improve the print quality
afranx
Posted · improve the print quality
I have printing problems whit PLA.
The layer above the infill is not created correctly. What should I change?
layer h:0.1
shell: 0.4
bottom\top 0.4
fill 3
speed: 40
temp: 210
    50-100% infill is not necessary, but you do need a thicker top layer. As the printer lays down strands of plastic for the first solid layer to span over the gaps in the infill, it will sag down. As the next layer goes down, it sags slightly less as it now has more support from underneath. When the third layer goes down it has even more support and so on. I like to get at minimum 6 solid layers on top of 20% infill. You're only using 3% which is basically nothing so you're going to need a lot more than 6 to cover the top properly.
    For 0.1mm layers I like 20% infill and 0.8-1mm top thickness.
    I also agree with the 0.8mm shell that swordriff suggested. It will produce a much stronger part.
    • 2 weeks later...
    plus just a note - you have a brim but the 'lines' are no touching - which they should be, and so it is worth levelling your bed closer to your nozzle to 'smush' the layers together. - will help with the appearance of the first layer and the brim if you re not getting any lifting and are happy with the first layer appearance then switch off the brim as it is not doing anything!
    Agree I rarely go over 20/25% infill and always do 6-8 top layers but only 6 bottom
    @jameshs - how can you make in Cura different number of bottom and top layers?
    @shurik I don't think it is possible in Cura - sorry have been using S3D for too long :)
