTY; without even the implied warranty of 2019-04-19 17:46:38,999 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the 2019-04-19 17:46:39,003 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] GNU Affero General Public License for more details. 2019-04-19 17:46:39,008 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:46:39,014 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] You should have received a copy of the GNU Affero General Public License 2019-04-19 17:46:39,019 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] along with this program. If not, see <http://www.gnu.org/licenses/>. 2019-04-19 17:46:41,780 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.loadAllMetadata [338]: Loading metadata into container registry took 2.887972354888916 seconds 2019-04-19 17:46:41,920 - DEBUG - [MainThread] cura.Scene.CuraSceneController.setActiveBuildPlate [104]: Select build plate: 0 2019-04-19 17:46:41,925 - INFO - [MainThread] cura.CuraApplication.run [695]: Initializing variant manager 2019-04-19 17:46:41,935 - DEBUG - [MainThread] cura.Machines.VariantManager.initialize [59]: Exclude variant [empty_variant] 2019-04-19 17:46:41,937 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container ultimaker_s5_glass 2019-04-19 17:46:41,945 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [ultimaker_s5_glass] added. 2019-04-19 17:46:41,946 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container ultimaker_s5 2019-04-19 17:46:42,095 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [ultimaker_s5] added. 2019-04-19 17:46:42,099 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container ultimaker_s5_aluminum 2019-04-19 17:46:42,106 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [ultimaker_s5_aluminum] added. 2019-04-19 17:46:42,114 - INFO - [MainThread] cura.CuraApplication.run [699]: Initializing material manager 2019-04-19 17:46:42,210 - INFO - [MainThread] cura.CuraApplication.run [704]: Initializing quality manager 2019-04-19 17:46:42,232 - DEBUG - [MainThread] cura.Machines.QualityManager.initialize [136]: Lookup tables updated. 2019-04-19 17:46:42,237 - INFO - [MainThread] cura.CuraApplication.run [709]: Initializing machine manager 2019-04-19 17:46:42,242 - INFO - [MainThread] cura.CuraApplication.run [712]: Initializing container manager 2019-04-19 17:46:42,247 - INFO - [MainThread] cura.CuraApplication.run [715]: Initializing machine error checker 2019-04-19 17:46:42,277 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container Creality CR-10 2019-04-19 17:46:42,282 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container Creality CR-10_user 2019-04-19 17:46:42,290 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [Creality CR-10_user] added. 2019-04-19 17:46:42,292 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container creality_cr10_pla 2019-04-19 17:46:42,300 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [creality_cr10_pla] added. 2019-04-19 17:46:42,301 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container draft 2019-04-19 17:46:42,309 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [draft] added. 2019-04-19 17:46:42,312 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container Creality CR-10_settings 2019-04-19 17:46:42,320 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [Creality CR-10_settings] added. 2019-04-19 17:46:42,322 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container creality_cr10 2019-04-19 17:46:42,397 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [creality_cr10] added. 2019-04-19 17:46:42,403 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [Creality CR-10] added. 2019-04-19 17:46:42,408 - INFO - [MainThread] cura.MachineActionManager.addDefaultMachineActions [72]: Default machine actions added for machine definition [creality_cr10] 2019-04-19 17:46:42,413 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container creality_cr10_extruder_0 #2 2019-04-19 17:46:42,418 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container creality_cr10_extruder_0 #2_user 2019-04-19 17:46:42,426 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [creality_cr10_extruder_0 #2_user] added. 2019-04-19 17:46:42,427 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container creality_cr10_extruder_0_pla 2019-04-19 17:46:42,437 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [creality_cr10_extruder_0_pla] added. 2019-04-19 17:46:42,439 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container generic_pla_175 2019-04-19 17:46:42,451 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [generic_pla_175_imade3d_jellybox] added. 2019-04-19 17:46:42,456 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [generic_pla_175_imade3d_jellybox_0.4_mm] added. 2019-04-19 17:46:42,460 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [generic_pla_175_imade3d_jellybox_0.4_mm_2-fans] added. 2019-04-19 17:46:42,465 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [generic_pla_175_cartesio] added. 2019-04-19 17:46:42,470 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [generic_pla_175_cartesio_0.25mm_thermoplastic_extruder] added. 2019-04-19 17:46:42,475 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [generic_pla_175_cartesio_0.4mm_thermoplastic_extruder] added. 2019-04-19 17:46:42,480 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [generic_pla_175_cartesio_0.8mm_thermoplastic_extruder] added. 2019-04-19 17:46:42,485 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [generic_pla_175] added. 2019-04-19 17:46:42,486 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container creality_cr10_extruder_0 #2_settings 2019-04-19 17:46:42,497 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [creality_cr10_extruder_0 #2_settings] added. 2019-04-19 17:46:42,499 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container creality_cr10_extruder_0 2019-04-19 17:46:42,505 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [creality_cr10_extruder_0] added. 2019-04-19 17:46:42,510 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [creality_cr10_extruder_0 #2] added. 2019-04-19 17:46:42,535 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container fdmprinter 2019-04-19 17:46:42,611 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [fdmprinter] added. 2019-04-19 17:46:42,906 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [170]: Begin loading of script: BQ_PauseAtHeight 2019-04-19 17:46:42,908 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [170]: Begin loading of script: ChangeAtZ 2019-04-19 17:46:42,910 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [170]: Begin loading of script: DisplayFilenameAndLayerOnLCD 2019-04-19 17:46:42,913 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [170]: Begin loading of script: FilamentChange 2019-04-19 17:46:42,914 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [170]: Begin loading of script: PauseAtHeight 2019-04-19 17:46:42,916 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [170]: Begin loading of script: PauseAtHeightRepRapFirmwareDuet 2019-04-19 17:46:42,918 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [170]: Begin loading of script: PauseAtHeightforRepetier 2019-04-19 17:46:42,920 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [170]: Begin loading of script: SearchAndReplace 2019-04-19 17:46:42,922 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [170]: Begin loading of script: Stretch 2019-04-19 17:46:42,926 - DEBUG - [MainThread] UM3NetworkPrinting.src.UM3OutputDevicePlugin.checkCloudFlowIsPossible [412]: Checking if cloud connection is possible... 2019-04-19 17:46:42,927 - DEBUG - [MainThread] UM3NetworkPrinting.src.UM3OutputDevicePlugin.checkCloudFlowIsPossible [435]: Cloud Flow not possible: User not logged in! 2019-04-19 17:46:43,079 - INFO - [MainThread] cura.Settings.GlobalStack.addExtruder [136]: Extruder[creality_cr10_extruder_0 #2] added to [Creality CR-10] at position [0] 2019-04-19 17:46:43,083 - WARNING - [MainThread] cura.Settings.ExtruderManager.registerExtruder [169]: Extruder [creality_cr10_extruder_0 #2] has already been registered on machine [Creality CR-10], not doing anything 2019-04-19 17:46:43,092 - INFO - [MainThread] cura.Settings.MachineManager._initMachineState [330]: Machine 'Creality CR-10' quality changes set to 'PLA #2' 2019-04-19 17:46:43,402 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._rescheduleCheck [136]: New error check scheduled. 2019-04-19 17:46:43,403 - INFO - [MainThread] FirmwareUpdateChecker.FirmwareUpdateChecker.checkFirmwareVersion [76]: No machine with name Creality CR-10 in list of firmware to check. 2019-04-19 17:46:44,857 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin._createView [280]: Creating post processing plugin view. 2019-04-19 17:46:44,985 - DEBUG - [MainThread] UM.Qt.Bindings.Theme.load [158]: Loading theme file: C:\Program Files\Ultimaker Cura 4.0\resources\themes\cura-light\theme.json 2019-04-19 17:46:45,089 - DEBUG - [MainThread] UM.Qt.Bindings.Theme.load [230]: Loaded theme C:\Program Files\Ultimaker Cura 4.0\resources\themes\cura-light 2019-04-19 17:46:45,176 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin._createView [290]: Post processing view created. 2019-04-19 17:46:45,439 - WARNING - [MainThread] UM.Qt.Bindings.Theme.getImage [133]: No image header_pattern defined in Theme 2019-04-19 17:46:45,457 - DEBUG - [MainThread] cura.Machines.Models.BuildPlateModel._update [33]: Updating BuildPlateModel. 2019-04-19 17:46:46,484 - DEBUG - [MainThread] cura.Machines.Models.NozzleModel._update [34]: Updating NozzleModel. 2019-04-19 17:46:46,714 - DEBUG - [MainThread] UM3NetworkPrinting.src.DiscoverUM3Action._createAdditionalComponentsView [196]: Creating additional ui components for UM3. 2019-04-19 17:46:46,771 - DEBUG - [MainThread] UM3NetworkPrinting.src.DiscoverUM3Action.startDiscovery [47]: Starting device discovery. 2019-04-19 17:46:46,787 - DEBUG - [MainThread] UM.Controller.setActiveStage [159]: Setting active stage to PrepareStage 2019-04-19 17:46:46,945 - DEBUG - [MainThread] cura.Machines.Models.NozzleModel._update [34]: Updating NozzleModel. 2019-04-19 17:46:47,107 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/plugins/PrepareStage/PrepareMain.qml:16:5: QML ActionPanelWidget: Binding loop detected for property "width" 2019-04-19 17:46:47,113 - DEBUG - [MainThread] UM.Controller.setActiveView [92]: Setting active view to SolidView 2019-04-19 17:46:47,155 - DEBUG - [MainThread] ModelChecker.ModelChecker._createView [103]: Creating model checker view. 2019-04-19 17:46:47,170 - DEBUG - [MainThread] ModelChecker.ModelChecker._createView [112]: Model checker view created. 2019-04-19 17:46:47,172 - DEBUG - [MainThread] SliceInfoPlugin.SliceInfo._createDialog [82]: Creating dialog [MoreInfoWindow.qml] 2019-04-19 17:46:47,256 - DEBUG - [MainThread] cura.CuraApplication.run [747]: Booting Cura took 12.433862924575806 seconds 2019-04-19 17:46:47,296 - INFO - [MainThread] cura.Machines.MaterialManager._updateMaps [279]: Updating material lookup data ... 2019-04-19 17:46:47,361 - INFO - [MainThread] cura.Settings.MachineManager._updateQualityWithMaterial [1270]: Updating quality/quality_changes due to material change 2019-04-19 17:46:47,367 - DEBUG - [MainThread] cura.Settings.MachineManager._updateQualityWithMaterial [1277]: Current quality type = [draft] 2019-04-19 17:46:47,371 - INFO - [MainThread] cura.Settings.MachineManager._updateQualityWithMaterial [1291]: Current available quality type [draft] is available, applying changes. 2019-04-19 17:46:47,434 - DEBUG - [MainThread] cura.Machines.QualityManager.initialize [136]: Lookup tables updated. 2019-04-19 17:46:47,461 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._checkStack [140]: Need to check for errors again. Discard the current progress and reschedule a check. 2019-04-19 17:46:47,541 - DEBUG - [MainThread] cura.Machines.Models.QualityProfilesDropDownMenuModel._update [61]: Updating QualityProfilesDropDownMenuModel. 2019-04-19 17:46:47,547 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container coarse 2019-04-19 17:46:47,554 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [coarse] added. 2019-04-19 17:46:47,592 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container extra_coarse 2019-04-19 17:46:47,600 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [extra_coarse] added. 2019-04-19 17:46:47,637 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container fast 2019-04-19 17:46:47,645 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [fast] added. 2019-04-19 17:46:47,727 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container high 2019-04-19 17:46:47,734 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [high] added. 2019-04-19 17:46:47,776 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container normal 2019-04-19 17:46:47,783 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [normal] added. 2019-04-19 17:46:47,785 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container extra_fast 2019-04-19 17:46:47,793 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [extra_fast] added. 2019-04-19 17:46:47,843 - DEBUG - [MainThread] cura.Machines.Models.CustomQualityProfilesDropDownMenuModel._update [15]: Updating CustomQualityProfilesDropDownMenuModel. 2019-04-19 17:46:47,851 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._rescheduleCheck [136]: New error check scheduled. 2019-04-19 17:46:49,068 - DEBUG - [MainThread] UM.Qt.QtRenderer._initialize [183]: Support for Vertex Array Objects: True 2019-04-19 17:46:49,083 - DEBUG - [MainThread] UM.View.GL.OpenGL.__init__ [99]: Initialized OpenGL subsystems. 2019-04-19 17:46:49,087 - DEBUG - [MainThread] UM.View.GL.OpenGL.__init__ [100]: OpenGL Version: 3.3.0 2019-04-19 17:46:49,092 - DEBUG - [MainThread] UM.View.GL.OpenGL.__init__ [101]: OpenGL Vendor: NVIDIA Corporation 2019-04-19 17:46:49,097 - DEBUG - [MainThread] UM.View.GL.OpenGL.__init__ [102]: OpenGL Renderer: GeForce 9500 GT/PCIe/SSE2 2019-04-19 17:46:49,102 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\default.shader]... 2019-04-19 17:46:49,109 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\selection.shader]... 2019-04-19 17:46:49,116 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\default.shader]... 2019-04-19 17:46:49,123 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\composite.shader]... 2019-04-19 17:46:49,131 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\overhang.shader]... 2019-04-19 17:46:49,140 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\striped.shader]... 2019-04-19 17:46:49,148 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\transparent_object.shader]... 2019-04-19 17:46:49,156 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\striped.shader]... 2019-04-19 17:46:49,208 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\default.shader]... 2019-04-19 17:46:49,224 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\grid.shader]... 2019-04-19 17:46:49,231 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\platform.shader]... 2019-04-19 17:46:49,362 - DEBUG - [MainThread] cura.Machines.QualityManager.initialize [136]: Lookup tables updated. 2019-04-19 17:46:49,488 - DEBUG - [MainThread] cura.Machines.Models.QualityProfilesDropDownMenuModel._update [61]: Updating QualityProfilesDropDownMenuModel. 2019-04-19 17:46:49,511 - DEBUG - [MainThread] cura.Machines.Models.CustomQualityProfilesDropDownMenuModel._update [15]: Updating CustomQualityProfilesDropDownMenuModel. 2019-04-19 17:46:50,969 - INFO - [MainThread] cura.Machines.MachineErrorChecker._setResult [188]: Error check finished, result = False, time = 3.1s 2019-04-19 17:46:59,417 - DEBUG - [MainThread] cura.AutoSave._onTimeout [48]: Autosaving preferences, instances and profiles 2019-04-19 17:46:59,955 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] [ERROR] Could not connect to the given address 2019-04-19 17:46:59,982 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onBackendQuit [811]: Backend quit with return code 0. Resetting process and socket. 2019-04-19 17:47:14,254 - INFO - [Thread-1] STLReader.STLReader.load_file [46]: Using NumPy-STL to load STL data. 2019-04-19 17:47:14,274 - DEBUG - [Thread-1] UM.Mesh.MeshData.calculateNormalsFromVertices [444]: Calculating normals took 0.005001544952392578 seconds 2019-04-19 17:47:14,280 - DEBUG - [Thread-1] STLReader.STLReader._read [97]: Loaded a mesh with 82644 vertices 2019-04-19 17:47:14,415 - DEBUG - [Thread-1] UM.Mesh.MeshData.approximateConvexHull [401]: approximateConvexHull(target_count=1024) Calculating 3D convex hull took 0.12900376319885254 seconds. 351 input vertices. 351 output vertices. 2019-04-19 17:47:14,451 - DEBUG - [Thread-1] UM.FileHandler.ReadFileJob.run [69]: Loading file took 0.2 seconds 2019-04-19 17:47:14,507 - DEBUG - [Thread-1] UM.Mesh.MeshData.approximateConvexHull [401]: approximateConvexHull(target_count=1024) Calculating 3D convex hull took 0.049997806549072266 seconds. 351 input vertices. 351 output vertices. 2019-04-19 17:47:14,545 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [per_object_stack_2609140226928] added. 2019-04-19 17:47:14,589 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\transparent_object.shader]... 2019-04-19 17:47:24,579 - DEBUG - [MainThread] cura.AutoSave._onTimeout [48]: Autosaving preferences, instances and profiles 2019-04-19 17:47:27,664 - DEBUG - [MainThread] cura.TaskManagement.OnExitCallbackManager.triggerNextCallback [51]: No more on-app-exit callbacks to process. Tell the app to exit. 2019-04-19 17:47:27,669 - INFO - [MainThread] cura.CuraApplication.closeApplication [547]: Close application 2019-04-19 17:47:27,687 - DEBUG - [MainThread] UM.Qt.QtApplication.windowClosed [417]: Shutting down cura 2019-04-19 17:47:27,721 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._terminate [295]: Attempting to kill the engine process 2019-04-19 17:54:11,043 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin FileLogger 2019-04-19 17:54:11,069 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin FirmwareUpdateChecker 2019-04-19 17:54:11,092 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin FirmwareUpdater 2019-04-19 17:54:11,115 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin GCodeGzReader 2019-04-19 17:54:11,144 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin GCodeGzWriter 2019-04-19 17:54:11,165 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin GCodeProfileReader 2019-04-19 17:54:11,199 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin GCodeReader 2019-04-19 17:54:11,221 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin GCodeWriter 2019-04-19 17:54:11,244 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin ImageReader 2019-04-19 17:54:11,266 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin LegacyProfileReader 2019-04-19 17:54:11,289 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin LocalContainerProvider 2019-04-19 17:54:11,319 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin LocalFileOutputDevice 2019-04-19 17:54:11,344 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin MachineSettingsAction 2019-04-19 17:54:11,368 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin ModelChecker 2019-04-19 17:54:11,395 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin MonitorStage 2019-04-19 17:54:11,428 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin PerObjectSettingsTool 2019-04-19 17:54:11,458 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin PostProcessingPlugin 2019-04-19 17:54:11,487 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin PrepareStage 2019-04-19 17:54:11,520 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin PreviewStage 2019-04-19 17:54:11,562 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin RemovableDriveOutputDevice 2019-04-19 17:54:11,604 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin SimulationView 2019-04-19 17:54:11,643 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin SliceInfoPlugin 2019-04-19 17:54:11,683 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin SolidView 2019-04-19 17:54:11,716 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin SupportEraser 2019-04-19 17:54:11,761 - DEBUG - [MainThread] cura.OAuth2.AuthorizationService.getAccessToken [106]: No auth data to retrieve the access_token from 2019-04-19 17:54:11,769 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin Toolbox 2019-04-19 17:54:11,839 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin CameraTool 2019-04-19 17:54:12,007 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin MirrorTool 2019-04-19 17:54:12,257 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin RotateTool 2019-04-19 17:54:12,321 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin ScaleTool 2019-04-19 17:54:12,373 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin SelectionTool 2019-04-19 17:54:12,418 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin TranslateTool 2019-04-19 17:54:12,518 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin UFPWriter 2019-04-19 17:54:12,573 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin UltimakerMachineActions 2019-04-19 17:54:12,827 - DEBUG - [MainThread] UM3NetworkPrinting.src.Cloud.CloudOutputDeviceManager._onLoginStateChanged [57]: Log in state changed to False 2019-04-19 17:54:12,828 - DEBUG - [MainThread] UM3NetworkPrinting.src.Cloud.CloudOutputDeviceManager._onGetRemoteClustersFinished [80]: Parsed remote clusters to [] 2019-04-19 17:54:12,829 - DEBUG - [MainThread] UM3NetworkPrinting.src.Cloud.CloudOutputDeviceManager._onGetRemoteClustersFinished [81]: Removed: 0, added: 0, updates: 0 2019-04-19 17:54:12,836 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin UM3NetworkPrinting 2019-04-19 17:54:12,900 - INFO - [Thread-2] UpdateChecker.UpdateCheckerJob.run [36]: Checking for new version of cura 2019-04-19 17:54:12,911 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin UpdateChecker 2019-04-19 17:54:13,053 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin USBPrinting 2019-04-19 17:54:13,127 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin UserAgreement 2019-04-19 17:54:13,215 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade21to22 2019-04-19 17:54:13,252 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade22to24 2019-04-19 17:54:13,289 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade25to26 2019-04-19 17:54:13,322 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade26to27 2019-04-19 17:54:13,357 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade27to30 2019-04-19 17:54:13,393 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade30to31 2019-04-19 17:54:13,426 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade32to33 2019-04-19 17:54:13,458 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade33to34 2019-04-19 17:54:13,491 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade34to35 2019-04-19 17:54:13,525 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade35to40 2019-04-19 17:54:13,560 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin SimpleView 2019-04-19 17:54:13,594 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin X3DReader 2019-04-19 17:54:13,634 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin XmlMaterialProfile 2019-04-19 17:54:13,670 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin XRayView 2019-04-19 17:54:13,708 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin CustomSupports 2019-04-19 17:54:13,747 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin OrientationPlugin 2019-04-19 17:54:13,777 - INFO - [MainThread] UM.VersionUpgradeManager.upgrade [143]: Looking for old configuration files to upgrade. 2019-04-19 17:54:13,828 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\packages.json, skip it 2019-04-19 17:54:13,839 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\plugins.json, skip it 2019-04-19 17:54:13,872 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\packages.json, skip it 2019-04-19 17:54:13,877 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\plugins.json, skip it 2019-04-19 17:54:13,908 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\packages.json, skip it 2019-04-19 17:54:13,914 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\plugins.json, skip it 2019-04-19 17:54:13,945 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\packages.json, skip it 2019-04-19 17:54:13,950 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\plugins.json, skip it 2019-04-19 17:54:13,983 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\packages.json, skip it 2019-04-19 17:54:13,989 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\plugins.json, skip it 2019-04-19 17:54:14,021 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\packages.json, skip it 2019-04-19 17:54:14,027 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\plugins.json, skip it 2019-04-19 17:54:14,059 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\packages.json, skip it 2019-04-19 17:54:14,064 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\plugins.json, skip it 2019-04-19 17:54:14,096 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\packages.json, skip it 2019-04-19 17:54:14,101 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\plugins.json, skip it 2019-04-19 17:54:14,192 - DEBUG - [MainThread] UM.Backend.Backend._onSocketError [213]: Socket was unable to bind to port, increasing port number to 49675 2019-04-19 17:54:14,196 - DEBUG - [MainThread] UM.Backend.Backend._createSocket [227]: Previous socket existed. Closing that first. 2019-04-19 17:54:14,200 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._terminate [295]: Attempting to kill the engine process 2019-04-19 17:54:14,205 - DEBUG - [MainThread] UM.Backend.Backend._createSocket [227]: Previous socket existed. Closing that first. 2019-04-19 17:54:14,426 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [187]: Socket state changed to Listening 2019-04-19 17:54:14,440 - INFO - [MainThread] UM.Backend.Backend.startEngine [81]: Started engine process: C:\Program Files\Ultimaker Cura 4.0\CuraEngine.exe 2019-04-19 17:54:14,445 - DEBUG - [MainThread] UM.Backend.Backend._backendLog [101]: [Backend] Calling engine with: ['C:\\Program Files\\Ultimaker Cura 4.0\\CuraEngine.exe', 'connect', '127.0.0.1:49675', ''] 2019-04-19 17:54:14,507 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:54:14,512 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] Cura_SteamEngine version 4.0.0 2019-04-19 17:54:14,516 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] Copyright (C) 2018 Ultimaker 2019-04-19 17:54:14,521 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:54:14,525 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] This program is free software: you can redistribute it and/or modify 2019-04-19 17:54:14,530 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] it under the terms of the GNU Affero General Public License as published by 2019-04-19 17:54:14,535 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] the Free Software Foundation, either version 3 of the License, or 2019-04-19 17:54:14,539 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] (at your option) any later version. 2019-04-19 17:54:14,544 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:54:14,549 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] This program is distributed in the hope that it will be useful, 2019-04-19 17:54:14,553 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] but WITHOUT ANY WARRANTY; without even the implied warranty of 2019-04-19 17:54:14,558 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the 2019-04-19 17:54:14,562 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] GNU Affero General Public License for more details. 2019-04-19 17:54:14,567 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:54:14,571 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] You should have received a copy of the GNU Affero General Public License 2019-04-19 17:54:14,576 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] along with this program. If not, see <http://www.gnu.org/licenses/>. 2019-04-19 17:54:18,487 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.loadAllMetadata [338]: Loading metadata into container registry took 4.031955003738403 seconds 2019-04-19 17:54:18,793 - DEBUG - [MainThread] cura.Scene.CuraSceneController.setActiveBuildPlate [104]: Select build plate: 0 2019-04-19 17:54:18,801 - INFO - [MainThread] cura.CuraApplication.run [695]: Initializing variant manager 2019-04-19 17:54:18,822 - DEBUG - [MainThread] cura.Machines.VariantManager.initialize [59]: Exclude variant [empty_variant] 2019-04-19 17:54:18,826 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container ultimaker_s5_aluminum 2019-04-19 17:54:18,845 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [ultimaker_s5_aluminum] added. 2019-04-19 17:54:18,849 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container ultimaker_s5 2019-04-19 17:54:19,157 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [ultimaker_s5] added. 2019-04-19 17:54:19,164 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container ultimaker_s5_glass 2019-04-19 17:54:19,172 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [ultimaker_s5_glass] added. 2019-04-19 17:54:19,181 - INFO - [MainThread] cura.CuraApplication.run [699]: Initializing material manager 2019-04-19 17:54:19,298 - INFO - [MainThread] cura.CuraApplication.run [704]: Initializing quality manager 2019-04-19 17:54:19,323 - DEBUG - [MainThread] cura.Machines.QualityManager.initialize [136]: Lookup tables updated. 2019-04-19 17:54:19,328 - INFO - [MainThread] cura.CuraApplication.run [709]: Initializing machine manager 2019-04-19 17:54:19,335 - INFO - [MainThread] cura.CuraApplication.run [712]: Initializing container manager 2019-04-19 17:54:19,339 - INFO - [MainThread] cura.CuraApplication.run [715]: Initializing machine error checker 2019-04-19 17:54:19,373 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container Creality CR-10 2019-04-19 17:54:19,378 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container Creality CR-10_user 2019-04-19 17:54:19,387 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [Creality CR-10_user] added. 2019-04-19 17:54:19,388 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container creality_cr10_pla 2019-04-19 17:54:19,397 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [creality_cr10_pla] added. 2019-04-19 17:54:19,399 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container draft 2019-04-19 17:54:19,408 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [draft] added. 2019-04-19 17:54:19,410 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container Creality CR-10_settings 2019-04-19 17:54:19,419 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [Creality CR-10_settings] added. 2019-04-19 17:54:19,420 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container creality_cr10 2019-04-19 17:54:19,503 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [creality_cr10] added. 2019-04-19 17:54:19,509 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [Creality CR-10] added. 2019-04-19 17:54:19,514 - INFO - [MainThread] cura.MachineActionManager.addDefaultMachineActions [72]: Default machine actions added for machine definition [creality_cr10] 2019-04-19 17:54:19,521 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container creality_cr10_extruder_0 #2 2019-04-19 17:54:19,526 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container creality_cr10_extruder_0 #2_user 2019-04-19 17:54:19,535 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [creality_cr10_extruder_0 #2_user] added. 2019-04-19 17:54:19,537 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container creality_cr10_extruder_0_pla 2019-04-19 17:54:19,549 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [creality_cr10_extruder_0_pla] added. 2019-04-19 17:54:19,550 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container generic_pla_175 2019-04-19 17:54:19,563 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [generic_pla_175_imade3d_jellybox] added. 2019-04-19 17:54:19,568 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [generic_pla_175_imade3d_jellybox_0.4_mm] added. 2019-04-19 17:54:19,574 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [generic_pla_175_imade3d_jellybox_0.4_mm_2-fans] added. 2019-04-19 17:54:19,578 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [generic_pla_175_cartesio] added. 2019-04-19 17:54:19,583 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [generic_pla_175_cartesio_0.25mm_thermoplastic_extruder] added. 2019-04-19 17:54:19,589 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [generic_pla_175_cartesio_0.4mm_thermoplastic_extruder] added. 2019-04-19 17:54:19,594 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [generic_pla_175_cartesio_0.8mm_thermoplastic_extruder] added. 2019-04-19 17:54:19,599 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [generic_pla_175] added. 2019-04-19 17:54:19,601 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container creality_cr10_extruder_0 #2_settings 2019-04-19 17:54:19,613 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [creality_cr10_extruder_0 #2_settings] added. 2019-04-19 17:54:19,615 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container creality_cr10_extruder_0 2019-04-19 17:54:19,622 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [creality_cr10_extruder_0] added. 2019-04-19 17:54:19,628 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [creality_cr10_extruder_0 #2] added. 2019-04-19 17:54:19,655 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container fdmprinter 2019-04-19 17:54:19,741 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [fdmprinter] added. 2019-04-19 17:54:20,059 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [170]: Begin loading of script: BQ_PauseAtHeight 2019-04-19 17:54:20,062 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [170]: Begin loading of script: ChangeAtZ 2019-04-19 17:54:20,065 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [170]: Begin loading of script: DisplayFilenameAndLayerOnLCD 2019-04-19 17:54:20,068 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [170]: Begin loading of script: FilamentChange 2019-04-19 17:54:20,070 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [170]: Begin loading of script: PauseAtHeight 2019-04-19 17:54:20,072 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [170]: Begin loading of script: PauseAtHeightRepRapFirmwareDuet 2019-04-19 17:54:20,074 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [170]: Begin loading of script: PauseAtHeightforRepetier 2019-04-19 17:54:20,077 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [170]: Begin loading of script: SearchAndReplace 2019-04-19 17:54:20,080 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [170]: Begin loading of script: Stretch 2019-04-19 17:54:20,084 - DEBUG - [MainThread] UM3NetworkPrinting.src.UM3OutputDevicePlugin.checkCloudFlowIsPossible [412]: Checking if cloud connection is possible... 2019-04-19 17:54:20,084 - DEBUG - [MainThread] UM3NetworkPrinting.src.UM3OutputDevicePlugin.checkCloudFlowIsPossible [435]: Cloud Flow not possible: User not logged in! 2019-04-19 17:54:20,256 - INFO - [MainThread] cura.Settings.GlobalStack.addExtruder [136]: Extruder[creality_cr10_extruder_0 #2] added to [Creality CR-10] at position [0] 2019-04-19 17:54:20,260 - WARNING - [MainThread] cura.Settings.ExtruderManager.registerExtruder [169]: Extruder [creality_cr10_extruder_0 #2] has already been registered on machine [Creality CR-10], not doing anything 2019-04-19 17:54:20,271 - INFO - [MainThread] cura.Settings.MachineManager._initMachineState [330]: Machine 'Creality CR-10' quality changes set to 'PLA #2' 2019-04-19 17:54:20,627 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._rescheduleCheck [136]: New error check scheduled. 2019-04-19 17:54:20,629 - INFO - [MainThread] FirmwareUpdateChecker.FirmwareUpdateChecker.checkFirmwareVersion [76]: No machine with name Creality CR-10 in list of firmware to check. 2019-04-19 17:54:22,783 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin._createView [280]: Creating post processing plugin view. 2019-04-19 17:54:22,924 - DEBUG - [MainThread] UM.Qt.Bindings.Theme.load [158]: Loading theme file: C:\Program Files\Ultimaker Cura 4.0\resources\themes\cura-light\theme.json 2019-04-19 17:54:23,047 - DEBUG - [MainThread] UM.Qt.Bindings.Theme.load [230]: Loaded theme C:\Program Files\Ultimaker Cura 4.0\resources\themes\cura-light 2019-04-19 17:54:23,187 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin._createView [290]: Post processing view created. 2019-04-19 17:54:23,477 - WARNING - [MainThread] UM.Qt.Bindings.Theme.getImage [133]: No image header_pattern defined in Theme 2019-04-19 17:54:23,496 - DEBUG - [MainThread] cura.Machines.Models.BuildPlateModel._update [33]: Updating BuildPlateModel. 2019-04-19 17:54:24,634 - DEBUG - [MainThread] cura.Machines.Models.NozzleModel._update [34]: Updating NozzleModel. 2019-04-19 17:54:24,894 - DEBUG - [MainThread] UM3NetworkPrinting.src.DiscoverUM3Action._createAdditionalComponentsView [196]: Creating additional ui components for UM3. 2019-04-19 17:54:24,955 - DEBUG - [MainThread] UM3NetworkPrinting.src.DiscoverUM3Action.startDiscovery [47]: Starting device discovery. 2019-04-19 17:54:24,973 - DEBUG - [MainThread] UM.Controller.setActiveStage [159]: Setting active stage to PrepareStage 2019-04-19 17:54:25,148 - DEBUG - [MainThread] cura.Machines.Models.NozzleModel._update [34]: Updating NozzleModel. 2019-04-19 17:54:25,331 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/plugins/PrepareStage/PrepareMain.qml:16:5: QML ActionPanelWidget: Binding loop detected for property "width" 2019-04-19 17:54:25,337 - DEBUG - [MainThread] UM.Controller.setActiveView [92]: Setting active view to SolidView 2019-04-19 17:54:25,341 - DEBUG - [MainThread] ModelChecker.ModelChecker._createView [103]: Creating model checker view. 2019-04-19 17:54:25,355 - DEBUG - [MainThread] ModelChecker.ModelChecker._createView [112]: Model checker view created. 2019-04-19 17:54:25,356 - DEBUG - [MainThread] SliceInfoPlugin.SliceInfo._createDialog [82]: Creating dialog [MoreInfoWindow.qml] 2019-04-19 17:54:25,447 - DEBUG - [MainThread] cura.CuraApplication.run [747]: Booting Cura took 16.137810468673706 seconds 2019-04-19 17:54:25,473 - INFO - [MainThread] cura.Machines.MaterialManager._updateMaps [279]: Updating material lookup data ... 2019-04-19 17:54:25,545 - INFO - [MainThread] cura.Settings.MachineManager._updateQualityWithMaterial [1270]: Updating quality/quality_changes due to material change 2019-04-19 17:54:25,551 - DEBUG - [MainThread] cura.Settings.MachineManager._updateQualityWithMaterial [1277]: Current quality type = [draft] 2019-04-19 17:54:25,556 - INFO - [MainThread] cura.Settings.MachineManager._updateQualityWithMaterial [1291]: Current available quality type [draft] is available, applying changes. 2019-04-19 17:54:25,624 - DEBUG - [MainThread] cura.Machines.QualityManager.initialize [136]: Lookup tables updated. 2019-04-19 17:54:25,672 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._checkStack [140]: Need to check for errors again. Discard the current progress and reschedule a check. 2019-04-19 17:54:25,727 - DEBUG - [MainThread] cura.Machines.Models.QualityProfilesDropDownMenuModel._update [61]: Updating QualityProfilesDropDownMenuModel. 2019-04-19 17:54:25,729 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container coarse 2019-04-19 17:54:25,737 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [coarse] added. 2019-04-19 17:54:25,775 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container extra_coarse 2019-04-19 17:54:25,783 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [extra_coarse] added. 2019-04-19 17:54:25,822 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container fast 2019-04-19 17:54:25,831 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [fast] added. 2019-04-19 17:54:25,918 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container high 2019-04-19 17:54:25,926 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [high] added. 2019-04-19 17:54:25,969 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container normal 2019-04-19 17:54:25,978 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [normal] added. 2019-04-19 17:54:25,980 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container extra_fast 2019-04-19 17:54:25,988 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [extra_fast] added. 2019-04-19 17:54:26,041 - DEBUG - [MainThread] cura.Machines.Models.CustomQualityProfilesDropDownMenuModel._update [15]: Updating CustomQualityProfilesDropDownMenuModel. 2019-04-19 17:54:26,050 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._rescheduleCheck [136]: New error check scheduled. 2019-04-19 17:54:27,372 - DEBUG - [MainThread] UM.Qt.QtRenderer._initialize [183]: Support for Vertex Array Objects: True 2019-04-19 17:54:27,390 - DEBUG - [MainThread] UM.View.GL.OpenGL.__init__ [99]: Initialized OpenGL subsystems. 2019-04-19 17:54:27,394 - DEBUG - [MainThread] UM.View.GL.OpenGL.__init__ [100]: OpenGL Version: 3.3.0 2019-04-19 17:54:27,399 - DEBUG - [MainThread] UM.View.GL.OpenGL.__init__ [101]: OpenGL Vendor: NVIDIA Corporation 2019-04-19 17:54:27,405 - DEBUG - [MainThread] UM.View.GL.OpenGL.__init__ [102]: OpenGL Renderer: GeForce 9500 GT/PCIe/SSE2 2019-04-19 17:54:27,410 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\default.shader]... 2019-04-19 17:54:27,418 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\selection.shader]... 2019-04-19 17:54:27,426 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\default.shader]... 2019-04-19 17:54:27,434 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\composite.shader]... 2019-04-19 17:54:27,444 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\overhang.shader]... 2019-04-19 17:54:27,452 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\striped.shader]... 2019-04-19 17:54:27,461 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\transparent_object.shader]... 2019-04-19 17:54:27,470 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\striped.shader]... 2019-04-19 17:54:27,480 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\default.shader]... 2019-04-19 17:54:27,488 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\grid.shader]... 2019-04-19 17:54:27,497 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\platform.shader]... 2019-04-19 17:54:27,636 - DEBUG - [MainThread] cura.Machines.QualityManager.initialize [136]: Lookup tables updated. 2019-04-19 17:54:27,759 - DEBUG - [MainThread] cura.Machines.Models.QualityProfilesDropDownMenuModel._update [61]: Updating QualityProfilesDropDownMenuModel. 2019-04-19 17:54:27,790 - DEBUG - [MainThread] cura.Machines.Models.CustomQualityProfilesDropDownMenuModel._update [15]: Updating CustomQualityProfilesDropDownMenuModel. 2019-04-19 17:54:30,021 - INFO - [MainThread] cura.Machines.MachineErrorChecker._setResult [188]: Error check finished, result = False, time = 4.0s 2019-04-19 17:54:35,517 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] [ERROR] Could not connect to the given address 2019-04-19 17:54:35,612 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onBackendQuit [811]: Backend quit with return code 0. Resetting process and socket. 2019-04-19 17:54:37,715 - DEBUG - [MainThread] cura.AutoSave._onTimeout [48]: Autosaving preferences, instances and profiles 2019-04-19 17:54:40,161 - INFO - [Thread-3] STLReader.STLReader.load_file [46]: Using NumPy-STL to load STL data. 2019-04-19 17:54:40,181 - DEBUG - [Thread-3] UM.Mesh.MeshData.calculateNormalsFromVertices [444]: Calculating normals took 0.004998683929443359 seconds 2019-04-19 17:54:40,184 - DEBUG - [Thread-3] STLReader.STLReader._read [97]: Loaded a mesh with 82644 vertices 2019-04-19 17:54:40,244 - DEBUG - [Thread-3] UM.Mesh.MeshData.approximateConvexHull [401]: approximateConvexHull(target_count=1024) Calculating 3D convex hull took 0.055002689361572266 seconds. 351 input vertices. 351 output vertices. 2019-04-19 17:54:40,325 - DEBUG - [Thread-3] UM.FileHandler.ReadFileJob.run [69]: Loading file took 0.2 seconds 2019-04-19 17:54:40,382 - DEBUG - [Thread-3] UM.Mesh.MeshData.approximateConvexHull [401]: approximateConvexHull(target_count=1024) Calculating 3D convex hull took 0.05100083351135254 seconds. 351 input vertices. 351 output vertices. 2019-04-19 17:54:40,403 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [per_object_stack_2494788975640] added. 2019-04-19 17:54:40,452 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\transparent_object.shader]... 2019-04-19 17:54:46,288 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend.slice [228]: Starting to slice... 2019-04-19 17:54:46,289 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend.slice [246]: Going to slice build plate [0]! 2019-04-19 17:54:46,295 - DEBUG - [MainThread] UM.Backend.Backend._createSocket [227]: Previous socket existed. Closing that first. 2019-04-19 17:54:46,698 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [187]: Socket state changed to Listening 2019-04-19 17:54:46,740 - INFO - [MainThread] UM.Backend.Backend.startEngine [81]: Started engine process: C:\Program Files\Ultimaker Cura 4.0\CuraEngine.exe 2019-04-19 17:54:46,752 - DEBUG - [MainThread] UM.Backend.Backend._backendLog [101]: [Backend] Calling engine with: ['C:\\Program Files\\Ultimaker Cura 4.0\\CuraEngine.exe', 'connect', '127.0.0.1:49675', ''] 2019-04-19 17:54:46,834 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:54:46,850 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] Cura_SteamEngine version 4.0.0 2019-04-19 17:54:46,858 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] Copyright (C) 2018 Ultimaker 2019-04-19 17:54:46,867 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:54:46,880 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] This program is free software: you can redistribute it and/or modify 2019-04-19 17:54:46,889 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] it under the terms of the GNU Affero General Public License as published by 2019-04-19 17:54:46,898 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] the Free Software Foundation, either version 3 of the License, or 2019-04-19 17:54:47,137 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] (at your option) any later version. 2019-04-19 17:54:47,148 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:54:47,154 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] This program is distributed in the hope that it will be useful, 2019-04-19 17:54:47,160 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] but WITHOUT ANY WARRANTY; without even the implied warranty of 2019-04-19 17:54:47,165 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the 2019-04-19 17:54:47,171 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] GNU Affero General Public License for more details. 2019-04-19 17:54:47,177 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:54:47,184 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] You should have received a copy of the GNU Affero General Public License 2019-04-19 17:54:47,189 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] along with this program. If not, see <http://www.gnu.org/licenses/>. 2019-04-19 17:54:47,582 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onStartSliceCompleted [432]: Sending slice message took 1.2929794788360596 seconds 2019-04-19 17:54:59,398 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\toolhandle.shader]... 2019-04-19 17:55:01,887 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._terminate [295]: Attempting to kill the engine process 2019-04-19 17:55:01,888 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._terminate [301]: Killing engine process 2019-04-19 17:55:01,894 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._terminate [304]: Engine process is killed. Received return code 1 2019-04-19 17:55:01,899 - DEBUG - [MainThread] UM.Backend.Backend._createSocket [227]: Previous socket existed. Closing that first. 2019-04-19 17:55:01,916 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [187]: Socket state changed to Listening 2019-04-19 17:55:01,930 - INFO - [MainThread] UM.Backend.Backend.startEngine [81]: Started engine process: C:\Program Files\Ultimaker Cura 4.0\CuraEngine.exe 2019-04-19 17:55:01,935 - DEBUG - [MainThread] UM.Backend.Backend._backendLog [101]: [Backend] Calling engine with: ['C:\\Program Files\\Ultimaker Cura 4.0\\CuraEngine.exe', 'connect', '127.0.0.1:49675', ''] 2019-04-19 17:55:02,000 - DEBUG - [Thread-17] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:55:02,006 - DEBUG - [Thread-17] UM.Backend.Backend._backendLog [101]: [Backend] Cura_SteamEngine version 4.0.0 2019-04-19 17:55:02,012 - DEBUG - [Thread-17] UM.Backend.Backend._backendLog [101]: [Backend] Copyright (C) 2018 Ultimaker 2019-04-19 17:55:02,019 - DEBUG - [Thread-17] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:55:02,024 - DEBUG - [Thread-17] UM.Backend.Backend._backendLog [101]: [Backend] This program is free software: you can redistribute it and/or modify 2019-04-19 17:55:02,030 - DEBUG - [Thread-17] UM.Backend.Backend._backendLog [101]: [Backend] it under the terms of the GNU Affero General Public License as published by 2019-04-19 17:55:02,035 - DEBUG - [Thread-17] UM.Backend.Backend._backendLog [101]: [Backend] the Free Software Foundation, either version 3 of the License, or 2019-04-19 17:55:02,040 - DEBUG - [Thread-17] UM.Backend.Backend._backendLog [101]: [Backend] (at your option) any later version. 2019-04-19 17:55:02,044 - DEBUG - [Thread-17] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:55:02,049 - DEBUG - [Thread-17] UM.Backend.Backend._backendLog [101]: [Backend] This program is distributed in the hope that it will be useful, 2019-04-19 17:55:02,054 - DEBUG - [Thread-17] UM.Backend.Backend._backendLog [101]: [Backend] but WITHOUT ANY WARRANTY; without even the implied warranty of 2019-04-19 17:55:02,058 - DEBUG - [Thread-17] UM.Backend.Backend._backendLog [101]: [Backend] MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the 2019-04-19 17:55:02,063 - DEBUG - [Thread-17] UM.Backend.Backend._backendLog [101]: [Backend] GNU Affero General Public License for more details. 2019-04-19 17:55:02,067 - DEBUG - [Thread-17] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:55:02,072 - DEBUG - [Thread-17] UM.Backend.Backend._backendLog [101]: [Backend] You should have received a copy of the GNU Affero General Public License 2019-04-19 17:55:02,076 - DEBUG - [Thread-17] UM.Backend.Backend._backendLog [101]: [Backend] along with this program. If not, see <http://www.gnu.org/licenses/>. 2019-04-19 17:55:03,013 - DEBUG - [MainThread] cura.TaskManagement.OnExitCallbackManager.triggerNextCallback [51]: No more on-app-exit callbacks to process. Tell the app to exit. 2019-04-19 17:55:03,018 - INFO - [MainThread] cura.CuraApplication.closeApplication [547]: Close application 2019-04-19 17:55:03,037 - DEBUG - [MainThread] UM.Qt.QtApplication.windowClosed [417]: Shutting down cura 2019-04-19 17:55:03,110 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._terminate [295]: Attempting to kill the engine process 2019-04-19 17:55:03,111 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._terminate [301]: Killing engine process 2019-04-19 17:55:03,120 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._terminate [304]: Engine process is killed. Received return code 1
