problem in printing ..looks like there isn't a layer
Paoloboni
Posted · problem in printing ..looks like there isn't a layer
Could you be a bit more specific?
What are you printing with? What are your settings?
Is this empty layer happening at the same height? Do you see the build plate going down more than it should? It could be the problem of the current of the motor being to high (it looks like it).
    Also check your model in cura layer view. Make sure there are no missing layers or problems with your model.
    It could be a layer of under extrusion, but as @DidierKlein says, Providing more Info help others understand your issue.
        • 9 replies
