Content Count
2,577 -
52
Calendar
5 hours ago, 3dnick said:
I need to be able to relocate Home position at the end G code to facilitate other activity.
That's a quite unspecific question, ...or is it a question at all?
The first thing that comes to my mind is...
well... adjust the end-script (in the machine settings dialog) to your needs and you're done.I guess answers will get more specific if you elaborate the task a bit more. 🤷♂️
10 hours ago, rayholland said:
Would changing the line '#define HEATER_BED_PIN 4' to '#define HEATER_BED_PIN 3' in the pins.h be sufficient?
Probably yes. I would swap the pin numbers between HEATER_1_PIN and HEATER_BED_PIN
Take sure that you are in the correct section (MOTHERBOARD == 72) and it should work.
2 hours ago, rayholland said:
So, i'm thinking, using the Tinker firmware, is it possible to use the 'heater2' terminal (not occopied) on the mainboard for the original headbed?
The buildplate heater draws a lot more current than a hotend. Dunno, but you should be absolute sure that the capability of the outputs is really the same before you change anything.
There are probably only minor things to change on the software side, but you have to compile a custom firmware in this case.
The replacement pattern is {build_volume_temperature} (the exact spelling is very important),
this should be replaced by the configured temperature:
M6013 {build_volume_temperature}
see here for a full list:
http://files.fieldofview.com/cura/Replacement_Patterns.html
@ahoeben may correct me, if I'm wrong...
1
Cura loads post-processing scripts from both places on startup. The scripts folder in the configuration (as described on the GitHub page) is intended to be used for those custom scripts (AFAIK).
If the python script doesn't show up you will probably find the reason (or error messages) in the file "cura.log". Cura reports a lot of stuff there, just search for the file name of the python script.
8 hours ago, PhiGide said:
Im Drucker selbst habe ich das Firmware Update gemacht, wie es Bondtech wollte.
Nur installiert oder auch den "factory reset" durchgeführt, wie in der Anleitung?
Hat Astroprint auch ein GCode Terminal/Konsole?
GCode M503 gibt alle aktuellen Einstellungen auf der Konsole aus. Das würde zur Kontrolle schon mal helfen.
Mit M92 können die steps/unit zur Not im (Astroprint-/ Cura-) Startskript auch manuell gesetzt werden, dann braucht es nicht unbedingt einen factory reset.
Edit:
Oh - und kontrolliere mal, ob in den Startskripten schon irgendwo M92 - Befehle drinstehen, dann muss das dort auch angepasst werden.
Allerdings: beim Umstieg von UM2+ auf Bondtech-Feeder werden die Steps von 369 auf 311 reduziert. Wenn das nicht geklappt hat, müsste jetzt eigentlich zuviel extrudiert werden...?
Der Stepper-Motor ist der Originale vom UM2+, oder irgendetwas anderes? -
Du hättest vielleicht erwähnen können, um welchen Drucker es geht...
Beim Ultimaker 2(+) werden die Materialprofile standardmäßig am Drucker eingestellt.
Bzw. aus Cura-Sicht: wenn in den "machine settings" der GCode-Flavor auf "Ultimaker" steht, werden keine Temperatur-Befehle generiert (u.a.).
Nur wenn der GCode-Flavor auf "Marlin" geändert wird, übernimmt Cura die volle Kontrolle und generiert eigene Start- und End-Prozeduren, sowie die Material-spezifischen Einstellungen.
Beim Drucken von sd-Karte muss das am Drucker jeweils auch nochmal bestätigt werden.
Hilft Dir das weiter?
Der BB-Core ist ausschließlich für PVA vorgesehen. Daher werden in Cura vermutlich keine Profile für andere Materialien vorhanden sein. TPU 95A soll mit einem AA Printcore verwendet werden.
Siehe auch:
https://support.ultimaker.com/hc/en-us/articles/360011940440
Zitat:
"You will need an AA print core to print TPU 95A on the Ultimaker S5, Ultimaker S3 and Ultimaker 3."
1
The model is overlapping with the prime tower, so...
switch the prime tower off (if you don't need it), or move the model (or the prime tower) to a different position.
3
3 hours ago, zet said:
And if there a setting allowing to make sure bridges are printed across the shortest distance?
I have no clue...
I may be wrong but I don't think it's possible to control this with a setting.
11 hours ago, zet said:
Ideally I'd like inactive extruder to reach printing T right in time, while the other head is printing.
It seems like Cura is actually trying something of that sort
Yes, actually that's the key feature of Cura for multi-extruder prints. It works great, but....:
For a custom machine you have to find the correct values for the following settings first (by experiment):
- "Heat Up Speed"
- "Cool Down Speed"
- "Minimal Time Standby Temperature"
- "Initial Printing Temperature"
- "Final Printing Temperature"
- "Extrusion Cool Down Speed Modifier"
That's what Ultimaker provides for their own printers with the "quality" profiles for each supported material.
The inactive nozzle will probably always ooze a bit while (re-)heating (depending on the used hardware of course). I would try to fight it with longer tool change retractions and proper primetower/ooze shield settings.