  7. So after a long time I instaled Cura 4.0 and tried slicing something , but the progress bar just won't advance , it did not work in 3.6 either. Here is a log file : 2019-04-19 16:57:08,328 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin FileLogger 2019-04-19 16:57:08,360 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin FirmwareUpdateChecker 2019-04-19 16:57:08,391 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin FirmwareUpdater 2019-04-19 16:57:08,407 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin GCodeGzReader 2019-04-19 16:57:08,422 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin GCodeGzWriter 2019-04-19 16:57:08,453 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin GCodeProfileReader 2019-04-19 16:57:08,485 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin GCodeReader 2019-04-19 16:57:08,516 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin GCodeWriter 2019-04-19 16:57:08,532 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin ImageReader 2019-04-19 16:57:08,563 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin LegacyProfileReader 2019-04-19 16:57:08,578 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin LocalContainerProvider 2019-04-19 16:57:08,610 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin LocalFileOutputDevice 2019-04-19 16:57:08,625 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin MachineSettingsAction 2019-04-19 16:57:08,641 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin ModelChecker 2019-04-19 16:57:08,672 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin MonitorStage 2019-04-19 16:57:08,688 - WARNING - [MainThread] UM.Preferences.getValue [97]: Tried to get the value of non-existing setting cura/active_mode. 2019-04-19 16:57:08,703 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin PerObjectSettingsTool 2019-04-19 16:57:08,735 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin PostProcessingPlugin 2019-04-19 16:57:08,750 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin PrepareStage 2019-04-19 16:57:08,766 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin PreviewStage 2019-04-19 16:57:08,797 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin RemovableDriveOutputDevice 2019-04-19 16:57:08,844 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin SimulationView 2019-04-19 16:57:08,875 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin SliceInfoPlugin 2019-04-19 16:57:08,907 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin SolidView 2019-04-19 16:57:08,922 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin SupportEraser 2019-04-19 16:57:08,969 - DEBUG - [MainThread] cura.OAuth2.AuthorizationService.getAccessToken [106]: No auth data to retrieve the access_token from 2019-04-19 16:57:08,985 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin Toolbox 2019-04-19 16:57:09,000 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin CameraTool 2019-04-19 16:57:09,032 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin MirrorTool 2019-04-19 16:57:09,063 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin RotateTool 2019-04-19 16:57:09,094 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin ScaleTool 2019-04-19 16:57:09,125 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin SelectionTool 2019-04-19 16:57:09,157 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin TranslateTool 2019-04-19 16:57:09,203 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin UFPWriter 2019-04-19 16:57:09,235 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin UltimakerMachineActions 2019-04-19 16:57:09,453 - DEBUG - [MainThread] UM3NetworkPrinting.src.Cloud.CloudOutputDeviceManager._onLoginStateChanged [57]: Log in state changed to False 2019-04-19 16:57:09,453 - DEBUG - [MainThread] UM3NetworkPrinting.src.Cloud.CloudOutputDeviceManager._onGetRemoteClustersFinished [80]: Parsed remote clusters to [] 2019-04-19 16:57:09,453 - DEBUG - [MainThread] UM3NetworkPrinting.src.Cloud.CloudOutputDeviceManager._onGetRemoteClustersFinished [81]: Removed: 0, added: 0, updates: 0 2019-04-19 16:57:09,453 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin UM3NetworkPrinting 2019-04-19 16:57:09,485 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin UpdateChecker 2019-04-19 16:57:09,500 - INFO - [Thread-2] UpdateChecker.UpdateCheckerJob.run [36]: Checking for new version of cura 2019-04-19 16:57:09,563 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin USBPrinting 2019-04-19 16:57:09,594 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin UserAgreement 2019-04-19 16:57:09,641 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade21to22 2019-04-19 16:57:09,657 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade22to24 2019-04-19 16:57:09,688 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade25to26 2019-04-19 16:57:09,719 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade26to27 2019-04-19 16:57:09,750 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade27to30 2019-04-19 16:57:09,782 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade30to31 2019-04-19 16:57:09,813 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade32to33 2019-04-19 16:57:09,844 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade33to34 2019-04-19 16:57:09,875 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade34to35 2019-04-19 16:57:09,891 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade35to40 2019-04-19 16:57:09,922 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin SimpleView 2019-04-19 16:57:09,969 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin X3DReader 2019-04-19 16:57:10,016 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin XmlMaterialProfile 2019-04-19 16:57:10,047 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin XRayView 2019-04-19 16:57:10,078 - INFO - [MainThread] UM.VersionUpgradeManager.upgrade [143]: Looking for old configuration files to upgrade. 2019-04-19 16:57:10,078 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\packages.json, skip it 2019-04-19 16:57:10,094 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\plugins.json, skip it 2019-04-19 16:57:10,094 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\packages.json, skip it 2019-04-19 16:57:10,094 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\plugins.json, skip it 2019-04-19 16:57:10,110 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\packages.json, skip it 2019-04-19 16:57:10,110 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\plugins.json, skip it 2019-04-19 16:57:10,125 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\packages.json, skip it 2019-04-19 16:57:10,125 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\plugins.json, skip it 2019-04-19 16:57:10,125 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\packages.json, skip it 2019-04-19 16:57:10,141 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\plugins.json, skip it 2019-04-19 16:57:10,141 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\packages.json, skip it 2019-04-19 16:57:10,141 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\plugins.json, skip it 2019-04-19 16:57:10,157 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\packages.json, skip it 2019-04-19 16:57:10,157 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\plugins.json, skip it 2019-04-19 16:57:10,172 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\packages.json, skip it 2019-04-19 16:57:10,172 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\plugins.json, skip it 2019-04-19 16:57:10,172 - INFO - [MainThread] UM.Qt.QtApplication.startSplashWindowPhase [198]: The preferences file cannot be found, will use default values 2019-04-19 16:57:10,188 - DEBUG - [MainThread] UM.Backend.Backend._onSocketError [213]: Socket was unable to bind to port, increasing port number to 49675 2019-04-19 16:57:10,188 - DEBUG - [MainThread] UM.Backend.Backend._createSocket [227]: Previous socket existed. Closing that first. 2019-04-19 16:57:10,188 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._terminate [295]: Attempting to kill the engine process 2019-04-19 16:57:10,203 - DEBUG - [MainThread] UM.Backend.Backend._createSocket [227]: Previous socket existed. Closing that first. 2019-04-19 16:57:10,203 - INFO - [MainThread] UM.Qt.QtApplication.startSplashWindowPhase [207]: The preferences file 'None' cannot be found, will use default values 2019-04-19 16:57:10,391 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [187]: Socket state changed to Listening 2019-04-19 16:57:10,407 - INFO - [MainThread] UM.Backend.Backend.startEngine [81]: Started engine process: C:\Program Files\Ultimaker Cura 4.0\CuraEngine.exe 2019-04-19 16:57:10,407 - DEBUG - [MainThread] UM.Backend.Backend._backendLog [101]: [Backend] Calling engine with: ['C:\\Program Files\\Ultimaker Cura 4.0\\CuraEngine.exe', 'connect', '127.0.0.1:49675', ''] 2019-04-19 16:57:10,453 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 16:57:10,469 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] Cura_SteamEngine version 4.0.0 2019-04-19 16:57:10,469 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] Copyright (C) 2018 Ultimaker 2019-04-19 16:57:10,469 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 16:57:10,485 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] This program is free software: you can redistribute it and/or modify 2019-04-19 16:57:10,485 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] it under the terms of the GNU Affero General Public License as published by 2019-04-19 16:57:10,485 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] the Free Software Foundation, either version 3 of the License, or 2019-04-19 16:57:10,485 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] (at your option) any later version. 2019-04-19 16:57:10,500 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 16:57:10,500 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] This program is distributed in the hope that it will be useful, 2019-04-19 16:57:10,500 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] but WITHOUT ANY WARRANTY; without even the implied warranty of 2019-04-19 16:57:10,516 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the 2019-04-19 16:57:10,516 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] GNU Affero General Public License for more details. 2019-04-19 16:57:10,516 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 16:57:10,516 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] You should have received a copy of the GNU Affero General Public License 2019-04-19 16:57:10,532 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] along with this program. If not, see <http://www.gnu.org/licenses/>. 2019-04-19 16:57:13,235 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.loadAllMetadata [338]: Loading metadata into container registry took 2.8125009536743164 seconds 2019-04-19 16:57:13,360 - DEBUG - [MainThread] cura.Scene.CuraSceneController.setActiveBuildPlate [104]: Select build plate: 0 2019-04-19 16:57:13,375 - INFO - [MainThread] cura.CuraApplication.run [695]: Initializing variant manager 2019-04-19 16:57:13,375 - DEBUG - [MainThread] cura.Machines.VariantManager.initialize [59]: Exclude variant [empty_variant] 2019-04-19 16:57:13,391 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container ultimaker_s5_glass 2019-04-19 16:57:13,391 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [ultimaker_s5_glass] added. 2019-04-19 16:57:13,391 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container ultimaker_s5 2019-04-19 16:57:13,469 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [ultimaker_s5] added. 2019-04-19 16:57:13,469 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container ultimaker_s5_aluminum 2019-04-19 16:57:13,485 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [ultimaker_s5_aluminum] added. 2019-04-19 16:57:13,485 - INFO - [MainThread] cura.CuraApplication.run [699]: Initializing material manager 2019-04-19 16:57:13,657 - INFO - [MainThread] cura.CuraApplication.run [704]: Initializing quality manager 2019-04-19 16:57:13,672 - DEBUG - [MainThread] cura.Machines.QualityManager.initialize [136]: Lookup tables updated. 2019-04-19 16:57:13,672 - INFO - [MainThread] cura.CuraApplication.run [709]: Initializing machine manager 2019-04-19 16:57:13,688 - INFO - [MainThread] cura.CuraApplication.run [712]: Initializing container manager 2019-04-19 16:57:13,688 - INFO - [MainThread] cura.CuraApplication.run [715]: Initializing machine error checker 2019-04-19 16:57:15,015 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin._createView [280]: Creating post processing plugin view. 2019-04-19 16:57:15,031 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [170]: Begin loading of script: BQ_PauseAtHeight 2019-04-19 16:57:15,031 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [170]: Begin loading of script: ChangeAtZ 2019-04-19 16:57:15,031 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [170]: Begin loading of script: DisplayFilenameAndLayerOnLCD 2019-04-19 16:57:15,031 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [170]: Begin loading of script: FilamentChange 2019-04-19 16:57:15,046 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [170]: Begin loading of script: PauseAtHeight 2019-04-19 16:57:15,046 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [170]: Begin loading of script: PauseAtHeightRepRapFirmwareDuet 2019-04-19 16:57:15,046 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [170]: Begin loading of script: PauseAtHeightforRepetier 2019-04-19 16:57:15,046 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [170]: Begin loading of script: SearchAndReplace 2019-04-19 16:57:15,062 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [170]: Begin loading of script: Stretch 2019-04-19 16:57:15,187 - DEBUG - [MainThread] UM.Qt.Bindings.Theme.load [158]: Loading theme file: C:\Program Files\Ultimaker Cura 4.0\resources\themes\cura-light\theme.json 2019-04-19 16:57:15,296 - DEBUG - [MainThread] UM.Qt.Bindings.Theme.load [230]: Loaded theme C:\Program Files\Ultimaker Cura 4.0\resources\themes\cura-light 2019-04-19 16:57:15,390 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin._createView [290]: Post processing view created. 2019-04-19 16:57:15,609 - WARNING - [MainThread] UM.Qt.Bindings.Theme.getImage [133]: No image header_pattern defined in Theme 2019-04-19 16:57:15,624 - DEBUG - [MainThread] cura.Machines.Models.BuildPlateModel._update [33]: Updating BuildPlateModel. 2019-04-19 16:57:16,624 - DEBUG - [MainThread] cura.Machines.Models.NozzleModel._update [34]: Updating NozzleModel. 2019-04-19 16:57:16,796 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/resources/qml/Menus/SettingsMenu.qml:23:20: Unable to assign [undefined] to QString 2019-04-19 16:57:16,796 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/resources/qml/Menus/MaterialMenu.qml:17:39: Unable to assign [undefined] to QString 2019-04-19 16:57:16,796 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/resources/qml/Menus/MaterialMenu.qml:16:44: Unable to assign [undefined] to QString 2019-04-19 16:57:16,796 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/resources/qml/Menus/SettingsMenu.qml:43: TypeError: Cannot read property 'isEnabled' of null 2019-04-19 16:57:16,812 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/resources/qml/Menus/SettingsMenu.qml:50: TypeError: Cannot read property 'isEnabled' of null 2019-04-19 16:57:16,812 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/resources/qml/Menus/SettingsMenu.qml:19: TypeError: Cannot read property 'extruderList' of null 2019-04-19 16:57:16,827 - DEBUG - [MainThread] UM3NetworkPrinting.src.DiscoverUM3Action._createAdditionalComponentsView [196]: Creating additional ui components for UM3. 2019-04-19 16:57:16,874 - DEBUG - [MainThread] UM3NetworkPrinting.src.DiscoverUM3Action.startDiscovery [47]: Starting device discovery. 2019-04-19 16:57:16,983 - DEBUG - [MainThread] UM.Controller.setActiveStage [159]: Setting active stage to PrepareStage 2019-04-19 16:57:17,146 - DEBUG - [MainThread] cura.Machines.Models.NozzleModel._update [34]: Updating NozzleModel. 2019-04-19 16:57:17,192 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/resources/qml/Menus/MaterialMenu.qml:17:39: Unable to assign [undefined] to QString 2019-04-19 16:57:17,196 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/resources/qml/Menus/MaterialMenu.qml:16:44: Unable to assign [undefined] to QString 2019-04-19 16:57:17,278 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/plugins/PrepareStage/PrepareMain.qml:16:5: QML ActionPanelWidget: Binding loop detected for property "width" 2019-04-19 16:57:17,283 - DEBUG - [MainThread] UM.Controller.setActiveView [92]: Setting active view to SolidView 2019-04-19 16:57:17,286 - DEBUG - [MainThread] ModelChecker.ModelChecker._createView [103]: Creating model checker view. 2019-04-19 16:57:17,300 - DEBUG - [MainThread] ModelChecker.ModelChecker._createView [112]: Model checker view created. 2019-04-19 16:57:17,302 - DEBUG - [MainThread] SliceInfoPlugin.SliceInfo._createDialog [82]: Creating dialog [MoreInfoWindow.qml] 2019-04-19 16:57:17,374 - DEBUG - [MainThread] cura.CuraApplication.run [747]: Booting Cura took 10.725345849990845 seconds 2019-04-19 16:57:17,469 - DEBUG - [MainThread] cura.Machines.Models.QualityProfilesDropDownMenuModel._update [61]: Updating QualityProfilesDropDownMenuModel. 2019-04-19 16:57:17,474 - DEBUG - [MainThread] cura.Machines.Models.QualityProfilesDropDownMenuModel._update [66]: No active GlobalStack, set quality profile model as empty. 2019-04-19 16:57:17,479 - DEBUG - [MainThread] cura.Machines.Models.CustomQualityProfilesDropDownMenuModel._update [15]: Updating CustomQualityProfilesDropDownMenuModel. 2019-04-19 16:57:17,484 - DEBUG - [MainThread] cura.Machines.Models.CustomQualityProfilesDropDownMenuModel._update [20]: No active GlobalStack, set CustomQualityProfilesDropDownMenuModel as empty. 2019-04-19 16:57:17,759 - DEBUG - [MainThread] UM.Qt.QtRenderer._initialize [183]: Support for Vertex Array Objects: True 2019-04-19 16:57:17,776 - DEBUG - [MainThread] UM.View.GL.OpenGL.__init__ [99]: Initialized OpenGL subsystems. 2019-04-19 16:57:17,781 - DEBUG - [MainThread] UM.View.GL.OpenGL.__init__ [100]: OpenGL Version: 3.3.0 2019-04-19 16:57:17,785 - DEBUG - [MainThread] UM.View.GL.OpenGL.__init__ [101]: OpenGL Vendor: NVIDIA Corporation 2019-04-19 16:57:17,790 - DEBUG - [MainThread] UM.View.GL.OpenGL.__init__ [102]: OpenGL Renderer: GeForce 9500 GT/PCIe/SSE2 2019-04-19 16:57:17,794 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\default.shader]... 2019-04-19 16:57:17,802 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\selection.shader]... 2019-04-19 16:57:17,809 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\default.shader]... 2019-04-19 16:57:17,816 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\composite.shader]... 2019-04-19 16:57:17,824 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\overhang.shader]... 2019-04-19 16:57:17,832 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\striped.shader]... 2019-04-19 16:57:17,840 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\transparent_object.shader]... 2019-04-19 16:57:17,848 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\striped.shader]... 2019-04-19 16:57:17,856 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\platform.shader]... 2019-04-19 16:57:25,360 - INFO - [MainThread] UserAgreement.UserAgreement.didAgree [35]: User agreed to the user agreement 2019-04-19 16:57:31,081 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container creality_cr10 2019-04-19 16:57:31,159 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [creality_cr10] added. 2019-04-19 16:57:31,206 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [Creality CR-10_settings] added. 2019-04-19 16:57:31,222 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [Creality CR-10_user] added. 2019-04-19 16:57:31,222 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container creality_cr10_extruder_0 2019-04-19 16:57:31,222 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [creality_cr10_extruder_0] added. 2019-04-19 16:57:31,222 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container generic_pla_175 2019-04-19 16:57:31,237 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [generic_pla_175_imade3d_jellybox] added. 2019-04-19 16:57:31,253 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [generic_pla_175_imade3d_jellybox_0.4_mm] added. 2019-04-19 16:57:31,253 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [generic_pla_175_imade3d_jellybox_0.4_mm_2-fans] added. 2019-04-19 16:57:31,253 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [generic_pla_175_cartesio] added. 2019-04-19 16:57:31,269 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [generic_pla_175_cartesio_0.25mm_thermoplastic_extruder] added. 2019-04-19 16:57:31,269 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [generic_pla_175_cartesio_0.4mm_thermoplastic_extruder] added. 2019-04-19 16:57:31,269 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [generic_pla_175_cartesio_0.8mm_thermoplastic_extruder] added. 2019-04-19 16:57:31,284 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [generic_pla_175] added. 2019-04-19 16:57:31,331 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [creality_cr10_extruder_0 #2_settings] added. 2019-04-19 16:57:31,331 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [creality_cr10_extruder_0 #2_user] added. 2019-04-19 16:57:31,347 - INFO - [MainThread] cura.Settings.GlobalStack.addExtruder [136]: Extruder[creality_cr10_extruder_0 #2] added to [Creality CR-10] at position [0] 2019-04-19 16:57:31,347 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/resources/qml/Menus/MaterialMenu.qml:17:39: Unable to assign [undefined] to QString 2019-04-19 16:57:31,347 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/resources/qml/Menus/MaterialMenu.qml:17:39: Unable to assign [undefined] to QString 2019-04-19 16:57:31,362 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [creality_cr10_extruder_0 #2] added. 2019-04-19 16:57:31,362 - WARNING - [MainThread] UM.Settings.ContainerRegistry.addContainer [375]: Container with ID creality_cr10_extruder_0 #2 was already added. 2019-04-19 16:57:31,362 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container draft 2019-04-19 16:57:31,378 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [draft] added. 2019-04-19 16:57:31,378 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [Creality CR-10] added. 2019-04-19 16:57:31,378 - INFO - [MainThread] cura.MachineActionManager.addDefaultMachineActions [72]: Default machine actions added for machine definition [creality_cr10] 2019-04-19 16:57:31,394 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container fdmprinter 2019-04-19 16:57:31,472 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [fdmprinter] added. 2019-04-19 16:57:31,487 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] [ERROR] Could not connect to the given address 2019-04-19 16:57:31,519 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/resources/qml/Menus/MaterialMenu.qml:16:44: Unable to assign [undefined] to QString 2019-04-19 16:57:31,519 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/resources/qml/Menus/MaterialMenu.qml:17:39: Unable to assign [undefined] to QString 2019-04-19 16:57:31,519 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/resources/qml/Menus/MaterialMenu.qml:17:39: Unable to assign [undefined] to QString 2019-04-19 16:57:31,534 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/resources/qml/Menus/MaterialMenu.qml:17:39: Unable to assign [undefined] to QString 2019-04-19 16:57:31,550 - DEBUG - [MainThread] UM3NetworkPrinting.src.UM3OutputDevicePlugin.checkCloudFlowIsPossible [412]: Checking if cloud connection is possible... 2019-04-19 16:57:31,550 - DEBUG - [MainThread] UM3NetworkPrinting.src.UM3OutputDevicePlugin.checkCloudFlowIsPossible [435]: Cloud Flow not possible: User not logged in! 2019-04-19 16:57:31,721 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/resources/qml/Menus/SettingsMenu.qml:50: TypeError: Cannot read property 'isEnabled' of null 2019-04-19 16:57:31,726 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/resources/qml/Menus/SettingsMenu.qml:43: TypeError: Cannot read property 'isEnabled' of null 2019-04-19 16:57:31,731 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/resources/qml/Menus/MaterialMenu.qml:16:44: Unable to assign [undefined] to QString 2019-04-19 16:57:31,736 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/resources/qml/Menus/MaterialMenu.qml:17:39: Unable to assign [undefined] to QString 2019-04-19 16:57:31,741 - DEBUG - [MainThread] cura.Machines.Models.NozzleModel._update [34]: Updating NozzleModel. 2019-04-19 16:57:31,803 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/resources/qml/Menus/MaterialMenu.qml:16:44: Unable to assign [undefined] to QString 2019-04-19 16:57:31,854 - DEBUG - [MainThread] cura.Machines.Models.BuildPlateModel._update [33]: Updating BuildPlateModel. 2019-04-19 16:57:31,859 - DEBUG - [MainThread] cura.Machines.Models.NozzleModel._update [34]: Updating NozzleModel. 2019-04-19 16:57:31,864 - DEBUG - [MainThread] cura.Machines.Models.NozzleModel._update [34]: Updating NozzleModel. 2019-04-19 16:57:31,869 - DEBUG - [MainThread] cura.Machines.Models.NozzleModel._update [34]: Updating NozzleModel. 2019-04-19 16:57:31,921 - WARNING - [MainThread] cura.Settings.GlobalStack.addExtruder [132]: Extruder [creality_cr10_extruder_0 #2] has already been added to this stack [Creality CR-10] 2019-04-19 16:57:31,926 - WARNING - [MainThread] cura.Settings.ExtruderManager.registerExtruder [169]: Extruder [creality_cr10_extruder_0 #2] has already been registered on machine [Creality CR-10], not doing anything 2019-04-19 16:57:31,990 - INFO - [MainThread] cura.Settings.MachineManager._initMachineState [337]: Machine 'Creality CR-10' quality set to 'draft' 2019-04-19 16:57:31,997 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/resources/qml/Menus/SettingsMenu.qml:50: TypeError: Cannot read property 'isEnabled' of null 2019-04-19 16:57:32,002 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/resources/qml/Menus/SettingsMenu.qml:43: TypeError: Cannot read property 'isEnabled' of null 2019-04-19 16:57:32,007 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/resources/qml/Menus/MaterialMenu.qml:16:44: Unable to assign [undefined] to QString 2019-04-19 16:57:32,012 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/resources/qml/Menus/MaterialMenu.qml:17:39: Unable to assign [undefined] to QString 2019-04-19 16:57:32,018 - DEBUG - [MainThread] cura.Machines.Models.NozzleModel._update [34]: Updating NozzleModel. 2019-04-19 16:57:32,126 - DEBUG - [MainThread] cura.Machines.Models.BuildPlateModel._update [33]: Updating BuildPlateModel. 2019-04-19 16:57:32,131 - DEBUG - [MainThread] cura.Machines.Models.NozzleModel._update [34]: Updating NozzleModel. 2019-04-19 16:57:32,136 - DEBUG - [MainThread] cura.Machines.Models.NozzleModel._update [34]: Updating NozzleModel. 2019-04-19 16:57:32,142 - DEBUG - [MainThread] cura.Machines.Models.NozzleModel._update [34]: Updating NozzleModel. 2019-04-19 16:57:32,154 - DEBUG - [MainThread] cura.Machines.Models.NozzleModel._update [34]: Updating NozzleModel. 2019-04-19 16:57:32,456 - INFO - [MainThread] FirmwareUpdateChecker.FirmwareUpdateChecker.checkFirmwareVersion [76]: No machine with name Creality CR-10 in list of firmware to check. 2019-04-19 16:57:32,461 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onBackendQuit [811]: Backend quit with return code 0. Resetting process and socket. 2019-04-19 16:57:32,592 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._rescheduleCheck [136]: New error check scheduled. 2019-04-19 16:57:32,621 - DEBUG - [MainThread] cura.Machines.Models.QualityProfilesDropDownMenuModel._update [61]: Updating QualityProfilesDropDownMenuModel. 2019-04-19 16:57:32,623 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container coarse 2019-04-19 16:57:32,631 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [coarse] added. 2019-04-19 16:57:32,668 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container extra_coarse 2019-04-19 16:57:32,676 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [extra_coarse] added. 2019-04-19 16:57:32,714 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container fast 2019-04-19 16:57:32,722 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [fast] added. 2019-04-19 16:57:32,808 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container high 2019-04-19 16:57:32,816 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [high] added. 2019-04-19 16:57:32,858 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container normal 2019-04-19 16:57:32,993 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [normal] added. 2019-04-19 16:57:32,995 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container extra_fast 2019-04-19 16:57:33,003 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [extra_fast] added. 2019-04-19 16:57:33,055 - DEBUG - [MainThread] cura.Machines.Models.CustomQualityProfilesDropDownMenuModel._update [15]: Updating CustomQualityProfilesDropDownMenuModel. 2019-04-19 16:57:33,060 - INFO - [MainThread] cura.Machines.QualityManager.getQualityChangesGroups [179]: Cannot find node for machine def [fdmprinter] in QualityChanges lookup table 2019-04-19 16:57:33,065 - INFO - [MainThread] cura.Machines.MaterialManager._updateMaps [279]: Updating material lookup data ... 2019-04-19 16:57:33,132 - INFO - [MainThread] cura.Settings.MachineManager._updateQualityWithMaterial [1270]: Updating quality/quality_changes due to material change 2019-04-19 16:57:33,138 - DEBUG - [MainThread] cura.Settings.MachineManager._updateQualityWithMaterial [1277]: Current quality type = [draft] 2019-04-19 16:57:33,142 - INFO - [MainThread] cura.Settings.MachineManager._updateQualityWithMaterial [1291]: Current available quality type [draft] is available, applying changes. 2019-04-19 16:57:33,219 - DEBUG - [MainThread] cura.Machines.QualityManager.initialize [136]: Lookup tables updated. 2019-04-19 16:57:33,412 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\default.shader]... 2019-04-19 16:57:33,419 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\grid.shader]... 2019-04-19 16:57:33,827 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._checkStack [140]: Need to check for errors again. Discard the current progress and reschedule a check. 2019-04-19 16:57:33,885 - DEBUG - [MainThread] cura.Machines.Models.QualityProfilesDropDownMenuModel._update [61]: Updating QualityProfilesDropDownMenuModel. 2019-04-19 16:57:33,910 - DEBUG - [MainThread] cura.Machines.Models.CustomQualityProfilesDropDownMenuModel._update [15]: Updating CustomQualityProfilesDropDownMenuModel. 2019-04-19 16:57:33,915 - INFO - [MainThread] cura.Machines.QualityManager.getQualityChangesGroups [179]: Cannot find node for machine def [fdmprinter] in QualityChanges lookup table 2019-04-19 16:57:33,921 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._rescheduleCheck [136]: New error check scheduled. 2019-04-19 16:57:33,981 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._checkStack [140]: Need to check for errors again. Discard the current progress and reschedule a check. 2019-04-19 16:57:34,550 - DEBUG - [MainThread] cura.Machines.QualityManager.initialize [136]: Lookup tables updated. 2019-04-19 16:57:34,669 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._rescheduleCheck [136]: New error check scheduled. 2019-04-19 16:57:34,674 - DEBUG - [MainThread] cura.Machines.Models.QualityProfilesDropDownMenuModel._update [61]: Updating QualityProfilesDropDownMenuModel. 2019-04-19 16:57:34,695 - DEBUG - [MainThread] cura.Machines.Models.CustomQualityProfilesDropDownMenuModel._update [15]: Updating CustomQualityProfilesDropDownMenuModel. 2019-04-19 16:57:34,699 - INFO - [MainThread] cura.Machines.QualityManager.getQualityChangesGroups [179]: Cannot find node for machine def [fdmprinter] in QualityChanges lookup table 2019-04-19 16:57:36,637 - INFO - [MainThread] cura.Machines.MachineErrorChecker._setResult [188]: Error check finished, result = False, time = 2.0s 2019-04-19 16:57:43,980 - DEBUG - [MainThread] cura.AutoSave._onTimeout [48]: Autosaving preferences, instances and profiles 2019-04-19 16:57:58,205 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._rescheduleCheck [136]: New error check scheduled. 2019-04-19 16:57:59,325 - INFO - [MainThread] cura.Machines.MachineErrorChecker._setResult [188]: Error check finished, result = False, time = 1.1s 2019-04-19 16:58:08,085 - DEBUG - [MainThread] cura.AutoSave._onTimeout [48]: Autosaving preferences, instances and profiles 2019-04-19 16:58:09,096 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._rescheduleCheck [136]: New error check scheduled. 2019-04-19 16:58:10,466 - INFO - [MainThread] cura.Machines.MachineErrorChecker._setResult [188]: Error check finished, result = False, time = 1.4s 2019-04-19 16:58:18,974 - DEBUG - [MainThread] cura.AutoSave._onTimeout [48]: Autosaving preferences, instances and profiles 2019-04-19 17:01:51,278 - DEBUG - [MainThread] cura.AutoSave._onTimeout [48]: Autosaving preferences, instances and profiles 2019-04-19 17:01:57,921 - WARNING - [MainThread] UM.PluginRegistry._populateMetaData [604]: Could not find plugin global_stack 2019-04-19 17:01:57,930 - WARNING - [MainThread] UM.PluginRegistry._populateMetaData [604]: Could not find plugin extruder_stack 2019-04-19 17:01:57,952 - WARNING - [MainThread] cura.Settings.ContainerManager.getContainerMetaDataEntry [65]: Could not get metadata of container Unknown because it was not found. 2019-04-19 17:01:58,189 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/resources/qml/Preferences/Materials/MaterialsBrandSection.qml:97:5: QML Column: Binding loop detected for property "height" 2019-04-19 17:01:58,311 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/resources/qml/Preferences/Materials/MaterialsPage.qml:236:13: QML MaterialsList: Binding loop detected for property "height" 2019-04-19 17:01:58,317 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/resources/qml/Preferences/Materials/MaterialsList.qml:135:5: QML Column: Binding loop detected for property "height" 2019-04-19 17:02:00,831 - DEBUG - [MainThread] cura.Machines.Models.QualityManagementModel._update [38]: Updating QualityManagementModel. 2019-04-19 17:02:00,847 - INFO - [MainThread] cura.Machines.QualityManager.getQualityChangesGroups [179]: Cannot find node for machine def [fdmprinter] in QualityChanges lookup table 2019-04-19 17:02:00,971 - DEBUG - [MainThread] cura.Machines.Models.QualitySettingsModel._update [73]: Updating QualitySettingsModel. 2019-04-19 17:02:00,976 - DEBUG - [MainThread] cura.Machines.Models.QualitySettingsModel._update [73]: Updating QualitySettingsModel. 2019-04-19 17:02:01,091 - DEBUG - [MainThread] cura.Machines.Models.QualitySettingsModel._update [73]: Updating QualitySettingsModel. 2019-04-19 17:02:08,211 - DEBUG - [MainThread] cura.AutoSave._onTimeout [48]: Autosaving preferences, instances and profiles 2019-04-19 17:02:17,265 - DEBUG - [MainThread] cura.Settings.CuraContainerRegistry.importProfile [168]: Attempting to import profile C:/Users/andre/Desktop/PETG.curaprofile 2019-04-19 17:02:17,328 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [creality_cr10_petg] added. 2019-04-19 17:02:17,343 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [creality_cr10_extruder_0_petg] added. 2019-04-19 17:02:17,766 - DEBUG - [MainThread] cura.Machines.QualityManager.initialize [136]: Lookup tables updated. 2019-04-19 17:02:17,773 - DEBUG - [MainThread] cura.Machines.Models.QualityManagementModel._update [38]: Updating QualityManagementModel. 2019-04-19 17:02:17,784 - DEBUG - [MainThread] cura.Machines.Models.QualitySettingsModel._update [73]: Updating QualitySettingsModel. 2019-04-19 17:02:17,888 - DEBUG - [MainThread] cura.Machines.Models.QualityProfilesDropDownMenuModel._update [61]: Updating QualityProfilesDropDownMenuModel. 2019-04-19 17:02:17,987 - DEBUG - [MainThread] cura.Machines.Models.CustomQualityProfilesDropDownMenuModel._update [15]: Updating CustomQualityProfilesDropDownMenuModel. 2019-04-19 17:02:23,177 - DEBUG - [MainThread] cura.Settings.CuraContainerRegistry.importProfile [168]: Attempting to import profile C:/Users/andre/Desktop/PLA.curaprofile 2019-04-19 17:02:23,224 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [creality_cr10_pla] added. 2019-04-19 17:02:23,255 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [creality_cr10_extruder_0_pla] added. 2019-04-19 17:02:23,607 - DEBUG - [MainThread] cura.Machines.QualityManager.initialize [136]: Lookup tables updated. 2019-04-19 17:02:23,612 - DEBUG - [MainThread] cura.Machines.Models.QualityManagementModel._update [38]: Updating QualityManagementModel. 2019-04-19 17:02:23,620 - DEBUG - [MainThread] cura.Machines.Models.QualitySettingsModel._update [73]: Updating QualitySettingsModel. 2019-04-19 17:02:23,718 - DEBUG - [MainThread] cura.Machines.Models.QualityProfilesDropDownMenuModel._update [61]: Updating QualityProfilesDropDownMenuModel. 2019-04-19 17:02:23,834 - DEBUG - [MainThread] cura.Machines.Models.CustomQualityProfilesDropDownMenuModel._update [15]: Updating CustomQualityProfilesDropDownMenuModel. 2019-04-19 17:02:27,377 - DEBUG - [MainThread] cura.AutoSave._onTimeout [48]: Autosaving preferences, instances and profiles 2019-04-19 17:02:28,133 - DEBUG - [MainThread] cura.Settings.CuraContainerRegistry.importProfile [168]: Attempting to import profile C:/Users/andre/Desktop/Polyflex.curaprofile 2019-04-19 17:02:28,164 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [creality_cr10_polyflex] added. 2019-04-19 17:02:28,195 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [creality_cr10_extruder_0_polyflex] added. 2019-04-19 17:02:28,559 - DEBUG - [MainThread] cura.Machines.QualityManager.initialize [136]: Lookup tables updated. 2019-04-19 17:02:28,565 - DEBUG - [MainThread] cura.Machines.Models.QualityManagementModel._update [38]: Updating QualityManagementModel. 2019-04-19 17:02:28,573 - DEBUG - [MainThread] cura.Machines.Models.QualitySettingsModel._update [73]: Updating QualitySettingsModel. 2019-04-19 17:02:28,670 - DEBUG - [MainThread] cura.Machines.Models.QualityProfilesDropDownMenuModel._update [61]: Updating QualityProfilesDropDownMenuModel. 2019-04-19 17:02:28,790 - DEBUG - [MainThread] cura.Machines.Models.CustomQualityProfilesDropDownMenuModel._update [15]: Updating CustomQualityProfilesDropDownMenuModel. 2019-04-19 17:02:33,314 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._rescheduleCheck [136]: New error check scheduled. 2019-04-19 17:02:33,335 - DEBUG - [MainThread] cura.Machines.Models.QualityProfilesDropDownMenuModel._update [61]: Updating QualityProfilesDropDownMenuModel. 2019-04-19 17:02:33,353 - DEBUG - [MainThread] cura.Machines.Models.CustomQualityProfilesDropDownMenuModel._update [15]: Updating CustomQualityProfilesDropDownMenuModel. 2019-04-19 17:02:35,370 - INFO - [MainThread] cura.Machines.MachineErrorChecker._setResult [188]: Error check finished, result = False, time = 2.0s 2019-04-19 17:02:48,842 - DEBUG - [MainThread] cura.AutoSave._onTimeout [48]: Autosaving preferences, instances and profiles 2019-04-19 17:04:55,605 - INFO - [Thread-1] STLReader.STLReader.load_file [46]: Using NumPy-STL to load STL data. 2019-04-19 17:04:55,615 - DEBUG - [Thread-1] UM.Mesh.MeshData.calculateNormalsFromVertices [444]: Calculating normals took 0.0009968280792236328 seconds 2019-04-19 17:04:55,616 - DEBUG - [Thread-1] STLReader.STLReader._read [97]: Loaded a mesh with 11556 vertices 2019-04-19 17:04:55,637 - DEBUG - [Thread-1] UM.Mesh.MeshData.approximateConvexHull [401]: approximateConvexHull(target_count=1024) Calculating 3D convex hull took 0.01399993896484375 seconds. 208 input vertices. 208 output vertices. 