333 -
2
from what I can tell, this technology is going to be geared towards industrial printers. I doubt we'll see a desktop version of this technology any time soon.
I'll post some more Form1+ experiences tomorrow.... It's been hit or miss lately, but I'm sure it's just me. There are so many different techniques to producing a good print. I don't want to just report failures because of my inabilities.
So... hold off on canceling my order???
The Meshlab video looks easy enough to stitch scans, which is a plus.
I got our Fuel3D a week back and have made a lot of scans, we love the unit and got some very good face scans out of the device. I was also frustrated with the software, but now use MeshMixer (free beta) to refine the print after the processing. It's not a quick process, but it does work.
very interested, can you send me some links, etc...?
thanks,
-Pat
damn....
My fuel3D scanner is shipping early April. I was hoping that it was going to allow me to scan to my hearts intent, but from what you posted, I'm going to have my work cut out for me :(
Also, I had no idea that I would have to pay for software? That sucks.
Keep us posted
Remember that as the extruder extrudes filament, the filament is being bonded to the layer underneath. With this comes a bond between print head and part. When the part gets to be so tall, the bond the print head is creating starts to move the tall structure in the XY plane. When you add something like a "T" support, the support prevents the print head from moving the tall structure as much. Anytime your print starts moving, even if it's very very little, you lose a lot of print quality. That tall pat will never be in the correct spot for the next layer.
OK this is weird ??
Printed this tube (on right) straight up so it would make a perfect circle. Turns out, it's too tight... all the other parts in the assembly were fitting, so I thought "What the hell"?
All the other parts that were in the assembly were printed at a tilt, so I thought I'd go back and print the tube at a tilt (print on left)
Sure enough, the part that was printed on a tilt is within a tenth of a mm from the specified part (28.02mm)
The part on the right is nearly 1 mm too small!!! Even though it was printed at a more uniform angle.
Will have to get into two separate mindsets... ultimaker printing (vertical prints=good) and Form1+ printing (vertical=bad)
I will have to do more testing, but this is definitely something to watch out for...
Sla printers usually tilt parts to prevent the part breaking the resin surface tension in a large area, which would produce a large motion on resin. This is not good on resin printers, so they tilt parts, at the expense of having much more support.
Yes, there is almost always support material used, but it is entirely different than FFF supports. You're left with little dots...half of which require no post process and the rest is usually fixed with a quick swipe of an e-xacto blade. At first I was put off by it, but it's not too bad.
@solidprint3d, now that you have been playing with the f1+ for a while, how are you finding the costs? In comparison with the um2 filament.
I've done the math, factoring in 1L of resin and a spare tray for every 1L, so $210 for 1L. Apparently, with losses in post process, people are reporting getting only 750 to 800 ml out of a 1L bottle. So a conservative estimate would be about 26 cents per gram (1059g/1000ml). Filament-wise, if you spent $35 on a 1000gr roll it comes to about .035 cents per gram. So, 7.5x more expensive than FFF. Keep in mind, you don't print big bulky parts at this price... rather small fine detailed parts. I've actually got a lot of parts lying around and half a bottle left, so it goes a long way.
Brilliant feedback, thank you SP3D!
The F1 was my very first choice of printer back when I was deciding to take the plunge into the 3D world. The reasons as you have stated, cost, messiness, UV post work etc were all the things I read about back then which put me off, and I chose the UM2.
That UV thing would bug the hell out of me ( come on, I live in the UK sun is limited lol ). It`s also odd how the F1 prefers to tilt your print orientation rather than leaving it flat.
I can see with the level of excellent small detail how the F1 and a UM2 would be a great combo!
Thanks for the insight.
Yes, the UV post cure can be a pain, but what people are doing is buying the $75 UV sterilizing cabinets and placing the parts in there to cure. Supposedly, it cures the part "cleaner" than the sun in that the parts don't yellow as much, shrink, or warp as much. (I haven't noticed much warping using the sun).
I'm also getting the hang of the post process work and cleanup. I've dedicated a space just for the F1+ and it's cleanup tools. It's actually not that bad... I don't wear gloves or aprons, and I manage not to get the resin on me or everywhere else. Plus, I love that Dr. Evil mad scientist feeling you get pulling parts out of goo
When printing tall thin objects, I noticed that the part tends to wobble/move to one side during printing, due to shrinkage of the printed layer,
you could try adding a support rib from the top of the print to the platform, that can be cut away later.
I agree.
Whenever I see a part like this, I add a .42mm ribbed wall. doesn't have to be dead center, but creating that "T" gives it much more stability.
But it's so cute.
It's great for people who have to show 3d printing off for whatever reason. It is small and has a travel case. I imagine it would be pretty useful for professors/teachers. Also some people don't need to print large things. I rarely print anything over 120mm.
