Overlapping Objects give weird Results
cody42
Posted · Overlapping Objects give weird Results
In Cura 15.06.02 overlapping don't work as they used to in previous versions.
Simple example: Two cubes that overlap
Result in 15.06.02
Result in 15.04
So previous versions looked at the union over the inside points of the objects but 15.06 takes the xor of all inside-points.
