I have been so out the loop with ultimaker products recently. by Origonal V1, i mean the UMO V1, and by the V2 i mean the nice fancy white metal and plastic Ultimaker 2
Mineral oil and tightening routine, check, the dust cover around the filament, also check!
I think its worth buying up a new nozzle and bowden tube, I like the idea of using a heat gun! genius! I have one knocking around i used to use to bend foam EVA mats to make costumes.
I also keep my ultimaker under a dust cover box (made from PE foam) and inside a cupboard, this acts as a decent heat chamber, could this be causing any issues to the machine? while its great for the noise and dust, could i be accidentally cooking it?
also CnC router, ouch, clogging up must be a nightmare. Requirement for lubricant + milled out particles = headache!
jameshs 42
@0235 I feel your pain.
For what the machine does I would say comparatively reliable - I have two UMO (I am assuming you mean UMO by V1 and UM2 by V2 or are you referring to the fact that the UMO has an earlier and later version?)
To improve reliability I have found that regular maintenance is important - tightening routine on screws, belts and pullys. regular mineral oil on the guide rods (checking that the head moves freely (I do not use WD40 as it is releasing oil and disapears quickly).
On the blockages front
reliable filament like colorfabb
keep the filament 'young' - I have found that older colorfabb acts differently to new and can gum up the nozzle
perform atomic clean on nozzles regularly (I swap mine around as I have several sizes and regularly use a heat gun to clean the threads and interior while I am printing with another)
only change and tighten nozzles with the head hot - leaking is often because of a lack of tightness caused by gunk
tighten carefully - these are not strong components
check the bowden off the machine - this checks filament diameter and bowden scratches
tiny amounts of oil
dust filter on the filament - I use the @iroberti print to hold foam against the filament and am amazed how dirty it gets.
So they are not walk away and print, but I also use a cnc router and it is a similar routine to keep a moving gantry in its sweet spot.
Hope that helps!
James
