Hy Torgeir, do you have a picture of your board wiring ?
To which ground point did you go ?
my problem is not solved , the two drivers are dead, so its not able to print anymore.
Chri
Hi Chri,
I've added pictures and details about this previous in this tread, have a look at topics on 27 of May.
I did not go externally to ground, but just made a jumper across the actual resistor on all the driver IC's.
Thanks.
Torgeir.
1
Torgeir 157
Thanks for the reply Torgeir. I have a limited understanding/knowledge of electronics in general let alone of stepper drivers. When you say "having installed this (A498X) series of stepper drivers" it sounds like you are saying that you installed a new physical stepper driver onto the printer. Is that correct or am i misunderstanding something.
And just to confirm, you are saying this mod should work with any other 3d printer using different electronics than the um2?
Thank you.
Hi.
The stepper driver I've been talking about is the one currently installed into the UM2 and this part number P/N is; A4988. I never changed this driver on my printer, just changed a resistor from "10 000 ohm" to "0 ohm". I have described this in detail previous in this tread.
When I talked about other 3d printers with this problem, they might have the A4988 installed or can also have a driver belonging to the "same family of drivers", meaning starting with the P/N; A498X, where X can be other number than 9.
As an example, UMO are using A4983 (if I'm right here) and later model/upgrade may have A4988 as the latest.
Thanks.
Torgeir.
neotko 1,416
Silly question for @torgeir since I know how to solder but I have zero electronic knowhow. It's the same to short it than take it away and solder both points or the resistor actually needs to stay there?
