17 hours ago, CostumeBiz said:
M907 E1400 ; increase extruder current
G28 ; home all axes
G1 X20 Y10 F3000 ; bring extruder to front
G92 E0 ; zero the extruded length
G1 Z10 ; lower
G1 E19 F200 ; purge nozzle quickly
G1 E26 F60 ; purge nozzle slowly
G92 E0 ; zero the extruded length again
G1 E-5.5 F400 ; retract
G1 X190 Z0 F9000 ; pull away filament
G1 X210 F9000 ; wipe
G1 Y20 F9000 ; wipe
G1 E0 ; feed filament back
Here's the starting script from Simplify3D
I recommend to remove the first line (M907) as soon as possible. This command increases the motor current for the extruder motor to 1400mA - that's too much and asks for trouble...
(i think the topic "overheating of stepper drivers" was already mentioned). It's only changed for the e-axis - but who knows....?
The default is 1250mA (or 1200?) - i use 1100mA for years without problems.
For older versions of S3D this was the standard script, but newer versions do not longer add this line to the start script (AFAIK).
4 hours ago, CostumeBiz said:
I have changed the jerk and acceleration settings on my CR10 for better prints can I do the same with Tinker Marlin?
Yes, but you don't need it for this purpose. You can adjust the motions settings with the standard firmware too. On an UM2 you find it in the menu:
Maintenance -> Advanced -> Motion settings
28 minutes ago, CostumeBiz said:why would the print go perfectly using Cura.. and wonky half thru using Simplify3D?
To rule out some things: can you show us the starting script from the S3D settings?
It looks like you have installed a firmware for the UM2 extended.
As a first step i would double check the firmware version and/or re-install the correct one for your printer.
- 2
2 hours ago, kmanstudios said:
You can unhide them there.
Not for gcode flavor "Ultimaker 2".... - retraction length and speed are adjusted on the printer itself in this case.
This gcode flavor is not suited for other printers than the UM2(+) series.
Sounds like you should subscribe to the fbrc8 youtube channel...
Calibrating the Lifting Switch: https://www.youtube.com/watch?v=O1hGURM8X7g
Belt Tightening--Long Belts: https://www.youtube.com/watch?v=zNLt8S9hjjc
- 2
Die Silikon-Abdeckung sollte es bei jedem Ultimaker-Händler geben, kosten ca. 1 EUR netto pro Stück. Wo hast Du den Drucker gekauft?
Die Bezeichnung ist "2161 - Silicone Nozzle Cover".
Ich vermute, das wäre auch die Lösung für den "HEATER_ERROR', dafür ist die Abdeckung u.a. auch wichtig.
Another common reason is a worn out PTFE coupler (it's a consumable). Have you checked it?
There's a picture at the end of this topic: https://ultimaker.com/en/resources/21477-how-to-fix-under-extrusion
Instructions for Replacing the PTFE coupler (from 3DVerkstan)
A: What is the filament brand: colorFabb
B: What is the type of filament: ngen
C: What is the diameter of the filament: 2.85
D: What is the weight of a full spool: 1025g
E: What is the inner diameter of the core? 52.9mm
F: What is the outer diameter of the core? ~105mm
G: What is the outer diameter of the whole spool? 200mm
H: What is the weight of an empty spool? 260g
I: Width of full spool (only when it is completely full because it can expand) 55.0mm
J: Width of an empty spool (only when almost or completely empty) 55.0mm
A: What is the filament brand: TwoBears
B: What is the type of filament: BioFila PlaTec
C: What is the diameter of the filament: 2.85mm
D: What is the weight of a full spool: 790g
E: What is the inner diameter of the core? 26.5mm
F: What is the outer diameter of the core? ~79mm
G: What is the outer diameter of the whole spool? 190mm
H: What is the weight of an empty spool? ~170g (cardboard with plastic core)
I: Width of full spool (only when it is completely full because it can expand) 68mm
J: Width of an empty spool (only when almost or completely empty) ~66mm cardboard (the plastic core is 70mm wide)
A: What is the filament brand: PolyMaker
B: What is the type of filament: PolySupport
D: What is the weight of a full spool: -?-
E: What is the inner diameter of the core? 55.0mm
F: What is the outer diameter of the core? 68.0mm
G: What is the outer diameter of the whole spool? 150mm
H: What is the weight of an empty spool? -?-
J: Width of an empty spool (only when almost or completely empty) 68mm
Hast Du schon die Z-Position für die beiden Teilobjekte kontrolliert?
Oder ist für den "Text"-Extruder irgendetwas für die "Horizontal Expansion" für den ersten Layer eingestellt?
Wie sind die beiden Teilobjekte designed? Ist der Text aus dem ersten Objekt ordentlich ausgeschnitten, oder überschneiden sich die beiden Dateien?
Je nachdem was zutrifft, könntest Du die verschiedenen Optionen im Abschnitt "Mesh Fixes" durchprobieren.
On 4/6/2018 at 11:11 PM, zerspaner_gerd said:
Ich persönlich vermute eher die Geschwindigkeit und die Beschleunigung/Jerk. Cura hat ja eine Funktion die setzt je nachdem die Beschleunigung Jerk runter bzw. auf bestimmte Werte.
