@m2tts: Yes, this is a known issue with Cura; it sometimes has a bit troubles with thin walls. You already found one solution; setting the line width to .39 or .38 in Cura might be another.
And you have to know Cura always makes double perimeters; it's a flaw IMHO, but it will take some time until it is bugfixed I guess.
@SandervG: This is a very good example of the not working search engine. It would be logic to use something like 'Cura thin wall' for the search. The list of results is over 3000 items long but no topic on the first page deals with the problem looked for. And there are quite a few posts and threads about this special Cura issues... at least one of them should appear on the first result page. With Google 'Cura thin wall site:ultimaker.com' I immediatley get them all on the very first page. Please fix it or use Google for the search.
A year after the merger of Ultimaker and MakerBotQQ, we have unlocked the ability for users of our Method series printers to slice files using UltiMaker Cura. As of this release, users can find profiles for our Method and Method XL printers, as well as material profiles for ABS-R, ABS-CF, and RapidRinse. Meaning it’s now possible to use either Cura or the existing cloud-slicing software CloudPrint when printing with these printers or materials
Dim3nsioneer 557
Edited by GuestLink to post
