If you have to replace one, Daid recommends pololu black:
http://www.pololu.com/product/2128
More discussion here:
http://umforum.ultimaker.com/index.php?/topic/4820-using-pololu-drv8825-stepper-drivers-on-a-um1/
http://umforum.ultimaker.com/index.php?/topic/1315-stepper-drivers-fried-replacements/
gr5 2,330
You can google "pololu current" and there are articles out there in the general reprap community that are better than discussion of this on the forum. There is a test point on or near the trim pot (depending on which pololu you have) and there is a formula to convert that voltage to a current. That is a reference voltage and the driver is careful to never go over that mount of current. I would disconnect the servo, measure the voltage and turn the trim pot the tiniest possible amount such that the value goes lower (lower voltage is lower current) and then continue in that direction and lower the voltage maybe 10% or so then connect it to the stepper. Don't do this while connected to the stepper as you can blow your stepper in well under a second if you turn the current up too much. Many people who mess with this have to order a new pololu (not expensive). That's probably why they are socketed.
