Thanks Daid, i will give it a try. I guess i must print it with ABS (i built a heated bed, and i'm afraid it will sag if i print it with PLA)?
I would also take this opportunity to thank you for all what you bring to the community, obviously Cura, but also all your constructive and pertinent contributions (even when you have to answer for the 100th time to the same question, asked each time by a different person )
So: Thanks a lot!
JP
Daid 303
I've replaced my fan shroud with the printable stock version, which looks the same as the stock, but is printable and doesn't unfold or shag like the stock.
My dual extrusion setup has the same issue, and I found the stock fan shroud pretty good on airflow actually.