2019-04-19 17:04:55,723 - DEBUG - [Thread-1] UM.FileHandler.ReadFileJob.run [69]: Loading file took 0.1 seconds 2019-04-19 17:04:55,750 - DEBUG - [Thread-1] UM.Mesh.MeshData.approximateConvexHull [401]: approximateConvexHull(target_count=1024) Calculating 3D convex hull took 0.023181915283203125 seconds. 208 input vertices. 208 output vertices. 2019-04-19 17:04:55,816 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [per_object_stack_1854010908624] added. 2019-04-19 17:04:55,861 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\transparent_object.shader]... 2019-04-19 17:04:56,640 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\toolhandle.shader]... 2019-04-19 17:05:01,427 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend.slice [228]: Starting to slice... 2019-04-19 17:05:01,427 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend.slice [246]: Going to slice build plate [0]! 2019-04-19 17:05:01,427 - DEBUG - [MainThread] UM.Backend.Backend._createSocket [227]: Previous socket existed. Closing that first. 2019-04-19 17:05:01,537 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [187]: Socket state changed to Listening 2019-04-19 17:05:01,646 - INFO - [MainThread] UM.Backend.Backend.startEngine [81]: Started engine process: C:\Program Files\Ultimaker Cura 4.0\CuraEngine.exe 2019-04-19 17:05:01,662 - DEBUG - [MainThread] UM.Backend.Backend._backendLog [101]: [Backend] Calling engine with: ['C:\\Program Files\\Ultimaker Cura 4.0\\CuraEngine.exe', 'connect', '127.0.0.1:49675', ''] 2019-04-19 17:05:01,719 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:05:01,782 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] Cura_SteamEngine version 4.0.0 2019-04-19 17:05:01,860 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] Copyright (C) 2018 Ultimaker 2019-04-19 17:05:01,938 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:05:01,985 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] This program is free software: you can redistribute it and/or modify 2019-04-19 17:05:02,047 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] it under the terms of the GNU Affero General Public License as published by 2019-04-19 17:05:02,110 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] the Free Software Foundation, either version 3 of the License, or 2019-04-19 17:05:02,172 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] (at your option) any later version. 2019-04-19 17:05:02,235 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:05:02,266 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] This program is distributed in the hope that it will be useful, 2019-04-19 17:05:02,266 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] but WITHOUT ANY WARRANTY; without even the implied warranty of 2019-04-19 17:05:02,282 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the 2019-04-19 17:05:02,282 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] GNU Affero General Public License for more details. 2019-04-19 17:05:02,297 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:05:02,297 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] You should have received a copy of the GNU Affero General Public License 2019-04-19 17:05:02,297 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] along with this program. If not, see <http://www.gnu.org/licenses/>. 2019-04-19 17:05:02,727 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onStartSliceCompleted [432]: Sending slice message took 1.2998261451721191 seconds 2019-04-19 17:05:05,376 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/resources/qml/RoundedRectangle.qml:68: TypeError: Cannot read property of null 2019-04-19 17:05:10,533 - INFO - [MainThread] Toolbox.src.Toolbox._makeRequestByType [553]: Requesting packages metadata from server. 2019-04-19 17:05:11,675 - INFO - [MainThread] Toolbox.src.Toolbox._makeRequestByType [553]: Requesting authors metadata from server. 2019-04-19 17:05:11,675 - DEBUG - [MainThread] Toolbox.src.Toolbox._createDialog [225]: Marketplace: Creating dialog [Toolbox.qml]. 2019-04-19 17:05:13,299 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/qml/QtQuick/Controls/ScrollView.qml:234:9: QML Binding: Binding loop detected for property "value" 2019-04-19 17:05:15,359 - DEBUG - [MainThread] cura.AutoSave._onTimeout [48]: Autosaving preferences, instances and profiles 2019-04-19 17:05:22,727 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] [ERROR] Could not connect to the given address 2019-04-19 17:05:22,827 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onBackendQuit [811]: Backend quit with return code 0. Resetting process and socket. 2019-04-19 17:05:44,406 - INFO - [MainThread] Toolbox.src.Toolbox.startDownload [562]: Attempting to download & install package from https://api.ultimaker.com/cura-packages/v1/cura/v6.0.0/packages/OrientationPlugin/download. 2019-04-19 17:05:45,059 - INFO - [MainThread] Toolbox.src.Toolbox._onDownloadComplete [680]: Download complete. 2019-04-19 17:05:45,064 - DEBUG - [MainThread] UM.PackageManager.getPackageInfo [430]: Found potential package.json file '/package.json' 2019-04-19 17:05:45,070 - DEBUG - [MainThread] UM.PackageManager.getPackageLicense [455]: Found potential license file '/files/plugins/OrientationPlugin/LICENSE' 2019-04-19 17:05:46,555 - DEBUG - [MainThread] UM.PackageManager.getPackageInfo [430]: Found potential package.json file '/package.json' 2019-04-19 17:05:46,555 - INFO - [MainThread] UM.PackageManager.installPackage [303]: Package [OrientationPlugin] version [3.2.1] is scheduled to be installed. 2019-04-19 17:05:46,571 - INFO - [MainThread] UM.PackageManager._saveManagementData [168]: Package management file C:\Users\andre\AppData\Roaming\cura\4.0\packages.json was saved 2019-04-19 17:05:53,283 - INFO - [MainThread] Toolbox.src.Toolbox.startDownload [562]: Attempting to download & install package from https://api.ultimaker.com/cura-packages/v1/cura/v6.0.0/packages/CustomSupports/download. 2019-04-19 17:05:53,619 - INFO - [MainThread] Toolbox.src.Toolbox._onDownloadComplete [680]: Download complete. 2019-04-19 17:05:53,625 - DEBUG - [MainThread] UM.PackageManager.getPackageInfo [430]: Found potential package.json file '/package.json' 2019-04-19 17:05:53,631 - DEBUG - [MainThread] UM.PackageManager.getPackageLicense [455]: Found potential license file '/files/plugins/CustomSupports/LICENSE' 2019-04-19 17:05:54,869 - DEBUG - [MainThread] UM.PackageManager.getPackageInfo [430]: Found potential package.json file '/package.json' 2019-04-19 17:05:54,869 - INFO - [MainThread] UM.PackageManager.installPackage [303]: Package [CustomSupports] version [0.0.4] is scheduled to be installed. 2019-04-19 17:05:54,885 - INFO - [MainThread] UM.PackageManager._saveManagementData [168]: Package management file C:\Users\andre\AppData\Roaming\cura\4.0\packages.json was saved 2019-04-19 17:06:05,968 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/plugins/Toolbox/resources/qml/SmallRatingWidget.qml:27: TypeError: Cannot read property 'average_rating' of null 2019-04-19 17:06:05,973 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/plugins/Toolbox/resources/qml/SmallRatingWidget.qml:17: TypeError: Cannot read property 'user_rating' of null 2019-04-19 17:06:05,978 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/plugins/Toolbox/resources/qml/SmallRatingWidget.qml:10: TypeError: Cannot read property 'average_rating' of null 2019-04-19 17:06:05,982 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/plugins/Toolbox/resources/qml/ToolboxDetailPage.qml:140: TypeError: Cannot read property 'type' of null 2019-04-19 17:06:05,987 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/plugins/Toolbox/resources/qml/ToolboxDetailPage.qml:141: TypeError: Cannot read property 'id' of null 2019-04-19 17:06:05,992 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/plugins/Toolbox/resources/qml/ToolboxDetailPage.qml:142: TypeError: Cannot read property 'user_rating' of null 2019-04-19 17:06:05,996 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/plugins/Toolbox/resources/qml/ToolboxDetailPage.qml:143: TypeError: Cannot read property 'id' of null 2019-04-19 17:06:06,001 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/plugins/Toolbox/resources/qml/SmallRatingWidget.qml:27: TypeError: Cannot read property 'average_rating' of null 2019-04-19 17:06:06,006 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/plugins/Toolbox/resources/qml/SmallRatingWidget.qml:17: TypeError: Cannot read property 'user_rating' of null 2019-04-19 17:06:06,010 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/plugins/Toolbox/resources/qml/SmallRatingWidget.qml:10: TypeError: Cannot read property 'average_rating' of null 2019-04-19 17:06:06,015 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/plugins/Toolbox/resources/qml/ToolboxAuthorPage.qml:136: TypeError: Cannot read property 'email' of null 2019-04-19 17:06:06,020 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/plugins/Toolbox/resources/qml/ToolboxAuthorPage.qml:119: TypeError: Cannot read property 'website' of null 2019-04-19 17:06:06,024 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/plugins/Toolbox/resources/qml/ToolboxAuthorPage.qml:67: TypeError: Cannot read property 'description' of null 2019-04-19 17:06:06,029 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/plugins/Toolbox/resources/qml/ToolboxAuthorPage.qml:57: TypeError: Cannot read property 'name' of null 2019-04-19 17:06:06,034 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/plugins/Toolbox/resources/qml/ToolboxAuthorPage.qml:34: TypeError: Cannot read property 'icon_url' of null 2019-04-19 17:07:16,469 - DEBUG - [MainThread] cura.TaskManagement.OnExitCallbackManager.triggerNextCallback [51]: No more on-app-exit callbacks to process. Tell the app to exit. 2019-04-19 17:07:16,469 - INFO - [MainThread] cura.CuraApplication.closeApplication [547]: Close application 2019-04-19 17:07:16,535 - DEBUG - [MainThread] UM.Qt.QtApplication.windowClosed [417]: Shutting down cura 2019-04-19 17:07:16,661 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._terminate [295]: Attempting to kill the engine process 2019-04-19 17:07:29,549 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin FileLogger 2019-04-19 17:07:29,580 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin FirmwareUpdateChecker 2019-04-19 17:07:29,596 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin FirmwareUpdater 2019-04-19 17:07:29,627 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin GCodeGzReader 2019-04-19 17:07:29,643 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin GCodeGzWriter 2019-04-19 17:07:29,658 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin GCodeProfileReader 2019-04-19 17:07:29,705 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin GCodeReader 2019-04-19 17:07:29,721 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin GCodeWriter 2019-04-19 17:07:29,752 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin ImageReader 2019-04-19 17:07:29,768 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin LegacyProfileReader 2019-04-19 17:07:29,799 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin LocalContainerProvider 2019-04-19 17:07:29,815 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin LocalFileOutputDevice 2019-04-19 17:07:29,846 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin MachineSettingsAction 2019-04-19 17:07:29,862 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin ModelChecker 2019-04-19 17:07:29,893 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin MonitorStage 2019-04-19 17:07:29,924 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin PerObjectSettingsTool 2019-04-19 17:07:29,940 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin PostProcessingPlugin 2019-04-19 17:07:29,971 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin PrepareStage 2019-04-19 17:07:29,987 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin PreviewStage 2019-04-19 17:07:30,018 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin RemovableDriveOutputDevice 2019-04-19 17:07:30,065 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin SimulationView 2019-04-19 17:07:30,107 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin SliceInfoPlugin 2019-04-19 17:07:30,125 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin SolidView 2019-04-19 17:07:30,156 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin SupportEraser 2019-04-19 17:07:30,203 - DEBUG - [MainThread] cura.OAuth2.AuthorizationService.getAccessToken [106]: No auth data to retrieve the access_token from 2019-04-19 17:07:30,203 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin Toolbox 2019-04-19 17:07:30,234 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin CameraTool 2019-04-19 17:07:30,281 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin MirrorTool 2019-04-19 17:07:30,320 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin RotateTool 2019-04-19 17:07:30,369 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin ScaleTool 2019-04-19 17:07:30,390 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin SelectionTool 2019-04-19 17:07:30,421 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin TranslateTool 2019-04-19 17:07:30,468 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin UFPWriter 2019-04-19 17:07:30,513 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin UltimakerMachineActions 2019-04-19 17:07:30,752 - DEBUG - [MainThread] UM3NetworkPrinting.src.Cloud.CloudOutputDeviceManager._onLoginStateChanged [57]: Log in state changed to False 2019-04-19 17:07:30,752 - DEBUG - [MainThread] UM3NetworkPrinting.src.Cloud.CloudOutputDeviceManager._onGetRemoteClustersFinished [80]: Parsed remote clusters to [] 2019-04-19 17:07:30,752 - DEBUG - [MainThread] UM3NetworkPrinting.src.Cloud.CloudOutputDeviceManager._onGetRemoteClustersFinished [81]: Removed: 0, added: 0, updates: 0 2019-04-19 17:07:30,752 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin UM3NetworkPrinting 2019-04-19 17:07:30,799 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin UpdateChecker 2019-04-19 17:07:30,799 - INFO - [Thread-2] UpdateChecker.UpdateCheckerJob.run [36]: Checking for new version of cura 2019-04-19 17:07:30,882 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin USBPrinting 2019-04-19 17:07:30,914 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin UserAgreement 2019-04-19 17:07:30,947 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade21to22 2019-04-19 17:07:30,978 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade22to24 2019-04-19 17:07:31,025 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade25to26 2019-04-19 17:07:31,077 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade26to27 2019-04-19 17:07:31,121 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade27to30 2019-04-19 17:07:31,164 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade30to31 2019-04-19 17:07:31,205 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade32to33 2019-04-19 17:07:31,244 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade33to34 2019-04-19 17:07:31,298 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade34to35 2019-04-19 17:07:31,361 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade35to40 2019-04-19 17:07:31,428 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin SimpleView 2019-04-19 17:07:31,508 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin X3DReader 2019-04-19 17:07:31,609 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin XmlMaterialProfile 2019-04-19 17:07:31,672 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin XRayView 2019-04-19 17:07:31,721 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin CustomSupports 2019-04-19 17:07:31,789 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin OrientationPlugin 2019-04-19 17:07:31,830 - INFO - [MainThread] UM.VersionUpgradeManager.upgrade [143]: Looking for old configuration files to upgrade. 2019-04-19 17:07:31,898 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\packages.json, skip it 2019-04-19 17:07:31,904 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\plugins.json, skip it 2019-04-19 17:07:31,934 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\packages.json, skip it 2019-04-19 17:07:31,934 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\plugins.json, skip it 2019-04-19 17:07:31,966 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\packages.json, skip it 2019-04-19 17:07:31,966 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\plugins.json, skip it 2019-04-19 17:07:32,065 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\packages.json, skip it 2019-04-19 17:07:32,068 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\plugins.json, skip it 2019-04-19 17:07:32,110 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\packages.json, skip it 2019-04-19 17:07:32,116 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\plugins.json, skip it 2019-04-19 17:07:32,156 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\packages.json, skip it 2019-04-19 17:07:32,163 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\plugins.json, skip it 2019-04-19 17:07:32,204 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\packages.json, skip it 2019-04-19 17:07:32,210 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\plugins.json, skip it 2019-04-19 17:07:32,254 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\packages.json, skip it 2019-04-19 17:07:32,260 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\plugins.json, skip it 2019-04-19 17:07:32,389 - DEBUG - [MainThread] UM.Backend.Backend._onSocketError [213]: Socket was unable to bind to port, increasing port number to 49675 2019-04-19 17:07:32,394 - DEBUG - [MainThread] UM.Backend.Backend._createSocket [227]: Previous socket existed. Closing that first. 2019-04-19 17:07:32,400 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._terminate [295]: Attempting to kill the engine process 2019-04-19 17:07:32,406 - DEBUG - [MainThread] UM.Backend.Backend._createSocket [227]: Previous socket existed. Closing that first. 2019-04-19 17:07:32,636 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [187]: Socket state changed to Listening 2019-04-19 17:07:32,636 - INFO - [MainThread] UM.Backend.Backend.startEngine [81]: Started engine process: C:\Program Files\Ultimaker Cura 4.0\CuraEngine.exe 2019-04-19 17:07:32,652 - DEBUG - [MainThread] UM.Backend.Backend._backendLog [101]: [Backend] Calling engine with: ['C:\\Program Files\\Ultimaker Cura 4.0\\CuraEngine.exe', 'connect', '127.0.0.1:49675', ''] 2019-04-19 17:07:32,746 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:07:32,751 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] Cura_SteamEngine version 4.0.0 2019-04-19 17:07:32,756 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] Copyright (C) 2018 Ultimaker 2019-04-19 17:07:32,761 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:07:32,766 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] This program is free software: you can redistribute it and/or modify 2019-04-19 17:07:32,771 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] it under the terms of the GNU Affero General Public License as published by 2019-04-19 17:07:32,777 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] the Free Software Foundation, either version 3 of the License, or 2019-04-19 17:07:32,783 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] (at your option) any later version. 2019-04-19 17:07:32,788 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:07:32,793 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] This program is distributed in the hope that it will be useful, 2019-04-19 17:07:32,796 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] but WITHOUT ANY WARRANTY; without even the implied warranty of 2019-04-19 17:07:32,796 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the 2019-04-19 17:07:32,796 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] GNU Affero General Public License for more details. 2019-04-19 17:07:32,811 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:07:32,811 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] You should have received a copy of the GNU Affero General Public License 2019-04-19 17:07:32,811 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] along with this program. If not, see <http://www.gnu.org/licenses/>. 2019-04-19 17:07:36,698 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.loadAllMetadata [338]: Loading metadata into container registry took 4.042280912399292 seconds 2019-04-19 17:07:36,860 - DEBUG - [MainThread] cura.Scene.CuraSceneController.setActiveBuildPlate [104]: Select build plate: 0 2019-04-19 17:07:36,865 - INFO - [MainThread] cura.CuraApplication.run [695]: Initializing variant manager 2019-04-19 17:07:36,873 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container ultimaker_s5_aluminum 2019-04-19 17:07:36,881 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [ultimaker_s5_aluminum] added. 2019-04-19 17:07:36,882 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container ultimaker_s5 2019-04-19 17:07:37,058 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [ultimaker_s5] added. 2019-04-19 17:07:37,087 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container ultimaker_s5_glass 2019-04-19 17:07:37,117 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [ultimaker_s5_glass] added. 2019-04-19 17:07:37,128 - DEBUG - [MainThread] cura.Machines.VariantManager.initialize [59]: Exclude variant [empty_variant] 2019-04-19 17:07:37,134 - INFO - [MainThread] cura.CuraApplication.run [699]: Initializing material manager 2019-04-19 17:07:37,265 - INFO - [MainThread] cura.CuraApplication.run [704]: Initializing quality manager 2019-04-19 17:07:37,293 - DEBUG - [MainThread] cura.Machines.QualityManager.initialize [136]: Lookup tables updated. 2019-04-19 17:07:37,300 - INFO - [MainThread] cura.CuraApplication.run [709]: Initializing machine manager 2019-04-19 17:07:37,306 - INFO - [MainThread] cura.CuraApplication.run [712]: Initializing container manager 2019-04-19 17:07:37,311 - INFO - [MainThread] cura.CuraApplication.run [715]: Initializing machine error checker 2019-04-19 17:07:37,350 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container Creality CR-10 2019-04-19 17:07:37,355 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container Creality CR-10_user 2019-04-19 17:07:37,365 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [Creality CR-10_user] added. 2019-04-19 17:07:37,367 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container creality_cr10_pla 2019-04-19 17:07:37,376 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [creality_cr10_pla] added. 2019-04-19 17:07:37,379 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container draft 2019-04-19 17:07:37,388 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [draft] added. 2019-04-19 17:07:37,399 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container Creality CR-10_settings 2019-04-19 17:07:37,450 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [Creality CR-10_settings] added. 2019-04-19 17:07:37,453 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container creality_cr10 2019-04-19 17:07:37,620 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [creality_cr10] added. 2019-04-19 17:07:37,625 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [Creality CR-10] added. 2019-04-19 17:07:37,634 - INFO - [MainThread] cura.MachineActionManager.addDefaultMachineActions [72]: Default machine actions added for machine definition [creality_cr10] 2019-04-19 17:07:37,642 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container creality_cr10_extruder_0 #2 2019-04-19 17:07:37,648 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container creality_cr10_extruder_0 #2_user 2019-04-19 17:07:37,669 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [creality_cr10_extruder_0 #2_user] added. 2019-04-19 17:07:37,671 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container creality_cr10_extruder_0_pla 2019-04-19 17:07:37,683 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [creality_cr10_extruder_0_pla] added. 2019-04-19 17:07:37,685 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container generic_pla_175 2019-04-19 17:07:37,705 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [generic_pla_175_imade3d_jellybox] added. 2019-04-19 17:07:37,718 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [generic_pla_175_imade3d_jellybox_0.4_mm] added. 2019-04-19 17:07:37,724 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [generic_pla_175_imade3d_jellybox_0.4_mm_2-fans] added. 2019-04-19 17:07:37,776 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [generic_pla_175_cartesio] added. 2019-04-19 17:07:37,783 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [generic_pla_175_cartesio_0.25mm_thermoplastic_extruder] added. 2019-04-19 17:07:37,792 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [generic_pla_175_cartesio_0.4mm_thermoplastic_extruder] added. 2019-04-19 17:07:37,802 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [generic_pla_175_cartesio_0.8mm_thermoplastic_extruder] added. 2019-04-19 17:07:37,810 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [generic_pla_175] added. 2019-04-19 17:07:37,813 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container creality_cr10_extruder_0 #2_settings 2019-04-19 17:07:37,829 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [creality_cr10_extruder_0 #2_settings] added. 2019-04-19 17:07:37,841 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container creality_cr10_extruder_0 2019-04-19 17:07:37,850 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [creality_cr10_extruder_0] added. 2019-04-19 17:07:37,857 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [creality_cr10_extruder_0 #2] added. 2019-04-19 17:07:37,865 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container fdmprinter 2019-04-19 17:07:38,036 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [fdmprinter] added. 2019-04-19 17:07:38,719 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [170]: Begin loading of script: BQ_PauseAtHeight 2019-04-19 17:07:38,725 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [170]: Begin loading of script: ChangeAtZ 2019-04-19 17:07:38,731 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [170]: Begin loading of script: DisplayFilenameAndLayerOnLCD 2019-04-19 17:07:38,737 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [170]: Begin loading of script: FilamentChange 2019-04-19 17:07:38,745 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [170]: Begin loading of script: PauseAtHeight 2019-04-19 17:07:38,748 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [170]: Begin loading of script: PauseAtHeightRepRapFirmwareDuet 2019-04-19 17:07:38,758 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [170]: Begin loading of script: PauseAtHeightforRepetier 2019-04-19 17:07:38,764 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [170]: Begin loading of script: SearchAndReplace 2019-04-19 17:07:38,777 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [170]: Begin loading of script: Stretch 2019-04-19 17:07:38,783 - DEBUG - [MainThread] UM3NetworkPrinting.src.UM3OutputDevicePlugin.checkCloudFlowIsPossible [412]: Checking if cloud connection is possible... 2019-04-19 17:07:38,784 - DEBUG - [MainThread] UM3NetworkPrinting.src.UM3OutputDevicePlugin.checkCloudFlowIsPossible [435]: Cloud Flow not possible: User not logged in! 2019-04-19 17:07:38,964 - INFO - [MainThread] cura.Settings.GlobalStack.addExtruder [136]: Extruder[creality_cr10_extruder_0 #2] added to [Creality CR-10] at position [0] 2019-04-19 17:07:38,969 - WARNING - [MainThread] cura.Settings.ExtruderManager.registerExtruder [169]: Extruder [creality_cr10_extruder_0 #2] has already been registered on machine [Creality CR-10], not doing anything 2019-04-19 17:07:38,983 - INFO - [MainThread] cura.Settings.MachineManager._initMachineState [330]: Machine 'Creality CR-10' quality changes set to 'PLA #2' 2019-04-19 17:07:39,329 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._rescheduleCheck [136]: New error check scheduled. 2019-04-19 17:07:39,329 - INFO - [MainThread] FirmwareUpdateChecker.FirmwareUpdateChecker.checkFirmwareVersion [76]: No machine with name Creality CR-10 in list of firmware to check. 2019-04-19 17:07:40,899 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin._createView [280]: Creating post processing plugin view. 2019-04-19 17:07:41,024 - DEBUG - [MainThread] UM.Qt.Bindings.Theme.load [158]: Loading theme file: C:\Program Files\Ultimaker Cura 4.0\resources\themes\cura-light\theme.json 2019-04-19 17:07:41,136 - DEBUG - [MainThread] UM.Qt.Bindings.Theme.load [230]: Loaded theme C:\Program Files\Ultimaker Cura 4.0\resources\themes\cura-light 2019-04-19 17:07:41,214 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin._createView [290]: Post processing view created. 2019-04-19 17:07:41,472 - WARNING - [MainThread] UM.Qt.Bindings.Theme.getImage [133]: No image header_pattern defined in Theme 2019-04-19 17:07:41,488 - DEBUG - [MainThread] cura.Machines.Models.BuildPlateModel._update [33]: Updating BuildPlateModel. 2019-04-19 17:07:42,667 - DEBUG - [MainThread] cura.Machines.Models.NozzleModel._update [34]: Updating NozzleModel. 2019-04-19 17:07:42,950 - DEBUG - [MainThread] UM3NetworkPrinting.src.DiscoverUM3Action._createAdditionalComponentsView [196]: Creating additional ui components for UM3. 2019-04-19 17:07:43,037 - DEBUG - [MainThread] UM3NetworkPrinting.src.DiscoverUM3Action.startDiscovery [47]: Starting device discovery. 2019-04-19 17:07:43,064 - DEBUG - [MainThread] UM.Controller.setActiveStage [159]: Setting active stage to PrepareStage 2019-04-19 17:07:43,267 - DEBUG - [MainThread] cura.Machines.Models.NozzleModel._update [34]: Updating NozzleModel. 2019-04-19 17:07:43,439 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/plugins/PrepareStage/PrepareMain.qml:16:5: QML ActionPanelWidget: Binding loop detected for property "width" 2019-04-19 17:07:43,448 - DEBUG - [MainThread] UM.Controller.setActiveView [92]: Setting active view to SolidView 2019-04-19 17:07:43,453 - DEBUG - [MainThread] ModelChecker.ModelChecker._createView [103]: Creating model checker view. 2019-04-19 17:07:43,468 - DEBUG - [MainThread] ModelChecker.ModelChecker._createView [112]: Model checker view created. 2019-04-19 17:07:43,469 - DEBUG - [MainThread] SliceInfoPlugin.SliceInfo._createDialog [82]: Creating dialog [MoreInfoWindow.qml] 2019-04-19 17:07:43,568 - DEBUG - [MainThread] cura.CuraApplication.run [747]: Booting Cura took 15.748594284057617 seconds 2019-04-19 17:07:43,580 - INFO - [MainThread] cura.Machines.MaterialManager._updateMaps [279]: Updating material lookup data ... 2019-04-19 17:07:43,644 - INFO - [MainThread] cura.Settings.MachineManager._updateQualityWithMaterial [1270]: Updating quality/quality_changes due to material change 2019-04-19 17:07:43,644 - DEBUG - [MainThread] cura.Settings.MachineManager._updateQualityWithMaterial [1277]: Current quality type = [draft] 2019-04-19 17:07:43,644 - INFO - [MainThread] cura.Settings.MachineManager._updateQualityWithMaterial [1291]: Current available quality type [draft] is available, applying changes. 2019-04-19 17:07:43,738 - DEBUG - [MainThread] cura.Machines.QualityManager.initialize [136]: Lookup tables updated. 2019-04-19 17:07:43,775 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._checkStack [140]: Need to check for errors again. Discard the current progress and reschedule a check. 2019-04-19 17:07:43,856 - DEBUG - [MainThread] cura.Machines.Models.QualityProfilesDropDownMenuModel._update [61]: Updating QualityProfilesDropDownMenuModel. 2019-04-19 17:07:43,858 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container coarse 2019-04-19 17:07:43,866 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [coarse] added. 2019-04-19 17:07:43,905 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container extra_coarse 2019-04-19 17:07:43,915 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [extra_coarse] added. 2019-04-19 17:07:43,954 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container fast 2019-04-19 17:07:43,962 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [fast] added. 2019-04-19 17:07:44,044 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container high 2019-04-19 17:07:44,052 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [high] added. 2019-04-19 17:07:44,092 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container normal 2019-04-19 17:07:44,100 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [normal] added. 2019-04-19 17:07:44,101 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container extra_fast 2019-04-19 17:07:44,111 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [extra_fast] added. 2019-04-19 17:07:44,171 - DEBUG - [MainThread] cura.Machines.Models.CustomQualityProfilesDropDownMenuModel._update [15]: Updating CustomQualityProfilesDropDownMenuModel. 2019-04-19 17:07:44,180 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._rescheduleCheck [136]: New error check scheduled. 2019-04-19 17:07:44,436 - DEBUG - [MainThread] UM.Qt.QtRenderer._initialize [183]: Support for Vertex Array Objects: True 2019-04-19 17:07:44,451 - DEBUG - [MainThread] UM.View.GL.OpenGL.__init__ [99]: Initialized OpenGL subsystems. 2019-04-19 17:07:44,456 - DEBUG - [MainThread] UM.View.GL.OpenGL.__init__ [100]: OpenGL Version: 3.3.0 2019-04-19 17:07:44,461 - DEBUG - [MainThread] UM.View.GL.OpenGL.__init__ [101]: OpenGL Vendor: NVIDIA Corporation 2019-04-19 17:07:44,465 - DEBUG - [MainThread] UM.View.GL.OpenGL.__init__ [102]: OpenGL Renderer: GeForce 9500 GT/PCIe/SSE2 2019-04-19 17:07:44,470 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\default.shader]... 2019-04-19 17:07:44,478 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\selection.shader]... 2019-04-19 17:07:44,487 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\default.shader]... 2019-04-19 17:07:44,496 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\composite.shader]... 2019-04-19 17:07:44,504 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\overhang.shader]... 2019-04-19 17:07:44,512 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\striped.shader]... 2019-04-19 17:07:44,520 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\transparent_object.shader]... 2019-04-19 17:07:44,528 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\striped.shader]... 2019-04-19 17:07:44,537 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\default.shader]... 2019-04-19 17:07:44,544 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\grid.shader]... 2019-04-19 17:07:44,552 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\platform.shader]... 2019-04-19 17:07:44,680 - DEBUG - [MainThread] cura.Machines.QualityManager.initialize [136]: Lookup tables updated. 2019-04-19 17:07:45,187 - DEBUG - [MainThread] cura.Machines.Models.QualityProfilesDropDownMenuModel._update [61]: Updating QualityProfilesDropDownMenuModel. 2019-04-19 17:07:45,194 - INFO - [Thread-3] STLReader.STLReader.load_file [46]: Using NumPy-STL to load STL data. 2019-04-19 17:07:45,203 - DEBUG - [Thread-3] UM.Mesh.MeshData.calculateNormalsFromVertices [444]: Calculating normals took 0.0009996891021728516 seconds 2019-04-19 17:07:45,205 - DEBUG - [Thread-3] STLReader.STLReader._read [97]: Loaded a mesh with 11556 vertices 2019-04-19 17:07:45,223 - DEBUG - [Thread-3] UM.Mesh.MeshData.approximateConvexHull [401]: approximateConvexHull(target_count=1024) Calculating 3D convex hull took 0.013009071350097656 seconds. 208 input vertices. 208 output vertices. 2019-04-19 17:07:45,230 - DEBUG - [MainThread] cura.Machines.Models.CustomQualityProfilesDropDownMenuModel._update [15]: Updating CustomQualityProfilesDropDownMenuModel. 2019-04-19 17:07:45,246 - DEBUG - [Thread-3] UM.FileHandler.ReadFileJob.run [69]: Loading file took 0.1 seconds 2019-04-19 17:07:45,263 - DEBUG - [Thread-3] UM.Mesh.MeshData.approximateConvexHull [401]: approximateConvexHull(target_count=1024) Calculating 3D convex hull took 0.01200103759765625 seconds. 208 input vertices. 208 output vertices. 2019-04-19 17:07:45,317 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [per_object_stack_3125713048520] added. 2019-04-19 17:07:45,385 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\transparent_object.shader]... 2019-04-19 17:07:46,718 - INFO - [MainThread] cura.Machines.MachineErrorChecker._setResult [188]: Error check finished, result = False, time = 2.5s 2019-04-19 17:07:53,758 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] [ERROR] Could not connect to the given address 2019-04-19 17:07:53,855 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onBackendQuit [811]: Backend quit with return code 0. Resetting process and socket. 2019-04-19 17:07:54,747 - DEBUG - [MainThread] cura.AutoSave._onTimeout [48]: Autosaving preferences, instances and profiles 2019-04-19 17:09:02,798 - DEBUG - [MainThread] cura.TaskManagement.OnExitCallbackManager.triggerNextCallback [51]: No more on-app-exit callbacks to process. Tell the app to exit. 2019-04-19 17:09:02,803 - INFO - [MainThread] cura.CuraApplication.closeApplication [547]: Close application 2019-04-19 17:09:02,830 - DEBUG - [MainThread] UM.Qt.QtApplication.windowClosed [417]: Shutting down cura 2019-04-19 17:09:02,876 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._terminate [295]: Attempting to kill the engine process 2019-04-19 17:09:11,687 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin FileLogger 2019-04-19 17:09:11,731 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin FirmwareUpdateChecker 2019-04-19 17:09:11,759 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin FirmwareUpdater 2019-04-19 17:09:11,786 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin GCodeGzReader 2019-04-19 17:09:11,812 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin GCodeGzWriter 2019-04-19 17:09:11,872 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin GCodeProfileReader 2019-04-19 17:09:11,926 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin GCodeReader 2019-04-19 17:09:11,956 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin GCodeWriter 2019-04-19 17:09:11,993 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin ImageReader 2019-04-19 17:09:12,025 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin LegacyProfileReader 2019-04-19 17:09:12,061 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin LocalContainerProvider 2019-04-19 17:09:12,097 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin LocalFileOutputDevice 2019-04-19 17:09:12,124 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin MachineSettingsAction 2019-04-19 17:09:12,152 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin ModelChecker 2019-04-19 17:09:12,182 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin MonitorStage 2019-04-19 17:09:12,221 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin PerObjectSettingsTool 2019-04-19 17:09:12,253 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin PostProcessingPlugin 2019-04-19 17:09:12,286 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin PrepareStage 2019-04-19 17:09:12,321 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin PreviewStage 2019-04-19 17:09:12,368 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin RemovableDriveOutputDevice 2019-04-19 17:09:12,434 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin SimulationView 2019-04-19 17:09:12,473 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin SliceInfoPlugin 2019-04-19 17:09:12,504 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin SolidView 2019-04-19 17:09:12,537 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin SupportEraser 2019-04-19 17:09:12,608 - DEBUG - [MainThread] cura.OAuth2.AuthorizationService.getAccessToken [106]: No auth data to retrieve the access_token from 2019-04-19 17:09:12,614 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin Toolbox 2019-04-19 17:09:12,660 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin CameraTool 2019-04-19 17:09:12,713 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin MirrorTool 2019-04-19 17:09:12,760 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin RotateTool 2019-04-19 17:09:12,808 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin ScaleTool 2019-04-19 17:09:12,841 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin SelectionTool 2019-04-19 17:09:12,886 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin TranslateTool 2019-04-19 17:09:12,977 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin UFPWriter 2019-04-19 17:09:13,040 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin UltimakerMachineActions 2019-04-19 17:09:13,392 - DEBUG - [MainThread] UM3NetworkPrinting.src.Cloud.CloudOutputDeviceManager._onLoginStateChanged [57]: Log in state changed to False 2019-04-19 17:09:13,393 - DEBUG - [MainThread] UM3NetworkPrinting.src.Cloud.CloudOutputDeviceManager._onGetRemoteClustersFinished [80]: Parsed remote clusters to [] 2019-04-19 17:09:13,394 - DEBUG - [MainThread] UM3NetworkPrinting.src.Cloud.CloudOutputDeviceManager._onGetRemoteClustersFinished [81]: Removed: 0, added: 0, updates: 0 2019-04-19 17:09:13,401 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin UM3NetworkPrinting 2019-04-19 17:09:13,466 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin UpdateChecker 2019-04-19 17:09:13,472 - INFO - [Thread-2] UpdateChecker.UpdateCheckerJob.run [36]: Checking for new version of cura 2019-04-19 17:09:13,572 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin USBPrinting 2019-04-19 17:09:13,614 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin UserAgreement 2019-04-19 17:09:13,676 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade21to22 2019-04-19 17:09:13,725 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade22to24 2019-04-19 17:09:13,768 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade25to26 2019-04-19 17:09:13,808 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade26to27 2019-04-19 17:09:13,854 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade27to30 2019-04-19 17:09:13,933 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade30to31 2019-04-19 17:09:13,998 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade32to33 2019-04-19 17:09:14,059 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade33to34 2019-04-19 17:09:14,103 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade34to35 2019-04-19 17:09:14,144 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade35to40 2019-04-19 17:09:14,185 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin SimpleView 2019-04-19 17:09:14,237 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin X3DReader 2019-04-19 17:09:14,301 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin XmlMaterialProfile 2019-04-19 17:09:14,347 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin XRayView 2019-04-19 17:09:14,385 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin CustomSupports 2019-04-19 17:09:14,429 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin OrientationPlugin 2019-04-19 17:09:14,462 - INFO - [MainThread] UM.VersionUpgradeManager.upgrade [143]: Looking for old configuration files to upgrade. 2019-04-19 17:09:14,518 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\packages.json, skip it 2019-04-19 17:09:14,526 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\plugins.json, skip it 2019-04-19 17:09:14,564 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\packages.json, skip it 2019-04-19 17:09:14,569 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\plugins.json, skip it 2019-04-19 17:09:14,607 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\packages.json, skip it 2019-04-19 17:09:14,612 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\plugins.json, skip it 2019-04-19 17:09:14,651 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\packages.json, skip it 2019-04-19 17:09:14,657 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\plugins.json, skip it 2019-04-19 17:09:14,689 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\packages.json, skip it 2019-04-19 17:09:14,694 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\plugins.json, skip it 2019-04-19 17:09:14,726 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\packages.json, skip it 2019-04-19 17:09:14,731 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\plugins.json, skip it 2019-04-19 17:09:14,761 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\packages.json, skip it 2019-04-19 17:09:14,766 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\plugins.json, skip it 2019-04-19 17:09:14,798 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\packages.json, skip it 2019-04-19 17:09:14,803 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\plugins.json, skip it 2019-04-19 17:09:14,903 - DEBUG - [MainThread] UM.Backend.Backend._onSocketError [213]: Socket was unable to bind to port, increasing port number to 49675 2019-04-19 17:09:14,908 - DEBUG - [MainThread] UM.Backend.Backend._createSocket [227]: Previous socket existed. Closing that first. 2019-04-19 17:09:14,912 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._terminate [295]: Attempting to kill the engine process 2019-04-19 17:09:14,917 - DEBUG - [MainThread] UM.Backend.Backend._createSocket [227]: Previous socket existed. Closing that first. 