Is that 350mm/s? :shock:
before we all get excited, I'll remind us of Daid's words earlier today regarding maximum speed and actual speed and the telling phrase "a small model"..
The default marlin settings would limit you to 250mm/s anyhow. But that's still insanely fast printing. But cooling settings and acceleration will prevent you from hitting this speed quite often.
ok back home.
here is the controller screen.
Ian
here is the product from my experiment.
i only got to make a video when i was running 300 today.
but i will make a better one tomorrow for you guys !
best wishes.
Ian :-)
http://www.youtube.com/watch?v=po-WHahN ... e=youtu.be
ok im printing with perfect walls in my office at the moment.
the speed control stops at 400.... :(
if i can print at full speed with great quality, how can i make my ultimaker go faster ?
the printer is just asking me to push it a little more.
why print a nice big model in 10 hours, why not 3 ??
any ideas guys.
Ian
ok im printing a big model, alsmot the full size of the print bed, blue ultimaker PLA 3mm.
fan 120
temp 240
speed 400
and after a gentle start from 80 to now printing 400, each layer is coming down beautifully.
also because im now running at full ultimaker speed with sharp results, the bridging between points is a lot better.
my next question is, how can i make my ultimaker go faster ?
I can really feel pla with the right temp and of course the right flow rate, can print... faster.... maybe ?? even twice so fast as 400... so a nice 800... im not 100% sure the motors could do it ?
how fast could the motors run compared to the limitation of 400 :-(
and is it possible to get a cracked version of the firmware to make this accleration possible ?
best wishes.
Ian
Psst, super secret h@x0r Site from that Warez-King "Daid" (he is really GANG-STA) :mrgreen:
http://daid.eu/~daid/marlin_build/
thanks a lot.
i never used this before.
I have it open and see Max acceleration rate at 9000 ?
Im not sure what the relationship between my 400 and this 9000 ?
Is there a idiots guide to how to apply the new firmware to the ultimaker ?
I am very curous to see how fast i can get my ultimaker running.. :-)
Ian
I think these are the maximum values that are hardcoded(?) into the firmware, IF you use the firmware the builder makes. I don't know if these can be overriden in software or not - but i reckon it to be a good idea, to set the values high if you want to be sure, that the firmware is not limiting you at _that_ point.
Applying is suprisingly easy - you get a .zip file which you unpack. There you will find a Batch-file - just click on it, enter the COM-Port of the Ultimaker (e.g. COM12) and then it flashes the firmware.
Did this just recently (also for the first time) and it went without any problems. Just check that you know the Comport and that you don't have any application using the Ultimaker at the time of flashing the firmware.
ian 32
really cool.
third attempt and produced my stair case in 15 minutes with a speed of 353.
absolute 100% smooth perfect sides and no problems with lack of material or too much pressure.
the only small problem is, when it prints the balkony in the middle of the stair case, the infill is not covering it brilliantly.
but my first time printing at 350 speeds and producing perfect models with ultimaker !!!!
