There was one small change in 15.04.. Expert Settings now has a checkbox for "Infill prints after perimeters".
2
Hmm, could be that one change snuck through. Daid told me the only real change was the firmware.
When you install it, it says:
New in this version:
* Fixed a small issue where Cura sometimes failed enable the save button
* Added save gcode shortcut key (CTRL+G)
* Update UM2, UM2go and UM2extended firmware for the new support url on errors
* Fixed small issue in the UM2go firmware
But I noticed also, that they moved Cura sources to Ultimaker. And it looks like a lot of changes to the build mechanics.
The version that is hosted with Ultimaker is a complete re-work of Cura, which is currently in closed beta.
currently I am running Cura 15.02.1.
But if I start Cura 15.02.1 it does not tell me that there is a new version available.
It neither asks for firmware update for my UM2.
Do I have to manually update to 15.04?
nallath 1,118
There is no 15.03. The only difference between 15.02 and 15.04 is changed firmware for the um2go.
PU is now in closed beta.
