I did more testing. I believe there are two causes of the ripples/ridges:
1. "Ringing" (small, higher frequency) caused by print head vibrations after sharp changes in direction, and
2. Larger, lower frequency ridges caused by the infill impressing upon the outer shell.
Ringing
These ridges/ripples start intense near the sharp turn and taper off (dampen).
- Acceleration: I lowered the acceleration to 1500 mm/s2 but this didn't make any difference
- Adding several (3) extra outer shell layers actually intensifies the ridges/ripples (makes them worse) - I think because the ripples of each layer are additive to the next. However, increasing the shell thickness to 2 layers from 1 layer didn't have much impact - but it solves the infill ridges (see next)
Infill Ridges
I have been able to address this by increasing the outer shell thickness to 2 layers (0.8mm). I see in Cura there is a setting for reducing overlap between your infill and our shell layers. Decreasing the overlap would probably also help.
A year after the merger of Ultimaker and MakerBotQQ, we have unlocked the ability for users of our Method series printers to slice files using UltiMaker Cura. As of this release, users can find profiles for our Method and Method XL printers, as well as material profiles for ABS-R, ABS-CF, and RapidRinse. Meaning it’s now possible to use either Cura or the existing cloud-slicing software CloudPrint when printing with these printers or materials
Eraser 31
Ringing
Infill Ridges