2019-04-19 17:09:15,114 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [187]: Socket state changed to Listening 2019-04-19 17:09:15,128 - INFO - [MainThread] UM.Backend.Backend.startEngine [81]: Started engine process: C:\Program Files\Ultimaker Cura 4.0\CuraEngine.exe 2019-04-19 17:09:15,132 - DEBUG - [MainThread] UM.Backend.Backend._backendLog [101]: [Backend] Calling engine with: ['C:\\Program Files\\Ultimaker Cura 4.0\\CuraEngine.exe', 'connect', '127.0.0.1:49675', ''] 2019-04-19 17:09:15,187 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:09:15,191 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] Cura_SteamEngine version 4.0.0 2019-04-19 17:09:15,196 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] Copyright (C) 2018 Ultimaker 2019-04-19 17:09:15,201 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:09:15,205 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] This program is free software: you can redistribute it and/or modify 2019-04-19 17:09:15,210 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] it under the terms of the GNU Affero General Public License as published by 2019-04-19 17:09:15,214 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] the Free Software Foundation, either version 3 of the License, or 2019-04-19 17:09:15,219 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] (at your option) any later version. 2019-04-19 17:09:15,223 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:09:15,227 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] This program is distributed in the hope that it will be useful, 2019-04-19 17:09:15,232 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] but WITHOUT ANY WARRANTY; without even the implied warranty of 2019-04-19 17:09:15,237 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the 2019-04-19 17:09:15,242 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] GNU Affero General Public License for more details. 2019-04-19 17:09:15,246 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:09:15,251 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] You should have received a copy of the GNU Affero General Public License 2019-04-19 17:09:15,255 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] along with this program. If not, see <http://www.gnu.org/licenses/>. 2019-04-19 17:09:18,845 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.loadAllMetadata [338]: Loading metadata into container registry took 3.693957567214966 seconds 2019-04-19 17:09:19,016 - DEBUG - [MainThread] cura.Scene.CuraSceneController.setActiveBuildPlate [104]: Select build plate: 0 2019-04-19 17:09:19,021 - INFO - [MainThread] cura.CuraApplication.run [695]: Initializing variant manager 2019-04-19 17:09:19,030 - DEBUG - [MainThread] cura.Machines.VariantManager.initialize [59]: Exclude variant [empty_variant] 2019-04-19 17:09:19,032 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container ultimaker_s5_glass 2019-04-19 17:09:19,040 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [ultimaker_s5_glass] added. 2019-04-19 17:09:19,041 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container ultimaker_s5 2019-04-19 17:09:19,201 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [ultimaker_s5] added. 2019-04-19 17:09:19,206 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container ultimaker_s5_aluminum 2019-04-19 17:09:19,214 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [ultimaker_s5_aluminum] added. 2019-04-19 17:09:19,226 - INFO - [MainThread] cura.CuraApplication.run [699]: Initializing material manager 2019-04-19 17:09:19,344 - INFO - [MainThread] cura.CuraApplication.run [704]: Initializing quality manager 2019-04-19 17:09:19,367 - DEBUG - [MainThread] cura.Machines.QualityManager.initialize [136]: Lookup tables updated. 2019-04-19 17:09:19,372 - INFO - [MainThread] cura.CuraApplication.run [709]: Initializing machine manager 2019-04-19 17:09:19,378 - INFO - [MainThread] cura.CuraApplication.run [712]: Initializing container manager 2019-04-19 17:09:19,383 - INFO - [MainThread] cura.CuraApplication.run [715]: Initializing machine error checker 2019-04-19 17:09:19,415 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container Creality CR-10 2019-04-19 17:09:19,420 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container Creality CR-10_user 2019-04-19 17:09:19,429 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [Creality CR-10_user] added. 2019-04-19 17:09:19,430 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container creality_cr10_pla 2019-04-19 17:09:19,439 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [creality_cr10_pla] added. 2019-04-19 17:09:19,440 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container draft 2019-04-19 17:09:19,448 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [draft] added. 2019-04-19 17:09:19,451 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container Creality CR-10_settings 2019-04-19 17:09:19,459 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [Creality CR-10_settings] added. 2019-04-19 17:09:19,460 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container creality_cr10 2019-04-19 17:09:19,552 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [creality_cr10] added. 2019-04-19 17:09:19,558 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [Creality CR-10] added. 2019-04-19 17:09:19,563 - INFO - [MainThread] cura.MachineActionManager.addDefaultMachineActions [72]: Default machine actions added for machine definition [creality_cr10] 2019-04-19 17:09:19,571 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container creality_cr10_extruder_0 #2 2019-04-19 17:09:19,575 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container creality_cr10_extruder_0 #2_user 2019-04-19 17:09:19,584 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [creality_cr10_extruder_0 #2_user] added. 2019-04-19 17:09:19,586 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container creality_cr10_extruder_0_pla 2019-04-19 17:09:19,596 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [creality_cr10_extruder_0_pla] added. 2019-04-19 17:09:19,600 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container generic_pla_175 2019-04-19 17:09:19,615 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [generic_pla_175_imade3d_jellybox] added. 2019-04-19 17:09:19,621 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [generic_pla_175_imade3d_jellybox_0.4_mm] added. 2019-04-19 17:09:19,627 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [generic_pla_175_imade3d_jellybox_0.4_mm_2-fans] added. 2019-04-19 17:09:19,633 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [generic_pla_175_cartesio] added. 2019-04-19 17:09:19,640 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [generic_pla_175_cartesio_0.25mm_thermoplastic_extruder] added. 2019-04-19 17:09:19,646 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [generic_pla_175_cartesio_0.4mm_thermoplastic_extruder] added. 2019-04-19 17:09:19,653 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [generic_pla_175_cartesio_0.8mm_thermoplastic_extruder] added. 2019-04-19 17:09:19,658 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [generic_pla_175] added. 2019-04-19 17:09:19,660 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container creality_cr10_extruder_0 #2_settings 2019-04-19 17:09:19,672 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [creality_cr10_extruder_0 #2_settings] added. 2019-04-19 17:09:19,673 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container creality_cr10_extruder_0 2019-04-19 17:09:19,681 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [creality_cr10_extruder_0] added. 2019-04-19 17:09:19,685 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [creality_cr10_extruder_0 #2] added. 2019-04-19 17:09:19,693 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container fdmprinter 2019-04-19 17:09:19,780 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [fdmprinter] added. 2019-04-19 17:09:20,312 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [170]: Begin loading of script: BQ_PauseAtHeight 2019-04-19 17:09:20,320 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [170]: Begin loading of script: ChangeAtZ 2019-04-19 17:09:20,328 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [170]: Begin loading of script: DisplayFilenameAndLayerOnLCD 2019-04-19 17:09:20,335 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [170]: Begin loading of script: FilamentChange 2019-04-19 17:09:20,344 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [170]: Begin loading of script: PauseAtHeight 2019-04-19 17:09:20,351 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [170]: Begin loading of script: PauseAtHeightRepRapFirmwareDuet 2019-04-19 17:09:20,402 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [170]: Begin loading of script: PauseAtHeightforRepetier 2019-04-19 17:09:20,430 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [170]: Begin loading of script: SearchAndReplace 2019-04-19 17:09:20,450 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [170]: Begin loading of script: Stretch 2019-04-19 17:09:20,457 - DEBUG - [MainThread] UM3NetworkPrinting.src.UM3OutputDevicePlugin.checkCloudFlowIsPossible [412]: Checking if cloud connection is possible... 2019-04-19 17:09:20,461 - DEBUG - [MainThread] UM3NetworkPrinting.src.UM3OutputDevicePlugin.checkCloudFlowIsPossible [435]: Cloud Flow not possible: User not logged in! 2019-04-19 17:09:20,691 - INFO - [MainThread] cura.Settings.GlobalStack.addExtruder [136]: Extruder[creality_cr10_extruder_0 #2] added to [Creality CR-10] at position [0] 2019-04-19 17:09:20,696 - WARNING - [MainThread] cura.Settings.ExtruderManager.registerExtruder [169]: Extruder [creality_cr10_extruder_0 #2] has already been registered on machine [Creality CR-10], not doing anything 2019-04-19 17:09:20,723 - INFO - [MainThread] cura.Settings.MachineManager._initMachineState [330]: Machine 'Creality CR-10' quality changes set to 'PLA #2' 2019-04-19 17:09:21,364 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._rescheduleCheck [136]: New error check scheduled. 2019-04-19 17:09:21,367 - INFO - [MainThread] FirmwareUpdateChecker.FirmwareUpdateChecker.checkFirmwareVersion [76]: No machine with name Creality CR-10 in list of firmware to check. 2019-04-19 17:09:21,711 - INFO - [MainThread] cura.Machines.MaterialManager._updateMaps [279]: Updating material lookup data ... 2019-04-19 17:09:21,866 - INFO - [MainThread] cura.Settings.MachineManager._updateQualityWithMaterial [1270]: Updating quality/quality_changes due to material change 2019-04-19 17:09:21,876 - DEBUG - [MainThread] cura.Settings.MachineManager._updateQualityWithMaterial [1277]: Current quality type = [draft] 2019-04-19 17:09:21,884 - INFO - [MainThread] cura.Settings.MachineManager._updateQualityWithMaterial [1291]: Current available quality type [draft] is available, applying changes. 2019-04-19 17:09:21,937 - DEBUG - [MainThread] cura.Machines.QualityManager.initialize [136]: Lookup tables updated. 2019-04-19 17:09:22,052 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._checkStack [140]: Need to check for errors again. Discard the current progress and reschedule a check. 2019-04-19 17:09:28,972 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin._createView [280]: Creating post processing plugin view. 2019-04-19 17:09:29,685 - DEBUG - [MainThread] UM.Qt.Bindings.Theme.load [158]: Loading theme file: C:\Program Files\Ultimaker Cura 4.0\resources\themes\cura-light\theme.json 2019-04-19 17:09:30,058 - DEBUG - [MainThread] UM.Qt.Bindings.Theme.load [230]: Loaded theme C:\Program Files\Ultimaker Cura 4.0\resources\themes\cura-light 2019-04-19 17:09:30,272 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin._createView [290]: Post processing view created. 2019-04-19 17:09:30,985 - WARNING - [MainThread] UM.Qt.Bindings.Theme.getImage [133]: No image header_pattern defined in Theme 2019-04-19 17:09:31,045 - DEBUG - [MainThread] cura.Machines.Models.BuildPlateModel._update [33]: Updating BuildPlateModel. 2019-04-19 17:09:32,520 - DEBUG - [MainThread] cura.Machines.Models.NozzleModel._update [34]: Updating NozzleModel. 2019-04-19 17:09:32,889 - DEBUG - [MainThread] UM3NetworkPrinting.src.DiscoverUM3Action._createAdditionalComponentsView [196]: Creating additional ui components for UM3. 2019-04-19 17:09:33,046 - DEBUG - [MainThread] UM3NetworkPrinting.src.DiscoverUM3Action.startDiscovery [47]: Starting device discovery. 2019-04-19 17:09:33,064 - DEBUG - [MainThread] UM.Controller.setActiveStage [159]: Setting active stage to PrepareStage 2019-04-19 17:09:33,778 - DEBUG - [MainThread] cura.Machines.Models.NozzleModel._update [34]: Updating NozzleModel. 2019-04-19 17:09:34,229 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/plugins/PrepareStage/PrepareMain.qml:16:5: QML ActionPanelWidget: Binding loop detected for property "width" 2019-04-19 17:09:34,236 - DEBUG - [MainThread] UM.Controller.setActiveView [92]: Setting active view to SolidView 2019-04-19 17:09:34,242 - DEBUG - [MainThread] ModelChecker.ModelChecker._createView [103]: Creating model checker view. 2019-04-19 17:09:34,284 - DEBUG - [MainThread] ModelChecker.ModelChecker._createView [112]: Model checker view created. 2019-04-19 17:09:34,286 - DEBUG - [MainThread] SliceInfoPlugin.SliceInfo._createDialog [82]: Creating dialog [MoreInfoWindow.qml] 2019-04-19 17:09:34,493 - DEBUG - [MainThread] cura.CuraApplication.run [747]: Booting Cura took 24.689333200454712 seconds 2019-04-19 17:09:34,507 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._rescheduleCheck [136]: New error check scheduled. 2019-04-19 17:09:34,553 - DEBUG - [MainThread] cura.Machines.Models.QualityProfilesDropDownMenuModel._update [61]: Updating QualityProfilesDropDownMenuModel. 2019-04-19 17:09:34,555 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container coarse 2019-04-19 17:09:34,568 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [coarse] added. 2019-04-19 17:09:34,609 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container extra_coarse 2019-04-19 17:09:34,618 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [extra_coarse] added. 2019-04-19 17:09:34,666 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container fast 2019-04-19 17:09:34,676 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [fast] added. 2019-04-19 17:09:34,818 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container high 2019-04-19 17:09:34,829 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [high] added. 2019-04-19 17:09:34,911 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container normal 2019-04-19 17:09:34,919 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [normal] added. 2019-04-19 17:09:34,921 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container extra_fast 2019-04-19 17:09:34,928 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [extra_fast] added. 2019-04-19 17:09:34,986 - DEBUG - [MainThread] cura.Machines.Models.CustomQualityProfilesDropDownMenuModel._update [15]: Updating CustomQualityProfilesDropDownMenuModel. 2019-04-19 17:09:35,381 - DEBUG - [MainThread] UM.Qt.QtRenderer._initialize [183]: Support for Vertex Array Objects: True 2019-04-19 17:09:35,408 - DEBUG - [MainThread] UM.View.GL.OpenGL.__init__ [99]: Initialized OpenGL subsystems. 2019-04-19 17:09:35,419 - DEBUG - [MainThread] UM.View.GL.OpenGL.__init__ [100]: OpenGL Version: 3.3.0 2019-04-19 17:09:35,427 - DEBUG - [MainThread] UM.View.GL.OpenGL.__init__ [101]: OpenGL Vendor: NVIDIA Corporation 2019-04-19 17:09:35,432 - DEBUG - [MainThread] UM.View.GL.OpenGL.__init__ [102]: OpenGL Renderer: GeForce 9500 GT/PCIe/SSE2 2019-04-19 17:09:35,437 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\default.shader]... 2019-04-19 17:09:35,446 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\selection.shader]... 2019-04-19 17:09:35,454 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\default.shader]... 2019-04-19 17:09:35,462 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\composite.shader]... 2019-04-19 17:09:35,471 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\overhang.shader]... 2019-04-19 17:09:35,481 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\striped.shader]... 2019-04-19 17:09:35,490 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\transparent_object.shader]... 2019-04-19 17:09:35,499 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\striped.shader]... 2019-04-19 17:09:35,510 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\default.shader]... 2019-04-19 17:09:35,517 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\grid.shader]... 2019-04-19 17:09:35,526 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\platform.shader]... 2019-04-19 17:09:35,677 - DEBUG - [MainThread] cura.Machines.QualityManager.initialize [136]: Lookup tables updated. 2019-04-19 17:09:36,215 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] [ERROR] Could not connect to the given address 2019-04-19 17:09:36,302 - DEBUG - [MainThread] cura.Machines.Models.QualityProfilesDropDownMenuModel._update [61]: Updating QualityProfilesDropDownMenuModel. 2019-04-19 17:09:36,323 - DEBUG - [MainThread] cura.Machines.Models.CustomQualityProfilesDropDownMenuModel._update [15]: Updating CustomQualityProfilesDropDownMenuModel. 2019-04-19 17:09:36,331 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onBackendQuit [811]: Backend quit with return code 0. Resetting process and socket. 2019-04-19 17:09:37,409 - INFO - [MainThread] cura.Machines.MachineErrorChecker._setResult [188]: Error check finished, result = False, time = 2.9s 2019-04-19 17:09:45,785 - DEBUG - [MainThread] cura.AutoSave._onTimeout [48]: Autosaving preferences, instances and profiles 2019-04-19 17:13:41,083 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._rescheduleCheck [136]: New error check scheduled. 2019-04-19 17:13:42,324 - INFO - [MainThread] cura.Machines.MachineErrorChecker._setResult [188]: Error check finished, result = False, time = 1.2s 2019-04-19 17:13:43,216 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._rescheduleCheck [136]: New error check scheduled. 2019-04-19 17:13:44,202 - INFO - [MainThread] cura.Machines.MachineErrorChecker._setResult [188]: Error check finished, result = False, time = 1.0s 2019-04-19 17:14:09,237 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/resources/qml/Settings/SettingItem.qml:124:19: Unable to assign [undefined] to QString 2019-04-19 17:14:09,243 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/resources/qml/Settings/SettingTextField.qml:97:19: Unable to assign [undefined] to QString 2019-04-19 17:14:09,248 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/resources/qml/Settings/SettingItem.qml:124:19: Unable to assign [undefined] to QString 2019-04-19 17:14:09,253 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/resources/qml/Settings/SettingTextField.qml:97:19: Unable to assign [undefined] to QString 2019-04-19 17:14:09,257 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/resources/qml/Settings/SettingItem.qml:124:19: Unable to assign [undefined] to QString 2019-04-19 17:14:09,263 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/resources/qml/Settings/SettingTextField.qml:97:19: Unable to assign [undefined] to QString 2019-04-19 17:14:09,267 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/resources/qml/Settings/SettingItem.qml:124:19: Unable to assign [undefined] to QString 2019-04-19 17:14:09,272 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/resources/qml/Settings/SettingTextField.qml:97:19: Unable to assign [undefined] to QString 2019-04-19 17:14:09,276 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/resources/qml/Settings/SettingItem.qml:124:19: Unable to assign [undefined] to QString 2019-04-19 17:14:09,281 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/resources/qml/Settings/SettingTextField.qml:97:19: Unable to assign [undefined] to QString 2019-04-19 17:14:09,285 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/resources/qml/Settings/SettingItem.qml:124:19: Unable to assign [undefined] to QString 2019-04-19 17:14:09,290 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/resources/qml/Settings/SettingTextField.qml:97:19: Unable to assign [undefined] to QString 2019-04-19 17:14:09,295 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/resources/qml/Settings/SettingItem.qml:124:19: Unable to assign [undefined] to QString 2019-04-19 17:14:09,299 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/resources/qml/Settings/SettingTextField.qml:97:19: Unable to assign [undefined] to QString 2019-04-19 17:14:21,503 - DEBUG - [MainThread] cura.AutoSave._onTimeout [48]: Autosaving preferences, instances and profiles 2019-04-19 17:14:36,244 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._rescheduleCheck [136]: New error check scheduled. 2019-04-19 17:14:36,680 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._checkStack [140]: Need to check for errors again. Discard the current progress and reschedule a check. 2019-04-19 17:14:36,790 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._rescheduleCheck [136]: New error check scheduled. 2019-04-19 17:14:37,770 - INFO - [MainThread] cura.Machines.MachineErrorChecker._setResult [188]: Error check finished, result = False, time = 1.0s 2019-04-19 17:14:39,916 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._rescheduleCheck [136]: New error check scheduled. 2019-04-19 17:14:40,901 - INFO - [MainThread] cura.Machines.MachineErrorChecker._setResult [188]: Error check finished, result = False, time = 1.0s 2019-04-19 17:14:44,796 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._rescheduleCheck [136]: New error check scheduled. 2019-04-19 17:14:44,951 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._checkStack [140]: Need to check for errors again. Discard the current progress and reschedule a check. 2019-04-19 17:14:45,061 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._rescheduleCheck [136]: New error check scheduled. 2019-04-19 17:14:45,515 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._checkStack [140]: Need to check for errors again. Discard the current progress and reschedule a check. 2019-04-19 17:14:45,612 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._rescheduleCheck [136]: New error check scheduled. 2019-04-19 17:14:46,282 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._checkStack [140]: Need to check for errors again. Discard the current progress and reschedule a check. 2019-04-19 17:14:46,383 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._rescheduleCheck [136]: New error check scheduled. 2019-04-19 17:14:47,735 - INFO - [MainThread] cura.Machines.MachineErrorChecker._setResult [188]: Error check finished, result = False, time = 1.4s 2019-04-19 17:14:51,228 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._rescheduleCheck [136]: New error check scheduled. 2019-04-19 17:14:51,929 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._checkStack [140]: Need to check for errors again. Discard the current progress and reschedule a check. 2019-04-19 17:14:52,038 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._rescheduleCheck [136]: New error check scheduled. 2019-04-19 17:14:53,152 - INFO - [MainThread] cura.Machines.MachineErrorChecker._setResult [188]: Error check finished, result = False, time = 1.1s 2019-04-19 17:15:02,263 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._rescheduleCheck [136]: New error check scheduled. 2019-04-19 17:15:03,433 - INFO - [MainThread] cura.Machines.MachineErrorChecker._setResult [188]: Error check finished, result = False, time = 1.2s 2019-04-19 17:15:04,825 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._rescheduleCheck [136]: New error check scheduled. 2019-04-19 17:15:06,041 - INFO - [MainThread] cura.Machines.MachineErrorChecker._setResult [188]: Error check finished, result = False, time = 1.2s 2019-04-19 17:15:09,140 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._rescheduleCheck [136]: New error check scheduled. 2019-04-19 17:15:09,273 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._checkStack [140]: Need to check for errors again. Discard the current progress and reschedule a check. 2019-04-19 17:15:09,383 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._rescheduleCheck [136]: New error check scheduled. 2019-04-19 17:15:09,674 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._checkStack [140]: Need to check for errors again. Discard the current progress and reschedule a check. 2019-04-19 17:15:09,784 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._rescheduleCheck [136]: New error check scheduled. 2019-04-19 17:15:10,749 - INFO - [MainThread] cura.Machines.MachineErrorChecker._setResult [188]: Error check finished, result = False, time = 0.9s 2019-04-19 17:15:10,972 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._rescheduleCheck [136]: New error check scheduled. 2019-04-19 17:15:11,576 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._checkStack [140]: Need to check for errors again. Discard the current progress and reschedule a check. 2019-04-19 17:15:11,685 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._rescheduleCheck [136]: New error check scheduled. 2019-04-19 17:15:11,878 - DEBUG - [MainThread] cura.AutoSave._onTimeout [48]: Autosaving preferences, instances and profiles 2019-04-19 17:15:12,424 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._checkStack [140]: Need to check for errors again. Discard the current progress and reschedule a check. 2019-04-19 17:15:12,534 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._rescheduleCheck [136]: New error check scheduled. 2019-04-19 17:15:13,910 - INFO - [MainThread] cura.Machines.MachineErrorChecker._setResult [188]: Error check finished, result = False, time = 1.4s 2019-04-19 17:15:31,173 - DEBUG - [MainThread] cura.AutoSave._onTimeout [48]: Autosaving preferences, instances and profiles 2019-04-19 17:15:43,933 - DEBUG - [MainThread] cura.AutoSave._onTimeout [48]: Autosaving preferences, instances and profiles 2019-04-19 17:16:22,206 - DEBUG - [MainThread] cura.AutoSave._onTimeout [48]: Autosaving preferences, instances and profiles 2019-04-19 17:16:46,422 - INFO - [Thread-1] STLReader.STLReader.load_file [46]: Using NumPy-STL to load STL data. 2019-04-19 17:16:46,423 - INFO - [Thread-2] STLReader.STLReader.load_file [46]: Using NumPy-STL to load STL data. 2019-04-19 17:16:46,424 - INFO - [Thread-3] STLReader.STLReader.load_file [46]: Using NumPy-STL to load STL data. 2019-04-19 17:16:46,452 - DEBUG - [Thread-1] UM.Mesh.MeshData.calculateNormalsFromVertices [444]: Calculating normals took 0.006998777389526367 seconds 2019-04-19 17:16:46,453 - DEBUG - [Thread-2] UM.Mesh.MeshData.calculateNormalsFromVertices [444]: Calculating normals took 0.0039980411529541016 seconds 2019-04-19 17:16:46,459 - DEBUG - [Thread-2] STLReader.STLReader._read [97]: Loaded a mesh with 11556 vertices 2019-04-19 17:16:46,460 - DEBUG - [Thread-1] STLReader.STLReader._read [97]: Loaded a mesh with 82644 vertices 2019-04-19 17:16:46,491 - DEBUG - [Thread-2] UM.Mesh.MeshData.approximateConvexHull [401]: approximateConvexHull(target_count=1024) Calculating 3D convex hull took 0.016998767852783203 seconds. 208 input vertices. 208 output vertices. 2019-04-19 17:16:46,505 - DEBUG - [Thread-3] UM.Mesh.MeshData.calculateNormalsFromVertices [444]: Calculating normals took 0.02187514305114746 seconds 2019-04-19 17:16:46,567 - DEBUG - [Thread-2] UM.FileHandler.ReadFileJob.run [69]: Loading file took 0.1 seconds 2019-04-19 17:16:46,583 - DEBUG - [Thread-1] UM.Mesh.MeshData.approximateConvexHull [401]: approximateConvexHull(target_count=1024) Calculating 3D convex hull took 0.10736823081970215 seconds. 351 input vertices. 351 output vertices. 2019-04-19 17:16:46,583 - DEBUG - [Thread-3] STLReader.STLReader._read [97]: Loaded a mesh with 291300 vertices 2019-04-19 17:16:46,598 - DEBUG - [Thread-2] UM.Mesh.MeshData.approximateConvexHull [401]: approximateConvexHull(target_count=1024) Calculating 3D convex hull took 0.03125357627868652 seconds. 208 input vertices. 208 output vertices. 2019-04-19 17:16:46,616 - INFO - [Thread-2] STLReader.STLReader.load_file [46]: Using NumPy-STL to load STL data. 2019-04-19 17:16:46,626 - DEBUG - [Thread-2] UM.Mesh.MeshData.calculateNormalsFromVertices [444]: Calculating normals took 0.0019989013671875 seconds 2019-04-19 17:16:46,628 - DEBUG - [Thread-2] STLReader.STLReader._read [97]: Loaded a mesh with 26622 vertices 2019-04-19 17:16:46,638 - DEBUG - [Thread-1] UM.FileHandler.ReadFileJob.run [69]: Loading file took 0.2 seconds 2019-04-19 17:16:46,647 - DEBUG - [Thread-2] UM.Mesh.MeshData.approximateConvexHull [401]: approximateConvexHull(target_count=1024) Calculating 3D convex hull took 0.014001846313476562 seconds. 55 input vertices. 55 output vertices. 2019-04-19 17:16:46,662 - DEBUG - [Thread-2] UM.FileHandler.ReadFileJob.run [69]: Loading file took 0.0 seconds 2019-04-19 17:16:46,681 - DEBUG - [Thread-2] UM.Mesh.MeshData.approximateConvexHull [401]: approximateConvexHull(target_count=1024) Calculating 3D convex hull took 0.01399850845336914 seconds. 54 input vertices. 54 output vertices. 2019-04-19 17:16:46,693 - DEBUG - [Thread-1] UM.Mesh.MeshData.approximateConvexHull [401]: approximateConvexHull(target_count=1024) Calculating 3D convex hull took 0.05099940299987793 seconds. 351 input vertices. 351 output vertices. 2019-04-19 17:16:46,790 - DEBUG - [Thread-3] UM.Mesh.MeshData.approximateConvexHull [401]: approximateConvexHull(target_count=1024) Calculating 3D convex hull took 0.20237088203430176 seconds. 2315 input vertices. 2315 output vertices. 2019-04-19 17:16:46,812 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [per_object_stack_2810009056144] added. 2019-04-19 17:16:46,881 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [per_object_stack_2810009095528] added. 2019-04-19 17:16:46,924 - DEBUG - [Thread-3] UM.FileHandler.ReadFileJob.run [69]: Loading file took 0.5 seconds 2019-04-19 17:16:46,949 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [per_object_stack_2810008705344] added. 2019-04-19 17:16:46,992 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\transparent_object.shader]... 2019-04-19 17:16:47,114 - DEBUG - [Thread-3] UM.Mesh.MeshData.approximateConvexHull [401]: approximateConvexHull(target_count=1024) Calculating 3D convex hull took 0.18399786949157715 seconds. 2315 input vertices. 2315 output vertices. 2019-04-19 17:16:47,186 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [per_object_stack_2810009164992] added. 2019-04-19 17:16:53,610 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\toolhandle.shader]... 2019-04-19 17:16:57,282 - DEBUG - [MainThread] cura.AutoSave._onTimeout [48]: Autosaving preferences, instances and profiles 2019-04-19 17:17:09,461 - DEBUG - [MainThread] cura.AutoSave._onTimeout [48]: Autosaving preferences, instances and profiles 2019-04-19 17:18:18,660 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend.slice [228]: Starting to slice... 2019-04-19 17:18:18,660 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend.slice [246]: Going to slice build plate [0]! 2019-04-19 17:18:18,660 - DEBUG - [MainThread] UM.Backend.Backend._createSocket [227]: Previous socket existed. Closing that first. 2019-04-19 17:18:18,785 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [187]: Socket state changed to Listening 2019-04-19 17:18:18,927 - INFO - [MainThread] UM.Backend.Backend.startEngine [81]: Started engine process: C:\Program Files\Ultimaker Cura 4.0\CuraEngine.exe 2019-04-19 17:18:18,938 - DEBUG - [MainThread] UM.Backend.Backend._backendLog [101]: [Backend] Calling engine with: ['C:\\Program Files\\Ultimaker Cura 4.0\\CuraEngine.exe', 'connect', '127.0.0.1:49675', ''] 2019-04-19 17:18:19,013 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:18:19,044 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] Cura_SteamEngine version 4.0.0 2019-04-19 17:18:19,060 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] Copyright (C) 2018 Ultimaker 2019-04-19 17:18:19,107 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:18:19,122 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] This program is free software: you can redistribute it and/or modify 2019-04-19 17:18:19,201 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] it under the terms of the GNU Affero General Public License as published by 2019-04-19 17:18:19,326 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] the Free Software Foundation, either version 3 of the License, or 2019-04-19 17:18:19,372 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] (at your option) any later version. 2019-04-19 17:18:19,372 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:18:19,451 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] This program is distributed in the hope that it will be useful, 2019-04-19 17:18:19,544 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] but WITHOUT ANY WARRANTY; without even the implied warranty of 2019-04-19 17:18:19,654 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the 2019-04-19 17:18:19,685 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] GNU Affero General Public License for more details. 2019-04-19 17:18:19,716 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:18:19,763 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] You should have received a copy of the GNU Affero General Public License 2019-04-19 17:18:19,925 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] along with this program. If not, see <http://www.gnu.org/licenses/>. 2019-04-19 17:18:20,951 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onStartSliceCompleted [432]: Sending slice message took 2.290106773376465 seconds 2019-04-19 17:18:40,018 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] [ERROR] Could not connect to the given address 2019-04-19 17:18:40,128 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onBackendQuit [811]: Backend quit with return code 0. Resetting process and socket. 2019-04-19 17:19:18,625 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._terminate [295]: Attempting to kill the engine process 2019-04-19 17:19:18,630 - DEBUG - [MainThread] UM.Backend.Backend._createSocket [227]: Previous socket existed. Closing that first. 2019-04-19 17:19:18,666 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [187]: Socket state changed to Listening 2019-04-19 17:19:18,681 - INFO - [MainThread] UM.Backend.Backend.startEngine [81]: Started engine process: C:\Program Files\Ultimaker Cura 4.0\CuraEngine.exe 2019-04-19 17:19:18,686 - DEBUG - [MainThread] UM.Backend.Backend._backendLog [101]: [Backend] Calling engine with: ['C:\\Program Files\\Ultimaker Cura 4.0\\CuraEngine.exe', 'connect', '127.0.0.1:49675', ''] 2019-04-19 17:19:18,817 - DEBUG - [Thread-17] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:19:18,833 - DEBUG - [Thread-17] UM.Backend.Backend._backendLog [101]: [Backend] Cura_SteamEngine version 4.0.0 2019-04-19 17:19:18,838 - DEBUG - [Thread-17] UM.Backend.Backend._backendLog [101]: [Backend] Copyright (C) 2018 Ultimaker 2019-04-19 17:19:18,844 - DEBUG - [Thread-17] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:19:18,850 - DEBUG - [Thread-17] UM.Backend.Backend._backendLog [101]: [Backend] This program is free software: you can redistribute it and/or modify 2019-04-19 17:19:18,855 - DEBUG - [Thread-17] UM.Backend.Backend._backendLog [101]: [Backend] it under the terms of the GNU Affero General Public License as published by 2019-04-19 17:19:18,861 - DEBUG - [Thread-17] UM.Backend.Backend._backendLog [101]: [Backend] the Free Software Foundation, either version 3 of the License, or 2019-04-19 17:19:18,867 - DEBUG - [Thread-17] UM.Backend.Backend._backendLog [101]: [Backend] (at your option) any later version. 2019-04-19 17:19:18,873 - DEBUG - [Thread-17] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:19:18,879 - DEBUG - [Thread-17] UM.Backend.Backend._backendLog [101]: [Backend] This program is distributed in the hope that it will be useful, 2019-04-19 17:19:18,885 - DEBUG - [Thread-17] UM.Backend.Backend._backendLog [101]: [Backend] but WITHOUT ANY WARRANTY; without even the implied warranty of 2019-04-19 17:19:18,891 - DEBUG - [Thread-17] UM.Backend.Backend._backendLog [101]: [Backend] MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the 2019-04-19 17:19:18,897 - DEBUG - [Thread-17] UM.Backend.Backend._backendLog [101]: [Backend] GNU Affero General Public License for more details. 2019-04-19 17:19:18,902 - DEBUG - [Thread-17] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:19:18,908 - DEBUG - [Thread-17] UM.Backend.Backend._backendLog [101]: [Backend] You should have received a copy of the GNU Affero General Public License 2019-04-19 17:19:18,913 - DEBUG - [Thread-17] UM.Backend.Backend._backendLog [101]: [Backend] along with this program. If not, see <http://www.gnu.org/licenses/>. 2019-04-19 17:19:38,689 - DEBUG - [MainThread] cura.AutoSave._onTimeout [48]: Autosaving preferences, instances and profiles 2019-04-19 17:19:39,842 - DEBUG - [Thread-17] UM.Backend.Backend._backendLog [101]: [Backend] [ERROR] Could not connect to the given address 2019-04-19 17:19:40,433 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onBackendQuit [811]: Backend quit with return code 0. Resetting process and socket. 2019-04-19 17:19:43,228 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._rescheduleCheck [136]: New error check scheduled. 2019-04-19 17:19:44,636 - INFO - [MainThread] cura.Machines.MachineErrorChecker._setResult [188]: Error check finished, result = False, time = 1.4s 2019-04-19 17:19:52,723 - DEBUG - [MainThread] cura.AutoSave._onTimeout [48]: Autosaving preferences, instances and profiles 2019-04-19 17:20:03,584 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._rescheduleCheck [136]: New error check scheduled. 2019-04-19 17:20:05,069 - INFO - [MainThread] cura.Machines.MachineErrorChecker._setResult [188]: Error check finished, result = False, time = 1.5s 2019-04-19 17:20:08,974 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._rescheduleCheck [136]: New error check scheduled. 2019-04-19 17:20:09,383 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._checkStack [140]: Need to check for errors again. Discard the current progress and reschedule a check. 2019-04-19 17:20:09,588 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._rescheduleCheck [136]: New error check scheduled. 2019-04-19 17:20:11,404 - INFO - [MainThread] cura.Machines.MachineErrorChecker._setResult [188]: Error check finished, result = False, time = 1.8s 2019-04-19 17:20:12,788 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend.slice [228]: Starting to slice... 2019-04-19 17:20:12,788 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend.slice [246]: Going to slice build plate [0]! 2019-04-19 17:20:12,788 - DEBUG - [MainThread] UM.Backend.Backend._createSocket [227]: Previous socket existed. Closing that first. 2019-04-19 17:20:12,929 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [187]: Socket state changed to Listening 2019-04-19 17:20:12,976 - INFO - [MainThread] UM.Backend.Backend.startEngine [81]: Started engine process: C:\Program Files\Ultimaker Cura 4.0\CuraEngine.exe 2019-04-19 17:20:12,992 - DEBUG - [MainThread] UM.Backend.Backend._backendLog [101]: [Backend] Calling engine with: ['C:\\Program Files\\Ultimaker Cura 4.0\\CuraEngine.exe', 'connect', '127.0.0.1:49675', ''] 2019-04-19 17:20:13,152 - DEBUG - [Thread-20] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:20:13,199 - DEBUG - [Thread-20] UM.Backend.Backend._backendLog [101]: [Backend] Cura_SteamEngine version 4.0.0 2019-04-19 17:20:13,246 - DEBUG - [Thread-20] UM.Backend.Backend._backendLog [101]: [Backend] Copyright (C) 2018 Ultimaker 2019-04-19 17:20:13,262 - DEBUG - [Thread-20] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:20:13,324 - DEBUG - [Thread-20] UM.Backend.Backend._backendLog [101]: [Backend] This program is free software: you can redistribute it and/or modify 2019-04-19 17:20:13,340 - DEBUG - [Thread-20] UM.Backend.Backend._backendLog [101]: [Backend] it under the terms of the GNU Affero General Public License as published by 2019-04-19 17:20:13,387 - DEBUG - [Thread-20] UM.Backend.Backend._backendLog [101]: [Backend] the Free Software Foundation, either version 3 of the License, or 2019-04-19 17:20:13,418 - DEBUG - [Thread-20] UM.Backend.Backend._backendLog [101]: [Backend] (at your option) any later version. 2019-04-19 17:20:13,449 - DEBUG - [Thread-20] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:20:13,481 - DEBUG - [Thread-20] UM.Backend.Backend._backendLog [101]: [Backend] This program is distributed in the hope that it will be useful, 2019-04-19 17:20:13,527 - DEBUG - [Thread-20] UM.Backend.Backend._backendLog [101]: [Backend] but WITHOUT ANY WARRANTY; without even the implied warranty of 2019-04-19 17:20:13,543 - DEBUG - [Thread-20] UM.Backend.Backend._backendLog [101]: [Backend] MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the 2019-04-19 17:20:13,574 - DEBUG - [Thread-20] UM.Backend.Backend._backendLog [101]: [Backend] GNU Affero General Public License for more details. 2019-04-19 17:20:13,606 - DEBUG - [Thread-20] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:20:13,652 - DEBUG - [Thread-20] UM.Backend.Backend._backendLog [101]: [Backend] You should have received a copy of the GNU Affero General Public License 2019-04-19 17:20:13,684 - DEBUG - [Thread-20] UM.Backend.Backend._backendLog [101]: [Backend] along with this program. If not, see <http://www.gnu.org/licenses/>. 2019-04-19 17:20:14,992 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onStartSliceCompleted [432]: Sending slice message took 2.202559471130371 seconds 2019-04-19 17:20:34,057 - DEBUG - [Thread-20] UM.Backend.Backend._backendLog [101]: [Backend] [ERROR] Could not connect to the given address 2019-04-19 17:20:34,068 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onBackendQuit [811]: Backend quit with return code 0. Resetting process and socket. 2019-04-19 17:22:05,995 - DEBUG - [MainThread] UM.Controller.setActiveStage [159]: Setting active stage to PreviewStage 2019-04-19 17:22:06,085 - DEBUG - [MainThread] UM.Controller.setActiveView [92]: Setting active view to SimulationView 2019-04-19 17:22:06,087 - INFO - [MainThread] STLReader.STLReader.load_file [46]: Using NumPy-STL to load STL data. 2019-04-19 17:22:06,094 - DEBUG - [MainThread] UM.Mesh.MeshData.calculateNormalsFromVertices [444]: Calculating normals took 0.0009989738464355469 seconds 2019-04-19 17:22:06,115 - DEBUG - [MainThread] UM.Mesh.MeshData.approximateConvexHull [401]: approximateConvexHull(target_count=1024) Calculating 3D convex hull took 0.014994144439697266 seconds. 351 input vertices. 351 output vertices. 2019-04-19 17:22:06,116 - DEBUG - [MainThread] STLReader.STLReader._read [97]: Loaded a mesh with 12612 vertices 2019-04-19 17:22:06,125 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\plugins\SimulationView\simulationview_composite.shader]... 2019-04-19 17:22:06,276 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/plugins/PreviewStage/PreviewMain.qml:22:5: QML ActionPanelWidget: Binding loop detected for property "width" 2019-04-19 17:22:06,656 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\color.shader]... 2019-04-19 17:22:06,670 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\plugins\SimulationView\layers.shader]... 2019-04-19 17:22:06,678 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\plugins\SimulationView\layers_shadow.shader]... 2019-04-19 17:22:06,686 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\toolhandle.shader]... 2019-04-19 17:22:06,693 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\color.shader]... 2019-04-19 17:22:07,236 - DEBUG - [MainThread] UM.Controller.setActiveStage [159]: Setting active stage to MonitorStage 2019-04-19 17:22:07,251 - DEBUG - [MainThread] UM.Controller.setActiveView [92]: Setting active view to SolidView 2019-04-19 17:22:09,556 - DEBUG - [MainThread] UM.Controller.setActiveStage [159]: Setting active stage to PrepareStage 2019-04-19 17:22:09,592 - DEBUG - [MainThread] cura.Machines.Models.NozzleModel._update [34]: Updating NozzleModel. 2019-04-19 17:22:09,705 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/plugins/PrepareStage/PrepareMain.qml:16:5: QML ActionPanelWidget: Binding loop detected for property "width" 2019-04-19 17:22:37,097 - DEBUG - [MainThread] cura.AutoSave._onTimeout [48]: Autosaving preferences, instances and profiles 2019-04-19 17:22:57,376 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._terminate [295]: Attempting to kill the engine process 2019-04-19 17:22:57,381 - DEBUG - [MainThread] UM.Backend.Backend._createSocket [227]: Previous socket existed. Closing that first. 2019-04-19 17:22:57,422 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [187]: Socket state changed to Listening 2019-04-19 17:22:57,436 - INFO - [MainThread] UM.Backend.Backend.startEngine [81]: Started engine process: C:\Program Files\Ultimaker Cura 4.0\CuraEngine.exe 2019-04-19 17:22:57,442 - DEBUG - [MainThread] UM.Backend.Backend._backendLog [101]: [Backend] Calling engine with: ['C:\\Program Files\\Ultimaker Cura 4.0\\CuraEngine.exe', 'connect', '127.0.0.1:49675', ''] 2019-04-19 17:22:57,507 - DEBUG - [Thread-23] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:22:57,507 - DEBUG - [Thread-23] UM.Backend.Backend._backendLog [101]: [Backend] Cura_SteamEngine version 4.0.0 2019-04-19 17:22:57,522 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._rescheduleCheck [136]: New error check scheduled. 2019-04-19 17:22:57,522 - DEBUG - [Thread-23] UM.Backend.Backend._backendLog [101]: [Backend] Copyright (C) 2018 Ultimaker 2019-04-19 17:22:57,537 - DEBUG - [Thread-23] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:22:57,544 - DEBUG - [Thread-23] UM.Backend.Backend._backendLog [101]: [Backend] This program is free software: you can redistribute it and/or modify 2019-04-19 17:22:57,544 - DEBUG - [Thread-23] UM.Backend.Backend._backendLog [101]: [Backend] it under the terms of the GNU Affero General Public License as published by 2019-04-19 17:22:57,559 - DEBUG - [Thread-23] UM.Backend.Backend._backendLog [101]: [Backend] the Free Software Foundation, either version 3 of the License, or 2019-04-19 17:22:57,559 - DEBUG - [Thread-23] UM.Backend.Backend._backendLog [101]: [Backend] (at your option) any later version. 