16 hours ago, Alexxx2005 said:
Habe mal Foto‘s gemacht , ich frag mich an was das liegt , stimmt da was mit der Geometrie nicht , oder ist das Normal.
Ich glaube, entweder werden meine Augen schlechter, oder der Monitor...
Ich sehe auf den Fotos keine gravierenden Unterschiede? 🤷♂️
XY-Kalibierung ist nur für Dual-Drucke relevant - dein Beispiel ist doch aber durchgängig mit einem Printcore gedruckt, oder?
Rechts in der Ecke könnte der "Z-Seam" sein und dann kommen vielleicht noch "Leerfahrten" dazu (je nach "Combing-Mode"). Beides würde man in der GCode-Vorschau sehen. Kannst Du die zugehörige gcode-Datei mal herzeigen?
(unter der Annahme, die Datei wurde mit Cura erstellt)
Oder hast Du die Möglichkeit, mal einen anderen Slicer zu benutzen?
Ich vermute, es hat eher etwas mit Cura (-Einstellungen) zu tun, als mit der Hardware.
1
14 hours ago, zet said:
I have carefully reviewed all Cura setting having anything to do with dual head printing but failed to find one allowing to move heads away from the model while heating.
If the firmware of the printer does not handle this, there are extruder (start/end) scripts in Cura that are intended to be used for these "extra stuff" that shall happen on every tool change.
Is it a custom printer or do you use one of the pre-defined multi-extruder configurations in Cura?
Extruder scripts can be created and edited in Cura machine settings (AFAIK).
3 hours ago, buteomont said:
But that's the whole question, the print times are different! I want to make them the same for all three printers. Why are they different?
Are the estimations of the CuraEngine different or the actual print times on each printer?
Be aware that different printers may be driven by different firmware (versions) with different limits for feed rate and acceleration.
There's not only a default value for those things, but also a maximum. For example: for Marlin firmware take a look at gcodes M201 to M203.
Are all printers in questions using the same motion system? (delta printers - e.g. - are a whole different topic regarding motion and speed calculations...)
There are probably much more firmware settings to consider, every printer has it's own capabilities and limits.
If you're interested in how the estimation for Cura is calculated, take a look at the "TimeEstimateCalculator" of CuraEngine:
https://github.com/Ultimaker/CuraEngine/blob/master/src/timeEstimate.cpp#L18
Edit:
the configured maximum values for Tronxy printers are set very low (in comparison) - i guess Cura will respect these limits in all its calculations:
https://github.com/Ultimaker/Cura/blob/master/resources/definitions/tronxy_x.def.json#L25
1
7 hours ago, banditbat said:
Attached are the STL and the gcode file. Any help would be greatly appreciated!
Analyzed by Meshmixer:
The pockets are marked with errors. There are probably doubled or not connected vertices or something similar.
Hope that helps.
7 minutes ago, Netweaver said:
This is the 3DSolex version
Ok, but... it still looks very different...? This can't be the part from your link - even if there is a huge camera distortion....?
I never saw a conical coupler... this can't be correct. 🤷♂️
Besides of the spring (instead of a spacer) it should look like this:
https://fbrc8.zendesk.com/hc/en-us/articles/115004703983-Printhead-Diagram-Ultimaker-2-
The PTFE coupler looks funny.... or wrong... or... at least quite different to those that i know? Is this a DIY solution or has the shape changed nowadays? Where does the bowden tube ends?
It should look like this, as far as i remember....?
3 hours ago, joatrash said:
Any thoughts as to what could be going on?
Dunno, can you translate "random super-fast print head movements" into a more precise measuring unit?🙂
Or can you share the gcode file?
9 hours ago, gstv said:
what can i do to make material - and printer profiles usable?
I think the intended method is to make the value in the quality profile (somehow) dependent on the material setting (in this example). So... use a formula in the quality profile instead of a literal value.
The developer wiki is a crucial source of information about those topics.
https://github.com/Ultimaker/Cura/wiki/Profiles-&-Settings
I think there is something wrong with the mesh structure of this model. It looks like there are extra (double?) walls around the holes or something similar.
It's probably not a single solid body (like it is supposed to be). If the model has errors the results are simply unpredictable.As a first step i would take a look at the "x-ray-view" in Cura and check for any unwanted geometry or red marked areas.
Well, then... flip the axis direction and the end-stop position for y in the configuration file and your clone should be satisfied 🙂
1
22 hours ago, JohnInOttawa said:
I'd like to be able to measure and plot the temperatures and signals as you experts on this thread have.
The temperature chart from above can be requested from the printer:
http://<ip_address>/info/temperature.html
1
7 minutes ago, Smithy said:
Meine neue Nachtlektüre lautet nun marlinfw.org
Bringt nix. Hab ich schon ein paar mal versucht...
Spätestens bei G4 bin ich immer eingeschlafen. 🥱 🙂
1
How to set IP address without WiFi or DHCP
in Ultimaker 3D printers
Which (kind of) printer are you referring to?
It was ever possible and it still works like described above.
It's not hard and has to be done only once.
BTW: those two requirements are not working well together...
I think this approach is questionable to say the least... (but that's a different topic of course)
