Posted · "Only follow mesh surface" AND "Z hop/retraction"
Hello,
I've been immensely enjoying using Cura to slice/generate g-code for models to be printed on my deltabot.
I almost now extensively print using only follow mesh surfaces as I often print things with single line width (e.g. a vase).
However, I've noticed, while "Spiralize the outer contour" also generates a brim and enables z hop/retraction, enabling the "Only follow mesh surface" does not (which I guess as the name implies).
I was wondering if it is possible to allow "Only follow mesh surface" to incorporate z-hop/retraction when generating g-code.
Thank you