2019-04-19 17:22:57,575 - DEBUG - [Thread-23] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:22:57,575 - DEBUG - [Thread-23] UM.Backend.Backend._backendLog [101]: [Backend] This program is distributed in the hope that it will be useful, 2019-04-19 17:22:57,575 - DEBUG - [Thread-23] UM.Backend.Backend._backendLog [101]: [Backend] but WITHOUT ANY WARRANTY; without even the implied warranty of 2019-04-19 17:22:57,591 - DEBUG - [Thread-23] UM.Backend.Backend._backendLog [101]: [Backend] MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the 2019-04-19 17:22:57,591 - DEBUG - [Thread-23] UM.Backend.Backend._backendLog [101]: [Backend] GNU Affero General Public License for more details. 2019-04-19 17:22:57,591 - DEBUG - [Thread-23] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:22:57,606 - DEBUG - [Thread-23] UM.Backend.Backend._backendLog [101]: [Backend] You should have received a copy of the GNU Affero General Public License 2019-04-19 17:22:57,606 - DEBUG - [Thread-23] UM.Backend.Backend._backendLog [101]: [Backend] along with this program. If not, see <http://www.gnu.org/licenses/>. 2019-04-19 17:22:57,755 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._checkStack [140]: Need to check for errors again. Discard the current progress and reschedule a check. 2019-04-19 17:22:57,883 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._rescheduleCheck [136]: New error check scheduled. 2019-04-19 17:22:58,722 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._checkStack [140]: Need to check for errors again. Discard the current progress and reschedule a check. 2019-04-19 17:22:58,877 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._rescheduleCheck [136]: New error check scheduled. 2019-04-19 17:22:59,858 - INFO - [MainThread] cura.Machines.MachineErrorChecker._setResult [188]: Error check finished, result = False, time = 1.0s 2019-04-19 17:23:02,384 - DEBUG - [MainThread] cura.AutoSave._onTimeout [48]: Autosaving preferences, instances and profiles 2019-04-19 17:23:08,684 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._rescheduleCheck [136]: New error check scheduled. 2019-04-19 17:23:09,744 - INFO - [MainThread] cura.Machines.MachineErrorChecker._setResult [188]: Error check finished, result = False, time = 1.0s 2019-04-19 17:23:10,209 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._rescheduleCheck [136]: New error check scheduled. 2019-04-19 17:23:11,190 - INFO - [MainThread] cura.Machines.MachineErrorChecker._setResult [188]: Error check finished, result = False, time = 1.0s 2019-04-19 17:23:18,528 - DEBUG - [Thread-23] UM.Backend.Backend._backendLog [101]: [Backend] [ERROR] Could not connect to the given address 2019-04-19 17:23:18,560 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onBackendQuit [811]: Backend quit with return code 0. Resetting process and socket. 2019-04-19 17:23:25,376 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend.slice [228]: Starting to slice... 2019-04-19 17:23:25,377 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend.slice [246]: Going to slice build plate [0]! 2019-04-19 17:23:25,382 - DEBUG - [MainThread] UM.Backend.Backend._createSocket [227]: Previous socket existed. Closing that first. 2019-04-19 17:23:26,247 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [187]: Socket state changed to Listening 2019-04-19 17:23:26,309 - INFO - [MainThread] UM.Backend.Backend.startEngine [81]: Started engine process: C:\Program Files\Ultimaker Cura 4.0\CuraEngine.exe 2019-04-19 17:23:26,356 - DEBUG - [MainThread] UM.Backend.Backend._backendLog [101]: [Backend] Calling engine with: ['C:\\Program Files\\Ultimaker Cura 4.0\\CuraEngine.exe', 'connect', '127.0.0.1:49675', ''] 2019-04-19 17:23:26,387 - DEBUG - [Thread-26] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:23:26,450 - DEBUG - [Thread-26] UM.Backend.Backend._backendLog [101]: [Backend] Cura_SteamEngine version 4.0.0 2019-04-19 17:23:26,575 - DEBUG - [Thread-26] UM.Backend.Backend._backendLog [101]: [Backend] Copyright (C) 2018 Ultimaker 2019-04-19 17:23:26,775 - DEBUG - [Thread-26] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:23:26,781 - DEBUG - [Thread-26] UM.Backend.Backend._backendLog [101]: [Backend] This program is free software: you can redistribute it and/or modify 2019-04-19 17:23:26,786 - DEBUG - [Thread-26] UM.Backend.Backend._backendLog [101]: [Backend] it under the terms of the GNU Affero General Public License as published by 2019-04-19 17:23:26,792 - DEBUG - [Thread-26] UM.Backend.Backend._backendLog [101]: [Backend] the Free Software Foundation, either version 3 of the License, or 2019-04-19 17:23:26,797 - DEBUG - [Thread-26] UM.Backend.Backend._backendLog [101]: [Backend] (at your option) any later version. 2019-04-19 17:23:26,802 - DEBUG - [Thread-26] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:23:26,808 - DEBUG - [Thread-26] UM.Backend.Backend._backendLog [101]: [Backend] This program is distributed in the hope that it will be useful, 2019-04-19 17:23:26,813 - DEBUG - [Thread-26] UM.Backend.Backend._backendLog [101]: [Backend] but WITHOUT ANY WARRANTY; without even the implied warranty of 2019-04-19 17:23:26,819 - DEBUG - [Thread-26] UM.Backend.Backend._backendLog [101]: [Backend] MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the 2019-04-19 17:23:26,825 - DEBUG - [Thread-26] UM.Backend.Backend._backendLog [101]: [Backend] GNU Affero General Public License for more details. 2019-04-19 17:23:26,831 - DEBUG - [Thread-26] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:23:26,836 - DEBUG - [Thread-26] UM.Backend.Backend._backendLog [101]: [Backend] You should have received a copy of the GNU Affero General Public License 2019-04-19 17:23:26,842 - DEBUG - [Thread-26] UM.Backend.Backend._backendLog [101]: [Backend] along with this program. If not, see <http://www.gnu.org/licenses/>. 2019-04-19 17:23:27,315 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onStartSliceCompleted [432]: Sending slice message took 1.9387853145599365 seconds 2019-04-19 17:23:32,197 - DEBUG - [MainThread] cura.AutoSave._onTimeout [48]: Autosaving preferences, instances and profiles 2019-04-19 17:23:47,399 - DEBUG - [Thread-26] UM.Backend.Backend._backendLog [101]: [Backend] [ERROR] Could not connect to the given address 2019-04-19 17:23:47,430 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onBackendQuit [811]: Backend quit with return code 0. Resetting process and socket. 2019-04-19 17:24:58,931 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._terminate [295]: Attempting to kill the engine process 2019-04-19 17:24:58,936 - DEBUG - [MainThread] UM.Backend.Backend._createSocket [227]: Previous socket existed. Closing that first. 2019-04-19 17:24:58,974 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [187]: Socket state changed to Listening 2019-04-19 17:24:58,988 - INFO - [MainThread] UM.Backend.Backend.startEngine [81]: Started engine process: C:\Program Files\Ultimaker Cura 4.0\CuraEngine.exe 2019-04-19 17:24:58,994 - DEBUG - [MainThread] UM.Backend.Backend._backendLog [101]: [Backend] Calling engine with: ['C:\\Program Files\\Ultimaker Cura 4.0\\CuraEngine.exe', 'connect', '127.0.0.1:49675', ''] 2019-04-19 17:24:59,233 - DEBUG - [Thread-29] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:24:59,238 - DEBUG - [Thread-29] UM.Backend.Backend._backendLog [101]: [Backend] Cura_SteamEngine version 4.0.0 2019-04-19 17:24:59,244 - DEBUG - [Thread-29] UM.Backend.Backend._backendLog [101]: [Backend] Copyright (C) 2018 Ultimaker 2019-04-19 17:24:59,249 - DEBUG - [Thread-29] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:24:59,255 - DEBUG - [Thread-29] UM.Backend.Backend._backendLog [101]: [Backend] This program is free software: you can redistribute it and/or modify 2019-04-19 17:24:59,260 - DEBUG - [Thread-29] UM.Backend.Backend._backendLog [101]: [Backend] it under the terms of the GNU Affero General Public License as published by 2019-04-19 17:24:59,266 - DEBUG - [Thread-29] UM.Backend.Backend._backendLog [101]: [Backend] the Free Software Foundation, either version 3 of the License, or 2019-04-19 17:24:59,271 - DEBUG - [Thread-29] UM.Backend.Backend._backendLog [101]: [Backend] (at your option) any later version. 2019-04-19 17:24:59,276 - DEBUG - [Thread-29] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:24:59,281 - DEBUG - [Thread-29] UM.Backend.Backend._backendLog [101]: [Backend] This program is distributed in the hope that it will be useful, 2019-04-19 17:24:59,285 - DEBUG - [Thread-29] UM.Backend.Backend._backendLog [101]: [Backend] but WITHOUT ANY WARRANTY; without even the implied warranty of 2019-04-19 17:24:59,290 - DEBUG - [Thread-29] UM.Backend.Backend._backendLog [101]: [Backend] MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the 2019-04-19 17:24:59,295 - DEBUG - [Thread-29] UM.Backend.Backend._backendLog [101]: [Backend] GNU Affero General Public License for more details. 2019-04-19 17:24:59,300 - DEBUG - [Thread-29] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:24:59,305 - DEBUG - [Thread-29] UM.Backend.Backend._backendLog [101]: [Backend] You should have received a copy of the GNU Affero General Public License 2019-04-19 17:24:59,310 - DEBUG - [Thread-29] UM.Backend.Backend._backendLog [101]: [Backend] along with this program. If not, see <http://www.gnu.org/licenses/>. 2019-04-19 17:25:02,207 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend.slice [228]: Starting to slice... 2019-04-19 17:25:02,208 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend.slice [246]: Going to slice build plate [0]! 2019-04-19 17:25:04,511 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onStartSliceCompleted [432]: Sending slice message took 2.3029661178588867 seconds 2019-04-19 17:25:20,254 - DEBUG - [Thread-29] UM.Backend.Backend._backendLog [101]: [Backend] [ERROR] Could not connect to the given address 2019-04-19 17:25:20,332 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onBackendQuit [811]: Backend quit with return code 0. Resetting process and socket. 2019-04-19 17:29:36,760 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._terminate [295]: Attempting to kill the engine process 2019-04-19 17:29:36,765 - DEBUG - [MainThread] UM.Backend.Backend._createSocket [227]: Previous socket existed. Closing that first. 2019-04-19 17:29:36,799 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [187]: Socket state changed to Listening 2019-04-19 17:29:36,815 - INFO - [MainThread] UM.Backend.Backend.startEngine [81]: Started engine process: C:\Program Files\Ultimaker Cura 4.0\CuraEngine.exe 2019-04-19 17:29:36,821 - DEBUG - [MainThread] UM.Backend.Backend._backendLog [101]: [Backend] Calling engine with: ['C:\\Program Files\\Ultimaker Cura 4.0\\CuraEngine.exe', 'connect', '127.0.0.1:49675', ''] 2019-04-19 17:29:36,896 - DEBUG - [Thread-32] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:29:36,901 - DEBUG - [Thread-32] UM.Backend.Backend._backendLog [101]: [Backend] Cura_SteamEngine version 4.0.0 2019-04-19 17:29:36,905 - DEBUG - [Thread-32] UM.Backend.Backend._backendLog [101]: [Backend] Copyright (C) 2018 Ultimaker 2019-04-19 17:29:36,911 - DEBUG - [Thread-32] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:29:36,916 - DEBUG - [Thread-32] UM.Backend.Backend._backendLog [101]: [Backend] This program is free software: you can redistribute it and/or modify 2019-04-19 17:29:36,921 - DEBUG - [Thread-32] UM.Backend.Backend._backendLog [101]: [Backend] it under the terms of the GNU Affero General Public License as published by 2019-04-19 17:29:36,925 - DEBUG - [Thread-32] UM.Backend.Backend._backendLog [101]: [Backend] the Free Software Foundation, either version 3 of the License, or 2019-04-19 17:29:36,930 - DEBUG - [Thread-32] UM.Backend.Backend._backendLog [101]: [Backend] (at your option) any later version. 2019-04-19 17:29:36,950 - DEBUG - [Thread-32] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:29:36,958 - DEBUG - [Thread-32] UM.Backend.Backend._backendLog [101]: [Backend] This program is distributed in the hope that it will be useful, 2019-04-19 17:29:36,964 - DEBUG - [Thread-32] UM.Backend.Backend._backendLog [101]: [Backend] but WITHOUT ANY WARRANTY; without even the implied warranty of 2019-04-19 17:29:36,970 - DEBUG - [Thread-32] UM.Backend.Backend._backendLog [101]: [Backend] MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the 2019-04-19 17:29:36,979 - DEBUG - [Thread-32] UM.Backend.Backend._backendLog [101]: [Backend] GNU Affero General Public License for more details. 2019-04-19 17:29:36,988 - DEBUG - [Thread-32] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:29:36,994 - DEBUG - [Thread-32] UM.Backend.Backend._backendLog [101]: [Backend] You should have received a copy of the GNU Affero General Public License 2019-04-19 17:29:37,000 - DEBUG - [Thread-32] UM.Backend.Backend._backendLog [101]: [Backend] along with this program. If not, see <http://www.gnu.org/licenses/>. 2019-04-19 17:29:57,904 - DEBUG - [Thread-32] UM.Backend.Backend._backendLog [101]: [Backend] [ERROR] Could not connect to the given address 2019-04-19 17:29:57,983 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onBackendQuit [811]: Backend quit with return code 0. Resetting process and socket. 2019-04-19 17:30:11,386 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend.slice [228]: Starting to slice... 2019-04-19 17:30:11,386 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend.slice [246]: Going to slice build plate [0]! 2019-04-19 17:30:11,392 - DEBUG - [MainThread] UM.Backend.Backend._createSocket [227]: Previous socket existed. Closing that first. 2019-04-19 17:30:11,448 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [187]: Socket state changed to Listening 2019-04-19 17:30:11,535 - INFO - [MainThread] UM.Backend.Backend.startEngine [81]: Started engine process: C:\Program Files\Ultimaker Cura 4.0\CuraEngine.exe 2019-04-19 17:30:11,543 - DEBUG - [MainThread] UM.Backend.Backend._backendLog [101]: [Backend] Calling engine with: ['C:\\Program Files\\Ultimaker Cura 4.0\\CuraEngine.exe', 'connect', '127.0.0.1:49675', ''] 2019-04-19 17:30:11,599 - DEBUG - [Thread-35] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:30:11,695 - DEBUG - [Thread-35] UM.Backend.Backend._backendLog [101]: [Backend] Cura_SteamEngine version 4.0.0 2019-04-19 17:30:11,702 - DEBUG - [Thread-35] UM.Backend.Backend._backendLog [101]: [Backend] Copyright (C) 2018 Ultimaker 2019-04-19 17:30:11,710 - DEBUG - [Thread-35] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:30:11,720 - DEBUG - [Thread-35] UM.Backend.Backend._backendLog [101]: [Backend] This program is free software: you can redistribute it and/or modify 2019-04-19 17:30:11,731 - DEBUG - [Thread-35] UM.Backend.Backend._backendLog [101]: [Backend] it under the terms of the GNU Affero General Public License as published by 2019-04-19 17:30:11,941 - DEBUG - [Thread-35] UM.Backend.Backend._backendLog [101]: [Backend] the Free Software Foundation, either version 3 of the License, or 2019-04-19 17:30:11,955 - DEBUG - [Thread-35] UM.Backend.Backend._backendLog [101]: [Backend] (at your option) any later version. 2019-04-19 17:30:11,976 - DEBUG - [Thread-35] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:30:11,983 - DEBUG - [Thread-35] UM.Backend.Backend._backendLog [101]: [Backend] This program is distributed in the hope that it will be useful, 2019-04-19 17:30:11,997 - DEBUG - [Thread-35] UM.Backend.Backend._backendLog [101]: [Backend] but WITHOUT ANY WARRANTY; without even the implied warranty of 2019-04-19 17:30:12,013 - DEBUG - [Thread-35] UM.Backend.Backend._backendLog [101]: [Backend] MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the 2019-04-19 17:30:12,018 - DEBUG - [Thread-35] UM.Backend.Backend._backendLog [101]: [Backend] GNU Affero General Public License for more details. 2019-04-19 17:30:12,023 - DEBUG - [Thread-35] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:30:12,032 - DEBUG - [Thread-35] UM.Backend.Backend._backendLog [101]: [Backend] You should have received a copy of the GNU Affero General Public License 2019-04-19 17:30:12,042 - DEBUG - [Thread-35] UM.Backend.Backend._backendLog [101]: [Backend] along with this program. If not, see <http://www.gnu.org/licenses/>. 2019-04-19 17:30:13,580 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onStartSliceCompleted [432]: Sending slice message took 2.19296932220459 seconds 2019-04-19 17:30:13,974 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._terminate [295]: Attempting to kill the engine process 2019-04-19 17:30:13,974 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._terminate [301]: Killing engine process 2019-04-19 17:30:13,982 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._terminate [304]: Engine process is killed. Received return code 1 2019-04-19 17:30:13,988 - DEBUG - [MainThread] UM.Backend.Backend._createSocket [227]: Previous socket existed. Closing that first. 2019-04-19 17:30:14,011 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [187]: Socket state changed to Listening 2019-04-19 17:30:14,025 - INFO - [MainThread] UM.Backend.Backend.startEngine [81]: Started engine process: C:\Program Files\Ultimaker Cura 4.0\CuraEngine.exe 2019-04-19 17:30:14,030 - DEBUG - [MainThread] UM.Backend.Backend._backendLog [101]: [Backend] Calling engine with: ['C:\\Program Files\\Ultimaker Cura 4.0\\CuraEngine.exe', 'connect', '127.0.0.1:49675', ''] 2019-04-19 17:30:14,099 - DEBUG - [Thread-38] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:30:14,104 - DEBUG - [Thread-38] UM.Backend.Backend._backendLog [101]: [Backend] Cura_SteamEngine version 4.0.0 2019-04-19 17:30:14,108 - DEBUG - [Thread-38] UM.Backend.Backend._backendLog [101]: [Backend] Copyright (C) 2018 Ultimaker 2019-04-19 17:30:14,113 - DEBUG - [Thread-38] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:30:14,118 - DEBUG - [Thread-38] UM.Backend.Backend._backendLog [101]: [Backend] This program is free software: you can redistribute it and/or modify 2019-04-19 17:30:14,122 - DEBUG - [Thread-38] UM.Backend.Backend._backendLog [101]: [Backend] it under the terms of the GNU Affero General Public License as published by 2019-04-19 17:30:14,127 - DEBUG - [Thread-38] UM.Backend.Backend._backendLog [101]: [Backend] the Free Software Foundation, either version 3 of the License, or 2019-04-19 17:30:14,131 - DEBUG - [Thread-38] UM.Backend.Backend._backendLog [101]: [Backend] (at your option) any later version. 2019-04-19 17:30:14,136 - DEBUG - [Thread-38] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:30:14,141 - DEBUG - [Thread-38] UM.Backend.Backend._backendLog [101]: [Backend] This program is distributed in the hope that it will be useful, 2019-04-19 17:30:14,145 - DEBUG - [Thread-38] UM.Backend.Backend._backendLog [101]: [Backend] but WITHOUT ANY WARRANTY; without even the implied warranty of 2019-04-19 17:30:14,150 - DEBUG - [Thread-38] UM.Backend.Backend._backendLog [101]: [Backend] MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the 2019-04-19 17:30:14,155 - DEBUG - [Thread-38] UM.Backend.Backend._backendLog [101]: [Backend] GNU Affero General Public License for more details. 2019-04-19 17:30:14,159 - DEBUG - [Thread-38] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:30:14,164 - DEBUG - [Thread-38] UM.Backend.Backend._backendLog [101]: [Backend] You should have received a copy of the GNU Affero General Public License 2019-04-19 17:30:14,169 - DEBUG - [Thread-38] UM.Backend.Backend._backendLog [101]: [Backend] along with this program. If not, see <http://www.gnu.org/licenses/>. 2019-04-19 17:30:14,642 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend.slice [228]: Starting to slice... 2019-04-19 17:30:14,643 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend.slice [246]: Going to slice build plate [0]! 2019-04-19 17:30:16,551 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onStartSliceCompleted [432]: Sending slice message took 1.906975507736206 seconds 2019-04-19 17:30:32,310 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._terminate [295]: Attempting to kill the engine process 2019-04-19 17:30:32,312 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._terminate [301]: Killing engine process 2019-04-19 17:30:32,317 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._terminate [304]: Engine process is killed. Received return code 1 2019-04-19 17:30:32,323 - DEBUG - [MainThread] UM.Backend.Backend._createSocket [227]: Previous socket existed. Closing that first. 2019-04-19 17:30:32,346 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [187]: Socket state changed to Listening 2019-04-19 17:30:32,362 - INFO - [MainThread] UM.Backend.Backend.startEngine [81]: Started engine process: C:\Program Files\Ultimaker Cura 4.0\CuraEngine.exe 2019-04-19 17:30:32,367 - DEBUG - [MainThread] UM.Backend.Backend._backendLog [101]: [Backend] Calling engine with: ['C:\\Program Files\\Ultimaker Cura 4.0\\CuraEngine.exe', 'connect', '127.0.0.1:49675', ''] 2019-04-19 17:30:32,437 - DEBUG - [Thread-41] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:30:32,442 - DEBUG - [Thread-41] UM.Backend.Backend._backendLog [101]: [Backend] Cura_SteamEngine version 4.0.0 2019-04-19 17:30:32,447 - DEBUG - [Thread-41] UM.Backend.Backend._backendLog [101]: [Backend] Copyright (C) 2018 Ultimaker 2019-04-19 17:30:32,451 - DEBUG - [Thread-41] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:30:32,456 - DEBUG - [Thread-41] UM.Backend.Backend._backendLog [101]: [Backend] This program is free software: you can redistribute it and/or modify 2019-04-19 17:30:32,460 - DEBUG - [Thread-41] UM.Backend.Backend._backendLog [101]: [Backend] it under the terms of the GNU Affero General Public License as published by 2019-04-19 17:30:32,465 - DEBUG - [Thread-41] UM.Backend.Backend._backendLog [101]: [Backend] the Free Software Foundation, either version 3 of the License, or 2019-04-19 17:30:32,470 - DEBUG - [Thread-41] UM.Backend.Backend._backendLog [101]: [Backend] (at your option) any later version. 2019-04-19 17:30:32,474 - DEBUG - [Thread-41] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:30:32,479 - DEBUG - [Thread-41] UM.Backend.Backend._backendLog [101]: [Backend] This program is distributed in the hope that it will be useful, 2019-04-19 17:30:32,484 - DEBUG - [Thread-41] UM.Backend.Backend._backendLog [101]: [Backend] but WITHOUT ANY WARRANTY; without even the implied warranty of 2019-04-19 17:30:32,489 - DEBUG - [Thread-41] UM.Backend.Backend._backendLog [101]: [Backend] MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the 2019-04-19 17:30:32,493 - DEBUG - [Thread-41] UM.Backend.Backend._backendLog [101]: [Backend] GNU Affero General Public License for more details. 2019-04-19 17:30:32,498 - DEBUG - [Thread-41] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:30:32,502 - DEBUG - [Thread-41] UM.Backend.Backend._backendLog [101]: [Backend] You should have received a copy of the GNU Affero General Public License 2019-04-19 17:30:32,507 - DEBUG - [Thread-41] UM.Backend.Backend._backendLog [101]: [Backend] along with this program. If not, see <http://www.gnu.org/licenses/>. 2019-04-19 17:30:33,328 - DEBUG - [MainThread] cura.TaskManagement.OnExitCallbackManager.triggerNextCallback [51]: No more on-app-exit callbacks to process. Tell the app to exit. 2019-04-19 17:30:33,333 - INFO - [MainThread] cura.CuraApplication.closeApplication [547]: Close application 2019-04-19 17:30:33,355 - DEBUG - [MainThread] UM.Qt.QtApplication.windowClosed [417]: Shutting down cura 2019-04-19 17:30:33,448 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._terminate [295]: Attempting to kill the engine process 2019-04-19 17:30:33,449 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._terminate [301]: Killing engine process 2019-04-19 17:30:33,460 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._terminate [304]: Engine process is killed. Received return code 1 2019-04-19 17:30:50,531 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin FileLogger 2019-04-19 17:30:50,561 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin FirmwareUpdateChecker 2019-04-19 17:30:50,588 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin FirmwareUpdater 2019-04-19 17:30:50,617 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin GCodeGzReader 2019-04-19 17:30:50,644 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin GCodeGzWriter 2019-04-19 17:30:50,673 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin GCodeProfileReader 2019-04-19 17:30:50,720 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin GCodeReader 2019-04-19 17:30:50,747 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin GCodeWriter 2019-04-19 17:30:50,774 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin ImageReader 2019-04-19 17:30:50,798 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin LegacyProfileReader 2019-04-19 17:30:50,821 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin LocalContainerProvider 2019-04-19 17:30:50,851 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin LocalFileOutputDevice 2019-04-19 17:30:50,877 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin MachineSettingsAction 2019-04-19 17:30:50,903 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin ModelChecker 2019-04-19 17:30:50,937 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin MonitorStage 2019-04-19 17:30:50,981 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin PerObjectSettingsTool 2019-04-19 17:30:51,025 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin PostProcessingPlugin 2019-04-19 17:30:51,057 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin PrepareStage 2019-04-19 17:30:51,090 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin PreviewStage 2019-04-19 17:30:51,126 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin RemovableDriveOutputDevice 2019-04-19 17:30:51,165 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin SimulationView 2019-04-19 17:30:51,193 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin SliceInfoPlugin 2019-04-19 17:30:51,219 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin SolidView 2019-04-19 17:30:51,247 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin SupportEraser 2019-04-19 17:30:51,289 - DEBUG - [MainThread] cura.OAuth2.AuthorizationService.getAccessToken [106]: No auth data to retrieve the access_token from 2019-04-19 17:30:51,297 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin Toolbox 2019-04-19 17:30:51,329 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin CameraTool 2019-04-19 17:30:51,362 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin MirrorTool 2019-04-19 17:30:51,401 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin RotateTool 2019-04-19 17:30:51,441 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin ScaleTool 2019-04-19 17:30:51,471 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin SelectionTool 2019-04-19 17:30:51,506 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin TranslateTool 2019-04-19 17:30:51,563 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin UFPWriter 2019-04-19 17:30:51,600 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin UltimakerMachineActions 2019-04-19 17:30:51,788 - DEBUG - [MainThread] UM3NetworkPrinting.src.Cloud.CloudOutputDeviceManager._onLoginStateChanged [57]: Log in state changed to False 2019-04-19 17:30:51,789 - DEBUG - [MainThread] UM3NetworkPrinting.src.Cloud.CloudOutputDeviceManager._onGetRemoteClustersFinished [80]: Parsed remote clusters to [] 2019-04-19 17:30:51,789 - DEBUG - [MainThread] UM3NetworkPrinting.src.Cloud.CloudOutputDeviceManager._onGetRemoteClustersFinished [81]: Removed: 0, added: 0, updates: 0 2019-04-19 17:30:51,796 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin UM3NetworkPrinting 2019-04-19 17:30:51,852 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin UpdateChecker 2019-04-19 17:30:51,864 - INFO - [Thread-2] UpdateChecker.UpdateCheckerJob.run [36]: Checking for new version of cura 2019-04-19 17:30:51,936 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin USBPrinting 2019-04-19 17:30:51,991 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin UserAgreement 2019-04-19 17:30:52,042 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade21to22 2019-04-19 17:30:52,077 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade22to24 2019-04-19 17:30:52,111 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade25to26 2019-04-19 17:30:52,147 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade26to27 2019-04-19 17:30:52,181 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade27to30 2019-04-19 17:30:52,216 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade30to31 2019-04-19 17:30:52,251 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade32to33 2019-04-19 17:30:52,289 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade33to34 2019-04-19 17:30:52,323 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade34to35 2019-04-19 17:30:52,362 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade35to40 2019-04-19 17:30:52,399 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin SimpleView 2019-04-19 17:30:52,437 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin X3DReader 2019-04-19 17:30:52,479 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin XmlMaterialProfile 2019-04-19 17:30:52,518 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin XRayView 2019-04-19 17:30:52,557 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin CustomSupports 2019-04-19 17:30:52,599 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin OrientationPlugin 2019-04-19 17:30:52,628 - INFO - [MainThread] UM.VersionUpgradeManager.upgrade [143]: Looking for old configuration files to upgrade. 2019-04-19 17:30:52,683 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\packages.json, skip it 2019-04-19 17:30:52,690 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\plugins.json, skip it 2019-04-19 17:30:52,724 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\packages.json, skip it 2019-04-19 17:30:52,729 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\plugins.json, skip it 2019-04-19 17:30:52,774 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\packages.json, skip it 2019-04-19 17:30:52,781 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\plugins.json, skip it 2019-04-19 17:30:52,815 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\packages.json, skip it 2019-04-19 17:30:52,820 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\plugins.json, skip it 2019-04-19 17:30:52,855 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\packages.json, skip it 2019-04-19 17:30:52,862 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\plugins.json, skip it 2019-04-19 17:30:52,898 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\packages.json, skip it 2019-04-19 17:30:52,904 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\plugins.json, skip it 2019-04-19 17:30:52,945 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\packages.json, skip it 2019-04-19 17:30:52,954 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\plugins.json, skip it 2019-04-19 17:30:53,002 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\packages.json, skip it 2019-04-19 17:30:53,009 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\plugins.json, skip it 2019-04-19 17:30:53,111 - DEBUG - [MainThread] UM.Backend.Backend._onSocketError [213]: Socket was unable to bind to port, increasing port number to 49675 2019-04-19 17:30:53,116 - DEBUG - [MainThread] UM.Backend.Backend._createSocket [227]: Previous socket existed. Closing that first. 2019-04-19 17:30:53,119 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._terminate [295]: Attempting to kill the engine process 2019-04-19 17:30:53,124 - DEBUG - [MainThread] UM.Backend.Backend._createSocket [227]: Previous socket existed. Closing that first. 2019-04-19 17:30:53,341 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [187]: Socket state changed to Listening 2019-04-19 17:30:53,356 - INFO - [MainThread] UM.Backend.Backend.startEngine [81]: Started engine process: C:\Program Files\Ultimaker Cura 4.0\CuraEngine.exe 2019-04-19 17:30:53,361 - DEBUG - [MainThread] UM.Backend.Backend._backendLog [101]: [Backend] Calling engine with: ['C:\\Program Files\\Ultimaker Cura 4.0\\CuraEngine.exe', 'connect', '127.0.0.1:49675', ''] 2019-04-19 17:30:53,424 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:30:53,430 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] Cura_SteamEngine version 4.0.0 2019-04-19 17:30:53,435 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] Copyright (C) 2018 Ultimaker 2019-04-19 17:30:53,441 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:30:53,446 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] This program is free software: you can redistribute it and/or modify 2019-04-19 17:30:53,451 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] it under the terms of the GNU Affero General Public License as published by 2019-04-19 17:30:53,456 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] the Free Software Foundation, either version 3 of the License, or 2019-04-19 17:30:53,462 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] (at your option) any later version. 2019-04-19 17:30:53,469 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:30:53,475 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] This program is distributed in the hope that it will be useful, 2019-04-19 17:30:53,481 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] but WITHOUT ANY WARRANTY; without even the implied warranty of 2019-04-19 17:30:53,486 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the 2019-04-19 17:30:53,490 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] GNU Affero General Public License for more details. 2019-04-19 17:30:53,496 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:30:53,501 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] You should have received a copy of the GNU Affero General Public License 2019-04-19 17:30:53,507 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] along with this program. If not, see <http://www.gnu.org/licenses/>. 2019-04-19 17:30:57,467 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.loadAllMetadata [338]: Loading metadata into container registry took 4.09795880317688 seconds 2019-04-19 17:30:57,617 - DEBUG - [MainThread] cura.Scene.CuraSceneController.setActiveBuildPlate [104]: Select build plate: 0 2019-04-19 17:30:57,622 - INFO - [MainThread] cura.CuraApplication.run [695]: Initializing variant manager 2019-04-19 17:30:57,629 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container ultimaker_s5_glass 2019-04-19 17:30:57,637 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [ultimaker_s5_glass] added. 2019-04-19 17:30:57,639 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container ultimaker_s5 2019-04-19 17:30:57,838 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [ultimaker_s5] added. 2019-04-19 17:30:57,846 - DEBUG - [MainThread] cura.Machines.VariantManager.initialize [59]: Exclude variant [empty_variant] 2019-04-19 17:30:57,848 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container ultimaker_s5_aluminum 2019-04-19 17:30:57,857 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [ultimaker_s5_aluminum] added. 2019-04-19 17:30:57,866 - INFO - [MainThread] cura.CuraApplication.run [699]: Initializing material manager 2019-04-19 17:30:57,976 - INFO - [MainThread] cura.CuraApplication.run [704]: Initializing quality manager 2019-04-19 17:30:58,000 - DEBUG - [MainThread] cura.Machines.QualityManager.initialize [136]: Lookup tables updated. 2019-04-19 17:30:58,005 - INFO - [MainThread] cura.CuraApplication.run [709]: Initializing machine manager 2019-04-19 17:30:58,010 - INFO - [MainThread] cura.CuraApplication.run [712]: Initializing container manager 2019-04-19 17:30:58,015 - INFO - [MainThread] cura.CuraApplication.run [715]: Initializing machine error checker 2019-04-19 17:30:58,047 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container Creality CR-10 2019-04-19 17:30:58,052 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container Creality CR-10_user 2019-04-19 17:30:58,061 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [Creality CR-10_user] added. 2019-04-19 17:30:58,062 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container creality_cr10_pla 2019-04-19 17:30:58,070 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [creality_cr10_pla] added. 2019-04-19 17:30:58,072 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container draft 2019-04-19 17:30:58,080 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [draft] added. 2019-04-19 17:30:58,082 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container Creality CR-10_settings 2019-04-19 17:30:58,090 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [Creality CR-10_settings] added. 2019-04-19 17:30:58,092 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container creality_cr10 2019-04-19 17:30:58,169 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [creality_cr10] added. 2019-04-19 17:30:58,174 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [Creality CR-10] added. 2019-04-19 17:30:58,179 - INFO - [MainThread] cura.MachineActionManager.addDefaultMachineActions [72]: Default machine actions added for machine definition [creality_cr10] 2019-04-19 17:30:58,186 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container creality_cr10_extruder_0 #2 2019-04-19 17:30:58,191 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container creality_cr10_extruder_0 #2_user 2019-04-19 17:30:58,200 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [creality_cr10_extruder_0 #2_user] added. 2019-04-19 17:30:58,202 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container creality_cr10_extruder_0_pla 2019-04-19 17:30:58,213 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [creality_cr10_extruder_0_pla] added. 2019-04-19 17:30:58,216 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container generic_pla_175 2019-04-19 17:30:58,230 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [generic_pla_175_imade3d_jellybox] added. 2019-04-19 17:30:58,235 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [generic_pla_175_imade3d_jellybox_0.4_mm] added. 2019-04-19 17:30:58,240 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [generic_pla_175_imade3d_jellybox_0.4_mm_2-fans] added. 2019-04-19 17:30:58,246 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [generic_pla_175_cartesio] added. 2019-04-19 17:30:58,251 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [generic_pla_175_cartesio_0.25mm_thermoplastic_extruder] added. 2019-04-19 17:30:58,257 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [generic_pla_175_cartesio_0.4mm_thermoplastic_extruder] added. 2019-04-19 17:30:58,263 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [generic_pla_175_cartesio_0.8mm_thermoplastic_extruder] added. 2019-04-19 17:30:58,268 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [generic_pla_175] added. 2019-04-19 17:30:58,270 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container creality_cr10_extruder_0 #2_settings 2019-04-19 17:30:58,283 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [creality_cr10_extruder_0 #2_settings] added. 2019-04-19 17:30:58,284 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container creality_cr10_extruder_0 2019-04-19 17:30:58,292 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [creality_cr10_extruder_0] added. 2019-04-19 17:30:58,297 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [creality_cr10_extruder_0 #2] added. 2019-04-19 17:30:58,324 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container fdmprinter 2019-04-19 17:30:58,405 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [fdmprinter] added. 2019-04-19 17:30:58,724 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [170]: Begin loading of script: BQ_PauseAtHeight 2019-04-19 17:30:58,726 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [170]: Begin loading of script: ChangeAtZ 2019-04-19 17:30:58,728 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [170]: Begin loading of script: DisplayFilenameAndLayerOnLCD 2019-04-19 17:30:58,730 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [170]: Begin loading of script: FilamentChange 2019-04-19 17:30:58,732 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [170]: Begin loading of script: PauseAtHeight 2019-04-19 17:30:58,735 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [170]: Begin loading of script: PauseAtHeightRepRapFirmwareDuet 2019-04-19 17:30:58,737 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [170]: Begin loading of script: PauseAtHeightforRepetier 2019-04-19 17:30:58,738 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [170]: Begin loading of script: SearchAndReplace 2019-04-19 17:30:58,741 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [170]: Begin loading of script: Stretch 2019-04-19 17:30:58,744 - DEBUG - [MainThread] UM3NetworkPrinting.src.UM3OutputDevicePlugin.checkCloudFlowIsPossible [412]: Checking if cloud connection is possible... 2019-04-19 17:30:58,745 - DEBUG - [MainThread] UM3NetworkPrinting.src.UM3OutputDevicePlugin.checkCloudFlowIsPossible [435]: Cloud Flow not possible: User not logged in! 2019-04-19 17:30:59,009 - INFO - [MainThread] cura.Settings.GlobalStack.addExtruder [136]: Extruder[creality_cr10_extruder_0 #2] added to [Creality CR-10] at position [0] 2019-04-19 17:30:59,014 - WARNING - [MainThread] cura.Settings.ExtruderManager.registerExtruder [169]: Extruder [creality_cr10_extruder_0 #2] has already been registered on machine [Creality CR-10], not doing anything 2019-04-19 17:30:59,024 - INFO - [MainThread] cura.Settings.MachineManager._initMachineState [330]: Machine 'Creality CR-10' quality changes set to 'PLA #2' 2019-04-19 17:30:59,376 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._rescheduleCheck [136]: New error check scheduled. 2019-04-19 17:30:59,378 - INFO - [MainThread] FirmwareUpdateChecker.FirmwareUpdateChecker.checkFirmwareVersion [76]: No machine with name Creality CR-10 in list of firmware to check. 2019-04-19 17:31:01,130 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin._createView [280]: Creating post processing plugin view. 2019-04-19 17:31:01,384 - DEBUG - [MainThread] UM.Qt.Bindings.Theme.load [158]: Loading theme file: C:\Program Files\Ultimaker Cura 4.0\resources\themes\cura-light\theme.json 2019-04-19 17:31:01,536 - DEBUG - [MainThread] UM.Qt.Bindings.Theme.load [230]: Loaded theme C:\Program Files\Ultimaker Cura 4.0\resources\themes\cura-light 2019-04-19 17:31:01,628 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin._createView [290]: Post processing view created. 2019-04-19 17:31:01,903 - WARNING - [MainThread] UM.Qt.Bindings.Theme.getImage [133]: No image header_pattern defined in Theme 2019-04-19 17:31:01,921 - DEBUG - [MainThread] cura.Machines.Models.BuildPlateModel._update [33]: Updating BuildPlateModel. 2019-04-19 17:31:03,176 - DEBUG - [MainThread] cura.Machines.Models.NozzleModel._update [34]: Updating NozzleModel. 2019-04-19 17:31:03,462 - DEBUG - [MainThread] UM3NetworkPrinting.src.DiscoverUM3Action._createAdditionalComponentsView [196]: Creating additional ui components for UM3. 2019-04-19 17:31:03,523 - DEBUG - [MainThread] UM3NetworkPrinting.src.DiscoverUM3Action.startDiscovery [47]: Starting device discovery. 2019-04-19 17:31:03,539 - DEBUG - [MainThread] UM.Controller.setActiveStage [159]: Setting active stage to PrepareStage 2019-04-19 17:31:03,713 - DEBUG - [MainThread] cura.Machines.Models.NozzleModel._update [34]: Updating NozzleModel. 2019-04-19 17:31:03,920 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/plugins/PrepareStage/PrepareMain.qml:16:5: QML ActionPanelWidget: Binding loop detected for property "width" 2019-04-19 17:31:03,926 - DEBUG - [MainThread] UM.Controller.setActiveView [92]: Setting active view to SolidView 2019-04-19 17:31:03,931 - DEBUG - [MainThread] ModelChecker.ModelChecker._createView [103]: Creating model checker view. 2019-04-19 17:31:03,948 - DEBUG - [MainThread] ModelChecker.ModelChecker._createView [112]: Model checker view created. 2019-04-19 17:31:03,950 - DEBUG - [MainThread] SliceInfoPlugin.SliceInfo._createDialog [82]: Creating dialog [MoreInfoWindow.qml] 2019-04-19 17:31:04,055 - DEBUG - [MainThread] cura.CuraApplication.run [747]: Booting Cura took 15.656819820404053 seconds 2019-04-19 17:31:04,083 - INFO - [MainThread] cura.Machines.MaterialManager._updateMaps [279]: Updating material lookup data ... 2019-04-19 17:31:04,224 - INFO - [MainThread] cura.Settings.MachineManager._updateQualityWithMaterial [1270]: Updating quality/quality_changes due to material change 2019-04-19 17:31:04,231 - DEBUG - [MainThread] cura.Settings.MachineManager._updateQualityWithMaterial [1277]: Current quality type = [draft] 2019-04-19 17:31:04,241 - INFO - [MainThread] cura.Settings.MachineManager._updateQualityWithMaterial [1291]: Current available quality type [draft] is available, applying changes. 2019-04-19 17:31:04,494 - DEBUG - [MainThread] cura.Machines.QualityManager.initialize [136]: Lookup tables updated. 2019-04-19 17:31:04,770 - DEBUG - [MainThread] cura.Machines.Models.QualityProfilesDropDownMenuModel._update [61]: Updating QualityProfilesDropDownMenuModel. 2019-04-19 17:31:04,773 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container coarse 2019-04-19 17:31:04,783 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [coarse] added. 2019-04-19 17:31:04,990 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container extra_coarse 2019-04-19 17:31:05,013 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [extra_coarse] added. 