Du solltest diesem Hinweis von Gerd mal nachgehen. Diese speziellen Einstellungen auf deinem linken Screenshot zu "Beschleunigung" und "Ruckfunktion" hat S3D nicht als einstellbare Parameter.
Das lässt sich auch in Cura komplett abschalten - das "Häkchen" dafür scheint aber bei Dir ausgeblendet zu sein. Mach das doch mal sichtbar, schalte die beiden Häkchen aus und teste, ob es die Rillen dann auch mit Cura gibt. Falls ja, hast Du den Unterschied gefunden...
Das hier sind die Einstellungen, die ich meine - die deutsche Übersetzung kann dir @zerspaner_gerd vermutlich sagen...
Vermutlich ist "Retract at Layer Change" noch aktiviert, das sollte noch ausgeschaltet werden.
Ich weiß nicht, wie das auf deutsch übersetzt wurde, sollte aber mit der Suchfunktion und "Rückzug" als Begriff gefunden werden (oder so ähnllich...).
13 hours ago, samtaylor said:
i noticed the stepper motors dont hold position when paused. i screwed up 2 prints changing filament by bumping the extruder across and one other the heated bed cables seem to have pulled the bed out of alignment when the steppers went to sleep. is there a fix for this?
That's a question for the manufacturer of your printer / firmware. Perhaps there is an inactivity timeout set for the stepper motors?
For Marlin firmware this can be changed with M85, but it really depends on your printer's firmware.
a cool thing you can do, which is heat the end a bit and pull until you get a nice center taper and just snip the very end off and it will feed into the mechanism much easier.
That was not me who told this to you, but it sounds like a good idea
A straight first piece of filament and a chamfered tip is usually sufficient for me, no need to lift the lever.
The stepper motor has to be moving of course - @Jesse Marcel it sounds like you are not using the material load / change "wizard" from the printers menu - for any special reason?
8 minutes ago, conny_g said:
Looks like the nozzle is unscrewed and flooded with filament....
Fascinating...
it looks like it is supposed to be so -
The easiest way is to add a M302 command at the beginning of the gcode file or to your start gcode.
If you use Cura: you can switch the GCode Flavor to "Marlin" in the machine settings. This makes the start script available for customizing.
2 hours ago, SandervG said:
By heating up your heaterblock to approximately 150ºC you should be able to pull of pieces of plastic after a few minutes.
But keep in mind that 150°C is hot... better use gloves and a pair of pliers / tweezers
The nozzle looks interesting - is it something special?
@porsche1 Because you mentioned your "kit" a few times: I hope you are aware that your "UM2+ kit" is not produced nor in any kind related to the Ultimaker company.
Ultimaker has never produced or sold printers of the Ultimaker2 family as a kit.What you probably got is a cheap copy where someone (illegally) painted the Ultimaker brand name on.
That does not mean that you are evil (as the buyer), but you should keep it in mind if it comes to questions like serial numbers and official support...I hope it was not soooo expensive (or you were duped somehow...)
- 2
10 hours ago, rhaven said:
The official extrusion upgrade kit extruder housing comes with an aluminum backplate now. So when attaching it to the feeder-mount.stl the screws needed to be countersunk to fit m3 screws under the aluminum backplate.
AFAIK you don't need the aluminum plate. Just leave it away.
10 hours ago, rhaven said:Is there any way to get a bed leveling sensor into the Mark2 firmware?
Well, the underlying Marlin that the Ultimakers use is quite old - i doubt that there's an easy way to integrate such things.
And as conny_g said - the demand is very low - the buildplate position of the UM2 is very stable and rarely needs a calibration.
Are you swapping the glass plates very often or why do have a need for such a sensor?
What's your requirement - only calibration of the z-position or true active / auto leveling?
40 minutes ago, GFlow said:
I think its the plastic bracket hitting the upright z bearing. I don't know how to adjust it however.
Well, the sliding block at the back is just slanted a bit. You can twist it back in place. And while you are at it - take sure that the rod does not stick out on the back of the sliding block. That's all. The glorious @fbrc8-erin made a video:
- 2
I can not check it, because i'm not able to get the 3.3 BETA running...
But the setting is called "Print Sequence", the search term "seq" is sufficient to show it up.
5 hours ago, harley573 said:
What is the extrusion upgrade kit for the conversion?
How to install the Extrusion upgrade kit
In the last picture it looks like the big nozzle is touching the fan shroud, if there's no gap between the neck of the nozzle and the fan shroud, the threaded part of the nozzle is probably not longer sealed against the teflon coupler.
@harley573 obviously you still use the old fan shroud. You don't used the extrusion upgrade kit for your conversion, right? And you use a nozzle type that is not intended for the Olsson block. Is this a nozzle from an Ultimaker Original?
In short: are you 100% sure that the reason is not just the wrong nozzle?
Sorry, but i can not get the Win64-Version to run. It crashes immediately after a printer is selected.
Log file: cura.log
Cura fails to slice properly when loading more than one part?
in UltiMaker Cura
https://community.ultimaker.com/topic/20748-cura-deleting-pre-modeled-supports-for-a-print/?do=findComment&comment=194799
