libC 0 Posted August 13, 2015 in Print head movement provides a terrible jackhammering/grindfest (edited) Problem Resolved Hello all I'm hoping someone in the community can point me in the right direction. We've had an Ultimaker 2 at work for the past 3 months without incident, but last night after having to take apart the material feeder at the back of the unit (as we've done countless times to remove jamming filament) the printer began to produce a terrible grinding sound whenever the print head would travel. The machine produced an error message: Error - X or Y switch stuck/broken; but a little searching of the community seemed to indicate that this error was being sunsetted for being too vague. Any ideas on what we can do to correct this problem? Thanks. Edited August 13, 2015 by Guest Share this post Link to post Share on other sites
JBEngineer 1 Posted August 13, 2015 in Print head movement provides a terrible jackhammering/grindfest I would check the belt pulleys and be sure that the set screws on all of them are tight and that the belts themselves are taut as my first step. From the video the belt looks like its slipping. If you take the feeder back off does it home properly? Does it only do this when the print head is moving in the Y direction? Share this post Link to post Share on other sites
libC 0 Posted August 13, 2015 in Print head movement provides a terrible jackhammering/grindfest Thanks for the reply. Apparently it was a pair of the wires getting caught by the endstops. Everything has returned to normal. I would check the belt pulleys and be sure that the set screws on all of them are tight and that the belts themselves are taut as my first step. From the video the belt looks like its slipping. If you take the feeder back off does it home properly? Does it only do this when the print head is moving in the Y direction? Share this post Link to post Share on other sites
JBEngineer 1 Posted August 13, 2015 in Print head movement provides a terrible jackhammering/grindfest Glad to hear its back to normal and it wasn't anything major. Share this post Link to post Share on other sites
