I ran 15.04 on my laptop today that is updated to Win10 and that worked fine. I'll see if I can remember to check all the other versions I have installed at work tomorrow.
I'm working with 15.02.1 and it runs with windows 10
edit..
Even the old version 13.04 I use for small and transparent prints still works (Lucky me )
I tried a random 13.x, 14.x, 15.04 and 15.06 install and they all worked without any problem. Well, they started at least, I didn't try to slice anything.
I've now even gone as far as stripping out the laptop and doing a clean install of windows 10 and every time I try to start the latest version of Cura it just pops up with will not run and closes down. Run in compatibility more for WIN 7 and 8 and same result. I tried running as admin and it still happens, takes a couple of minutes but just shuts down.
All my drivers are upto date and It's not leaving me an error file or giving me a reason it won't run.
- 3 months later...
I worked with Cura 15.04 and Windows 10 without any crashs. Since yesterday and the update KB3122947 and KB 3116908 - Windows 10 Version 1511 I got crashs of Cura 15.04 and 15.06.
Hopefully a update will come soon.
Dim3nsioneer 557
Maybe an update of the display drivers already does the job?
I already updated the AMD Radeon Driver 15.30.1025
- 2 years later...
I've updated my windows 10 and since then I can not run any of the versions of Cure, nor the latest version.
The problem is that I have Simplifly3D and neither is it running after I've updated windows.
I do not know what I do, I just can not slice anything!
Check you graphics card drivers and update to the latest version. This could fix the issue.
- 4 months later...
Dim3nsioneer 557
Compatibility mode?
