While I have found 1.99 stable, the layer view stutters quite badly, in that when dragging the layer slider up and down, it's really not smooth, whereas 15.04 (which I still use for production) is much smoother on layer view.
1.99 is pretty stable and I have been using it for quite a few weeks now with few problems.
Same here.
I'm new to GitHub but would this be the place for end users to look to find out if the current version is "stable" enough for their personal sense of adventure level?
https://github.com/Ultimaker/Cura/labels/bug
Also since depending on use and feature expectations..... one man's "pretty stable" is another man's "totally unusable".
No. We actually only do public tracking there. Most of the (bug) tracking is done on a private tracker that can do a whole lot more than the shitty one github provides.
The best way to see if there is a stable release is to wait for the release. Inbetween releases tend to be somewhat stable and nightly tend to be unstable (although nightlies can be stable...)
- 7 years later...
On 9/20/2015 at 1:36 PM, ivan-lipunov said:After the comment about the limitations of multithreading in Python some time I googled this question and found here some interesting option: https://docs.python.org/2/library/multiprocessing.html
This method has its limitations in terms of platform dependence, but the execution speed is obviously higher than when using GIL. @nallath, you have not considered the possibility of changes in this way?
Have been able to do multi threading in a post procesing script in Cura ? I try myself and it always won't work
On 8/10/2023 at 1:46 PM, VictorMic said:it always won't work
There is no information in this statement that enables anyone to give you any help or advice.
What are you doing? How are you doing that (post a link to code you are using). What happens when you run the code? How does it "not work"? Do you get specific error messages?
Just now, ahoeben said:There is no information in this statement that enables anyone to give you any help or advice.
hello,
Thank you for your answer. So the goal of my company is to create a new way to create industrial metal pieces by using 3d printing firstly to create the piece in plastic and with this plastic piece create a mold in which aluminium is poured and melt the plastic (so we need a 3d printing with the lowest density, so all the plastic will be burn by the aluminium. I am currently creating a post processing python script for Cura, of which the goal is to increment the E value of the gcode to compensate for the loss of materials, that occur when the extruder of the 3d printer is moving without printing. We need to compensate these loss because otherwise it create holes in the printing. But the size of the pieces are great (millions of gcodes lines), so to be able to modify the gcode in a correct amount of time I used the Multiprocessing of python. I had to work on windows so to use multiprocessing i need to have this line :
When launch by myself (like in VS code) without Cura all is good. But the issue here is that it can't enter the loop because __name__ will never be equal to '__main__', but it always equal to :
where 'ModificationGcodeMultiProcessing' is the name of my postprocessing script and i never found any other script that was using multiprocessing so i was wandering if anybody has any clue for me.
"Do you get specific error messages" I don t have any error message but at the end 'Fichier' (which should contain the gcode that i modify) is empty.
I attach my code. But the issue is located in the function improve_extrusion (the other work perfectly)
In your code, the actual processing is only executed if the script is run outside of Cura. That is what that line "if __name__ == '__main__':" does. The "# Multiprocessing" is just a comment and does nothing.
Change this:
if __name__ == '__main__': # MultiProcessing with Pool() as p: resultat = p.map(traitement_gcode_lineaire,liste_traitement)
To this:
Note that I changed the indentation of those two lines. This is important in Python.
It would be better if you change the functions you define into methods of the class, but that takes more modifications than I care to do right now.
I have not tested your code, but at least this way Cura should try to run it.
For further questions, it is probably better to start a new thread than to tack onto a non-related 6 year old thread.
Edited by ahoebenIn fact please start a new topic and then link to it from this topic. Just in case there is more discussion.
Just now, ahoeben said:In your code, the actual processing is only executed if the script is run outside of Cura. That is what that line "if __name__ == '__main__':" does. The "# Multiprocessing" is just a comment and does nothing.
Change this:
To this:
with Pool() as p: resultat = p.map(traitement_gcode_lineaire,liste_traitement)Note that I changed the indentation of those two lines. This is important in Python.
Thank you for the answer, i didn t before sending my fisrt message that this thread was dead since 7 years, but pls don t be condescending :
_"The "# Multiprocessing" is just a comment and does nothing" i write for you just to be sure. yes i know how to comment on python don t worry
_"if the script is run outside of Cura. That is what that line "if __name__ == '__main__':" does." I know that like i mentionned but the problem is that on windows i didn't fin any means to do without this "if", because your changement will just create an infinite loop
_"Note that I changed the indentation of those two lines. This is important in Python" No i didn t know !
_i have already create another topic : https://community.ultimaker.com/topic/40911-post-processing-script-logs/
Just now, VictorMic said:Thank you for the answer, i didn t before sending my fisrt message that this thread was dead since 7 years, but pls don t be condescending :
wrong link : https://community.ultimaker.com/topic/44004-multithreading-and-multi-processing-for-python-script-in-cura/
I am sorry I made you feel condescended, I will stop wasting my time by further trying to help you. Good luck with your endeavors!
ok 👍
Top Posters In This Topic
44
24
14
12
Popular Days
Jul 4
15
Sep 15
15
Jul 2
14
Jul 3
14
nallath 44 posts
cloakfiend 24 posts
gr5 14 posts
Blizz 12 posts
Popular Days
Jul 4 2015
Sep 15 2015
Jul 2 2015
Jul 3 2015
Posted Images
Dim3nsioneer 557
Same here.
