Thanks for the help! I took out the bowden tube and the filament did not come out with it, it looks like the filament must be attached to the upper extruder. I tried the atomic method and just a tiny bit of filament came out but the piece of filament is still stuck there.
Should I take apart the extruder at this point?
gr5 1,872
This is a common problem if the 3rd fan isn't working.
Anyway to fix it I would completely remove the bowden which means filament needs to be out of the feeder. Mark the bowden with tape so you don't reverse ends (it matters). Remove from both ends by removing the clip, pushing down on the collet while pulling up on the bowden. If the collet doesn't go down on the print head unscrew the 4 thumb screws 5 or 10 turn or until the collet is loose and you can push down on it while pulling up on the bowden. Not pushing down on the collet will scratch and somewhat damage the bowden as it has 4 tiny metal blades inside.
Once the bowden is off you can soak it in hot water (160F to 200F or 70C to 90C) for 30 seconds and then fish out the PLA goo with toothpick or something - repeatedly putting it back in hot water (e.g. boil some water in microwave or on stove).
