Why is cura 15.04 causing this bad edge print?
spikee
Posted · Why is cura 15.04 causing this bad edge print?
I have printed a few files with cura 15.04 lately and i have been experiencing bad print quality for a while.
Settings:
Layer hight: 0.2 mm
Shell thickness: 3 mm
Enable retraction (true)
bottom/ top thickness: 3 mm
Fill density 50%
print speed 50 mm/s
support type none
platform adhesion type: none
Print pics:
http://i.imgur.com/CXp7Xeo.jpg
http://i.imgur.com/tohVJwh.jpg
http://i.imgur.com/I5FUkv8.jpg
http://i.imgur.com/ZVwv5Rl.jpg
http://i.imgur.com/WXawIJe.jpg
http://i.imgur.com/ogFC7WV.jpg
http://i.imgur.com/R3p2tPW.jpg
The straight lines of the wall make the parts pretty weak. Epoxy on top/bottom is needed to make it really strong.
Old prints with cura 14.01 did a sideways top line over top/bottom to make it strong:
http://i.imgur.com/ceb3aoU.jpg
http://i.imgur.com/U0obvl8.jpg
This part does not have the same settings but still , much better top/bottom print.
Is this a bug in the new cura or am i doing something wrong?
I have a Ultimaker 2 , printing with 3mm PLA.
Thanks