But a heated bed would be nice.
I must be an odd-ball, cuz the regular UM2 is pretty darn portable. I've been going to the schools and doing 3D printing demonstrations... I just throw the UM2 in the back seat No fancy mini version with a case needed!
check out my method I posted here
I'm finding lately that more and more often, ABS print temps are dropping. When I first started 3D printing, 260 C was absolutely necessary... now I'm getting away with 230~235 with most quality filaments (additives?)
print bed should be 100~110 (I use 100 C with the ABS slurry)
enclosing the chamber helps as well (especially for warp-prone parts) but isn't absolutely necessary for smaller parts. Turn fan to 0~25% (not the 50%... although that's not really relevant for you becasue they shouldn't be coming on anyways until a couple more layers in)
If it still won't stick, send the crap back cuz it aint ABS
swap at z plugin.
https://www.youmagine.com/designs/swap-at-z
Download it and copy it to your Cura Plugins folder...restart Cura.
To use:
Set the model up for the 10% fill you'd like. Save the model to your hard drive. (ex. C:\10fill.gcode)
Now set the bottom layer up to 100% infill. Go to plugins tab and initialize the "swap at z" plugin.
Enter height you want the 10 percent version to start (ex. 6.2mm)
Enter the name you saved the 10% gcode as (C:\10fill.gcode)
*** Make sure you add the ".gcode" *****
Layer view doesn't always show updated gcode
works with multiple gcodes
Be sure to give pmdude a big thank you!
This might sound odd, but a client of mine had his Ultimaker go out so he brought his file and a roll of eSun Red ABS over for me to print his part with.
I was shocked at how well it turned out, primarily the layer adhesion and surface finish. Just to make sure I printed a .42mm walled ring @ 1" diameter x 3" tall. Generally, if you squeeze an ABS ring printed with such thin walls, you will hear cracking immediately and break it soon after (at least with IC3D, Ultibot, Jet, etc. etc. filaments) . The ring printed in eSun was the toughest yet.
I know you're saying "well colorfab this, matterhackers that" but come on, at $26 a roll and free shipping with amazon prime, I'll most likely be loading up on some of this stuff.
I've been asked how do the print times compare , Um2 vs. F1+
Here are the 3 gears I printed this morning. First image is print times in Cura @ .05mm layer height.
Here is the print time in Preform
Interestingly enough, and I have no idea why, the F1+ actually printed the gears in well under 3 hours, opposed to the 3 Hr 13 minutes preform shows. More like 2.5 hours.
I thought this was just a fluke, so I loaded another, larger model. First image is the Cura print times @ .1mm layers
Here is the same model at the same layer height.
Half the time! I've seen posts where people are saying the F1+ generally takes longer than other printers, but from everything I've printed so far, it's much faster? I know there are a ton of variables like print speed I can tweak in Cura, but I like to keep the print speeds conservative so the part actually turns out good. Also, .1mm layer height might be a little fine-detail for a part like this, but it is a customer part that needs to look good.
Will keep you posted on further developments
I just put the parts in sunlight for about 20 minutes. I live in Florida, so there's no shortage of sunlight. But yes, it is recommended to post cure in UV light, or "near ultraviolet" light. For the prints that finish at night, I wait until the morning to cure... seems to work just fine.
Update
As I said earlier, my brand new Form1+ conked out on me after 3 prints. Some sort of laser malfunction. Formlabs sent a new printer (different serial numbers...I checked :: ) and it's been running great for a couple of days now.
I took a look at some of the recent parts that I printed on the UM2's that didn't turn out that well. I tried them on the Form 1+ to get a better comparison.
Here is a gear I printed in red PLA that I just could not get to print well. I ended up printing 8 of these or so in multiple configurations, and even changed the pitch of the teeth to compensate for curling during the UM2 prints. Printed another on the Form1+ and it came out really nice first try, with original pitch.
here is the side-by-side
Another thing I wanted to test was a structural part. I've read some people having issues with tolerances, so I thought I'd try this little washer handle part to check dimensions. The rod fits like a glove, and the overall dimensions are accurate.
Being an Ultimaker lover, I thought I'd demonstrate the real advantages of this blessed union between UM2 & F1+. Here is a little project I'm working on for my son. It's a 15" (38cm) Unlimited Hydroplane. There's now way in hell I'm printing the bulk of the boat in $150/L resin. This is where the UM2 shines... brightly . All of the Large pieces are printed on the UM2 in ABS, but the UM2 just cannot print the detailed parts.
This is where the F1+ shines. I was simply blown away at how small you can actually print. Here is one of the sideview mirrors. No post process.
