The UMO wants settings such as temperature in the g-code. The UM2 wants this set on the machine. If the um2 sees a temperature setting in the g-code it will give this warning.
;Generated with Cura_SteamEngine DEV
;LAYER:0
M107
G0 F9000 X87.493 Y71.263 Z0.299
G0 X90.218 Y69.590
;TYPE:SKIRT
G1 F900 X91.692 Y69.478 E0.17680
G1 F3000 X92.503 Y101.554 E4130.59734
G10
M107
G0 F9000 X92.503 Y101.554 Z23.000
M104 S0
M140 S0
;Retract the filament
G92 E1
G1 E-1 F300
G28 X0 Y0
M84
It could be that the m104 is the problem; it sets the temperature to 0. If you remove the m104 command and the m140 command, do you still get the errors?
the M104 and M140 is part end code? So those should be after the "G1 E-1 F300"
Dim3nsioneer 528
Sounds as if you try to print an UMO file on an UM2.
