Cura for Ubuntu
Shad0w
Posted · Cura for Ubuntu
Hey yall.
I installed ubuntu on an old computer of mine, a dell dimension, in hopes of using it as a 3d printer terminal. Since i Had no windows licences left, I installed ubuntu. I was originally going to use 3dprinteros, but after installing it with the .deb file, I noticed it wouldn't launch. And so, I used cura. I downloaded a 32 bit version of cura, and installed it using the .deb file again. However, it still wouldn't launch. Do any of you have insight as to why?
    Some questions to refine your problem:
    I installed ubuntu
    version?
    again - version?
    think this means if you click the cura icon?
    what happens if you try to start cura via the terminal?
    any error messages?
    • Like 2