And the prop, which would not print on the UM2 unless I made the blades much thicker.
I will note that for general model making, clear might not be the best color. As you can see from the prop, I had to prime it just to see what post process work needed to be done. Interestingly enough, the same primer I use for my UM2 prints is WAY too thick for F1+ prints. I would recommend a very thin primer as your not really having to hide layer lines.
So far I'm finding that where one printer lacks, the other makes up for, making these 2 printers a perfect pair.
I think I've only ever printed one or two items at .02mm layer height. I find that .05~.06mm works just fine if you're looking for smooth prints, but don't want to waste time.
Just to show time difference when printing 1cm cube (50mm/sec speed)
.1mm = 11 minutes
.06= 18 minutes
.02 = 52 minutes!
I also found that in the couple of prints I did at .02mm, there were some noticeable spots where flow rate resulted in some abnormalities, probably filament diameter related.
If you find a way, let me know
For now, I manually add brim in the modeling program when it needs to be controlled. If my initial layer height is set to .2mm, Ill add a .2mm brim to the part and cut out areas I don't want it.
use the swap at z plugin... I believe you'll have to download it, as I dont think it comes standard with cura.. basically it merges 2 different gcodes together. you can have 1 gcode with settings for a thick bottom, and when you get to, say, 3mm, you can tell it to switch to the second gcode (the specialized one)
Praise Jesus, praise the lord halleluiah, amen amen amen
Bullets were printed at .05. The only reason the UM2 print looks bad is becasue at each split it has to retract. If it were a perfect ring, it would look a lot better, and of course, the camera exaggerates things. Keep in mind these are 15mm tall, so there are quite small. I picked the worst of both samples (had to because the client took all the best ones). The UM2 sample has blobs from retraction were the splits start, and the Form 1+ has the supports snipped, but not razor bladed smooth, as well as the splits being fused (like explained earlier)
When I get the printer back from Formlabs in a couple of days, I'll do some pretty in-depth side by side comparisons.
They're not bullets, they are sabot round prototypes (they are hollow and encase a smaller bullet). It's one of the first prints I did so It's all I had on hand for a comparison of a side by side for UM2 and Form 1+, but I think it demonstrates the print differences. Making a mold with the slits would be almost impossible. I was just making a cleanup time comparison with the whole 500 thing. Again, acetone washing takes time. My point was that I clipped off 6 supports, and the part is ready to go...period.
Yes, the Form1+ is definitely more expensive to run, but it opens up avenues that you wouldn't otherwise have with the UM2 alone, such as castable resins for sacrificial molds, highly detailed small parts, clean and legible text on prints, glass-like prints (with some polishing), and very nice organic modeling. The Form 1+ is not for basketball sized prints. There are also people mixing cheaper resins with form1 resins to lower costs. There are tutorials on re-coating the trays yourself for $10. I'm sure resin prices will go down, and Formlabs is purportedly working on a tray that doesn't need to be replaced as often.
I disagree that it's only for Zbrush experts. I'm designing 1/84th scale model railroad equipment for a client that just cannot be printed on the UM2. I've also seen architectural buildings on the form 1+ that has all the details of the building intact , whereas a hotel I'm designing for a client misses all the detail in Cura, but Preform shows all the detail. Haven't tried it yet, but it's a night and day difference in slicing views.
I was wondering what that did
A surface model has 0 thickness, so it's not actually a solid or closed mesh. You'll have to use the thicken command (that's what inventor calls it, not sure what it's called in Rhino) to apply thickness to the surfaces. This will turn it into a measurable solid. I would start with a thickness of .42mm or greater, depending on how many passes you want the print head to take.
*Note: The printer will always take at least 2 passes.
In response to Sanders asking me to write something after I received my Form1+
So after Ultimaker announced they weren't coming out with the dual extruder, I thought I'd try another printer since I was in the market for another one.
I decided on the Form 1+. I have 2 UM2's which can handle the large and tough parts, so I thought I'd go for something that could produce highly detailed parts, even though I'd have to sacrifice build volume. I suppose I could split large parts and glue together if needed, but keep in mind, the resin is $163 a bottle, shipped.
Here is my first print. Both are printed using the same resolution. The part on the left is black PLA from my UM2, the one on the right is clear resin off the Form1+.
Needless to say I was Impressed! The way the Form1+ prints just makes the layer lines all but vanish, and there's no boogers from retraction. An added benefit is that the part is super clear, and with minimal effort I can actually get it looking glass-like.Print times were probably a little longer on the Form1+, but not much so.
Price is a different story. As you can imagine, the black PLA part on the left (which is the size of a 9mm bullet) is very, very cheap to produce. Talking a couple of pennies here. I did the math, and the Clear resin part on the right cost just over 17 cents.
