Posted (edited) · Best Fan Mount for Ultimaker2?
OK, I'm new. I think I want to try one of the improved fan mounts people have made.
Does anybody have experience comparing them. A lot of them look similar. Is there one that stands out above the rest?
What material would you recommend making the fan mount out of? Is there a high temp filament?
I do not have the Olsson Hot End.
Ultimaker 2 fan mount - DUAL by venkel
Ultimaker 2 Fan Mount by Spirit
UM2 Dual Fan Shroud by Labern
Ultimaker 2 fan mount double by zerspaner.gerd
Support Dual fan for UM2  by Duriel
Ultimaker 2 Fan Shroud by cor3ys
Fan Base UM2 by Zetoff
Fanduct - another idea by venkel
Ultimaker 2 fan mount - 40mm by venkel
Fan Mount (UM2 + Olsson block) by mechaMecha
Thanks.
    Posted · Best Fan Mount for Ultimaker2?
    what I can say now, after over nine month of usage, is that the Fan Base UM2 by Zetoff work very well and I'm very satisfied with the results :)
    Adding, ad described, a little metal shield (... from a beer can :D ) , I don't have had any problem of deformation due to temperature of the hot-end :)
    Certainly I recommend it!
    Only one negative point ... to mount and dismount ... you have to remove the fans first ... :(
    Guglielmo
