Layer does not fully fill out, doesn't reach the outline
Posted
· Layer does not fully fill out, doesn't reach the outline
This is very common on UMO and is caused by backlash which basically means the nozzle isn't moving all the way to where the stepper told it to go.
Paradoxically it is most often caused by belts too tight or too loose. If the long belts are too tight the resistance can be very high to moving the head. If the long or short belts are too loose then the head isn't moving all the way to position either.
Usually it's the short belts are too loose - loosen the 4 screws holding the motors, push down hard on the stepper and re-tighten. It's possible you need to lengthen the wood slots in the wall of the UMO but not likely.
The long belts don't need to be very tight but if you pluck them they should emit a pitch discernible by the human ear (e.g. like the lowest note on piano). As opposed to slower than 10 times per second (not audible).
A year after the merger of Ultimaker and MakerBotQQ, we have unlocked the ability for users of our Method series printers to slice files using UltiMaker Cura. As of this release, users can find profiles for our Method and Method XL printers, as well as material profiles for ABS-R, ABS-CF, and RapidRinse. Meaning it’s now possible to use either Cura or the existing cloud-slicing software CloudPrint when printing with these printers or materials
gr5 2,094
