Posted
· Print multiple parts in shadowed empty space
You could right click the STL with the two objects in it and select "Split object into parts". This will cause cura to try and split the STL into separate parts which you could then re-arrange and print all at once.
Posted
Thank you Robert for your answer. Didn't know that option. Still, I guess it would not work if I wanted to put the bolt inside a hollow rectangle, and also guess this is the way Cura works.
IRobertI 520
