tinkergnome 926
Hi @Kermit65,
if i were you..., i would... (in ascending order)
- add a small chamfer to the edges where the small parts are attached to the base
- printing with zero infill but a larger shell width instead (try 1.2mm - 3 shells)
- increase the layer height to (at least) 0.1 and increase the bottom/top thickness to (at least) 1.0mm - i even think there will be no drawbacks if you use a combination of 0.12 / 1.2
- consider to split the parts in a different way (to make it printable without support)
Edit:
...and don't use the default speed settings - the default infill speed (80 mm/s) is way too fast IMHO. Set all speeds to the same value (or the advanced speed settings all to zero) - and choose 40mm/s as the basic print speed.
DidierKlein 729
Interesting project
For your problem it seems to like your print is underextruded could you share your print parameters and material used?
I would also change the design a bit to add more strength to those 4 pieces, maybe add some chamfers could help?
Increase the infill also, are you sure it's 40% ?
