You should not randomly change you steps per E, use Curas configuration wizard to reset it properly.
It sounds like you have other problems, not over feeding, which is pretty much impossible without a misconfigured step per E value. Packing, for PLA, should be 1. I'm not sure of the filament density value, never fiddled with it sorry.
Thanks! I try not to change it randomly, I usually run the test using printurn with the extruder hot.I just tried puting it down a bit, but apparently its some other problem.
jcosmo 5
