The Z axis jumping suddenly is a new issue and it seems to be related to overheating of the *driver* on the board under the printer. Most people fix it by lowering the current slightly. The issue possibly is *not* temperature related as some people claim cooling the board doesn't help yet lowering the current *does* help. Anyway try adding this gcode to see what happens:
M907 Z1000
That sets the Z stepper current to 1000ma. Default is possibly 1300? I forget. Also consider removing bottom cover, printing with printer at 45 degrees (it will print at any angle and even upside-down just fine) and have a fan blow gently on the underside.
Experiment and let us know what works so I can tell other people. It's really a small percentage of people with this problem (guessing 1% but don't really know) and it's a new issue (something different about the driver chip maybe or just the hot weather?).
A year after the merger of Ultimaker and MakerBotQQ, we have unlocked the ability for users of our Method series printers to slice files using UltiMaker Cura. As of this release, users can find profiles for our Method and Method XL printers, as well as material profiles for ABS-R, ABS-CF, and RapidRinse. Meaning it’s now possible to use either Cura or the existing cloud-slicing software CloudPrint when printing with these printers or materials
gr5 2,094
M907 Z1000