Now, you might say "Holy crap that's a lot more" but keep in mind that I have almost NO post process work to do on the clear resin print, whereas the black PLA needs about 2 or 3 minutes worth. Now, if I have to make 500 of these, that's 1500 minutes worth of prep, or 25 hours! I'd be happy to pay extra for the resin if it saves me 25 hours of prep work (even if it only saved me 10 hours, that's what $200+ worth of labor).
Supports are also amazing on the Form1+. The software automatically tilts the object to the correct angle. No, you don't print flat like an FDM). It then goes on to automatically add supports, much the same way Meshmixer does, but easier. You can even easily edit the supports, so if it places one where you don't want it, you just move a dot around. Super easy. On top of that, they're very easy to remove. Comparing it to breaking off support from a PLA print is like comparing writing a novel to writing your signature. OK, I might be overdoing it with that last statement, but it really is easy. While I'm on supports, I might as well mention how the printer generally needs a lot less of them. You can actually get away with a lot more on the Form1+ than you can FDM machines. Impossible looking FDM prints can be done on the Form1+ with minimal amount of supports.
Now for the bad. It isn't as dimensionally stable as the UM2. Both the prints have slits in them. The slits in the black UM2 print are dependably reproduced. Some of the clear prints fused the slits together. Not a big deal for this particular print becasue I just enlarged the splits a little so they didn't fuse. I haven't printed any large prints yet that need to have tight tolerances, but I predict more variation than the UM2.
It's also a lot more, shall we say, messy, than an FDM printer. The resin smells god awful, and if it gets on anything, it's like trying to clean maple syrup up. I can see how over time, all my tools are going to have maple syrup on them, which is a little difficult to clean up. You'll also needs large amounts of high grade Isopropyl Alcohol on hand to operate. The parts need to be rinsed in one container of alcohol, then switched to another and rinsed again. This is a personal preference, but I'd much rather small acetone spills than Alcohol spills. The acetone evaporates and dissipates quickly, whereas the alcohol just lingers for a while. The build tray actually submerges itself in the resin, so I have no idea how I'm going to clean that up as the resin starts to harden from natural sunlight . Probably just buy a new one, $99.
Which brings me to another down side. Operational cost. When I went to buy the Form1+, I had no idea that the resin trays needed to be replaced very often. We're talking 1 to 2 liters worth of resin, then it's time for a new tank, $60.
The cool castable resin is the same price yet only comes in half-liter sizes. As mentioned earlier, you'll have to shell out $99 for another build platform (before shipping).
And the last downside I can think of is the post curing. That's right, you don't just simply pull the part out of the printer. You pull it out, drown it in alcohol...twice, then you have to cure it with UV light. I used the sun (about 30 minutes to an hour) but if all your work is done at night you'll need to get a UV curing chamber or build one yourself. It's not that big of a deal for me, but it's an added step, and it looks kinda red-necky having crap outside curing all over the place
Unfortunately, My printer had to be shipped back this morning due to a laser malfunction. I've been assured that I'll have a replacement in 6 days. Customer support seems to be good. Unfortunately it broke when Boston was being hit by the snow storm so employees couldn't make it into work for days. Just my luck.
Still, though, it sucks that its only a week old and died. I've read several horror stories about people going through 3 printers before they received one that finally held up. Those stories tend to gravitate towards the original form 1, but it's something to think about.
In conclusion, I really enjoy the Form 1+ for it super-fine detail, clarity with clear resins, ability to use castable resins for metal casting, nice software, and overall ease of use (if not messy). It's a great companion to the UM2's, and would be a great tool for anyone wanting to break the boundaries of an FDM-only setup.
Form1+ Experience
in UltiMaker 3D printers
Apparently, my tray wasn't perfectly level in my cabinet and spilled $50 worth of resin everywhere. Lesson Learned there
as for the printer, I'm still having problems. They say you are supposed to use canned compressed air to blow the mirrors off periodically. I've been doing just that, but it appears that my canned air is leaving a residue on the mirrors. Looks like a purple film. I had to get PEC*Pads delivered to me from formlabs to clean the mirrors. Just cleaned the mirrors this morning and have a print on now, so we'll see if that fixed the problems I was having... which was basically "ragging", or at least that's what formlabs calls it. It's where the flakes of excess material hang off the prints and degrade print quality.
Another issue I had in the past week was one of my $60 resin trays started to disintegrate at the back left corner. I have no idea why, as I'm very careful with the trays. Luckily, they sent me a replacement tray free of charge.
Basically, formlabs has been great in helping me sort out the kinks, but with shipping times, and back and forth communication, it's taking forever to get to a state where prints turn out dependably.
