4 skins? What does that mean? I still am unable to print the fingers. What settings and filament can they be printed with?
my guess is 4 perimeters.
what settings are you using and what is failing?
what machine do you have?
Yes 4 perimeters,
I'm using Recreus FilaFlex.
Nozzle Temperature 240'C
Speed 10mm/s so very slow.
Layer, 0.15 or 0.2mm.
Print them at 45' angle
There is a set of files for the fingers at 45' with supports
jameshs 42
you print them standing vertical with a small amount of support to stop them falling over. While that works well, I am not impressed with the design - the location of the finger depends on the printed hinge - I tried filaflex, semiflex and ningaflex and never found a happy compromise between closing force and open position - so I personally would not recommend this design to a recipient at the moment. Quite fiddly to assemble and keep the hinges in place. But as an idea platform it is really interesting.
