1. Check if the pulleys sit tightly on the rods
2. Make sure the belt tension is reasonable so neither the x nor the y motor does skip steps.
I've checked after
and they are not loose
it virked not
what should I do
I've checked after
it virked not
what should I do
Make sure the long belts are also not too tight.
they are not too tight
Dim3nsioneer 528
