Thanks for your answer, being impatient I took the feeder off anyway and the above drawing is very helpful except, where does the tiny grommet go?
The metal grommet goes at the bottom of the feeder. It keeps the PLA from grinding away at the black nylon case and getting nylon up into your nozzle causing clogs.
It goes into the entry hole where you insert the filament. Larger diameter flange goes on the outside.
thanks! (ah the learning curve of a new printer!)
As a new user you might find these helpful:
so now I think the rear motor falling is keeping me from putting the screws back into the feeder they just spin like there stripped (but there not) I lifted the motor a tiny bit. Any tips for making sure that is seated properly?
Thanks
yep found those a few days ago thanks!
you have to remove that metal cover. It's held in by one screw somewhere along the edge of the cover. The white cover on the inside of the machine that covers both the stepper motors.
Edited by GuestIs it 1 on newer machines? Mine has 2. One in the side panel and one in the rear panel...
Two for newer machines is correct. I think it was only in the very beginning it was only one screw.
gr5 1,871
You don't. If you insert a 2mm hex wrench from the hole in the top that turns a 3mm screw that controls the tension.
