This has to be specified in the firmware. Afaik your printer also uses Marlin. Check configuration.h for the homing directions.
OK got it, I thought so. I'm guessing that the "0,0" home position indicator (black crosshair symbol) will always be shown in the front left corner on the graphic display in Cura regardless of which side the printer will be set up on?
Dim3nsioneer 559
