Thanks, Robert
that is the solution!
Cheers,
Andreas
Sure, just select "Outline" under the same option.
I'm having an issue where selecting outline and support at the same time causes it to try to print a raft under the model. The only way to get support to work properly is to do it without the outline as well.
IRobertI 502
On the print tab there's a "Raft type" setting, set this to "No raft" and you should be good to go.
