Please post german language only in german part of the forums.
Is this a UM2 or UMO or something else?
This problem is rare on a UM2 but common on the UMO and other printers. It is caused by "backlash". But backlash is complicated. Backlash means that the print head isn't moving all the way to the postition that the stepper is moving to. It is caused either by:
A ) Belts too loose such that the head doesn't move all the way.
B ) Friction too high such that the head doesn't move all the way.
B is easy to test for - just push the print head around with power off. Make sure the resistance is about the same.
A is also easy to test for - pluck the belts like playing a guitar string - particular the 2 short belts to the XY steppers. If an X or Y stepper belt is loose, loosen the 4 screws going to the stepper, then push down hard on the stepper as you tighten them back up again. Before doing that remove the cover that hides the stepper (one or two screws depending on when your UM2 was made).
gr5 2,333
