Hi SandervG
Here's a image of my build so far. I changed the height to be 480mm and kept the width and length the same so that the standard bed and belts will work. The stepper drives I sourced form South Africa and the controller and bearings I sourced from AliExpress. I also included the image of the controller. Most of the other parts I made myself on my CNC and with my printed with my Mendel90.
The body was cut from MDF 6mm.
The electronics is standard meaning the standard connections should work.
- 1
SandervG 1,521
Hi Nambass,
Did you source the entire Ultimaker 2 Extended yourself?
Because we don't sell a DIY-version. If we want to help you troubleshoot or point you in the right direction it is valuable information to determine if you are working with official Ultimaker parts or if you have sourced everything yourself.
Do you have a picture to share of your machine?
Thanks and good luck!