2019-04-19 17:31:05,127 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container fast 2019-04-19 17:31:05,140 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [fast] added. 2019-04-19 17:31:05,330 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container high 2019-04-19 17:31:05,352 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [high] added. 2019-04-19 17:31:05,475 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container normal 2019-04-19 17:31:05,498 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [normal] added. 2019-04-19 17:31:05,500 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container extra_fast 2019-04-19 17:31:05,517 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [extra_fast] added. 2019-04-19 17:31:05,595 - DEBUG - [MainThread] cura.Machines.Models.CustomQualityProfilesDropDownMenuModel._update [15]: Updating CustomQualityProfilesDropDownMenuModel. 2019-04-19 17:31:05,604 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._checkStack [140]: Need to check for errors again. Discard the current progress and reschedule a check. 2019-04-19 17:31:05,613 - INFO - [Thread-1] STLReader.STLReader.load_file [46]: Using NumPy-STL to load STL data. 2019-04-19 17:31:05,622 - DEBUG - [Thread-1] UM.Mesh.MeshData.calculateNormalsFromVertices [444]: Calculating normals took 0.0009999275207519531 seconds 2019-04-19 17:31:05,625 - DEBUG - [Thread-1] STLReader.STLReader._read [97]: Loaded a mesh with 11556 vertices 2019-04-19 17:31:05,645 - DEBUG - [MainThread] UM.Mesh.MeshData.approximateConvexHull [401]: approximateConvexHull(target_count=1024) Calculating 3D convex hull took 0.016993999481201172 seconds. 208 input vertices. 208 output vertices. 2019-04-19 17:31:05,717 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._rescheduleCheck [136]: New error check scheduled. 2019-04-19 17:31:05,746 - DEBUG - [Thread-1] UM.FileHandler.ReadFileJob.run [69]: Loading file took 0.1 seconds 2019-04-19 17:31:05,796 - DEBUG - [Thread-1] UM.Mesh.MeshData.approximateConvexHull [401]: approximateConvexHull(target_count=1024) Calculating 3D convex hull took 0.042996883392333984 seconds. 208 input vertices. 208 output vertices. 2019-04-19 17:31:07,502 - DEBUG - [MainThread] UM.Qt.QtRenderer._initialize [183]: Support for Vertex Array Objects: True 2019-04-19 17:31:07,529 - DEBUG - [MainThread] UM.View.GL.OpenGL.__init__ [99]: Initialized OpenGL subsystems. 2019-04-19 17:31:07,535 - DEBUG - [MainThread] UM.View.GL.OpenGL.__init__ [100]: OpenGL Version: 3.3.0 2019-04-19 17:31:07,541 - DEBUG - [MainThread] UM.View.GL.OpenGL.__init__ [101]: OpenGL Vendor: NVIDIA Corporation 2019-04-19 17:31:07,547 - DEBUG - [MainThread] UM.View.GL.OpenGL.__init__ [102]: OpenGL Renderer: GeForce 9500 GT/PCIe/SSE2 2019-04-19 17:31:07,552 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\default.shader]... 2019-04-19 17:31:07,563 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\selection.shader]... 2019-04-19 17:31:07,571 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\default.shader]... 2019-04-19 17:31:07,580 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\composite.shader]... 2019-04-19 17:31:07,590 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\overhang.shader]... 2019-04-19 17:31:07,598 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\striped.shader]... 2019-04-19 17:31:07,609 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\transparent_object.shader]... 2019-04-19 17:31:07,617 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\striped.shader]... 2019-04-19 17:31:07,629 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\default.shader]... 2019-04-19 17:31:07,637 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\grid.shader]... 2019-04-19 17:31:07,649 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\platform.shader]... 2019-04-19 17:31:07,845 - DEBUG - [MainThread] cura.Machines.QualityManager.initialize [136]: Lookup tables updated. 2019-04-19 17:31:07,978 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [per_object_stack_2376451691352] added. 2019-04-19 17:31:08,568 - DEBUG - [MainThread] cura.Machines.Models.QualityProfilesDropDownMenuModel._update [61]: Updating QualityProfilesDropDownMenuModel. 2019-04-19 17:31:08,608 - DEBUG - [MainThread] cura.Machines.Models.CustomQualityProfilesDropDownMenuModel._update [15]: Updating CustomQualityProfilesDropDownMenuModel. 2019-04-19 17:31:08,640 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\transparent_object.shader]... 2019-04-19 17:31:12,094 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend.slice [228]: Starting to slice... 2019-04-19 17:31:12,095 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend.slice [246]: Going to slice build plate [0]! 2019-04-19 17:31:13,119 - INFO - [MainThread] cura.Machines.MachineErrorChecker._setResult [188]: Error check finished, result = False, time = 7.4s 2019-04-19 17:31:13,591 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onStartSliceCompleted [432]: Sending slice message took 1.495973825454712 seconds 2019-04-19 17:31:14,436 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] [ERROR] Could not connect to the given address 2019-04-19 17:31:14,440 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onBackendQuit [811]: Backend quit with return code 0. Resetting process and socket. 2019-04-19 17:31:18,032 - DEBUG - [MainThread] cura.AutoSave._onTimeout [48]: Autosaving preferences, instances and profiles 2019-04-19 17:31:32,791 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._terminate [295]: Attempting to kill the engine process 2019-04-19 17:31:32,796 - DEBUG - [MainThread] UM.Backend.Backend._createSocket [227]: Previous socket existed. Closing that first. 2019-04-19 17:31:32,814 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [187]: Socket state changed to Listening 2019-04-19 17:31:32,828 - INFO - [MainThread] UM.Backend.Backend.startEngine [81]: Started engine process: C:\Program Files\Ultimaker Cura 4.0\CuraEngine.exe 2019-04-19 17:31:32,834 - DEBUG - [MainThread] UM.Backend.Backend._backendLog [101]: [Backend] Calling engine with: ['C:\\Program Files\\Ultimaker Cura 4.0\\CuraEngine.exe', 'connect', '127.0.0.1:49675', ''] 2019-04-19 17:31:32,917 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:31:32,923 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] Cura_SteamEngine version 4.0.0 2019-04-19 17:31:32,930 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] Copyright (C) 2018 Ultimaker 2019-04-19 17:31:32,936 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:31:32,943 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] This program is free software: you can redistribute it and/or modify 2019-04-19 17:31:32,949 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] it under the terms of the GNU Affero General Public License as published by 2019-04-19 17:31:32,964 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] the Free Software Foundation, either version 3 of the License, or 2019-04-19 17:31:32,970 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] (at your option) any later version. 2019-04-19 17:31:32,978 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:31:32,984 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] This program is distributed in the hope that it will be useful, 2019-04-19 17:31:32,990 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] but WITHOUT ANY WARRANTY; without even the implied warranty of 2019-04-19 17:31:32,996 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the 2019-04-19 17:31:33,003 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] GNU Affero General Public License for more details. 2019-04-19 17:31:33,010 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:31:33,018 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] You should have received a copy of the GNU Affero General Public License 2019-04-19 17:31:33,023 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] along with this program. If not, see <http://www.gnu.org/licenses/>. 2019-04-19 17:31:53,923 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] [ERROR] Could not connect to the given address 2019-04-19 17:31:54,056 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onBackendQuit [811]: Backend quit with return code 0. Resetting process and socket. 2019-04-19 17:36:35,969 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend.slice [228]: Starting to slice... 2019-04-19 17:36:35,969 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend.slice [246]: Going to slice build plate [0]! 2019-04-19 17:36:35,975 - DEBUG - [MainThread] UM.Backend.Backend._createSocket [227]: Previous socket existed. Closing that first. 2019-04-19 17:36:36,032 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [187]: Socket state changed to Listening 2019-04-19 17:36:36,127 - INFO - [MainThread] UM.Backend.Backend.startEngine [81]: Started engine process: C:\Program Files\Ultimaker Cura 4.0\CuraEngine.exe 2019-04-19 17:36:36,134 - DEBUG - [MainThread] UM.Backend.Backend._backendLog [101]: [Backend] Calling engine with: ['C:\\Program Files\\Ultimaker Cura 4.0\\CuraEngine.exe', 'connect', '127.0.0.1:49675', ''] 2019-04-19 17:36:36,228 - DEBUG - [Thread-17] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:36:36,357 - DEBUG - [Thread-17] UM.Backend.Backend._backendLog [101]: [Backend] Cura_SteamEngine version 4.0.0 2019-04-19 17:36:36,408 - DEBUG - [Thread-17] UM.Backend.Backend._backendLog [101]: [Backend] Copyright (C) 2018 Ultimaker 2019-04-19 17:36:36,431 - DEBUG - [Thread-17] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:36:36,578 - DEBUG - [Thread-17] UM.Backend.Backend._backendLog [101]: [Backend] This program is free software: you can redistribute it and/or modify 2019-04-19 17:36:36,597 - DEBUG - [Thread-17] UM.Backend.Backend._backendLog [101]: [Backend] it under the terms of the GNU Affero General Public License as published by 2019-04-19 17:36:36,602 - DEBUG - [Thread-17] UM.Backend.Backend._backendLog [101]: [Backend] the Free Software Foundation, either version 3 of the License, or 2019-04-19 17:36:36,609 - DEBUG - [Thread-17] UM.Backend.Backend._backendLog [101]: [Backend] (at your option) any later version. 2019-04-19 17:36:36,639 - DEBUG - [Thread-17] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:36:36,649 - DEBUG - [Thread-17] UM.Backend.Backend._backendLog [101]: [Backend] This program is distributed in the hope that it will be useful, 2019-04-19 17:36:36,661 - DEBUG - [Thread-17] UM.Backend.Backend._backendLog [101]: [Backend] but WITHOUT ANY WARRANTY; without even the implied warranty of 2019-04-19 17:36:36,778 - DEBUG - [Thread-17] UM.Backend.Backend._backendLog [101]: [Backend] MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the 2019-04-19 17:36:36,871 - DEBUG - [Thread-17] UM.Backend.Backend._backendLog [101]: [Backend] GNU Affero General Public License for more details. 2019-04-19 17:36:36,876 - DEBUG - [Thread-17] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:36:36,881 - DEBUG - [Thread-17] UM.Backend.Backend._backendLog [101]: [Backend] You should have received a copy of the GNU Affero General Public License 2019-04-19 17:36:36,886 - DEBUG - [Thread-17] UM.Backend.Backend._backendLog [101]: [Backend] along with this program. If not, see <http://www.gnu.org/licenses/>. 2019-04-19 17:36:37,332 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onStartSliceCompleted [432]: Sending slice message took 1.3629786968231201 seconds 2019-04-19 17:36:41,199 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._terminate [295]: Attempting to kill the engine process 2019-04-19 17:36:41,200 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._terminate [301]: Killing engine process 2019-04-19 17:36:41,206 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._terminate [304]: Engine process is killed. Received return code 1 2019-04-19 17:36:41,212 - DEBUG - [MainThread] UM.Backend.Backend._createSocket [227]: Previous socket existed. Closing that first. 2019-04-19 17:36:41,229 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [187]: Socket state changed to Listening 2019-04-19 17:36:41,239 - INFO - [MainThread] UM.Backend.Backend.startEngine [81]: Started engine process: C:\Program Files\Ultimaker Cura 4.0\CuraEngine.exe 2019-04-19 17:36:41,245 - DEBUG - [MainThread] UM.Backend.Backend._backendLog [101]: [Backend] Calling engine with: ['C:\\Program Files\\Ultimaker Cura 4.0\\CuraEngine.exe', 'connect', '127.0.0.1:49675', ''] 2019-04-19 17:36:41,316 - DEBUG - [Thread-20] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:36:41,323 - DEBUG - [Thread-20] UM.Backend.Backend._backendLog [101]: [Backend] Cura_SteamEngine version 4.0.0 2019-04-19 17:36:41,329 - DEBUG - [Thread-20] UM.Backend.Backend._backendLog [101]: [Backend] Copyright (C) 2018 Ultimaker 2019-04-19 17:36:41,335 - DEBUG - [Thread-20] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:36:41,341 - DEBUG - [Thread-20] UM.Backend.Backend._backendLog [101]: [Backend] This program is free software: you can redistribute it and/or modify 2019-04-19 17:36:41,347 - DEBUG - [Thread-20] UM.Backend.Backend._backendLog [101]: [Backend] it under the terms of the GNU Affero General Public License as published by 2019-04-19 17:36:41,352 - DEBUG - [Thread-20] UM.Backend.Backend._backendLog [101]: [Backend] the Free Software Foundation, either version 3 of the License, or 2019-04-19 17:36:41,357 - DEBUG - [Thread-20] UM.Backend.Backend._backendLog [101]: [Backend] (at your option) any later version. 2019-04-19 17:36:41,362 - DEBUG - [Thread-20] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:36:41,366 - DEBUG - [Thread-20] UM.Backend.Backend._backendLog [101]: [Backend] This program is distributed in the hope that it will be useful, 2019-04-19 17:36:41,371 - DEBUG - [Thread-20] UM.Backend.Backend._backendLog [101]: [Backend] but WITHOUT ANY WARRANTY; without even the implied warranty of 2019-04-19 17:36:41,376 - DEBUG - [Thread-20] UM.Backend.Backend._backendLog [101]: [Backend] MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the 2019-04-19 17:36:41,381 - DEBUG - [Thread-20] UM.Backend.Backend._backendLog [101]: [Backend] GNU Affero General Public License for more details. 2019-04-19 17:36:41,386 - DEBUG - [Thread-20] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:36:41,391 - DEBUG - [Thread-20] UM.Backend.Backend._backendLog [101]: [Backend] You should have received a copy of the GNU Affero General Public License 2019-04-19 17:36:41,395 - DEBUG - [Thread-20] UM.Backend.Backend._backendLog [101]: [Backend] along with this program. If not, see <http://www.gnu.org/licenses/>. 2019-04-19 17:37:02,323 - DEBUG - [Thread-20] UM.Backend.Backend._backendLog [101]: [Backend] [ERROR] Could not connect to the given address 2019-04-19 17:37:02,327 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onBackendQuit [811]: Backend quit with return code 0. Resetting process and socket. 2019-04-19 17:37:42,709 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend.slice [228]: Starting to slice... 2019-04-19 17:37:42,710 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend.slice [246]: Going to slice build plate [0]! 2019-04-19 17:37:42,717 - DEBUG - [MainThread] UM.Backend.Backend._createSocket [227]: Previous socket existed. Closing that first. 2019-04-19 17:37:42,740 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [187]: Socket state changed to Listening 2019-04-19 17:37:43,122 - INFO - [MainThread] UM.Backend.Backend.startEngine [81]: Started engine process: C:\Program Files\Ultimaker Cura 4.0\CuraEngine.exe 2019-04-19 17:37:43,128 - DEBUG - [MainThread] UM.Backend.Backend._backendLog [101]: [Backend] Calling engine with: ['C:\\Program Files\\Ultimaker Cura 4.0\\CuraEngine.exe', 'connect', '127.0.0.1:49675', ''] 2019-04-19 17:37:43,854 - DEBUG - [Thread-23] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:37:43,860 - DEBUG - [Thread-23] UM.Backend.Backend._backendLog [101]: [Backend] Cura_SteamEngine version 4.0.0 2019-04-19 17:37:43,865 - DEBUG - [Thread-23] UM.Backend.Backend._backendLog [101]: [Backend] Copyright (C) 2018 Ultimaker 2019-04-19 17:37:43,870 - DEBUG - [Thread-23] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:37:43,875 - DEBUG - [Thread-23] UM.Backend.Backend._backendLog [101]: [Backend] This program is free software: you can redistribute it and/or modify 2019-04-19 17:37:43,880 - DEBUG - [Thread-23] UM.Backend.Backend._backendLog [101]: [Backend] it under the terms of the GNU Affero General Public License as published by 2019-04-19 17:37:43,891 - DEBUG - [Thread-23] UM.Backend.Backend._backendLog [101]: [Backend] the Free Software Foundation, either version 3 of the License, or 2019-04-19 17:37:43,898 - DEBUG - [Thread-23] UM.Backend.Backend._backendLog [101]: [Backend] (at your option) any later version. 2019-04-19 17:37:43,903 - DEBUG - [Thread-23] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:37:43,908 - DEBUG - [Thread-23] UM.Backend.Backend._backendLog [101]: [Backend] This program is distributed in the hope that it will be useful, 2019-04-19 17:37:43,913 - DEBUG - [Thread-23] UM.Backend.Backend._backendLog [101]: [Backend] but WITHOUT ANY WARRANTY; without even the implied warranty of 2019-04-19 17:37:43,919 - DEBUG - [Thread-23] UM.Backend.Backend._backendLog [101]: [Backend] MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the 2019-04-19 17:37:43,927 - DEBUG - [Thread-23] UM.Backend.Backend._backendLog [101]: [Backend] GNU Affero General Public License for more details. 2019-04-19 17:37:43,933 - DEBUG - [Thread-23] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:37:43,939 - DEBUG - [Thread-23] UM.Backend.Backend._backendLog [101]: [Backend] You should have received a copy of the GNU Affero General Public License 2019-04-19 17:37:43,944 - DEBUG - [Thread-23] UM.Backend.Backend._backendLog [101]: [Backend] along with this program. If not, see <http://www.gnu.org/licenses/>. 2019-04-19 17:37:46,053 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend.slice [228]: Starting to slice... 2019-04-19 17:37:46,072 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend.slice [246]: Going to slice build plate [0]! 2019-04-19 17:37:46,073 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._terminate [295]: Attempting to kill the engine process 2019-04-19 17:37:46,074 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._terminate [301]: Killing engine process 2019-04-19 17:37:46,092 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._terminate [304]: Engine process is killed. Received return code 1 2019-04-19 17:37:46,099 - DEBUG - [MainThread] UM.Backend.Backend._createSocket [227]: Previous socket existed. Closing that first. 2019-04-19 17:37:46,115 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [187]: Socket state changed to Listening 2019-04-19 17:37:46,130 - INFO - [MainThread] UM.Backend.Backend.startEngine [81]: Started engine process: C:\Program Files\Ultimaker Cura 4.0\CuraEngine.exe 2019-04-19 17:37:46,136 - DEBUG - [MainThread] UM.Backend.Backend._backendLog [101]: [Backend] Calling engine with: ['C:\\Program Files\\Ultimaker Cura 4.0\\CuraEngine.exe', 'connect', '127.0.0.1:49675', ''] 2019-04-19 17:37:46,281 - DEBUG - [Thread-26] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:37:46,304 - DEBUG - [Thread-26] UM.Backend.Backend._backendLog [101]: [Backend] Cura_SteamEngine version 4.0.0 2019-04-19 17:37:46,319 - DEBUG - [Thread-26] UM.Backend.Backend._backendLog [101]: [Backend] Copyright (C) 2018 Ultimaker 2019-04-19 17:37:46,333 - DEBUG - [Thread-26] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:37:46,348 - DEBUG - [Thread-26] UM.Backend.Backend._backendLog [101]: [Backend] This program is free software: you can redistribute it and/or modify 2019-04-19 17:37:46,361 - DEBUG - [Thread-26] UM.Backend.Backend._backendLog [101]: [Backend] it under the terms of the GNU Affero General Public License as published by 2019-04-19 17:37:46,370 - DEBUG - [Thread-26] UM.Backend.Backend._backendLog [101]: [Backend] the Free Software Foundation, either version 3 of the License, or 2019-04-19 17:37:46,440 - DEBUG - [Thread-26] UM.Backend.Backend._backendLog [101]: [Backend] (at your option) any later version. 2019-04-19 17:37:46,453 - DEBUG - [Thread-26] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:37:46,479 - DEBUG - [Thread-26] UM.Backend.Backend._backendLog [101]: [Backend] This program is distributed in the hope that it will be useful, 2019-04-19 17:37:46,488 - DEBUG - [Thread-26] UM.Backend.Backend._backendLog [101]: [Backend] but WITHOUT ANY WARRANTY; without even the implied warranty of 2019-04-19 17:37:46,526 - DEBUG - [Thread-26] UM.Backend.Backend._backendLog [101]: [Backend] MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the 2019-04-19 17:37:46,544 - DEBUG - [Thread-26] UM.Backend.Backend._backendLog [101]: [Backend] GNU Affero General Public License for more details. 2019-04-19 17:37:46,554 - DEBUG - [Thread-26] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:37:46,571 - DEBUG - [Thread-26] UM.Backend.Backend._backendLog [101]: [Backend] You should have received a copy of the GNU Affero General Public License 2019-04-19 17:37:46,590 - DEBUG - [Thread-26] UM.Backend.Backend._backendLog [101]: [Backend] along with this program. If not, see <http://www.gnu.org/licenses/>. 2019-04-19 17:37:52,381 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onStartSliceCompleted [432]: Sending slice message took 6.327927589416504 seconds 2019-04-19 17:37:57,606 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._terminate [295]: Attempting to kill the engine process 2019-04-19 17:37:57,607 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._terminate [301]: Killing engine process 2019-04-19 17:37:57,614 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._terminate [304]: Engine process is killed. Received return code 1 2019-04-19 17:37:57,620 - DEBUG - [MainThread] UM.Backend.Backend._createSocket [227]: Previous socket existed. Closing that first. 2019-04-19 17:37:57,639 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [187]: Socket state changed to Listening 2019-04-19 17:37:57,654 - INFO - [MainThread] UM.Backend.Backend.startEngine [81]: Started engine process: C:\Program Files\Ultimaker Cura 4.0\CuraEngine.exe 2019-04-19 17:37:57,659 - DEBUG - [MainThread] UM.Backend.Backend._backendLog [101]: [Backend] Calling engine with: ['C:\\Program Files\\Ultimaker Cura 4.0\\CuraEngine.exe', 'connect', '127.0.0.1:49675', ''] 2019-04-19 17:37:57,760 - DEBUG - [Thread-29] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:37:57,767 - DEBUG - [Thread-29] UM.Backend.Backend._backendLog [101]: [Backend] Cura_SteamEngine version 4.0.0 2019-04-19 17:37:57,774 - DEBUG - [Thread-29] UM.Backend.Backend._backendLog [101]: [Backend] Copyright (C) 2018 Ultimaker 2019-04-19 17:37:57,781 - DEBUG - [Thread-29] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:37:57,788 - DEBUG - [Thread-29] UM.Backend.Backend._backendLog [101]: [Backend] This program is free software: you can redistribute it and/or modify 2019-04-19 17:37:57,794 - DEBUG - [Thread-29] UM.Backend.Backend._backendLog [101]: [Backend] it under the terms of the GNU Affero General Public License as published by 2019-04-19 17:37:57,803 - DEBUG - [Thread-29] UM.Backend.Backend._backendLog [101]: [Backend] the Free Software Foundation, either version 3 of the License, or 2019-04-19 17:37:57,810 - DEBUG - [Thread-29] UM.Backend.Backend._backendLog [101]: [Backend] (at your option) any later version. 2019-04-19 17:37:57,817 - DEBUG - [Thread-29] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:37:57,823 - DEBUG - [Thread-29] UM.Backend.Backend._backendLog [101]: [Backend] This program is distributed in the hope that it will be useful, 2019-04-19 17:37:57,830 - DEBUG - [Thread-29] UM.Backend.Backend._backendLog [101]: [Backend] but WITHOUT ANY WARRANTY; without even the implied warranty of 2019-04-19 17:37:57,838 - DEBUG - [Thread-29] UM.Backend.Backend._backendLog [101]: [Backend] MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the 2019-04-19 17:37:57,844 - DEBUG - [Thread-29] UM.Backend.Backend._backendLog [101]: [Backend] GNU Affero General Public License for more details. 2019-04-19 17:37:57,850 - DEBUG - [Thread-29] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:37:57,855 - DEBUG - [Thread-29] UM.Backend.Backend._backendLog [101]: [Backend] You should have received a copy of the GNU Affero General Public License 2019-04-19 17:37:57,860 - DEBUG - [Thread-29] UM.Backend.Backend._backendLog [101]: [Backend] along with this program. If not, see <http://www.gnu.org/licenses/>. 2019-04-19 17:38:18,757 - DEBUG - [Thread-29] UM.Backend.Backend._backendLog [101]: [Backend] [ERROR] Could not connect to the given address 2019-04-19 17:38:18,813 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onBackendQuit [811]: Backend quit with return code 0. Resetting process and socket. 2019-04-19 17:38:48,283 - WARNING - [MainThread] UM.PluginRegistry._populateMetaData [604]: Could not find plugin extruder_stack 2019-04-19 17:38:48,295 - WARNING - [MainThread] UM.PluginRegistry._populateMetaData [604]: Could not find plugin global_stack 2019-04-19 17:38:48,320 - WARNING - [MainThread] cura.Settings.ContainerManager.getContainerMetaDataEntry [65]: Could not get metadata of container Unknown because it was not found. 2019-04-19 17:38:48,703 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/resources/qml/Preferences/Materials/MaterialsPage.qml:236:13: QML MaterialsList: Binding loop detected for property "height" 2019-04-19 17:38:48,710 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/resources/qml/Preferences/Materials/MaterialsList.qml:135:5: QML Column: Binding loop detected for property "height" 2019-04-19 17:38:54,435 - DEBUG - [MainThread] cura.AutoSave._onTimeout [48]: Autosaving preferences, instances and profiles 2019-04-19 17:39:59,878 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend.slice [228]: Starting to slice... 2019-04-19 17:39:59,879 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend.slice [246]: Going to slice build plate [0]! 2019-04-19 17:39:59,884 - DEBUG - [MainThread] UM.Backend.Backend._createSocket [227]: Previous socket existed. Closing that first. 2019-04-19 17:40:00,003 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [187]: Socket state changed to Listening 2019-04-19 17:40:00,121 - INFO - [MainThread] UM.Backend.Backend.startEngine [81]: Started engine process: C:\Program Files\Ultimaker Cura 4.0\CuraEngine.exe 2019-04-19 17:40:00,127 - DEBUG - [MainThread] UM.Backend.Backend._backendLog [101]: [Backend] Calling engine with: ['C:\\Program Files\\Ultimaker Cura 4.0\\CuraEngine.exe', 'connect', '127.0.0.1:49675', ''] 2019-04-19 17:40:00,310 - DEBUG - [Thread-32] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:40:00,323 - DEBUG - [Thread-32] UM.Backend.Backend._backendLog [101]: [Backend] Cura_SteamEngine version 4.0.0 2019-04-19 17:40:00,337 - DEBUG - [Thread-32] UM.Backend.Backend._backendLog [101]: [Backend] Copyright (C) 2018 Ultimaker 2019-04-19 17:40:00,355 - DEBUG - [Thread-32] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:40:00,398 - DEBUG - [Thread-32] UM.Backend.Backend._backendLog [101]: [Backend] This program is free software: you can redistribute it and/or modify 2019-04-19 17:40:00,458 - DEBUG - [Thread-32] UM.Backend.Backend._backendLog [101]: [Backend] it under the terms of the GNU Affero General Public License as published by 2019-04-19 17:40:00,551 - DEBUG - [Thread-32] UM.Backend.Backend._backendLog [101]: [Backend] the Free Software Foundation, either version 3 of the License, or 2019-04-19 17:40:00,557 - DEBUG - [Thread-32] UM.Backend.Backend._backendLog [101]: [Backend] (at your option) any later version. 2019-04-19 17:40:00,570 - DEBUG - [Thread-32] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:40:00,585 - DEBUG - [Thread-32] UM.Backend.Backend._backendLog [101]: [Backend] This program is distributed in the hope that it will be useful, 2019-04-19 17:40:00,606 - DEBUG - [Thread-32] UM.Backend.Backend._backendLog [101]: [Backend] but WITHOUT ANY WARRANTY; without even the implied warranty of 2019-04-19 17:40:00,614 - DEBUG - [Thread-32] UM.Backend.Backend._backendLog [101]: [Backend] MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the 2019-04-19 17:40:00,622 - DEBUG - [Thread-32] UM.Backend.Backend._backendLog [101]: [Backend] GNU Affero General Public License for more details. 2019-04-19 17:40:00,628 - DEBUG - [Thread-32] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:40:00,644 - DEBUG - [Thread-32] UM.Backend.Backend._backendLog [101]: [Backend] You should have received a copy of the GNU Affero General Public License 2019-04-19 17:40:00,676 - DEBUG - [Thread-32] UM.Backend.Backend._backendLog [101]: [Backend] along with this program. If not, see <http://www.gnu.org/licenses/>. 2019-04-19 17:40:01,281 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onStartSliceCompleted [432]: Sending slice message took 1.4019780158996582 seconds 2019-04-19 17:40:20,152 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._terminate [295]: Attempting to kill the engine process 2019-04-19 17:40:20,153 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._terminate [301]: Killing engine process 2019-04-19 17:40:20,160 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._terminate [304]: Engine process is killed. Received return code 1 2019-04-19 17:40:20,165 - DEBUG - [MainThread] UM.Backend.Backend._createSocket [227]: Previous socket existed. Closing that first. 2019-04-19 17:40:20,182 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [187]: Socket state changed to Listening 2019-04-19 17:40:20,197 - INFO - [MainThread] UM.Backend.Backend.startEngine [81]: Started engine process: C:\Program Files\Ultimaker Cura 4.0\CuraEngine.exe 2019-04-19 17:40:20,203 - DEBUG - [MainThread] UM.Backend.Backend._backendLog [101]: [Backend] Calling engine with: ['C:\\Program Files\\Ultimaker Cura 4.0\\CuraEngine.exe', 'connect', '127.0.0.1:49675', ''] 2019-04-19 17:40:20,270 - DEBUG - [Thread-35] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:40:20,276 - DEBUG - [Thread-35] UM.Backend.Backend._backendLog [101]: [Backend] Cura_SteamEngine version 4.0.0 2019-04-19 17:40:20,282 - DEBUG - [Thread-35] UM.Backend.Backend._backendLog [101]: [Backend] Copyright (C) 2018 Ultimaker 2019-04-19 17:40:20,288 - DEBUG - [Thread-35] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:40:20,295 - DEBUG - [Thread-35] UM.Backend.Backend._backendLog [101]: [Backend] This program is free software: you can redistribute it and/or modify 2019-04-19 17:40:20,299 - DEBUG - [Thread-35] UM.Backend.Backend._backendLog [101]: [Backend] it under the terms of the GNU Affero General Public License as published by 2019-04-19 17:40:20,304 - DEBUG - [Thread-35] UM.Backend.Backend._backendLog [101]: [Backend] the Free Software Foundation, either version 3 of the License, or 2019-04-19 17:40:20,309 - DEBUG - [Thread-35] UM.Backend.Backend._backendLog [101]: [Backend] (at your option) any later version. 2019-04-19 17:40:20,314 - DEBUG - [Thread-35] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:40:20,318 - DEBUG - [Thread-35] UM.Backend.Backend._backendLog [101]: [Backend] This program is distributed in the hope that it will be useful, 2019-04-19 17:40:20,323 - DEBUG - [Thread-35] UM.Backend.Backend._backendLog [101]: [Backend] but WITHOUT ANY WARRANTY; without even the implied warranty of 2019-04-19 17:40:20,328 - DEBUG - [Thread-35] UM.Backend.Backend._backendLog [101]: [Backend] MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the 2019-04-19 17:40:20,333 - DEBUG - [Thread-35] UM.Backend.Backend._backendLog [101]: [Backend] GNU Affero General Public License for more details. 2019-04-19 17:40:20,338 - DEBUG - [Thread-35] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:40:20,342 - DEBUG - [Thread-35] UM.Backend.Backend._backendLog [101]: [Backend] You should have received a copy of the GNU Affero General Public License 2019-04-19 17:40:20,347 - DEBUG - [Thread-35] UM.Backend.Backend._backendLog [101]: [Backend] along with this program. If not, see <http://www.gnu.org/licenses/>. 2019-04-19 17:40:21,259 - DEBUG - [MainThread] cura.TaskManagement.OnExitCallbackManager.triggerNextCallback [51]: No more on-app-exit callbacks to process. Tell the app to exit. 2019-04-19 17:40:21,264 - INFO - [MainThread] cura.CuraApplication.closeApplication [547]: Close application 2019-04-19 17:40:21,309 - DEBUG - [MainThread] UM.Qt.QtApplication.windowClosed [417]: Shutting down cura 2019-04-19 17:40:21,374 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._terminate [295]: Attempting to kill the engine process 2019-04-19 17:40:21,374 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._terminate [301]: Killing engine process 2019-04-19 17:40:21,384 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._terminate [304]: Engine process is killed. Received return code 1 2019-04-19 17:40:59,849 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin FileLogger 2019-04-19 17:40:59,879 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin FirmwareUpdateChecker 2019-04-19 17:40:59,903 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin FirmwareUpdater 2019-04-19 17:40:59,924 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin GCodeGzReader 2019-04-19 17:40:59,945 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin GCodeGzWriter 2019-04-19 17:40:59,965 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin GCodeProfileReader 2019-04-19 17:41:00,000 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin GCodeReader 2019-04-19 17:41:00,023 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin GCodeWriter 2019-04-19 17:41:00,046 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin ImageReader 2019-04-19 17:41:00,068 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin LegacyProfileReader 2019-04-19 17:41:00,088 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin LocalContainerProvider 2019-04-19 17:41:00,113 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin LocalFileOutputDevice 2019-04-19 17:41:00,134 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin MachineSettingsAction 2019-04-19 17:41:00,156 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin ModelChecker 2019-04-19 17:41:00,181 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin MonitorStage 2019-04-19 17:41:00,210 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin PerObjectSettingsTool 2019-04-19 17:41:00,235 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin PostProcessingPlugin 2019-04-19 17:41:00,260 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin PrepareStage 2019-04-19 17:41:00,284 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin PreviewStage 2019-04-19 17:41:00,315 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin RemovableDriveOutputDevice 2019-04-19 17:41:00,351 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin SimulationView 2019-04-19 17:41:00,378 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin SliceInfoPlugin 2019-04-19 17:41:00,403 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin SolidView 2019-04-19 17:41:00,431 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin SupportEraser 2019-04-19 17:41:00,467 - DEBUG - [MainThread] cura.OAuth2.AuthorizationService.getAccessToken [106]: No auth data to retrieve the access_token from 2019-04-19 17:41:00,473 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin Toolbox 2019-04-19 17:41:00,503 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin CameraTool 2019-04-19 17:41:00,533 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin MirrorTool 2019-04-19 17:41:00,565 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin RotateTool 2019-04-19 17:41:00,596 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin ScaleTool 2019-04-19 17:41:00,622 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin SelectionTool 2019-04-19 17:41:00,653 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin TranslateTool 2019-04-19 17:41:00,715 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin UFPWriter 2019-04-19 17:41:00,747 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin UltimakerMachineActions 2019-04-19 17:41:00,919 - DEBUG - [MainThread] UM3NetworkPrinting.src.Cloud.CloudOutputDeviceManager._onLoginStateChanged [57]: Log in state changed to False 2019-04-19 17:41:00,920 - DEBUG - [MainThread] UM3NetworkPrinting.src.Cloud.CloudOutputDeviceManager._onGetRemoteClustersFinished [80]: Parsed remote clusters to [] 2019-04-19 17:41:00,921 - DEBUG - [MainThread] UM3NetworkPrinting.src.Cloud.CloudOutputDeviceManager._onGetRemoteClustersFinished [81]: Removed: 0, added: 0, updates: 0 2019-04-19 17:41:00,927 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin UM3NetworkPrinting 2019-04-19 17:41:00,977 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin UpdateChecker 2019-04-19 17:41:00,983 - INFO - [Thread-2] UpdateChecker.UpdateCheckerJob.run [36]: Checking for new version of cura 2019-04-19 17:41:01,041 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin USBPrinting 2019-04-19 17:41:01,072 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin UserAgreement 2019-04-19 17:41:01,115 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade21to22 2019-04-19 17:41:01,147 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade22to24 2019-04-19 17:41:01,179 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade25to26 2019-04-19 17:41:01,211 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade26to27 2019-04-19 17:41:01,245 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade27to30 2019-04-19 17:41:01,278 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade30to31 2019-04-19 17:41:01,313 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade32to33 2019-04-19 17:41:01,346 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade33to34 2019-04-19 17:41:01,381 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade34to35 2019-04-19 17:41:01,416 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade35to40 2019-04-19 17:41:01,454 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin SimpleView 2019-04-19 17:41:01,490 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin X3DReader 2019-04-19 17:41:01,533 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin XmlMaterialProfile 2019-04-19 17:41:01,571 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin XRayView 2019-04-19 17:41:01,609 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin CustomSupports 2019-04-19 17:41:01,650 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin OrientationPlugin 2019-04-19 17:41:01,679 - INFO - [MainThread] UM.VersionUpgradeManager.upgrade [143]: Looking for old configuration files to upgrade. 2019-04-19 17:41:01,732 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\packages.json, skip it 2019-04-19 17:41:01,739 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\plugins.json, skip it 2019-04-19 17:41:01,772 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\packages.json, skip it 2019-04-19 17:41:01,777 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\plugins.json, skip it 2019-04-19 17:41:01,810 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\packages.json, skip it 2019-04-19 17:41:01,816 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\plugins.json, skip it 2019-04-19 17:41:01,847 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\packages.json, skip it 2019-04-19 17:41:01,853 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\plugins.json, skip it 2019-04-19 17:41:01,892 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\packages.json, skip it 2019-04-19 17:41:01,897 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\plugins.json, skip it 2019-04-19 17:41:01,930 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\packages.json, skip it 2019-04-19 17:41:01,936 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\plugins.json, skip it 2019-04-19 17:41:01,967 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\packages.json, skip it 2019-04-19 17:41:01,972 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\plugins.json, skip it 2019-04-19 17:41:02,004 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\packages.json, skip it 2019-04-19 17:41:02,009 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\plugins.json, skip it 2019-04-19 17:41:02,101 - DEBUG - [MainThread] UM.Backend.Backend._onSocketError [213]: Socket was unable to bind to port, increasing port number to 49675 2019-04-19 17:41:02,106 - DEBUG - [MainThread] UM.Backend.Backend._createSocket [227]: Previous socket existed. Closing that first. 2019-04-19 17:41:02,110 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._terminate [295]: Attempting to kill the engine process 2019-04-19 17:41:02,114 - DEBUG - [MainThread] UM.Backend.Backend._createSocket [227]: Previous socket existed. Closing that first. 2019-04-19 17:41:02,325 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [187]: Socket state changed to Listening 2019-04-19 17:41:02,339 - INFO - [MainThread] UM.Backend.Backend.startEngine [81]: Started engine process: C:\Program Files\Ultimaker Cura 4.0\CuraEngine.exe 2019-04-19 17:41:02,344 - DEBUG - [MainThread] UM.Backend.Backend._backendLog [101]: [Backend] Calling engine with: ['C:\\Program Files\\Ultimaker Cura 4.0\\CuraEngine.exe', 'connect', '127.0.0.1:49675', ''] 2019-04-19 17:41:02,404 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:41:02,409 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] Cura_SteamEngine version 4.0.0 2019-04-19 17:41:02,414 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] Copyright (C) 2018 Ultimaker 2019-04-19 17:41:02,419 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:41:02,424 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] This program is free software: you can redistribute it and/or modify 2019-04-19 17:41:02,428 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] it under the terms of the GNU Affero General Public License as published by 2019-04-19 17:41:02,433 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] the Free Software Foundation, either version 3 of the License, or 2019-04-19 17:41:02,438 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] (at your option) any later version. 2019-04-19 17:41:02,443 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:41:02,448 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] This program is distributed in the hope that it will be useful, 2019-04-19 17:41:02,452 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] but WITHOUT ANY WARRANTY; without even the implied warranty of 2019-04-19 17:41:02,457 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the 2019-04-19 17:41:02,462 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] GNU Affero General Public License for more details. 2019-04-19 17:41:02,466 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:41:02,471 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] You should have received a copy of the GNU Affero General Public License 2019-04-19 17:41:02,476 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] along with this program. If not, see <http://www.gnu.org/licenses/>. 2019-04-19 17:41:05,433 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.loadAllMetadata [338]: Loading metadata into container registry took 3.0819644927978516 seconds 2019-04-19 17:41:05,606 - DEBUG - [MainThread] cura.Scene.CuraSceneController.setActiveBuildPlate [104]: Select build plate: 0 2019-04-19 17:41:05,610 - INFO - [MainThread] cura.CuraApplication.run [695]: Initializing variant manager 2019-04-19 17:41:05,618 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container ultimaker_s5_aluminum 2019-04-19 17:41:05,625 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [ultimaker_s5_aluminum] added. 2019-04-19 17:41:05,627 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container ultimaker_s5 2019-04-19 17:41:05,792 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [ultimaker_s5] added. 2019-04-19 17:41:05,799 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container ultimaker_s5_glass 2019-04-19 17:41:05,807 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [ultimaker_s5_glass] added. 2019-04-19 17:41:05,814 - DEBUG - [MainThread] cura.Machines.VariantManager.initialize [59]: Exclude variant [empty_variant] 2019-04-19 17:41:05,819 - INFO - [MainThread] cura.CuraApplication.run [699]: Initializing material manager 2019-04-19 17:41:06,049 - INFO - [MainThread] cura.CuraApplication.run [704]: Initializing quality manager 2019-04-19 17:41:06,071 - DEBUG - [MainThread] cura.Machines.QualityManager.initialize [136]: Lookup tables updated. 2019-04-19 17:41:06,076 - INFO - [MainThread] cura.CuraApplication.run [709]: Initializing machine manager 2019-04-19 17:41:06,081 - INFO - [MainThread] cura.CuraApplication.run [712]: Initializing container manager 2019-04-19 17:41:06,086 - INFO - [MainThread] cura.CuraApplication.run [715]: Initializing machine error checker 2019-04-19 17:41:06,117 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container Creality CR-10 2019-04-19 17:41:06,122 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container Creality CR-10_user 2019-04-19 17:41:06,130 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [Creality CR-10_user] added. 2019-04-19 17:41:06,132 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container creality_cr10_pla 2019-04-19 17:41:06,140 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [creality_cr10_pla] added. 2019-04-19 17:41:06,142 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container draft 2019-04-19 17:41:06,150 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [draft] added. 