IRobertI 520
Yup
ultiarjan 1,223
I think it's real stupid that they mess with the current in there default UM2 profile....
Just for info here's what I use as start code, I start mid-front iso left front so normally your 2th line would be more like X10 Y10
G28 ; home all axes
G1 X110 Y45 F3000 ; bring extruder to the front
G92 E0 ; zero the extruded length
G1 Z30 ; lower
G1 E50 F225 ; purge nozzle with 50mm of filament
G1 X80 Y60 F3000 ; move little to the side
G92 E0 ; zero the extruded length again
JohnK 30
I agree, not sure what the reasoning is behind that.
Any particular reason you have it start in the middle ?
I'm still experimenting with simpify3d, getting decent prints but sometimes not as good as I want, especially in regards to blobs/stringing.
