Posted · Cura 15.06.02 Big Problem
Hey ,
i use a Windows 7 64 bit Laptop and the latest Cura Version.
The mail Problem is if i load a Item i don´t can use any Tool. ( Rotation , Scale etc.)
I click on the buttons but they don´t work.
What can be the Problem? Don´t find any Answer in the Web. Some Guys had this Problem but find any way to get it on the run.
Problem 2:
I Download Cura 15.01.1
And ther all tools work fine.
But i don´t get a good Layer constraction. Many Layer on the Print are lost and the Printer works in the Air Tonight :-)
I Try to Cura the selm Opjekt a second time, so the most Layer work but the last Layers not. Dont have take other options.
Pleas Help i buy a UM2 and can´t use them.
Whats the Problem with Cura 15.06.02 ?
Is they are other Software i can use ?
By the way, i have hade a opjekt thats to big for my UM2 is ther a Program that can Split this Objekt?
I Hope really you can Help me thats all very Frustration.
Greetings CG
    Posted (edited) · Cura 15.06.02 Big Problem
    15.04 works. I'm pretty sure that it does. I don't have experience with the other software.
    Is the error also in the (just released) 15.04.03 version?
    I try the 14.04 Software the tools work. Print Layer Problem- Not testet yet
    The 15.04.03 Version i will try ..
    Don´t know if i had to open a new Topic but anyone knows witch Software to use to Split bigger Opjekts to print?
    I read good about the 3d PrintTech 2.0 Software but can´t find them anywhere.
    So how do you all split to big opjekts that are finished?
    Thanks a lot
    CG
    Netfabb can split objects. There are instructions in here.
    Or you can use Cura to cut off the "bottom" of your model, then flip it over to print the other portion.
    Try Cura 15.04.03 same error with the tools..
    Will use 14.02 of Cura.
    Have downloaded Meshmixer and Netfabb will try it and hope that it will do what i need..
    Try to Print a Iron Man Helmet but its to big for the UM2 so i hope the one of the Software will help to split the parts.
    Thank you CG