2019-04-19 17:41:06,155 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container Creality CR-10_settings 2019-04-19 17:41:06,163 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [Creality CR-10_settings] added. 2019-04-19 17:41:06,165 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container creality_cr10 2019-04-19 17:41:06,245 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [creality_cr10] added. 2019-04-19 17:41:06,250 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [Creality CR-10] added. 2019-04-19 17:41:06,255 - INFO - [MainThread] cura.MachineActionManager.addDefaultMachineActions [72]: Default machine actions added for machine definition [creality_cr10] 2019-04-19 17:41:06,259 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container creality_cr10_extruder_0 #2 2019-04-19 17:41:06,263 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container creality_cr10_extruder_0 #2_user 2019-04-19 17:41:06,271 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [creality_cr10_extruder_0 #2_user] added. 2019-04-19 17:41:06,272 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container creality_cr10_extruder_0_pla 2019-04-19 17:41:06,282 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [creality_cr10_extruder_0_pla] added. 2019-04-19 17:41:06,284 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container generic_pla_175 2019-04-19 17:41:06,296 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [generic_pla_175_imade3d_jellybox] added. 2019-04-19 17:41:06,301 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [generic_pla_175_imade3d_jellybox_0.4_mm] added. 2019-04-19 17:41:06,306 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [generic_pla_175_imade3d_jellybox_0.4_mm_2-fans] added. 2019-04-19 17:41:06,311 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [generic_pla_175_cartesio] added. 2019-04-19 17:41:06,316 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [generic_pla_175_cartesio_0.25mm_thermoplastic_extruder] added. 2019-04-19 17:41:06,320 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [generic_pla_175_cartesio_0.4mm_thermoplastic_extruder] added. 2019-04-19 17:41:06,325 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [generic_pla_175_cartesio_0.8mm_thermoplastic_extruder] added. 2019-04-19 17:41:06,330 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [generic_pla_175] added. 2019-04-19 17:41:06,332 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container creality_cr10_extruder_0 #2_settings 2019-04-19 17:41:06,342 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [creality_cr10_extruder_0 #2_settings] added. 2019-04-19 17:41:06,344 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container creality_cr10_extruder_0 2019-04-19 17:41:06,350 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [creality_cr10_extruder_0] added. 2019-04-19 17:41:06,356 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [creality_cr10_extruder_0 #2] added. 2019-04-19 17:41:06,379 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container fdmprinter 2019-04-19 17:41:06,457 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [fdmprinter] added. 2019-04-19 17:41:06,757 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [170]: Begin loading of script: BQ_PauseAtHeight 2019-04-19 17:41:06,759 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [170]: Begin loading of script: ChangeAtZ 2019-04-19 17:41:06,761 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [170]: Begin loading of script: DisplayFilenameAndLayerOnLCD 2019-04-19 17:41:06,764 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [170]: Begin loading of script: FilamentChange 2019-04-19 17:41:06,766 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [170]: Begin loading of script: PauseAtHeight 2019-04-19 17:41:06,768 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [170]: Begin loading of script: PauseAtHeightRepRapFirmwareDuet 2019-04-19 17:41:06,770 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [170]: Begin loading of script: PauseAtHeightforRepetier 2019-04-19 17:41:06,771 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [170]: Begin loading of script: SearchAndReplace 2019-04-19 17:41:06,774 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [170]: Begin loading of script: Stretch 2019-04-19 17:41:06,777 - DEBUG - [MainThread] UM3NetworkPrinting.src.UM3OutputDevicePlugin.checkCloudFlowIsPossible [412]: Checking if cloud connection is possible... 2019-04-19 17:41:06,778 - DEBUG - [MainThread] UM3NetworkPrinting.src.UM3OutputDevicePlugin.checkCloudFlowIsPossible [435]: Cloud Flow not possible: User not logged in! 2019-04-19 17:41:06,937 - INFO - [MainThread] cura.Settings.GlobalStack.addExtruder [136]: Extruder[creality_cr10_extruder_0 #2] added to [Creality CR-10] at position [0] 2019-04-19 17:41:06,941 - WARNING - [MainThread] cura.Settings.ExtruderManager.registerExtruder [169]: Extruder [creality_cr10_extruder_0 #2] has already been registered on machine [Creality CR-10], not doing anything 2019-04-19 17:41:06,951 - INFO - [MainThread] cura.Settings.MachineManager._initMachineState [330]: Machine 'Creality CR-10' quality changes set to 'PLA #2' 2019-04-19 17:41:07,265 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._rescheduleCheck [136]: New error check scheduled. 2019-04-19 17:41:07,267 - INFO - [MainThread] FirmwareUpdateChecker.FirmwareUpdateChecker.checkFirmwareVersion [76]: No machine with name Creality CR-10 in list of firmware to check. 2019-04-19 17:41:08,853 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin._createView [280]: Creating post processing plugin view. 2019-04-19 17:41:08,991 - DEBUG - [MainThread] UM.Qt.Bindings.Theme.load [158]: Loading theme file: C:\Program Files\Ultimaker Cura 4.0\resources\themes\cura-light\theme.json 2019-04-19 17:41:09,097 - DEBUG - [MainThread] UM.Qt.Bindings.Theme.load [230]: Loaded theme C:\Program Files\Ultimaker Cura 4.0\resources\themes\cura-light 2019-04-19 17:41:09,186 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin._createView [290]: Post processing view created. 2019-04-19 17:41:09,462 - WARNING - [MainThread] UM.Qt.Bindings.Theme.getImage [133]: No image header_pattern defined in Theme 2019-04-19 17:41:09,481 - DEBUG - [MainThread] cura.Machines.Models.BuildPlateModel._update [33]: Updating BuildPlateModel. 2019-04-19 17:41:10,546 - DEBUG - [MainThread] cura.Machines.Models.NozzleModel._update [34]: Updating NozzleModel. 2019-04-19 17:41:10,785 - DEBUG - [MainThread] UM3NetworkPrinting.src.DiscoverUM3Action._createAdditionalComponentsView [196]: Creating additional ui components for UM3. 2019-04-19 17:41:10,843 - DEBUG - [MainThread] UM3NetworkPrinting.src.DiscoverUM3Action.startDiscovery [47]: Starting device discovery. 2019-04-19 17:41:10,864 - DEBUG - [MainThread] UM.Controller.setActiveStage [159]: Setting active stage to PrepareStage 2019-04-19 17:41:11,031 - DEBUG - [MainThread] cura.Machines.Models.NozzleModel._update [34]: Updating NozzleModel. 2019-04-19 17:41:11,200 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/plugins/PrepareStage/PrepareMain.qml:16:5: QML ActionPanelWidget: Binding loop detected for property "width" 2019-04-19 17:41:11,205 - DEBUG - [MainThread] UM.Controller.setActiveView [92]: Setting active view to SolidView 2019-04-19 17:41:11,215 - DEBUG - [MainThread] ModelChecker.ModelChecker._createView [103]: Creating model checker view. 2019-04-19 17:41:11,232 - DEBUG - [MainThread] ModelChecker.ModelChecker._createView [112]: Model checker view created. 2019-04-19 17:41:11,234 - DEBUG - [MainThread] SliceInfoPlugin.SliceInfo._createDialog [82]: Creating dialog [MoreInfoWindow.qml] 2019-04-19 17:41:11,348 - DEBUG - [MainThread] cura.CuraApplication.run [747]: Booting Cura took 13.938833713531494 seconds 2019-04-19 17:41:11,392 - DEBUG - [MainThread] cura.Machines.QualityManager.initialize [136]: Lookup tables updated. 2019-04-19 17:41:11,413 - INFO - [MainThread] cura.Machines.MaterialManager._updateMaps [279]: Updating material lookup data ... 2019-04-19 17:41:11,481 - INFO - [MainThread] cura.Settings.MachineManager._updateQualityWithMaterial [1270]: Updating quality/quality_changes due to material change 2019-04-19 17:41:11,486 - DEBUG - [MainThread] cura.Settings.MachineManager._updateQualityWithMaterial [1277]: Current quality type = [draft] 2019-04-19 17:41:11,491 - INFO - [MainThread] cura.Settings.MachineManager._updateQualityWithMaterial [1291]: Current available quality type [draft] is available, applying changes. 2019-04-19 17:41:11,561 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._checkStack [140]: Need to check for errors again. Discard the current progress and reschedule a check. 2019-04-19 17:41:11,602 - DEBUG - [MainThread] cura.Machines.Models.QualityProfilesDropDownMenuModel._update [61]: Updating QualityProfilesDropDownMenuModel. 2019-04-19 17:41:11,604 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container coarse 2019-04-19 17:41:11,612 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [coarse] added. 2019-04-19 17:41:11,652 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container extra_coarse 2019-04-19 17:41:11,660 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [extra_coarse] added. 2019-04-19 17:41:11,696 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container fast 2019-04-19 17:41:11,704 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [fast] added. 2019-04-19 17:41:11,786 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container high 2019-04-19 17:41:11,794 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [high] added. 2019-04-19 17:41:11,835 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container normal 2019-04-19 17:41:11,842 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [normal] added. 2019-04-19 17:41:11,845 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container extra_fast 2019-04-19 17:41:11,852 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [extra_fast] added. 2019-04-19 17:41:11,910 - DEBUG - [MainThread] cura.Machines.Models.CustomQualityProfilesDropDownMenuModel._update [15]: Updating CustomQualityProfilesDropDownMenuModel. 2019-04-19 17:41:11,918 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._rescheduleCheck [136]: New error check scheduled. 2019-04-19 17:41:13,175 - DEBUG - [MainThread] UM.Qt.QtRenderer._initialize [183]: Support for Vertex Array Objects: True 2019-04-19 17:41:13,202 - DEBUG - [MainThread] UM.View.GL.OpenGL.__init__ [99]: Initialized OpenGL subsystems. 2019-04-19 17:41:13,207 - DEBUG - [MainThread] UM.View.GL.OpenGL.__init__ [100]: OpenGL Version: 3.3.0 2019-04-19 17:41:13,211 - DEBUG - [MainThread] UM.View.GL.OpenGL.__init__ [101]: OpenGL Vendor: NVIDIA Corporation 2019-04-19 17:41:13,216 - DEBUG - [MainThread] UM.View.GL.OpenGL.__init__ [102]: OpenGL Renderer: GeForce 9500 GT/PCIe/SSE2 2019-04-19 17:41:13,221 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\default.shader]... 2019-04-19 17:41:13,229 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\selection.shader]... 2019-04-19 17:41:13,236 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\default.shader]... 2019-04-19 17:41:13,243 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\composite.shader]... 2019-04-19 17:41:13,251 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\overhang.shader]... 2019-04-19 17:41:13,259 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\striped.shader]... 2019-04-19 17:41:13,268 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\transparent_object.shader]... 2019-04-19 17:41:13,276 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\striped.shader]... 2019-04-19 17:41:13,287 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\default.shader]... 2019-04-19 17:41:13,294 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\grid.shader]... 2019-04-19 17:41:13,302 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\platform.shader]... 2019-04-19 17:41:13,435 - DEBUG - [MainThread] cura.Machines.QualityManager.initialize [136]: Lookup tables updated. 2019-04-19 17:41:13,538 - INFO - [Thread-1] STLReader.STLReader.load_file [46]: Using NumPy-STL to load STL data. 2019-04-19 17:41:13,548 - DEBUG - [Thread-1] UM.Mesh.MeshData.calculateNormalsFromVertices [444]: Calculating normals took 0.0019996166229248047 seconds 2019-04-19 17:41:13,551 - DEBUG - [Thread-1] STLReader.STLReader._read [97]: Loaded a mesh with 26622 vertices 2019-04-19 17:41:13,568 - DEBUG - [MainThread] cura.Machines.Models.QualityProfilesDropDownMenuModel._update [61]: Updating QualityProfilesDropDownMenuModel. 2019-04-19 17:41:13,583 - DEBUG - [Thread-1] UM.Mesh.MeshData.approximateConvexHull [401]: approximateConvexHull(target_count=1024) Calculating 3D convex hull took 0.026998519897460938 seconds. 55 input vertices. 55 output vertices. 2019-04-19 17:41:13,602 - DEBUG - [MainThread] cura.Machines.Models.CustomQualityProfilesDropDownMenuModel._update [15]: Updating CustomQualityProfilesDropDownMenuModel. 2019-04-19 17:41:13,611 - DEBUG - [Thread-1] UM.FileHandler.ReadFileJob.run [69]: Loading file took 0.1 seconds 2019-04-19 17:41:13,630 - DEBUG - [Thread-1] UM.Mesh.MeshData.approximateConvexHull [401]: approximateConvexHull(target_count=1024) Calculating 3D convex hull took 0.01400136947631836 seconds. 54 input vertices. 54 output vertices. 2019-04-19 17:41:13,680 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [per_object_stack_2040198927304] added. 2019-04-19 17:41:13,767 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\transparent_object.shader]... 2019-04-19 17:41:15,838 - INFO - [MainThread] cura.Machines.MachineErrorChecker._setResult [188]: Error check finished, result = False, time = 3.9s 2019-04-19 17:41:23,413 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] [ERROR] Could not connect to the given address 2019-04-19 17:41:23,421 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onBackendQuit [811]: Backend quit with return code 0. Resetting process and socket. 2019-04-19 17:41:23,717 - DEBUG - [MainThread] cura.AutoSave._onTimeout [48]: Autosaving preferences, instances and profiles 2019-04-19 17:43:24,615 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend.slice [228]: Starting to slice... 2019-04-19 17:43:24,616 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend.slice [246]: Going to slice build plate [0]! 2019-04-19 17:43:24,622 - DEBUG - [MainThread] UM.Backend.Backend._createSocket [227]: Previous socket existed. Closing that first. 2019-04-19 17:43:24,836 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [187]: Socket state changed to Listening 2019-04-19 17:43:24,895 - INFO - [MainThread] UM.Backend.Backend.startEngine [81]: Started engine process: C:\Program Files\Ultimaker Cura 4.0\CuraEngine.exe 2019-04-19 17:43:24,909 - DEBUG - [MainThread] UM.Backend.Backend._backendLog [101]: [Backend] Calling engine with: ['C:\\Program Files\\Ultimaker Cura 4.0\\CuraEngine.exe', 'connect', '127.0.0.1:49675', ''] 2019-04-19 17:43:24,971 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:43:25,007 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] Cura_SteamEngine version 4.0.0 2019-04-19 17:43:25,014 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] Copyright (C) 2018 Ultimaker 2019-04-19 17:43:25,049 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:43:25,084 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] This program is free software: you can redistribute it and/or modify 2019-04-19 17:43:25,152 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] it under the terms of the GNU Affero General Public License as published by 2019-04-19 17:43:25,215 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] the Free Software Foundation, either version 3 of the License, or 2019-04-19 17:43:25,230 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] (at your option) any later version. 2019-04-19 17:43:25,249 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:43:25,340 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] This program is distributed in the hope that it will be useful, 2019-04-19 17:43:25,434 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] but WITHOUT ANY WARRANTY; without even the implied warranty of 2019-04-19 17:43:25,465 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the 2019-04-19 17:43:25,473 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] GNU Affero General Public License for more details. 2019-04-19 17:43:25,481 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:43:25,489 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] You should have received a copy of the GNU Affero General Public License 2019-04-19 17:43:25,496 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] along with this program. If not, see <http://www.gnu.org/licenses/>. 2019-04-19 17:43:26,060 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onStartSliceCompleted [432]: Sending slice message took 1.4439780712127686 seconds 2019-04-19 17:43:40,054 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._terminate [295]: Attempting to kill the engine process 2019-04-19 17:43:40,054 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._terminate [301]: Killing engine process 2019-04-19 17:43:40,061 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._terminate [304]: Engine process is killed. Received return code 1 2019-04-19 17:43:40,066 - DEBUG - [MainThread] UM.Backend.Backend._createSocket [227]: Previous socket existed. Closing that first. 2019-04-19 17:43:40,087 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [187]: Socket state changed to Listening 2019-04-19 17:43:40,101 - INFO - [MainThread] UM.Backend.Backend.startEngine [81]: Started engine process: C:\Program Files\Ultimaker Cura 4.0\CuraEngine.exe 2019-04-19 17:43:40,107 - DEBUG - [MainThread] UM.Backend.Backend._backendLog [101]: [Backend] Calling engine with: ['C:\\Program Files\\Ultimaker Cura 4.0\\CuraEngine.exe', 'connect', '127.0.0.1:49675', ''] 2019-04-19 17:43:40,196 - DEBUG - [Thread-17] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:43:40,201 - DEBUG - [Thread-17] UM.Backend.Backend._backendLog [101]: [Backend] Cura_SteamEngine version 4.0.0 2019-04-19 17:43:40,205 - DEBUG - [Thread-17] UM.Backend.Backend._backendLog [101]: [Backend] Copyright (C) 2018 Ultimaker 2019-04-19 17:43:40,210 - DEBUG - [Thread-17] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:43:40,215 - DEBUG - [Thread-17] UM.Backend.Backend._backendLog [101]: [Backend] This program is free software: you can redistribute it and/or modify 2019-04-19 17:43:40,219 - DEBUG - [Thread-17] UM.Backend.Backend._backendLog [101]: [Backend] it under the terms of the GNU Affero General Public License as published by 2019-04-19 17:43:40,224 - DEBUG - [Thread-17] UM.Backend.Backend._backendLog [101]: [Backend] the Free Software Foundation, either version 3 of the License, or 2019-04-19 17:43:40,229 - DEBUG - [Thread-17] UM.Backend.Backend._backendLog [101]: [Backend] (at your option) any later version. 2019-04-19 17:43:40,233 - DEBUG - [Thread-17] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:43:40,238 - DEBUG - [Thread-17] UM.Backend.Backend._backendLog [101]: [Backend] This program is distributed in the hope that it will be useful, 2019-04-19 17:43:40,243 - DEBUG - [Thread-17] UM.Backend.Backend._backendLog [101]: [Backend] but WITHOUT ANY WARRANTY; without even the implied warranty of 2019-04-19 17:43:40,247 - DEBUG - [Thread-17] UM.Backend.Backend._backendLog [101]: [Backend] MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the 2019-04-19 17:43:40,252 - DEBUG - [Thread-17] UM.Backend.Backend._backendLog [101]: [Backend] GNU Affero General Public License for more details. 2019-04-19 17:43:40,256 - DEBUG - [Thread-17] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:43:40,262 - DEBUG - [Thread-17] UM.Backend.Backend._backendLog [101]: [Backend] You should have received a copy of the GNU Affero General Public License 2019-04-19 17:43:40,266 - DEBUG - [Thread-17] UM.Backend.Backend._backendLog [101]: [Backend] along with this program. If not, see <http://www.gnu.org/licenses/>. 2019-04-19 17:43:41,894 - DEBUG - [MainThread] cura.TaskManagement.OnExitCallbackManager.triggerNextCallback [51]: No more on-app-exit callbacks to process. Tell the app to exit. 2019-04-19 17:43:41,899 - INFO - [MainThread] cura.CuraApplication.closeApplication [547]: Close application 2019-04-19 17:43:41,961 - DEBUG - [MainThread] UM.Qt.QtApplication.windowClosed [417]: Shutting down cura 2019-04-19 17:43:42,021 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._terminate [295]: Attempting to kill the engine process 2019-04-19 17:43:42,022 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._terminate [301]: Killing engine process 2019-04-19 17:43:42,028 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._terminate [304]: Engine process is killed. Received return code 1 2019-04-19 17:46:36,498 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin FileLogger 2019-04-19 17:46:36,523 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin FirmwareUpdateChecker 2019-04-19 17:46:36,545 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin FirmwareUpdater 2019-04-19 17:46:36,566 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin GCodeGzReader 2019-04-19 17:46:36,585 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin GCodeGzWriter 2019-04-19 17:46:36,606 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin GCodeProfileReader 2019-04-19 17:46:36,638 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin GCodeReader 2019-04-19 17:46:36,659 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin GCodeWriter 2019-04-19 17:46:36,682 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin ImageReader 2019-04-19 17:46:36,703 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin LegacyProfileReader 2019-04-19 17:46:36,723 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin LocalContainerProvider 2019-04-19 17:46:36,748 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin LocalFileOutputDevice 2019-04-19 17:46:36,768 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin MachineSettingsAction 2019-04-19 17:46:36,790 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin ModelChecker 2019-04-19 17:46:36,814 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin MonitorStage 2019-04-19 17:46:36,842 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin PerObjectSettingsTool 2019-04-19 17:46:36,866 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin PostProcessingPlugin 2019-04-19 17:46:36,891 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin PrepareStage 2019-04-19 17:46:36,914 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin PreviewStage 2019-04-19 17:46:36,945 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin RemovableDriveOutputDevice 2019-04-19 17:46:36,979 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin SimulationView 2019-04-19 17:46:37,006 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin SliceInfoPlugin 2019-04-19 17:46:37,030 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin SolidView 2019-04-19 17:46:37,057 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin SupportEraser 2019-04-19 17:46:37,092 - DEBUG - [MainThread] cura.OAuth2.AuthorizationService.getAccessToken [106]: No auth data to retrieve the access_token from 2019-04-19 17:46:37,098 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin Toolbox 2019-04-19 17:46:37,126 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin CameraTool 2019-04-19 17:46:37,156 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin MirrorTool 2019-04-19 17:46:37,188 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin RotateTool 2019-04-19 17:46:37,221 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin ScaleTool 2019-04-19 17:46:37,246 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin SelectionTool 2019-04-19 17:46:37,277 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin TranslateTool 2019-04-19 17:46:37,325 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin UFPWriter 2019-04-19 17:46:37,356 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin UltimakerMachineActions 2019-04-19 17:46:37,512 - DEBUG - [MainThread] UM3NetworkPrinting.src.Cloud.CloudOutputDeviceManager._onLoginStateChanged [57]: Log in state changed to False 2019-04-19 17:46:37,512 - DEBUG - [MainThread] UM3NetworkPrinting.src.Cloud.CloudOutputDeviceManager._onGetRemoteClustersFinished [80]: Parsed remote clusters to [] 2019-04-19 17:46:37,513 - DEBUG - [MainThread] UM3NetworkPrinting.src.Cloud.CloudOutputDeviceManager._onGetRemoteClustersFinished [81]: Removed: 0, added: 0, updates: 0 2019-04-19 17:46:37,519 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin UM3NetworkPrinting 2019-04-19 17:46:37,571 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin UpdateChecker 2019-04-19 17:46:37,578 - INFO - [Thread-2] UpdateChecker.UpdateCheckerJob.run [36]: Checking for new version of cura 2019-04-19 17:46:37,633 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin USBPrinting 2019-04-19 17:46:37,663 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin UserAgreement 2019-04-19 17:46:37,704 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade21to22 2019-04-19 17:46:37,736 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade22to24 2019-04-19 17:46:37,768 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade25to26 2019-04-19 17:46:37,801 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade26to27 2019-04-19 17:46:37,833 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade27to30 2019-04-19 17:46:37,867 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade30to31 2019-04-19 17:46:37,900 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade32to33 2019-04-19 17:46:37,932 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade33to34 2019-04-19 17:46:37,966 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade34to35 2019-04-19 17:46:37,999 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade35to40 2019-04-19 17:46:38,034 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin SimpleView 2019-04-19 17:46:38,070 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin X3DReader 2019-04-19 17:46:38,110 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin XmlMaterialProfile 2019-04-19 17:46:38,145 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin XRayView 2019-04-19 17:46:38,182 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin CustomSupports 2019-04-19 17:46:38,222 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin OrientationPlugin 2019-04-19 17:46:38,249 - INFO - [MainThread] UM.VersionUpgradeManager.upgrade [143]: Looking for old configuration files to upgrade. 2019-04-19 17:46:38,300 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\packages.json, skip it 2019-04-19 17:46:38,306 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\plugins.json, skip it 2019-04-19 17:46:38,338 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\packages.json, skip it 2019-04-19 17:46:38,343 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\plugins.json, skip it 2019-04-19 17:46:38,374 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\packages.json, skip it 2019-04-19 17:46:38,379 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\plugins.json, skip it 2019-04-19 17:46:38,410 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\packages.json, skip it 2019-04-19 17:46:38,415 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\plugins.json, skip it 2019-04-19 17:46:38,446 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\packages.json, skip it 2019-04-19 17:46:38,451 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\plugins.json, skip it 2019-04-19 17:46:38,482 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\packages.json, skip it 2019-04-19 17:46:38,487 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\plugins.json, skip it 2019-04-19 17:46:38,517 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\packages.json, skip it 2019-04-19 17:46:38,523 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\plugins.json, skip it 2019-04-19 17:46:38,553 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\packages.json, skip it 2019-04-19 17:46:38,560 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\plugins.json, skip it 2019-04-19 17:46:38,647 - DEBUG - [MainThread] UM.Backend.Backend._onSocketError [213]: Socket was unable to bind to port, increasing port number to 49675 2019-04-19 17:46:38,651 - DEBUG - [MainThread] UM.Backend.Backend._createSocket [227]: Previous socket existed. Closing that first. 2019-04-19 17:46:38,655 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._terminate [295]: Attempting to kill the engine process 2019-04-19 17:46:38,659 - DEBUG - [MainThread] UM.Backend.Backend._createSocket [227]: Previous socket existed. Closing that first. 2019-04-19 17:46:38,866 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [187]: Socket state changed to Listening 2019-04-19 17:46:38,879 - INFO - [MainThread] UM.Backend.Backend.startEngine [81]: Started engine process: C:\Program Files\Ultimaker Cura 4.0\CuraEngine.exe 2019-04-19 17:46:38,884 - DEBUG - [MainThread] UM.Backend.Backend._backendLog [101]: [Backend] Calling engine with: ['C:\\Program Files\\Ultimaker Cura 4.0\\CuraEngine.exe', 'connect', '127.0.0.1:49675', ''] 2019-04-19 17:46:38,946 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:46:38,951 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] Cura_SteamEngine version 4.0.0 2019-04-19 17:46:38,956 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] Copyright (C) 2018 Ultimaker 2019-04-19 17:46:38,961 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:46:38,966 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] This program is free software: you can redistribute it and/or modify 2019-04-19 17:46:38,970 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] it under the terms of the GNU Affero General Public License as published by 2019-04-19 17:46:38,975 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] the Free Software Foundation, either version 3 of the License, or 2019-04-19 17:46:38,980 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] (at your option) any later version. 2019-04-19 17:46:38,984 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:46:38,989 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] This program is distributed in the hope that it will be useful, 2019-04-19 17:46:38,994 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] but WITHOUT ANY WARRANTY; without even the implied warranty of 2019-04-19 17:46:38,999 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the 2019-04-19 17:46:39,003 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] GNU Affero General Public License for more details. 2019-04-19 17:46:39,008 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:46:39,014 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] You should have received a copy of the GNU Affero General Public License 2019-04-19 17:46:39,019 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] along with this program. If not, see <http://www.gnu.org/licenses/>. 2019-04-19 17:46:41,780 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.loadAllMetadata [338]: Loading metadata into container registry took 2.887972354888916 seconds 2019-04-19 17:46:41,920 - DEBUG - [MainThread] cura.Scene.CuraSceneController.setActiveBuildPlate [104]: Select build plate: 0 2019-04-19 17:46:41,925 - INFO - [MainThread] cura.CuraApplication.run [695]: Initializing variant manager 2019-04-19 17:46:41,935 - DEBUG - [MainThread] cura.Machines.VariantManager.initialize [59]: Exclude variant [empty_variant] 2019-04-19 17:46:41,937 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container ultimaker_s5_glass 2019-04-19 17:46:41,945 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [ultimaker_s5_glass] added. 2019-04-19 17:46:41,946 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container ultimaker_s5 2019-04-19 17:46:42,095 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [ultimaker_s5] added. 2019-04-19 17:46:42,099 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container ultimaker_s5_aluminum 2019-04-19 17:46:42,106 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [ultimaker_s5_aluminum] added. 2019-04-19 17:46:42,114 - INFO - [MainThread] cura.CuraApplication.run [699]: Initializing material manager 2019-04-19 17:46:42,210 - INFO - [MainThread] cura.CuraApplication.run [704]: Initializing quality manager 2019-04-19 17:46:42,232 - DEBUG - [MainThread] cura.Machines.QualityManager.initialize [136]: Lookup tables updated. 2019-04-19 17:46:42,237 - INFO - [MainThread] cura.CuraApplication.run [709]: Initializing machine manager 2019-04-19 17:46:42,242 - INFO - [MainThread] cura.CuraApplication.run [712]: Initializing container manager 2019-04-19 17:46:42,247 - INFO - [MainThread] cura.CuraApplication.run [715]: Initializing machine error checker 2019-04-19 17:46:42,277 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container Creality CR-10 2019-04-19 17:46:42,282 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container Creality CR-10_user 2019-04-19 17:46:42,290 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [Creality CR-10_user] added. 2019-04-19 17:46:42,292 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container creality_cr10_pla 2019-04-19 17:46:42,300 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [creality_cr10_pla] added. 2019-04-19 17:46:42,301 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container draft 2019-04-19 17:46:42,309 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [draft] added. 2019-04-19 17:46:42,312 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container Creality CR-10_settings 2019-04-19 17:46:42,320 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [Creality CR-10_settings] added. 2019-04-19 17:46:42,322 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container creality_cr10 2019-04-19 17:46:42,397 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [creality_cr10] added. 2019-04-19 17:46:42,403 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [Creality CR-10] added. 2019-04-19 17:46:42,408 - INFO - [MainThread] cura.MachineActionManager.addDefaultMachineActions [72]: Default machine actions added for machine definition [creality_cr10] 2019-04-19 17:46:42,413 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container creality_cr10_extruder_0 #2 2019-04-19 17:46:42,418 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container creality_cr10_extruder_0 #2_user 2019-04-19 17:46:42,426 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [creality_cr10_extruder_0 #2_user] added. 2019-04-19 17:46:42,427 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container creality_cr10_extruder_0_pla 2019-04-19 17:46:42,437 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [creality_cr10_extruder_0_pla] added. 2019-04-19 17:46:42,439 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container generic_pla_175 2019-04-19 17:46:42,451 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [generic_pla_175_imade3d_jellybox] added. 2019-04-19 17:46:42,456 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [generic_pla_175_imade3d_jellybox_0.4_mm] added. 2019-04-19 17:46:42,460 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [generic_pla_175_imade3d_jellybox_0.4_mm_2-fans] added. 2019-04-19 17:46:42,465 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [generic_pla_175_cartesio] added. 2019-04-19 17:46:42,470 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [generic_pla_175_cartesio_0.25mm_thermoplastic_extruder] added. 2019-04-19 17:46:42,475 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [generic_pla_175_cartesio_0.4mm_thermoplastic_extruder] added. 2019-04-19 17:46:42,480 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [generic_pla_175_cartesio_0.8mm_thermoplastic_extruder] added. 2019-04-19 17:46:42,485 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [generic_pla_175] added. 2019-04-19 17:46:42,486 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container creality_cr10_extruder_0 #2_settings 2019-04-19 17:46:42,497 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [creality_cr10_extruder_0 #2_settings] added. 2019-04-19 17:46:42,499 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container creality_cr10_extruder_0 2019-04-19 17:46:42,505 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [creality_cr10_extruder_0] added. 2019-04-19 17:46:42,510 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [creality_cr10_extruder_0 #2] added. 2019-04-19 17:46:42,535 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container fdmprinter 2019-04-19 17:46:42,611 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [fdmprinter] added. 2019-04-19 17:46:42,906 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [170]: Begin loading of script: BQ_PauseAtHeight 2019-04-19 17:46:42,908 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [170]: Begin loading of script: ChangeAtZ 2019-04-19 17:46:42,910 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [170]: Begin loading of script: DisplayFilenameAndLayerOnLCD 2019-04-19 17:46:42,913 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [170]: Begin loading of script: FilamentChange 2019-04-19 17:46:42,914 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [170]: Begin loading of script: PauseAtHeight 2019-04-19 17:46:42,916 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [170]: Begin loading of script: PauseAtHeightRepRapFirmwareDuet 2019-04-19 17:46:42,918 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [170]: Begin loading of script: PauseAtHeightforRepetier 2019-04-19 17:46:42,920 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [170]: Begin loading of script: SearchAndReplace 2019-04-19 17:46:42,922 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [170]: Begin loading of script: Stretch 2019-04-19 17:46:42,926 - DEBUG - [MainThread] UM3NetworkPrinting.src.UM3OutputDevicePlugin.checkCloudFlowIsPossible [412]: Checking if cloud connection is possible... 2019-04-19 17:46:42,927 - DEBUG - [MainThread] UM3NetworkPrinting.src.UM3OutputDevicePlugin.checkCloudFlowIsPossible [435]: Cloud Flow not possible: User not logged in! 2019-04-19 17:46:43,079 - INFO - [MainThread] cura.Settings.GlobalStack.addExtruder [136]: Extruder[creality_cr10_extruder_0 #2] added to [Creality CR-10] at position [0] 2019-04-19 17:46:43,083 - WARNING - [MainThread] cura.Settings.ExtruderManager.registerExtruder [169]: Extruder [creality_cr10_extruder_0 #2] has already been registered on machine [Creality CR-10], not doing anything 2019-04-19 17:46:43,092 - INFO - [MainThread] cura.Settings.MachineManager._initMachineState [330]: Machine 'Creality CR-10' quality changes set to 'PLA #2' 2019-04-19 17:46:43,402 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._rescheduleCheck [136]: New error check scheduled. 2019-04-19 17:46:43,403 - INFO - [MainThread] FirmwareUpdateChecker.FirmwareUpdateChecker.checkFirmwareVersion [76]: No machine with name Creality CR-10 in list of firmware to check. 2019-04-19 17:46:44,857 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin._createView [280]: Creating post processing plugin view. 2019-04-19 17:46:44,985 - DEBUG - [MainThread] UM.Qt.Bindings.Theme.load [158]: Loading theme file: C:\Program Files\Ultimaker Cura 4.0\resources\themes\cura-light\theme.json 2019-04-19 17:46:45,089 - DEBUG - [MainThread] UM.Qt.Bindings.Theme.load [230]: Loaded theme C:\Program Files\Ultimaker Cura 4.0\resources\themes\cura-light 2019-04-19 17:46:45,176 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin._createView [290]: Post processing view created. 2019-04-19 17:46:45,439 - WARNING - [MainThread] UM.Qt.Bindings.Theme.getImage [133]: No image header_pattern defined in Theme 2019-04-19 17:46:45,457 - DEBUG - [MainThread] cura.Machines.Models.BuildPlateModel._update [33]: Updating BuildPlateModel. 2019-04-19 17:46:46,484 - DEBUG - [MainThread] cura.Machines.Models.NozzleModel._update [34]: Updating NozzleModel. 2019-04-19 17:46:46,714 - DEBUG - [MainThread] UM3NetworkPrinting.src.DiscoverUM3Action._createAdditionalComponentsView [196]: Creating additional ui components for UM3. 2019-04-19 17:46:46,771 - DEBUG - [MainThread] UM3NetworkPrinting.src.DiscoverUM3Action.startDiscovery [47]: Starting device discovery. 2019-04-19 17:46:46,787 - DEBUG - [MainThread] UM.Controller.setActiveStage [159]: Setting active stage to PrepareStage 2019-04-19 17:46:46,945 - DEBUG - [MainThread] cura.Machines.Models.NozzleModel._update [34]: Updating NozzleModel. 2019-04-19 17:46:47,107 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/plugins/PrepareStage/PrepareMain.qml:16:5: QML ActionPanelWidget: Binding loop detected for property "width" 2019-04-19 17:46:47,113 - DEBUG - [MainThread] UM.Controller.setActiveView [92]: Setting active view to SolidView 2019-04-19 17:46:47,155 - DEBUG - [MainThread] ModelChecker.ModelChecker._createView [103]: Creating model checker view. 2019-04-19 17:46:47,170 - DEBUG - [MainThread] ModelChecker.ModelChecker._createView [112]: Model checker view created. 2019-04-19 17:46:47,172 - DEBUG - [MainThread] SliceInfoPlugin.SliceInfo._createDialog [82]: Creating dialog [MoreInfoWindow.qml] 2019-04-19 17:46:47,256 - DEBUG - [MainThread] cura.CuraApplication.run [747]: Booting Cura took 12.433862924575806 seconds 2019-04-19 17:46:47,296 - INFO - [MainThread] cura.Machines.MaterialManager._updateMaps [279]: Updating material lookup data ... 2019-04-19 17:46:47,361 - INFO - [MainThread] cura.Settings.MachineManager._updateQualityWithMaterial [1270]: Updating quality/quality_changes due to material change 2019-04-19 17:46:47,367 - DEBUG - [MainThread] cura.Settings.MachineManager._updateQualityWithMaterial [1277]: Current quality type = [draft] 2019-04-19 17:46:47,371 - INFO - [MainThread] cura.Settings.MachineManager._updateQualityWithMaterial [1291]: Current available quality type [draft] is available, applying changes. 2019-04-19 17:46:47,434 - DEBUG - [MainThread] cura.Machines.QualityManager.initialize [136]: Lookup tables updated. 2019-04-19 17:46:47,461 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._checkStack [140]: Need to check for errors again. Discard the current progress and reschedule a check. 2019-04-19 17:46:47,541 - DEBUG - [MainThread] cura.Machines.Models.QualityProfilesDropDownMenuModel._update [61]: Updating QualityProfilesDropDownMenuModel. 2019-04-19 17:46:47,547 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container coarse 2019-04-19 17:46:47,554 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [coarse] added. 2019-04-19 17:46:47,592 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container extra_coarse 2019-04-19 17:46:47,600 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [extra_coarse] added. 2019-04-19 17:46:47,637 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container fast 2019-04-19 17:46:47,645 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [fast] added. 2019-04-19 17:46:47,727 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container high 2019-04-19 17:46:47,734 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [high] added. 2019-04-19 17:46:47,776 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container normal 2019-04-19 17:46:47,783 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [normal] added. 2019-04-19 17:46:47,785 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container extra_fast 2019-04-19 17:46:47,793 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [extra_fast] added. 2019-04-19 17:46:47,843 - DEBUG - [MainThread] cura.Machines.Models.CustomQualityProfilesDropDownMenuModel._update [15]: Updating CustomQualityProfilesDropDownMenuModel. 2019-04-19 17:46:47,851 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._rescheduleCheck [136]: New error check scheduled. 2019-04-19 17:46:49,068 - DEBUG - [MainThread] UM.Qt.QtRenderer._initialize [183]: Support for Vertex Array Objects: True 2019-04-19 17:46:49,083 - DEBUG - [MainThread] UM.View.GL.OpenGL.__init__ [99]: Initialized OpenGL subsystems. 2019-04-19 17:46:49,087 - DEBUG - [MainThread] UM.View.GL.OpenGL.__init__ [100]: OpenGL Version: 3.3.0 2019-04-19 17:46:49,092 - DEBUG - [MainThread] UM.View.GL.OpenGL.__init__ [101]: OpenGL Vendor: NVIDIA Corporation 2019-04-19 17:46:49,097 - DEBUG - [MainThread] UM.View.GL.OpenGL.__init__ [102]: OpenGL Renderer: GeForce 9500 GT/PCIe/SSE2 2019-04-19 17:46:49,102 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\default.shader]... 2019-04-19 17:46:49,109 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\selection.shader]... 2019-04-19 17:46:49,116 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\default.shader]... 2019-04-19 17:46:49,123 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\composite.shader]... 2019-04-19 17:46:49,131 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\overhang.shader]... 2019-04-19 17:46:49,140 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\striped.shader]... 2019-04-19 17:46:49,148 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\transparent_object.shader]... 2019-04-19 17:46:49,156 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\striped.shader]... 2019-04-19 17:46:49,208 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\default.shader]... 2019-04-19 17:46:49,224 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\grid.shader]... 2019-04-19 17:46:49,231 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\platform.shader]... 2019-04-19 17:46:49,362 - DEBUG - [MainThread] cura.Machines.QualityManager.initialize [136]: Lookup tables updated. 2019-04-19 17:46:49,488 - DEBUG - [MainThread] cura.Machines.Models.QualityProfilesDropDownMenuModel._update [61]: Updating QualityProfilesDropDownMenuModel. 2019-04-19 17:46:49,511 - DEBUG - [MainThread] cura.Machines.Models.CustomQualityProfilesDropDownMenuModel._update [15]: Updating CustomQualityProfilesDropDownMenuModel. 