I have posted the following before, unfortunately nobody from Ultimaker has responded about this. Also unfortunately the same thing is happening again now.
For a model I currently want to print Cura reporta the following:
At a print speed of 50 mm/sec the reported print time is 2 hours and 47 minutes
At a print speed of 20 mm/sec the reported print time is 2 days, 9 hours and 54 minutes!
Obviously something is very wrong here.
I really wish somebody from Ultimaker would respond to this, and tell me either what I can do to fix this or tell us when a fix for this will be available.
How can one see an added image in full size once it is uploaded? This was easily done in the previous version of this forum, and now I can't seem to figure out how to see a full size image.
Top Posters In This Topic
44
24
14
12
Popular Days
Jul 4
15
Sep 15
15
Jul 2
14
Jul 3
14
nallath 44 posts
cloakfiend 24 posts
gr5 14 posts
Blizz 12 posts
Popular Days
Jul 4 2015
Sep 15 2015
Jul 2 2015
Jul 3 2015
Posted Images
Blizz 53
I don't get the discussion here about "nozzle size not being needed anymore". Of course it is!
How I look at it it's
You push a "tube of plastic" through the nozzle (the nozzle hole size + feed rate determines the exact diameter of that). The layer height and the moving speed determine how much the entire thing is flattened out, thus effectively how width the resulting line of plastic will be.
You are the second person in this thread to claim that simply "specifying the line width" is enough, but how I'm looking at it that is a mathematical impossibility. It means Cura is able to guess everything else, which I don't believe.
But I guess that's me being stupid again.
jens 9
Erm. I didn't mean for this to get ... all emotional. Sorry.
I don't know, if the program still uses the nozzle size, but, it doesn't need to. If you specify travel speed, line width and layer height, you get the volume per time that has to be extruded - it doesn't depend on the size of the hole it is pressed through (it could, if go deep deep into the effect of the nozzle size on the shape of the cross section of a single extruded line ... like, slightly rounder edges or whatever).