2019-04-19 17:46:50,969 - INFO - [MainThread] cura.Machines.MachineErrorChecker._setResult [188]: Error check finished, result = False, time = 3.1s 2019-04-19 17:46:59,417 - DEBUG - [MainThread] cura.AutoSave._onTimeout [48]: Autosaving preferences, instances and profiles 2019-04-19 17:46:59,955 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] [ERROR] Could not connect to the given address 2019-04-19 17:46:59,982 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onBackendQuit [811]: Backend quit with return code 0. Resetting process and socket. 2019-04-19 17:47:14,254 - INFO - [Thread-1] STLReader.STLReader.load_file [46]: Using NumPy-STL to load STL data. 2019-04-19 17:47:14,274 - DEBUG - [Thread-1] UM.Mesh.MeshData.calculateNormalsFromVertices [444]: Calculating normals took 0.005001544952392578 seconds 2019-04-19 17:47:14,280 - DEBUG - [Thread-1] STLReader.STLReader._read [97]: Loaded a mesh with 82644 vertices 2019-04-19 17:47:14,415 - DEBUG - [Thread-1] UM.Mesh.MeshData.approximateConvexHull [401]: approximateConvexHull(target_count=1024) Calculating 3D convex hull took 0.12900376319885254 seconds. 351 input vertices. 351 output vertices. 2019-04-19 17:47:14,451 - DEBUG - [Thread-1] UM.FileHandler.ReadFileJob.run [69]: Loading file took 0.2 seconds 2019-04-19 17:47:14,507 - DEBUG - [Thread-1] UM.Mesh.MeshData.approximateConvexHull [401]: approximateConvexHull(target_count=1024) Calculating 3D convex hull took 0.049997806549072266 seconds. 351 input vertices. 351 output vertices. 2019-04-19 17:47:14,545 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [per_object_stack_2609140226928] added. 2019-04-19 17:47:14,589 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\transparent_object.shader]... 2019-04-19 17:47:24,579 - DEBUG - [MainThread] cura.AutoSave._onTimeout [48]: Autosaving preferences, instances and profiles 2019-04-19 17:47:27,664 - DEBUG - [MainThread] cura.TaskManagement.OnExitCallbackManager.triggerNextCallback [51]: No more on-app-exit callbacks to process. Tell the app to exit. 2019-04-19 17:47:27,669 - INFO - [MainThread] cura.CuraApplication.closeApplication [547]: Close application 2019-04-19 17:47:27,687 - DEBUG - [MainThread] UM.Qt.QtApplication.windowClosed [417]: Shutting down cura 2019-04-19 17:47:27,721 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._terminate [295]: Attempting to kill the engine process 2019-04-19 17:54:11,043 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin FileLogger 2019-04-19 17:54:11,069 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin FirmwareUpdateChecker 2019-04-19 17:54:11,092 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin FirmwareUpdater 2019-04-19 17:54:11,115 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin GCodeGzReader 2019-04-19 17:54:11,144 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin GCodeGzWriter 2019-04-19 17:54:11,165 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin GCodeProfileReader 2019-04-19 17:54:11,199 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin GCodeReader 2019-04-19 17:54:11,221 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin GCodeWriter 2019-04-19 17:54:11,244 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin ImageReader 2019-04-19 17:54:11,266 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin LegacyProfileReader 2019-04-19 17:54:11,289 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin LocalContainerProvider 2019-04-19 17:54:11,319 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin LocalFileOutputDevice 2019-04-19 17:54:11,344 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin MachineSettingsAction 2019-04-19 17:54:11,368 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin ModelChecker 2019-04-19 17:54:11,395 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin MonitorStage 2019-04-19 17:54:11,428 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin PerObjectSettingsTool 2019-04-19 17:54:11,458 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin PostProcessingPlugin 2019-04-19 17:54:11,487 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin PrepareStage 2019-04-19 17:54:11,520 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin PreviewStage 2019-04-19 17:54:11,562 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin RemovableDriveOutputDevice 2019-04-19 17:54:11,604 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin SimulationView 2019-04-19 17:54:11,643 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin SliceInfoPlugin 2019-04-19 17:54:11,683 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin SolidView 2019-04-19 17:54:11,716 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin SupportEraser 2019-04-19 17:54:11,761 - DEBUG - [MainThread] cura.OAuth2.AuthorizationService.getAccessToken [106]: No auth data to retrieve the access_token from 2019-04-19 17:54:11,769 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin Toolbox 2019-04-19 17:54:11,839 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin CameraTool 2019-04-19 17:54:12,007 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin MirrorTool 2019-04-19 17:54:12,257 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin RotateTool 2019-04-19 17:54:12,321 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin ScaleTool 2019-04-19 17:54:12,373 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin SelectionTool 2019-04-19 17:54:12,418 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin TranslateTool 2019-04-19 17:54:12,518 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin UFPWriter 2019-04-19 17:54:12,573 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin UltimakerMachineActions 2019-04-19 17:54:12,827 - DEBUG - [MainThread] UM3NetworkPrinting.src.Cloud.CloudOutputDeviceManager._onLoginStateChanged [57]: Log in state changed to False 2019-04-19 17:54:12,828 - DEBUG - [MainThread] UM3NetworkPrinting.src.Cloud.CloudOutputDeviceManager._onGetRemoteClustersFinished [80]: Parsed remote clusters to [] 2019-04-19 17:54:12,829 - DEBUG - [MainThread] UM3NetworkPrinting.src.Cloud.CloudOutputDeviceManager._onGetRemoteClustersFinished [81]: Removed: 0, added: 0, updates: 0 2019-04-19 17:54:12,836 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin UM3NetworkPrinting 2019-04-19 17:54:12,900 - INFO - [Thread-2] UpdateChecker.UpdateCheckerJob.run [36]: Checking for new version of cura 2019-04-19 17:54:12,911 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin UpdateChecker 2019-04-19 17:54:13,053 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin USBPrinting 2019-04-19 17:54:13,127 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin UserAgreement 2019-04-19 17:54:13,215 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade21to22 2019-04-19 17:54:13,252 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade22to24 2019-04-19 17:54:13,289 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade25to26 2019-04-19 17:54:13,322 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade26to27 2019-04-19 17:54:13,357 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade27to30 2019-04-19 17:54:13,393 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade30to31 2019-04-19 17:54:13,426 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade32to33 2019-04-19 17:54:13,458 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade33to34 2019-04-19 17:54:13,491 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade34to35 2019-04-19 17:54:13,525 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin VersionUpgrade35to40 2019-04-19 17:54:13,560 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin SimpleView 2019-04-19 17:54:13,594 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin X3DReader 2019-04-19 17:54:13,634 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin XmlMaterialProfile 2019-04-19 17:54:13,670 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin XRayView 2019-04-19 17:54:13,708 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin CustomSupports 2019-04-19 17:54:13,747 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [436]: Loaded plugin OrientationPlugin 2019-04-19 17:54:13,777 - INFO - [MainThread] UM.VersionUpgradeManager.upgrade [143]: Looking for old configuration files to upgrade. 2019-04-19 17:54:13,828 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\packages.json, skip it 2019-04-19 17:54:13,839 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\plugins.json, skip it 2019-04-19 17:54:13,872 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\packages.json, skip it 2019-04-19 17:54:13,877 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\plugins.json, skip it 2019-04-19 17:54:13,908 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\packages.json, skip it 2019-04-19 17:54:13,914 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\plugins.json, skip it 2019-04-19 17:54:13,945 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\packages.json, skip it 2019-04-19 17:54:13,950 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\plugins.json, skip it 2019-04-19 17:54:13,983 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\packages.json, skip it 2019-04-19 17:54:13,989 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\plugins.json, skip it 2019-04-19 17:54:14,021 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\packages.json, skip it 2019-04-19 17:54:14,027 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\plugins.json, skip it 2019-04-19 17:54:14,059 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\packages.json, skip it 2019-04-19 17:54:14,064 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\plugins.json, skip it 2019-04-19 17:54:14,096 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\packages.json, skip it 2019-04-19 17:54:14,101 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [295]: Failed to get file version: .\plugins.json, skip it 2019-04-19 17:54:14,192 - DEBUG - [MainThread] UM.Backend.Backend._onSocketError [213]: Socket was unable to bind to port, increasing port number to 49675 2019-04-19 17:54:14,196 - DEBUG - [MainThread] UM.Backend.Backend._createSocket [227]: Previous socket existed. Closing that first. 2019-04-19 17:54:14,200 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._terminate [295]: Attempting to kill the engine process 2019-04-19 17:54:14,205 - DEBUG - [MainThread] UM.Backend.Backend._createSocket [227]: Previous socket existed. Closing that first. 2019-04-19 17:54:14,426 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [187]: Socket state changed to Listening 2019-04-19 17:54:14,440 - INFO - [MainThread] UM.Backend.Backend.startEngine [81]: Started engine process: C:\Program Files\Ultimaker Cura 4.0\CuraEngine.exe 2019-04-19 17:54:14,445 - DEBUG - [MainThread] UM.Backend.Backend._backendLog [101]: [Backend] Calling engine with: ['C:\\Program Files\\Ultimaker Cura 4.0\\CuraEngine.exe', 'connect', '127.0.0.1:49675', ''] 2019-04-19 17:54:14,507 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:54:14,512 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] Cura_SteamEngine version 4.0.0 2019-04-19 17:54:14,516 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] Copyright (C) 2018 Ultimaker 2019-04-19 17:54:14,521 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:54:14,525 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] This program is free software: you can redistribute it and/or modify 2019-04-19 17:54:14,530 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] it under the terms of the GNU Affero General Public License as published by 2019-04-19 17:54:14,535 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] the Free Software Foundation, either version 3 of the License, or 2019-04-19 17:54:14,539 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] (at your option) any later version. 2019-04-19 17:54:14,544 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:54:14,549 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] This program is distributed in the hope that it will be useful, 2019-04-19 17:54:14,553 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] but WITHOUT ANY WARRANTY; without even the implied warranty of 2019-04-19 17:54:14,558 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the 2019-04-19 17:54:14,562 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] GNU Affero General Public License for more details. 2019-04-19 17:54:14,567 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:54:14,571 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] You should have received a copy of the GNU Affero General Public License 2019-04-19 17:54:14,576 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] along with this program. If not, see <http://www.gnu.org/licenses/>. 2019-04-19 17:54:18,487 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.loadAllMetadata [338]: Loading metadata into container registry took 4.031955003738403 seconds 2019-04-19 17:54:18,793 - DEBUG - [MainThread] cura.Scene.CuraSceneController.setActiveBuildPlate [104]: Select build plate: 0 2019-04-19 17:54:18,801 - INFO - [MainThread] cura.CuraApplication.run [695]: Initializing variant manager 2019-04-19 17:54:18,822 - DEBUG - [MainThread] cura.Machines.VariantManager.initialize [59]: Exclude variant [empty_variant] 2019-04-19 17:54:18,826 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container ultimaker_s5_aluminum 2019-04-19 17:54:18,845 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [ultimaker_s5_aluminum] added. 2019-04-19 17:54:18,849 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container ultimaker_s5 2019-04-19 17:54:19,157 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [ultimaker_s5] added. 2019-04-19 17:54:19,164 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container ultimaker_s5_glass 2019-04-19 17:54:19,172 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [ultimaker_s5_glass] added. 2019-04-19 17:54:19,181 - INFO - [MainThread] cura.CuraApplication.run [699]: Initializing material manager 2019-04-19 17:54:19,298 - INFO - [MainThread] cura.CuraApplication.run [704]: Initializing quality manager 2019-04-19 17:54:19,323 - DEBUG - [MainThread] cura.Machines.QualityManager.initialize [136]: Lookup tables updated. 2019-04-19 17:54:19,328 - INFO - [MainThread] cura.CuraApplication.run [709]: Initializing machine manager 2019-04-19 17:54:19,335 - INFO - [MainThread] cura.CuraApplication.run [712]: Initializing container manager 2019-04-19 17:54:19,339 - INFO - [MainThread] cura.CuraApplication.run [715]: Initializing machine error checker 2019-04-19 17:54:19,373 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container Creality CR-10 2019-04-19 17:54:19,378 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container Creality CR-10_user 2019-04-19 17:54:19,387 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [Creality CR-10_user] added. 2019-04-19 17:54:19,388 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container creality_cr10_pla 2019-04-19 17:54:19,397 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [creality_cr10_pla] added. 2019-04-19 17:54:19,399 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container draft 2019-04-19 17:54:19,408 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [draft] added. 2019-04-19 17:54:19,410 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container Creality CR-10_settings 2019-04-19 17:54:19,419 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [Creality CR-10_settings] added. 2019-04-19 17:54:19,420 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container creality_cr10 2019-04-19 17:54:19,503 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [creality_cr10] added. 2019-04-19 17:54:19,509 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [Creality CR-10] added. 2019-04-19 17:54:19,514 - INFO - [MainThread] cura.MachineActionManager.addDefaultMachineActions [72]: Default machine actions added for machine definition [creality_cr10] 2019-04-19 17:54:19,521 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container creality_cr10_extruder_0 #2 2019-04-19 17:54:19,526 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container creality_cr10_extruder_0 #2_user 2019-04-19 17:54:19,535 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [creality_cr10_extruder_0 #2_user] added. 2019-04-19 17:54:19,537 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container creality_cr10_extruder_0_pla 2019-04-19 17:54:19,549 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [creality_cr10_extruder_0_pla] added. 2019-04-19 17:54:19,550 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container generic_pla_175 2019-04-19 17:54:19,563 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [generic_pla_175_imade3d_jellybox] added. 2019-04-19 17:54:19,568 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [generic_pla_175_imade3d_jellybox_0.4_mm] added. 2019-04-19 17:54:19,574 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [generic_pla_175_imade3d_jellybox_0.4_mm_2-fans] added. 2019-04-19 17:54:19,578 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [generic_pla_175_cartesio] added. 2019-04-19 17:54:19,583 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [generic_pla_175_cartesio_0.25mm_thermoplastic_extruder] added. 2019-04-19 17:54:19,589 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [generic_pla_175_cartesio_0.4mm_thermoplastic_extruder] added. 2019-04-19 17:54:19,594 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [generic_pla_175_cartesio_0.8mm_thermoplastic_extruder] added. 2019-04-19 17:54:19,599 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [generic_pla_175] added. 2019-04-19 17:54:19,601 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container creality_cr10_extruder_0 #2_settings 2019-04-19 17:54:19,613 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [creality_cr10_extruder_0 #2_settings] added. 2019-04-19 17:54:19,615 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container creality_cr10_extruder_0 2019-04-19 17:54:19,622 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [creality_cr10_extruder_0] added. 2019-04-19 17:54:19,628 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [creality_cr10_extruder_0 #2] added. 2019-04-19 17:54:19,655 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container fdmprinter 2019-04-19 17:54:19,741 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [fdmprinter] added. 2019-04-19 17:54:20,059 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [170]: Begin loading of script: BQ_PauseAtHeight 2019-04-19 17:54:20,062 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [170]: Begin loading of script: ChangeAtZ 2019-04-19 17:54:20,065 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [170]: Begin loading of script: DisplayFilenameAndLayerOnLCD 2019-04-19 17:54:20,068 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [170]: Begin loading of script: FilamentChange 2019-04-19 17:54:20,070 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [170]: Begin loading of script: PauseAtHeight 2019-04-19 17:54:20,072 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [170]: Begin loading of script: PauseAtHeightRepRapFirmwareDuet 2019-04-19 17:54:20,074 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [170]: Begin loading of script: PauseAtHeightforRepetier 2019-04-19 17:54:20,077 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [170]: Begin loading of script: SearchAndReplace 2019-04-19 17:54:20,080 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [170]: Begin loading of script: Stretch 2019-04-19 17:54:20,084 - DEBUG - [MainThread] UM3NetworkPrinting.src.UM3OutputDevicePlugin.checkCloudFlowIsPossible [412]: Checking if cloud connection is possible... 2019-04-19 17:54:20,084 - DEBUG - [MainThread] UM3NetworkPrinting.src.UM3OutputDevicePlugin.checkCloudFlowIsPossible [435]: Cloud Flow not possible: User not logged in! 2019-04-19 17:54:20,256 - INFO - [MainThread] cura.Settings.GlobalStack.addExtruder [136]: Extruder[creality_cr10_extruder_0 #2] added to [Creality CR-10] at position [0] 2019-04-19 17:54:20,260 - WARNING - [MainThread] cura.Settings.ExtruderManager.registerExtruder [169]: Extruder [creality_cr10_extruder_0 #2] has already been registered on machine [Creality CR-10], not doing anything 2019-04-19 17:54:20,271 - INFO - [MainThread] cura.Settings.MachineManager._initMachineState [330]: Machine 'Creality CR-10' quality changes set to 'PLA #2' 2019-04-19 17:54:20,627 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._rescheduleCheck [136]: New error check scheduled. 2019-04-19 17:54:20,629 - INFO - [MainThread] FirmwareUpdateChecker.FirmwareUpdateChecker.checkFirmwareVersion [76]: No machine with name Creality CR-10 in list of firmware to check. 2019-04-19 17:54:22,783 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin._createView [280]: Creating post processing plugin view. 2019-04-19 17:54:22,924 - DEBUG - [MainThread] UM.Qt.Bindings.Theme.load [158]: Loading theme file: C:\Program Files\Ultimaker Cura 4.0\resources\themes\cura-light\theme.json 2019-04-19 17:54:23,047 - DEBUG - [MainThread] UM.Qt.Bindings.Theme.load [230]: Loaded theme C:\Program Files\Ultimaker Cura 4.0\resources\themes\cura-light 2019-04-19 17:54:23,187 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin._createView [290]: Post processing view created. 2019-04-19 17:54:23,477 - WARNING - [MainThread] UM.Qt.Bindings.Theme.getImage [133]: No image header_pattern defined in Theme 2019-04-19 17:54:23,496 - DEBUG - [MainThread] cura.Machines.Models.BuildPlateModel._update [33]: Updating BuildPlateModel. 2019-04-19 17:54:24,634 - DEBUG - [MainThread] cura.Machines.Models.NozzleModel._update [34]: Updating NozzleModel. 2019-04-19 17:54:24,894 - DEBUG - [MainThread] UM3NetworkPrinting.src.DiscoverUM3Action._createAdditionalComponentsView [196]: Creating additional ui components for UM3. 2019-04-19 17:54:24,955 - DEBUG - [MainThread] UM3NetworkPrinting.src.DiscoverUM3Action.startDiscovery [47]: Starting device discovery. 2019-04-19 17:54:24,973 - DEBUG - [MainThread] UM.Controller.setActiveStage [159]: Setting active stage to PrepareStage 2019-04-19 17:54:25,148 - DEBUG - [MainThread] cura.Machines.Models.NozzleModel._update [34]: Updating NozzleModel. 2019-04-19 17:54:25,331 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [352]: file:///C:/Program Files/Ultimaker Cura 4.0/plugins/PrepareStage/PrepareMain.qml:16:5: QML ActionPanelWidget: Binding loop detected for property "width" 2019-04-19 17:54:25,337 - DEBUG - [MainThread] UM.Controller.setActiveView [92]: Setting active view to SolidView 2019-04-19 17:54:25,341 - DEBUG - [MainThread] ModelChecker.ModelChecker._createView [103]: Creating model checker view. 2019-04-19 17:54:25,355 - DEBUG - [MainThread] ModelChecker.ModelChecker._createView [112]: Model checker view created. 2019-04-19 17:54:25,356 - DEBUG - [MainThread] SliceInfoPlugin.SliceInfo._createDialog [82]: Creating dialog [MoreInfoWindow.qml] 2019-04-19 17:54:25,447 - DEBUG - [MainThread] cura.CuraApplication.run [747]: Booting Cura took 16.137810468673706 seconds 2019-04-19 17:54:25,473 - INFO - [MainThread] cura.Machines.MaterialManager._updateMaps [279]: Updating material lookup data ... 2019-04-19 17:54:25,545 - INFO - [MainThread] cura.Settings.MachineManager._updateQualityWithMaterial [1270]: Updating quality/quality_changes due to material change 2019-04-19 17:54:25,551 - DEBUG - [MainThread] cura.Settings.MachineManager._updateQualityWithMaterial [1277]: Current quality type = [draft] 2019-04-19 17:54:25,556 - INFO - [MainThread] cura.Settings.MachineManager._updateQualityWithMaterial [1291]: Current available quality type [draft] is available, applying changes. 2019-04-19 17:54:25,624 - DEBUG - [MainThread] cura.Machines.QualityManager.initialize [136]: Lookup tables updated. 2019-04-19 17:54:25,672 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._checkStack [140]: Need to check for errors again. Discard the current progress and reschedule a check. 2019-04-19 17:54:25,727 - DEBUG - [MainThread] cura.Machines.Models.QualityProfilesDropDownMenuModel._update [61]: Updating QualityProfilesDropDownMenuModel. 2019-04-19 17:54:25,729 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container coarse 2019-04-19 17:54:25,737 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [coarse] added. 2019-04-19 17:54:25,775 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container extra_coarse 2019-04-19 17:54:25,783 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [extra_coarse] added. 2019-04-19 17:54:25,822 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container fast 2019-04-19 17:54:25,831 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [fast] added. 2019-04-19 17:54:25,918 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container high 2019-04-19 17:54:25,926 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [high] added. 2019-04-19 17:54:25,969 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container normal 2019-04-19 17:54:25,978 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [normal] added. 2019-04-19 17:54:25,980 - DEBUG - [MainThread] LocalContainerProvider.LocalContainerProvider.loadContainer [59]: Loading container extra_fast 2019-04-19 17:54:25,988 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [extra_fast] added. 2019-04-19 17:54:26,041 - DEBUG - [MainThread] cura.Machines.Models.CustomQualityProfilesDropDownMenuModel._update [15]: Updating CustomQualityProfilesDropDownMenuModel. 2019-04-19 17:54:26,050 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._rescheduleCheck [136]: New error check scheduled. 2019-04-19 17:54:27,372 - DEBUG - [MainThread] UM.Qt.QtRenderer._initialize [183]: Support for Vertex Array Objects: True 2019-04-19 17:54:27,390 - DEBUG - [MainThread] UM.View.GL.OpenGL.__init__ [99]: Initialized OpenGL subsystems. 2019-04-19 17:54:27,394 - DEBUG - [MainThread] UM.View.GL.OpenGL.__init__ [100]: OpenGL Version: 3.3.0 2019-04-19 17:54:27,399 - DEBUG - [MainThread] UM.View.GL.OpenGL.__init__ [101]: OpenGL Vendor: NVIDIA Corporation 2019-04-19 17:54:27,405 - DEBUG - [MainThread] UM.View.GL.OpenGL.__init__ [102]: OpenGL Renderer: GeForce 9500 GT/PCIe/SSE2 2019-04-19 17:54:27,410 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\default.shader]... 2019-04-19 17:54:27,418 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\selection.shader]... 2019-04-19 17:54:27,426 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\default.shader]... 2019-04-19 17:54:27,434 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\composite.shader]... 2019-04-19 17:54:27,444 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\overhang.shader]... 2019-04-19 17:54:27,452 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\striped.shader]... 2019-04-19 17:54:27,461 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\transparent_object.shader]... 2019-04-19 17:54:27,470 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\striped.shader]... 2019-04-19 17:54:27,480 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\default.shader]... 2019-04-19 17:54:27,488 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\grid.shader]... 2019-04-19 17:54:27,497 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\platform.shader]... 2019-04-19 17:54:27,636 - DEBUG - [MainThread] cura.Machines.QualityManager.initialize [136]: Lookup tables updated. 2019-04-19 17:54:27,759 - DEBUG - [MainThread] cura.Machines.Models.QualityProfilesDropDownMenuModel._update [61]: Updating QualityProfilesDropDownMenuModel. 2019-04-19 17:54:27,790 - DEBUG - [MainThread] cura.Machines.Models.CustomQualityProfilesDropDownMenuModel._update [15]: Updating CustomQualityProfilesDropDownMenuModel. 2019-04-19 17:54:30,021 - INFO - [MainThread] cura.Machines.MachineErrorChecker._setResult [188]: Error check finished, result = False, time = 4.0s 2019-04-19 17:54:35,517 - DEBUG - [Thread-11] UM.Backend.Backend._backendLog [101]: [Backend] [ERROR] Could not connect to the given address 2019-04-19 17:54:35,612 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onBackendQuit [811]: Backend quit with return code 0. Resetting process and socket. 2019-04-19 17:54:37,715 - DEBUG - [MainThread] cura.AutoSave._onTimeout [48]: Autosaving preferences, instances and profiles 2019-04-19 17:54:40,161 - INFO - [Thread-3] STLReader.STLReader.load_file [46]: Using NumPy-STL to load STL data. 2019-04-19 17:54:40,181 - DEBUG - [Thread-3] UM.Mesh.MeshData.calculateNormalsFromVertices [444]: Calculating normals took 0.004998683929443359 seconds 2019-04-19 17:54:40,184 - DEBUG - [Thread-3] STLReader.STLReader._read [97]: Loaded a mesh with 82644 vertices 2019-04-19 17:54:40,244 - DEBUG - [Thread-3] UM.Mesh.MeshData.approximateConvexHull [401]: approximateConvexHull(target_count=1024) Calculating 3D convex hull took 0.055002689361572266 seconds. 351 input vertices. 351 output vertices. 2019-04-19 17:54:40,325 - DEBUG - [Thread-3] UM.FileHandler.ReadFileJob.run [69]: Loading file took 0.2 seconds 2019-04-19 17:54:40,382 - DEBUG - [Thread-3] UM.Mesh.MeshData.approximateConvexHull [401]: approximateConvexHull(target_count=1024) Calculating 3D convex hull took 0.05100083351135254 seconds. 351 input vertices. 351 output vertices. 2019-04-19 17:54:40,403 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.addContainer [386]: Container [per_object_stack_2494788975640] added. 2019-04-19 17:54:40,452 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\transparent_object.shader]... 2019-04-19 17:54:46,288 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend.slice [228]: Starting to slice... 2019-04-19 17:54:46,289 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend.slice [246]: Going to slice build plate [0]! 2019-04-19 17:54:46,295 - DEBUG - [MainThread] UM.Backend.Backend._createSocket [227]: Previous socket existed. Closing that first. 2019-04-19 17:54:46,698 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [187]: Socket state changed to Listening 2019-04-19 17:54:46,740 - INFO - [MainThread] UM.Backend.Backend.startEngine [81]: Started engine process: C:\Program Files\Ultimaker Cura 4.0\CuraEngine.exe 2019-04-19 17:54:46,752 - DEBUG - [MainThread] UM.Backend.Backend._backendLog [101]: [Backend] Calling engine with: ['C:\\Program Files\\Ultimaker Cura 4.0\\CuraEngine.exe', 'connect', '127.0.0.1:49675', ''] 2019-04-19 17:54:46,834 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:54:46,850 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] Cura_SteamEngine version 4.0.0 2019-04-19 17:54:46,858 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] Copyright (C) 2018 Ultimaker 2019-04-19 17:54:46,867 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:54:46,880 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] This program is free software: you can redistribute it and/or modify 2019-04-19 17:54:46,889 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] it under the terms of the GNU Affero General Public License as published by 2019-04-19 17:54:46,898 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] the Free Software Foundation, either version 3 of the License, or 2019-04-19 17:54:47,137 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] (at your option) any later version. 2019-04-19 17:54:47,148 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:54:47,154 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] This program is distributed in the hope that it will be useful, 2019-04-19 17:54:47,160 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] but WITHOUT ANY WARRANTY; without even the implied warranty of 2019-04-19 17:54:47,165 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the 2019-04-19 17:54:47,171 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] GNU Affero General Public License for more details. 2019-04-19 17:54:47,177 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:54:47,184 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] You should have received a copy of the GNU Affero General Public License 2019-04-19 17:54:47,189 - DEBUG - [Thread-14] UM.Backend.Backend._backendLog [101]: [Backend] along with this program. If not, see <http://www.gnu.org/licenses/>. 2019-04-19 17:54:47,582 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onStartSliceCompleted [432]: Sending slice message took 1.2929794788360596 seconds 2019-04-19 17:54:59,398 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 4.0\resources\shaders\toolhandle.shader]... 2019-04-19 17:55:01,887 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._terminate [295]: Attempting to kill the engine process 2019-04-19 17:55:01,888 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._terminate [301]: Killing engine process 2019-04-19 17:55:01,894 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._terminate [304]: Engine process is killed. Received return code 1 2019-04-19 17:55:01,899 - DEBUG - [MainThread] UM.Backend.Backend._createSocket [227]: Previous socket existed. Closing that first. 2019-04-19 17:55:01,916 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [187]: Socket state changed to Listening 2019-04-19 17:55:01,930 - INFO - [MainThread] UM.Backend.Backend.startEngine [81]: Started engine process: C:\Program Files\Ultimaker Cura 4.0\CuraEngine.exe 2019-04-19 17:55:01,935 - DEBUG - [MainThread] UM.Backend.Backend._backendLog [101]: [Backend] Calling engine with: ['C:\\Program Files\\Ultimaker Cura 4.0\\CuraEngine.exe', 'connect', '127.0.0.1:49675', ''] 2019-04-19 17:55:02,000 - DEBUG - [Thread-17] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:55:02,006 - DEBUG - [Thread-17] UM.Backend.Backend._backendLog [101]: [Backend] Cura_SteamEngine version 4.0.0 2019-04-19 17:55:02,012 - DEBUG - [Thread-17] UM.Backend.Backend._backendLog [101]: [Backend] Copyright (C) 2018 Ultimaker 2019-04-19 17:55:02,019 - DEBUG - [Thread-17] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:55:02,024 - DEBUG - [Thread-17] UM.Backend.Backend._backendLog [101]: [Backend] This program is free software: you can redistribute it and/or modify 2019-04-19 17:55:02,030 - DEBUG - [Thread-17] UM.Backend.Backend._backendLog [101]: [Backend] it under the terms of the GNU Affero General Public License as published by 2019-04-19 17:55:02,035 - DEBUG - [Thread-17] UM.Backend.Backend._backendLog [101]: [Backend] the Free Software Foundation, either version 3 of the License, or 2019-04-19 17:55:02,040 - DEBUG - [Thread-17] UM.Backend.Backend._backendLog [101]: [Backend] (at your option) any later version. 2019-04-19 17:55:02,044 - DEBUG - [Thread-17] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:55:02,049 - DEBUG - [Thread-17] UM.Backend.Backend._backendLog [101]: [Backend] This program is distributed in the hope that it will be useful, 2019-04-19 17:55:02,054 - DEBUG - [Thread-17] UM.Backend.Backend._backendLog [101]: [Backend] but WITHOUT ANY WARRANTY; without even the implied warranty of 2019-04-19 17:55:02,058 - DEBUG - [Thread-17] UM.Backend.Backend._backendLog [101]: [Backend] MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the 2019-04-19 17:55:02,063 - DEBUG - [Thread-17] UM.Backend.Backend._backendLog [101]: [Backend] GNU Affero General Public License for more details. 2019-04-19 17:55:02,067 - DEBUG - [Thread-17] UM.Backend.Backend._backendLog [101]: [Backend] 2019-04-19 17:55:02,072 - DEBUG - [Thread-17] UM.Backend.Backend._backendLog [101]: [Backend] You should have received a copy of the GNU Affero General Public License 2019-04-19 17:55:02,076 - DEBUG - [Thread-17] UM.Backend.Backend._backendLog [101]: [Backend] along with this program. If not, see <http://www.gnu.org/licenses/>. 2019-04-19 17:55:03,013 - DEBUG - [MainThread] cura.TaskManagement.OnExitCallbackManager.triggerNextCallback [51]: No more on-app-exit callbacks to process. Tell the app to exit. 2019-04-19 17:55:03,018 - INFO - [MainThread] cura.CuraApplication.closeApplication [547]: Close application 2019-04-19 17:55:03,037 - DEBUG - [MainThread] UM.Qt.QtApplication.windowClosed [417]: Shutting down cura 2019-04-19 17:55:03,110 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._terminate [295]: Attempting to kill the engine process 2019-04-19 17:55:03,111 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._terminate [301]: Killing engine process 2019-04-19 17:55:03,120 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._terminate [304]: Engine process is killed. Received return code 1
  8. I'm printing with one material and removed the other material from the printer. I also set the second material in the Cura software to the same material as the printed material. However, your answer was still helpful, as it made me try to deactivate material 2, which did the trick. I hope this bug will be fixed soon. Thanks!
  9. Das letzte Foto zeigt, dass sich das Zahnrad vom Feeder ins Filament frisst, d.h. er will weiter befördern kann aber nicht und dann fräst er dir das FIlament an. Warum er nicht mehr weiter transportieren kann, kann mehrere Ursachen haben, verstopfte Düse (das hast du ja schon geprüft bzw. gereinigt) oder du druckst zu schnell und/oder zu wenig heiß. Bei hohen Geschwindigkeiten bringt der die Menge FIlament nicht mehr zum schmelzen. Weiters kann auch die Bowden Tube ein Problem haben, einfach einmal schauen ob die Filament per Hand gut durchschieben kannst. Feeder Spannung steht in der Mitte? Du siehst das an einem kleinen Marker am Feeder selbst. Zuführung um Feeder passt? Verhederte Spulen können das auch auslösen.
  10. bonjour gros soucis de plateau avec l'um5, après une impression qui a finie en catastrophe, le plateau est HS. explication des évènements: durant l'impression un morceau de support c'est détaché. le reste de l'impression (20h) a donc généré beaucoup de fil support en vrac dans l'imprimante. la dernière fois que j'ai observé l'impression, il restait 7h et tout était correct (sauf le fil support en vrac à l'endroit du support défectueux). le lendemain matin, l'impression est inachevé, la tête est remplit de plastique. heureusement la fin d'impression était proche donc peu de dégât dans la tête. le nettoyage c'est bien passé. sauf le plateau. en voulant faire le nettoyage sous le plateau, j'ai fait une monté plateau en manuel. et la c'est le drame. le plateau couine, fait des secousses rapide de quelques millimètres sans bouger. le bruit est inquiétant. la mise hors énergie et le redémarrage de l'imprimante se passe bien. mais dés que je veux bouger le plateau il fait les secousses. une idée ?
  11. Arya
    Problem with TPU
    Hi everyone! I have some problems to print with TPU95A, I try literally everything but it seems nothing change. I would like to obtain a simple parallelepiped scaffold (dimension: X=10mm; Y=10mm and Z=2mm) but the last layers printed are not perfect as if there isn't a good connection. I have changed a lot of parameters, read all forums and topics but nothing. The principal problem seems to be the non-adhesion between the last layers, as you can see in the pictures. There are some parameters that I use/used: Layer height: 0.1 but also try with 0.2 and 0.05; Line width: 0.35/0.27; Infill line: 1 mm; Pattern: grid; Temperature: 230° C (also 235 and 240); Speed rate: 11 mm/s; Build plate temperature: 60° (also try with cold plate and 70°); Flow: 100% (try with 120%); I also have modified some parameters for extrusion (also try without it) but nothing works. In addition a put some stick on the plate to have a good adhesion. Any suggestions?
  12. I really want to display the layer number, but I do not want to display the filename on LCD, there is no space in my LCD. I know I can use search and replace to replace to remove the filename, but I need to enter in every g-code change the search field, etc... In my understanding there should or might be an option to do this in the Configure Cura menu automatically. As this option does not exist yet, I will use the search and replace to do the job.
  13. I *only* use manual leveling. Once set, the leveling doesn't need to be messed with for months.
  14. Hey Tvb1996 did the profile work for the UM2E+ ? I just came across this thread after playing unsuccessfully for the last year.
  15. Soooo, why dontcha tells us how you really feel 😂 In all seriousness, it is very easy to work in imperial and send out as metric. Just takes a bit of awareness so that there is not missed step. In one of my software packages (3DS Max) I can use, say, metric, and type measurements in imperial and the conversion is done for me to the proper units. I also work a lot in metric. Depends on the needs of project I am working on. If I am doing architecture work, I work in feet and inches and then convert the scale to a printer size.. When I am just squirreling about modeling I work in native metric. I also have two 'stage' files that holds a lined off cube that defines the printing area of my S5 and UM3E. This allows me to place my objects or check size restrictions.
  16. Oui elle a un intérêt sinon je ne l'aurais pas faite 😂 C'est pas pour guider l'entrée du feeder mais pour éviter que le fil ne sorte de la bague métallique d'entraînement. C'est la pièce dont j'ai mis une image dans mon message du 23 mars, je t'envoie le stl plus tard. J'ai une buse de diamètre 0,4 et j'imprime de 0,4 à 0,1.
  17. It doesn't. The plugin effectively changes the z-coordinates in the gcode, without knowing anything about how the firmware handles these z-coordinates. So if the firmware somehow adds an offset, the two offsets will both affect the physical height. The z offset is limited to the negative of the Initial Layer height. Putting a lower value in there would result in negative coordinates for the z axis, which at best would be caught by the firmware and result in an error during printing, and at worst would lead to the nozzle being pushed into the build plate, damaging the printer. For more information about how the plugin works, see the readme: https://github.com/fieldOfView/Cura-ZOffsetPlugin/blob/3.5/README.md
  18. Ahoeben, I am wondering if I can ask you a question ? How does the z offset plugin relate to the z home offset in the eeprom. Does it add, subtract or replace ? In other words, could I add offset in the eeprom on top of your plugin offset to achieve a greater range ? I prefer adjusting for things like a nozzle change (resulting in a slight height change) in software rather than to recalibrate the bed. Thanks PS.: I am using a CR-10S printer
  19. It should, yes. I can't test it with all printers though. Specifically, I don't have a delta so I never tested the plugin with one. I don't know if there is an issue with using G92 with a delta running Marlin. How old is your Marlin? It could be this issue: https://github.com/MarlinFirmware/Marlin/issues/2106
  20. Hi Geert_2, yes i understand what you say. I know it was clear thats impossible to print magnetic materials. I think so strange forward of my idea to use it for my prototypes 😉 I think it it not possible to magnetized the material direct in the near of the nozzle. The magnet will click on the nozzle. I do a small test with one of my magnet´s. After a distance < 4 cm the magnet jump up to the nozzle. The second problem is the iron based filament will rusty after a small time. So i must print the first 1mm with TPU then the next 3 mm with iron-filled filament the 1mm with Carbon. I think the iron-filled filament in 3 mm it not strong enough to hold my parts. But i will test it the next 14 days. Do you have a recommendation for ferrous filament. Thanks Michael
  21. Hi Foehnsturm, this should be able to work on the UMO, right? Yeah, yeah, it's an oldie, but my heavily modded UMO (heated bed with PEI, E3Dv6, your own pulley upgrade, etc, etc) is still working its magic, so no reason to give up on it just yet. Still loving the original, although I do have other machines. Any thoughts on how to get this running on the UMO? I'll also be glad to get my hands on one.
  22. Thanks for your reply. I will have a look at the SD card slot. And by pointing me in this direction, I realised that I now use a SD slot extension cable, which also may cause corrupt the data coming from the card.
  23. Yeah, we saw both problems in fact, Yesterday I set it to weekly and it printed way too close - altough we leveled one Minute before.
  24. It worked for me too with "every week". The only setting that IS different is "Never" which now turns active leveling completely off (to be manually leveled properly).
  25. You are still confusing "plugins" and "scripts". What used to be a "plugin" in the old Cura is now called a "script". You might infer from that that what is now called a "plugin" is something different. A large part of the functionality of Cura is implemented as a "plugin". Instead of the program being a single block of code with all functionality built-in, it consists of a smaller "core" which is extended with plugins (which can - in theory - be disabled/removed). These plugins add different types of functionality. For example loading different 3d formats is implemented as plugins, but also connecting to printers (over USB, or over the network). Even the different "views" such as the normal view, layer view and x-ray view are plugins. Even the functionality to run "scripts" on the created gcode is by itself a plugin ("PostProcessing"). Most of the plugins that you found are enabled by default, so you never need to worry about them. The plugins that are available in the Marketplace are plugins of the same type (NOT postprocessing scripts).
  26. The " M117 Tail_1.0 layer: 0 " line that you quote is put there by a postprocessing script ("Display filename and layer on LCD"). This script has a setting called "text to display". If you enter anything at all there, that will be used instead of the filename.
  1. Load more activity
Important Information
